[PATCH 0/3] riscv: Move timers into drivers/timer
Now that mtime sources are regular timers, they can go in with the rest of the timer drivers. I have assigned maintenance of these drivers to Rick Chen, as they were previous under his purview. This series is based off of -next.
Passing CI located at [1].
[1] https://dev.azure.com/seanga2/9603e4b8-6f49-4106-b8fc-46e66a869d69/_build/re...
Sean Anderson (3): riscv: Move Andes PLMT driver to drivers/timer timer: Add _TIMER suffix to Andes PLMT Kconfig riscv: Move timer portions of SiFive CLINT to drivers/timer
MAINTAINERS | 2 + arch/riscv/Kconfig | 7 --- arch/riscv/cpu/ax25/Kconfig | 2 +- arch/riscv/lib/Makefile | 1 - arch/riscv/lib/sifive_clint.c | 43 +--------------- drivers/timer/Kconfig | 7 +++ drivers/timer/Makefile | 2 + .../timer/andes_plmt_timer.c | 0 drivers/timer/sifive_clint_timer.c | 49 +++++++++++++++++++ 9 files changed, 63 insertions(+), 50 deletions(-) rename arch/riscv/lib/andes_plmt.c => drivers/timer/andes_plmt_timer.c (100%) create mode 100644 drivers/timer/sifive_clint_timer.c
This is a regular timer driver, and should live with the other timer drivers.
Signed-off-by: Sean Anderson seanga2@gmail.com ---
MAINTAINERS | 1 + arch/riscv/Kconfig | 7 ------- arch/riscv/lib/Makefile | 1 - drivers/timer/Kconfig | 7 +++++++ drivers/timer/Makefile | 1 + .../lib/andes_plmt.c => drivers/timer/andes_plmt_timer.c | 0 6 files changed, 9 insertions(+), 8 deletions(-) rename arch/riscv/lib/andes_plmt.c => drivers/timer/andes_plmt_timer.c (100%)
diff --git a/MAINTAINERS b/MAINTAINERS index c96b8b6baa..32a2cdb52b 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -927,6 +927,7 @@ S: Maintained T: git https://gitlab.denx.de/u-boot/custodians/u-boot-riscv.git F: arch/riscv/ F: cmd/riscv/ +F: drivers/timer/andes_plmt_timer.c F: tools/prelink-riscv.c
RISC-V KENDRYTE diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index aaa3b833a5..30934d9cc6 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -170,13 +170,6 @@ config ANDES_PLIC The Andes PLIC block holds memory-mapped claim and pending registers associated with software interrupt.
-config ANDES_PLMT - bool - depends on RISCV_MMODE || SPL_RISCV_MMODE - help - The Andes PLMT block holds memory-mapped mtime register - associated with timer tick. - config SYS_MALLOC_F_LEN default 0x1000
diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index 10ac5b06d3..12c14f2019 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -13,7 +13,6 @@ obj-y += cache.o ifeq ($(CONFIG_$(SPL_)RISCV_MMODE),y) obj-$(CONFIG_SIFIVE_CLINT) += sifive_clint.o obj-$(CONFIG_ANDES_PLIC) += andes_plic.o -obj-$(CONFIG_ANDES_PLMT) += andes_plmt.o else obj-$(CONFIG_SBI) += sbi.o obj-$(CONFIG_SBI_IPI) += sbi_ipi.o diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index d40d313011..2f9c8f84f0 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -53,6 +53,13 @@ config ALTERA_TIMER Select this to enable a timer for Altera devices. Please find details on the "Embedded Peripherals IP User Guide" of Altera.
+config ANDES_PLMT + bool + depends on RISCV_MMODE || SPL_RISCV_MMODE + help + The Andes PLMT block holds memory-mapped mtime register + associated with timer tick. + config ARC_TIMER bool "ARC timer support" depends on TIMER && ARC && CLK diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index c22ffebcde..d22813127f 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -5,6 +5,7 @@ obj-y += timer-uclass.o obj-$(CONFIG_AG101P_TIMER) += ag101p_timer.o obj-$(CONFIG_ALTERA_TIMER) += altera_timer.o +obj-$(CONFIG_ANDES_PLMT) += andes_plmt_timer.o obj-$(CONFIG_ARC_TIMER) += arc_timer.o obj-$(CONFIG_AST_TIMER) += ast_timer.o obj-$(CONFIG_ATCPIT100_TIMER) += atcpit100_timer.o diff --git a/arch/riscv/lib/andes_plmt.c b/drivers/timer/andes_plmt_timer.c similarity index 100% rename from arch/riscv/lib/andes_plmt.c rename to drivers/timer/andes_plmt_timer.c
Reviewed-by: Rick Chen rick@andestech.com
This matches the naming scheme of other timer drivers.
arch/riscv/cpu/ax25/Kconfig | 2 +- drivers/timer/Kconfig | 2 +- drivers/timer/Makefile | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/riscv/cpu/ax25/Kconfig b/arch/riscv/cpu/ax25/Kconfig index 5cb5bb51eb..327b74e20a 100644 --- a/arch/riscv/cpu/ax25/Kconfig +++ b/arch/riscv/cpu/ax25/Kconfig @@ -5,7 +5,7 @@ config RISCV_NDS imply CPU_RISCV imply RISCV_TIMER if (RISCV_SMODE || SPL_RISCV_SMODE) imply ANDES_PLIC if (RISCV_MMODE || SPL_RISCV_MMODE) - imply ANDES_PLMT if (RISCV_MMODE || SPL_RISCV_MMODE) + imply ANDES_PLMT_TIMER if (RISCV_MMODE || SPL_RISCV_MMODE) imply SPL_CPU_SUPPORT imply SPL_OPENSBI imply SPL_LOAD_FIT diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 2f9c8f84f0..e5948e10c6 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -53,7 +53,7 @@ config ALTERA_TIMER Select this to enable a timer for Altera devices. Please find details on the "Embedded Peripherals IP User Guide" of Altera.
-config ANDES_PLMT +config ANDES_PLMT_TIMER bool depends on RISCV_MMODE || SPL_RISCV_MMODE help diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index d22813127f..eda311f0f5 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -5,7 +5,7 @@ obj-y += timer-uclass.o obj-$(CONFIG_AG101P_TIMER) += ag101p_timer.o obj-$(CONFIG_ALTERA_TIMER) += altera_timer.o -obj-$(CONFIG_ANDES_PLMT) += andes_plmt_timer.o +obj-$(CONFIG_ANDES_PLMT_TIMER) += andes_plmt_timer.o obj-$(CONFIG_ARC_TIMER) += arc_timer.o obj-$(CONFIG_AST_TIMER) += ast_timer.o obj-$(CONFIG_ATCPIT100_TIMER) += atcpit100_timer.o
Half of this driver is a DM-based timer driver, and half is RISC-V-specific IPI code. Move the timer portions in with the other timer drivers. The KConfig is not moved, since it also enables IPIs. It could also be split into two configs, but no boards use the timer but not the IPI atm, so I haven't split it.
MAINTAINERS | 1 + arch/riscv/lib/sifive_clint.c | 43 ++------------------------ drivers/timer/Makefile | 1 + drivers/timer/sifive_clint_timer.c | 49 ++++++++++++++++++++++++++++++ 4 files changed, 53 insertions(+), 41 deletions(-) create mode 100644 drivers/timer/sifive_clint_timer.c
diff --git a/MAINTAINERS b/MAINTAINERS index 32a2cdb52b..73d1c20a26 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -928,6 +928,7 @@ T: git https://gitlab.denx.de/u-boot/custodians/u-boot-riscv.git F: arch/riscv/ F: cmd/riscv/ F: drivers/timer/andes_plmt_timer.c +F: drivers/timer/sifive_clint_timer.c F: tools/prelink-riscv.c
RISC-V KENDRYTE diff --git a/arch/riscv/lib/sifive_clint.c b/arch/riscv/lib/sifive_clint.c index c9704c596f..c8079dc510 100644 --- a/arch/riscv/lib/sifive_clint.c +++ b/arch/riscv/lib/sifive_clint.c @@ -1,5 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* + * Copyright (C) 2020, Sean Anderson seanga2@gmail.com * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com * * U-Boot syscon driver for SiFive's Core Local Interruptor (CLINT). @@ -8,19 +9,13 @@ */
#include <common.h> -#include <clk.h> #include <dm.h> -#include <timer.h> #include <asm/io.h> -#include <asm/syscon.h> +#include <asm/smp.h> #include <linux/err.h>
/* MSIP registers */ #define MSIP_REG(base, hart) ((ulong)(base) + (hart) * 4) -/* mtime compare register */ -#define MTIMECMP_REG(base, hart) ((ulong)(base) + 0x4000 + (hart) * 8) -/* mtime register */ -#define MTIME_REG(base) ((ulong)(base) + 0xbff8)
DECLARE_GLOBAL_DATA_PTR;
@@ -61,37 +56,3 @@ int riscv_get_ipi(int hart, int *pending)
return 0; } - -static int sifive_clint_get_count(struct udevice *dev, u64 *count) -{ - *count = readq((void __iomem *)MTIME_REG(dev->priv)); - - return 0; -} - -static const struct timer_ops sifive_clint_ops = { - .get_count = sifive_clint_get_count, -}; - -static int sifive_clint_probe(struct udevice *dev) -{ - dev->priv = dev_read_addr_ptr(dev); - if (!dev->priv) - return -EINVAL; - - return timer_timebase_fallback(dev); -} - -static const struct udevice_id sifive_clint_ids[] = { - { .compatible = "riscv,clint0" }, - { } -}; - -U_BOOT_DRIVER(sifive_clint) = { - .name = "sifive_clint", - .id = UCLASS_TIMER, - .of_match = sifive_clint_ids, - .probe = sifive_clint_probe, - .ops = &sifive_clint_ops, - .flags = DM_FLAG_PRE_RELOC, -}; diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index eda311f0f5..410ada87b7 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -19,6 +19,7 @@ obj-$(CONFIG_RENESAS_OSTM_TIMER) += ostm_timer.o obj-$(CONFIG_RISCV_TIMER) += riscv_timer.o obj-$(CONFIG_ROCKCHIP_TIMER) += rockchip_timer.o obj-$(CONFIG_SANDBOX_TIMER) += sandbox_timer.o +obj-$(CONFIG_SIFIVE_CLINT) += sifive_clint_timer.o obj-$(CONFIG_STI_TIMER) += sti-timer.o obj-$(CONFIG_STM32_TIMER) += stm32_timer.o obj-$(CONFIG_X86_TSC_TIMER) += tsc_timer.o diff --git a/drivers/timer/sifive_clint_timer.c b/drivers/timer/sifive_clint_timer.c new file mode 100644 index 0000000000..04e85c2564 --- /dev/null +++ b/drivers/timer/sifive_clint_timer.c @@ -0,0 +1,49 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020, Sean Anderson seanga2@gmail.com + * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <timer.h> +#include <asm/io.h> +#include <linux/err.h> + +/* mtime register */ +#define MTIME_REG(base) ((ulong)(base) + 0xbff8) + +static int sifive_clint_get_count(struct udevice *dev, u64 *count) +{ + *count = readq((void __iomem *)MTIME_REG(dev->priv)); + + return 0; +} + +static const struct timer_ops sifive_clint_ops = { + .get_count = sifive_clint_get_count, +}; + +static int sifive_clint_probe(struct udevice *dev) +{ + dev->priv = dev_read_addr_ptr(dev); + if (!dev->priv) + return -EINVAL; + + return timer_timebase_fallback(dev); +} + +static const struct udevice_id sifive_clint_ids[] = { + { .compatible = "riscv,clint0" }, + { } +}; + +U_BOOT_DRIVER(sifive_clint) = { + .name = "sifive_clint", + .id = UCLASS_TIMER, + .of_match = sifive_clint_ids, + .probe = sifive_clint_probe, + .ops = &sifive_clint_ops, + .flags = DM_FLAG_PRE_RELOC, +};
- Copyright (C) 2020, Sean Anderson seanga2@gmail.com
- Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com
- U-Boot syscon driver for SiFive's Core Local Interruptor (CLINT).
if (!dev->priv)
return -EINVAL;
.id = UCLASS_TIMER,
no _TIMER suffix ?
if (!dev->priv)
return -EINVAL;
.id = UCLASS_TIMER,
2.28.0
LGTM. Other than that, Reviewed-by: Rick Chen rick@andestech.com
if (!dev->priv)
return -EINVAL;
.id = UCLASS_TIMER,
no _TIMER suffix ?
I chose to keep the current Kconfig option semantics and naming. This reflects that it enables both an IPI driver and a timer driver.
--Sean
if (!dev->priv)
return -EINVAL;
.id = UCLASS_TIMER,
2.28.0
Hi Sean
I am trying to sync to master, but it conflicts. Can you rebase again ?
Applying: riscv: Move Andes PLMT driver to drivers/timer Applying: timer: Add _TIMER suffix to Andes PLMT Kconfig Applying: riscv: Move timer portions of SiFive CLINT to drivers/timer error: patch failed: arch/riscv/lib/sifive_clint.c:61 error: arch/riscv/lib/sifive_clint.c: patch does not apply Patch failed at 0003 riscv: Move timer portions of SiFive CLINT to drivers/timer
Thanks, Rick
Rick Chen
Sean Anderson
