[PATCH 0/5] sunxi: remove lowlevel_init
For a long time the Allwinner platform was using the lowlevel_init() routine in U-Boot's boot process, even though there did not seem to be a real need for that. The README file suggests it should only be used for "bare minimum" tasks to reach board_init_f(). The routines called in arch/arm/mach-sunxi/board.c:s_init() did nothing that really warranted the early and special execution. Since we always run with an SPL, the board_init_f() routine in there seems to be the right place for early peripherals initialisation. Having those routines in s_init() actually forced other parts of U-Boot to follow suit: for instance we added a lowlevel_init() function to the armv8 side, just for sunxi. The same game seems to repeat for the ARM9 support we need for the F1C100s chip, and possibly for the RISC-V part as well.
To avoid this and to cleanup some code on the way, remove the need for lowlevel_init for sunxi completely, by: - moving the early peripheral init (clocks, timer, pinmux) to board_init_f(). This also avoids executing those bits a second time when we boot up U-Boot proper. (patch 1/5) - move the "SRAM setup" bits for just a few old SoCs into a separate file, and include this only if needed. (patch 3/5) - move the ACTLR.SMPEN bit setting from board.c into start.S, because we actually need to set this bit early. Other platforms should be able to scrap their own copies and piggy back on this change. (patch 2/5) This allows us to actually remove the lowlevel_init.S file from armv8 in patch 4/5, as sunxi was the only user. For good measure, we also clean up some bits in sunxi_common.h. (patch 5/5)
I compile tested this for all sunxi boards, and boot tested (into Linux) on Pine64, PineH64, BananaPi M1, OrangePi Zero. But there is a high chance of something breaking, so please give it a good shake on whatever Allwinner hardware you have access to.
Thanks, Andre
Andre Przywara (5): sunxi: move non-essential code out of s_init() sunxi: move Cortex SMPEN setting into start.S sunxi: move early "SRAM setup" into separate file armv8: remove no longer needed lowlevel_init.S sunxi-common.h: remove pointless #ifdefs
arch/arm/Kconfig | 3 -- arch/arm/cpu/armv7/Kconfig | 7 +++ arch/arm/cpu/armv7/start.S | 11 +++++ arch/arm/cpu/armv7/sunxi/Makefile | 3 ++ arch/arm/cpu/armv7/sunxi/sram.c | 45 +++++++++++++++++ arch/arm/cpu/armv8/Makefile | 1 - arch/arm/cpu/armv8/lowlevel_init.S | 43 ---------------- arch/arm/mach-sunxi/Kconfig | 2 - arch/arm/mach-sunxi/board.c | 78 ++++++++---------------------- include/configs/sunxi-common.h | 7 --- 10 files changed, 86 insertions(+), 114 deletions(-) create mode 100644 arch/arm/cpu/armv7/sunxi/sram.c delete mode 100644 arch/arm/cpu/armv8/lowlevel_init.S
So far all Allwinner based boards were doing some not-so-lowlevel-setup in lowlevel's s_init() routine. This includes the initial clock, timer and pinmux setup, among other things. This is clearly out of the "absolute bare minimum to get started" scope that lowlevel_init.S suggests for this function.
Since we have an SPL, which is called right after s_init(), move those calls to our board_init_f() function. As we overwrite this only for the SPL, this has the added benefit of not doing this setup *again* shortly afterwards, when running U-Boot proper.
This makes gpio_init() to be called from the SPL only, so pull this code into a CONFIG_SPL_BUILD protected part to avoid build warnings.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/mach-sunxi/board.c | 27 ++++++++++++++------------- 1 file changed, 14 insertions(+), 13 deletions(-)
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 3ef179742c5..390c9f8850d 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -75,6 +75,7 @@ ulong board_get_usable_ram_top(ulong total_size) } #endif
+#ifdef CONFIG_SPL_BUILD static int gpio_init(void) { __maybe_unused uint val; @@ -172,7 +173,6 @@ static int gpio_init(void) return 0; }
-#if defined(CONFIG_SPL_BOARD_LOAD_IMAGE) && defined(CONFIG_SPL_BUILD) static int spl_board_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) { @@ -227,18 +227,6 @@ void s_init(void) "mcr p15, 0, r0, c1, c0, 1\n" ::: "r0"); #endif -#if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I_H3 - /* Enable non-secure access to some peripherals */ - tzpc_init(); -#endif - - clock_init(); - timer_init(); - gpio_init(); -#if !CONFIG_IS_ENABLED(DM_I2C) - i2c_init_board(); -#endif - eth_init_board(); }
#define SUNXI_INVALID_BOOT_SOURCE -1 @@ -335,6 +323,19 @@ u32 spl_boot_device(void)
void board_init_f(ulong dummy) { +#if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I_H3 + /* Enable non-secure access to some peripherals */ + tzpc_init(); +#endif + + clock_init(); + timer_init(); + gpio_init(); +#if !CONFIG_IS_ENABLED(DM_I2C) + i2c_init_board(); +#endif + eth_init_board(); + spl_init(); preloader_console_init();
Reviewed-by: Samuel Holland samuel@sholland.org
As far as I can tell, this is the _only_ place that checks CONFIG_SPL_BOARD_LOAD_IMAGE, so that definition could be removed from everywhere now.
- tzpc_init();
-#endif
- clock_init();
- timer_init();
- gpio_init();
- i2c_init_board();
-#endif
- eth_init_board();
- tzpc_init();
- clock_init();
- timer_init();
- gpio_init();
- i2c_init_board();
You could move this down a few lines, near the call to i2c_init, inside the existing #if.
- eth_init_board();
- spl_init(); preloader_console_init();
Reviewed-by: Simon Glass sjg@chromium.org Tested on: orangepi_pc2, orangepi_pc, A20-OLinuXino_MICRO Tested-by: Simon Glass sjg@chromium.org
tzpc_init();
-#endif
clock_init();
timer_init();
gpio_init();
i2c_init_board();
-#endif
eth_init_board();
tzpc_init();
clock_init();
timer_init();
gpio_init();
i2c_init_board();
eth_init_board();
-- 2.17.6
According to their TRMs, Cortex ARMv7 CPUs with SMP support require the ACTLR.SMPEN bit to be set as early as possible, before any cache or TLB maintenance operations are done. As we do those things still in start.S, we need to move the SMPEN bit setting there, too.
This introduces a new ARMv7 wide symbol and code to set bit 6 in ACTLR very early in start.S, and moves sunxi boards over to use that instead of the custom code we had in our board.c file (where it was called technically too late).
In practice we got away with this so far, because at this point all the other cores were still in reset, so any broadcasting would have been ignored anyway. But it is architecturally cleaner to do it early, and we move a core specific piece of code out of board.c.
This also gets rid of the ARM_CORTEX_CPU_IS_UP kludge I introduced a few years back, and moves the respective logic into the new Kconfig entry.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/Kconfig | 3 --- arch/arm/cpu/armv7/Kconfig | 7 +++++++ arch/arm/cpu/armv7/start.S | 11 +++++++++++ arch/arm/mach-sunxi/Kconfig | 2 -- arch/arm/mach-sunxi/board.c | 9 --------- 5 files changed, 18 insertions(+), 14 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 6b11c3a50d9..7893d74fab2 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -452,9 +452,6 @@ config ENABLE_ARM_SOC_BOOT0_HOOK values, then choose this option, and create a file included as <asm/arch/boot0.h> which contains the required assembler code.
-config ARM_CORTEX_CPU_IS_UP - bool - config USE_ARCH_MEMCPY bool "Use an assembly optimized implementation of memcpy" default y if !ARM64 diff --git a/arch/arm/cpu/armv7/Kconfig b/arch/arm/cpu/armv7/Kconfig index 60bb0a9e1ec..85e5229a060 100644 --- a/arch/arm/cpu/armv7/Kconfig +++ b/arch/arm/cpu/armv7/Kconfig @@ -76,4 +76,11 @@ config ARMV7_LPAE Say Y here to use the long descriptor page table format. This is required if U-Boot runs in HYP mode.
+config ARMV7_SET_CORTEX_SMPEN + bool "Enable ACTLR.SMP bit" + default n if MACH_SUN4I || MACH_SUN5I + default y if ARCH_SUNXI && !ARM64 + help + Enable the ARM Cortex ACTLR.SMP enable bit on startup. + endif diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 698e15b8e18..af87a5432ae 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -173,6 +173,17 @@ ENDPROC(switch_to_hypervisor) * *************************************************************************/ ENTRY(cpu_init_cp15) + +#if CONFIG_IS_ENABLED(ARMV7_SET_CORTEX_SMPEN) + /* + * The Arm Cortex-A7 TRM says this bit must be enabled before + * "any cache or TLB maintenance operations are performed". + */ + mrc p15, 0, r0, c1, c0, 1 @ read auxilary control register + orr r0, r0, #1 << 6 @ set SMP bit to enable coherency + mcr p15, 0, r0, c1, c0, 1 @ write auxilary control register +#endif + /* * Invalidate L1 I/D */ diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 2c18cf02d1a..4e49ad4f0c0 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -186,7 +186,6 @@ choice config MACH_SUN4I bool "sun4i (Allwinner A10)" select CPU_V7A - select ARM_CORTEX_CPU_IS_UP select PHY_SUN4I_USB select DRAM_SUN4I select SUNXI_GEN_SUN4I @@ -197,7 +196,6 @@ config MACH_SUN4I config MACH_SUN5I bool "sun5i (Allwinner A13)" select CPU_V7A - select ARM_CORTEX_CPU_IS_UP select DRAM_SUN4I select PHY_SUN4I_USB select SUNXI_GEN_SUN4I diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 390c9f8850d..8667ddf58e3 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -218,15 +218,6 @@ void s_init(void) /* A83T BSP never modifies SUNXI_SRAMC_BASE + 0x44 */ /* No H3 BSP, boot0 seems to not modify SUNXI_SRAMC_BASE + 0x44 */ #endif - -#if !defined(CONFIG_ARM_CORTEX_CPU_IS_UP) && !defined(CONFIG_ARM64) - /* Enable SMP mode for CPU0, by setting bit 6 of Auxiliary Ctl reg */ - asm volatile( - "mrc p15, 0, r0, c1, c0, 1\n" - "orr r0, r0, #1 << 6\n" - "mcr p15, 0, r0, c1, c0, 1\n" - ::: "r0"); -#endif }
- bool
- bool "Enable ACTLR.SMP bit"
- default n if MACH_SUN4I || MACH_SUN5I
- default y if ARCH_SUNXI && !ARM64
If this is required by the CPU, why is it shown to the user? Shouldn't it be selected by MACH_SUN6/7/8/9I? That is what I see platforms doing with ARMV8_SET_SMPEN.
- help
- mrc p15, 0, r0, c1, c0, 1 @ read auxilary control register
- orr r0, r0, #1 << 6 @ set SMP bit to enable coherency
- mcr p15, 0, r0, c1, c0, 1 @ write auxilary control register
- Invalidate L1 I/D
- asm volatile(
::: "r0");
-#endif }
On Mon, 24 Jan 2022 20:47:30 -0600 Samuel Holland samuel@sholland.org wrote:
Hi Samuel,
many thanks for having a look!
- bool
You are right, it shouldn't be user visible, instead selected by platform Kconfigs. Technically we could even work that out at runtime (read MIDR & MPIDR), but I think there are situations were we want to avoid this, so we would probably need an opt-in from the platform anyways. This patch was just trying to mimic the existing logic as close as possible, since we know that works for years. Changing this is scary enough. And the negative logic is shorter than enumerating all ARMv7 SMP cores, the list of which could even grow.
But indeed there is more cleanup potential here. I see some platforms setting this bit in their code (similar to what sunxi did), but I didn't dare to touch those. Maybe I add a follow up patch to move those platforms over, and possibly merge this with ARMV8_SET_SMPEN on the way.
Cheers, Andre
- help
- Invalidate L1 I/D
- asm volatile(
::: "r0");
-#endif }
Currently we do some magic "SRAM setup" MMIO writes in s_init(), copied from the original BSP U-Boot. The comment speaks of this being required before DRAM access gets enabled, but there is no indication that this would actually be required that early.
Move this out of s_init(), into board_init_f(). Since this actually only affects a very few older SoCs, the actual code goes into the cpu/armv7 directory, to move it out of the way for all other SoCs.
This also uses the opportunity to convert some #ifdefs over to the fancy IS_ENABLED() macros used in actual C code.
We keep the s_init() stub around for now, since armv8's lowlevel_init still relies on it.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/cpu/armv7/sunxi/Makefile | 3 +++ arch/arm/cpu/armv7/sunxi/sram.c | 45 +++++++++++++++++++++++++++++++ arch/arm/mach-sunxi/board.c | 38 +++++--------------------- 3 files changed, 54 insertions(+), 32 deletions(-) create mode 100644 arch/arm/cpu/armv7/sunxi/sram.c
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index 1d40d6a18dc..ad11be78632 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -10,6 +10,9 @@ obj-y += timer.o obj-$(CONFIG_MACH_SUN6I) += tzpc.o obj-$(CONFIG_MACH_SUN8I_H3) += tzpc.o
+obj-$(CONFIG_MACH_SUN6I) += sram.o +obj-$(CONFIG_MACH_SUN8I) += sram.o + ifndef CONFIG_SPL_BUILD obj-$(CONFIG_ARMV7_PSCI) += psci.o endif diff --git a/arch/arm/cpu/armv7/sunxi/sram.c b/arch/arm/cpu/armv7/sunxi/sram.c new file mode 100644 index 00000000000..19395cce17c --- /dev/null +++ b/arch/arm/cpu/armv7/sunxi/sram.c @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2012 Henrik Nordstrom henrik@henriknordstrom.net + * + * (C) Copyright 2007-2011 + * Allwinner Technology Co., Ltd. <www.allwinnertech.com> + * Tom Cubie tangliang@allwinnertech.com + * + * SRAM init for older sunxi SoCs. + */ + +#include <common.h> +#include <init.h> +#include <asm/io.h> + +void sunxi_sram_init(void) +{ + /* + * Undocumented magic taken from boot0, without this DRAM + * access gets messed up (seems cache related). + * The boot0 sources describe this as: "config ema for cache sram" + * Newer SoCs (A83T, H3 and anything beyond) don't need this anymore. + */ + if (IS_ENABLED(CONFIG_MACH_SUN6I)) + setbits_le32(SUNXI_SRAMC_BASE + 0x44, 0x1800); + + if (IS_ENABLED(CONFIG_MACH_SUN8I)) { + uint version; + + /* Unlock sram version info reg, read it, relock */ + setbits_le32(SUNXI_SRAMC_BASE + 0x24, (1 << 15)); + version = readl(SUNXI_SRAMC_BASE + 0x24) >> 16; + clrbits_le32(SUNXI_SRAMC_BASE + 0x24, (1 << 15)); + + if (IS_ENABLED(CONFIG_MACH_SUN8I_A23)) { + if (version == 0x1650) + setbits_le32(SUNXI_SRAMC_BASE + 0x44, 0x1800); + else /* 0x1661 ? */ + setbits_le32(SUNXI_SRAMC_BASE + 0x44, 0xc0); + } else if (IS_ENABLED(CONFIG_MACH_SUN8I_A33)) { + if (version != 0x1667) + setbits_le32(SUNXI_SRAMC_BASE + 0x44, 0xc0); + } + } +} diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 8667ddf58e3..42ec02d96e3 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -186,38 +186,6 @@ SPL_LOAD_IMAGE_METHOD("FEL", 0, BOOT_DEVICE_BOARD, spl_board_load_image);
void s_init(void) { - /* - * Undocumented magic taken from boot0, without this DRAM - * access gets messed up (seems cache related). - * The boot0 sources describe this as: "config ema for cache sram" - */ -#if defined CONFIG_MACH_SUN6I - setbits_le32(SUNXI_SRAMC_BASE + 0x44, 0x1800); -#elif defined CONFIG_MACH_SUN8I - __maybe_unused uint version; - - /* Unlock sram version info reg, read it, relock */ - setbits_le32(SUNXI_SRAMC_BASE + 0x24, (1 << 15)); - version = readl(SUNXI_SRAMC_BASE + 0x24) >> 16; - clrbits_le32(SUNXI_SRAMC_BASE + 0x24, (1 << 15)); - - /* - * Ideally this would be a switch case, but we do not know exactly - * which versions there are and which version needs which settings, - * so reproduce the per SoC code from the BSP. - */ -#if defined CONFIG_MACH_SUN8I_A23 - if (version == 0x1650) - setbits_le32(SUNXI_SRAMC_BASE + 0x44, 0x1800); - else /* 0x1661 ? */ - setbits_le32(SUNXI_SRAMC_BASE + 0x44, 0xc0); -#elif defined CONFIG_MACH_SUN8I_A33 - if (version != 0x1667) - setbits_le32(SUNXI_SRAMC_BASE + 0x44, 0xc0); -#endif - /* A83T BSP never modifies SUNXI_SRAMC_BASE + 0x44 */ - /* No H3 BSP, boot0 seems to not modify SUNXI_SRAMC_BASE + 0x44 */ -#endif }
#define SUNXI_INVALID_BOOT_SOURCE -1 @@ -312,8 +280,14 @@ u32 spl_boot_device(void) return sunxi_get_boot_device(); }
+__weak void sunxi_sram_init(void) +{ +} + void board_init_f(ulong dummy) { + sunxi_sram_init(); + #if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I_H3 /* Enable non-secure access to some peripherals */ tzpc_init();
- (C) Copyright 2012 Henrik Nordstrom henrik@henriknordstrom.net
- (C) Copyright 2007-2011
- Allwinner Technology Co., Ltd. <www.allwinnertech.com>
- Tom Cubie tangliang@allwinnertech.com
- SRAM init for older sunxi SoCs.
- if (IS_ENABLED(CONFIG_MACH_SUN6I))
- if (IS_ENABLED(CONFIG_MACH_SUN8I)) {
uint version;
This is an open-coded version of sunxi_get_sram_id().
else /* 0x1661 ? */
void s_init(void) {
-#endif
-#endif }
In configurations other than MACH_SUN6/8I, the strong definition of sunxi_sram_init() is also an empty function, so this is no more efficient than unconditionally compiling sram.c.
- sunxi_sram_init();
On Mon, 24 Jan 2022 20:56:12 -0600 Samuel Holland samuel@sholland.org wrote:
Hi Samuel,
uint version;
Indeed, thanks. Needs a prototype, though, I just picked one header file in all of this mess ;-)
else /* 0x1661 ? */
void s_init(void) {
-#endif
-#endif }
I know, but I put this here to be able to keep this SRAM cruft in cpu/armv7/sunxi, and avoid compiling this file for everyone else (ARM9, ARMv8, RISC-V). Do you have a better idea? I actually tried several ways before, and this seemed to be the cleanest. Yes, we do a call to a ret, for most boards, but we probably have bigger problems. And I consider this just the beginning of a sunxi cleanup journey, so we can revisit this later.
Cheers, Andre
Hi Samuel,
uint version;
else /* 0x1661 ? */
void s_init(void) {
-#endif
-#endif }
Ah, right, that makes sense. I missed the directory change here.
No, I am fine with your method.
Regards, Samuel
Cheers, Andre
When we added Allwinner SoC support to ARMv8, we needed to pull in an implementation of lowlevel_init, as sunxi required it at this time.
The last few patches got rid of this bogus requirement, and as sunxi was still the only user, we can now remove lowlevel_init from ARMv8 altogether.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/cpu/armv8/Makefile | 1 - arch/arm/cpu/armv8/lowlevel_init.S | 43 ------------------------------ arch/arm/mach-sunxi/board.c | 4 --- 3 files changed, 48 deletions(-) delete mode 100644 arch/arm/cpu/armv8/lowlevel_init.S
diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index d85ddde430a..85fe0475c86 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -42,6 +42,5 @@ obj-$(CONFIG_FSL_LAYERSCAPE) += fsl-layerscape/ obj-$(CONFIG_S32V234) += s32v234/ obj-$(CONFIG_TARGET_HIKEY) += hisilicon/ obj-$(CONFIG_ARMV8_PSCI) += psci.o -obj-$(CONFIG_ARCH_SUNXI) += lowlevel_init.o obj-$(CONFIG_TARGET_BCMNS3) += bcmns3/ obj-$(CONFIG_XEN) += xen/ diff --git a/arch/arm/cpu/armv8/lowlevel_init.S b/arch/arm/cpu/armv8/lowlevel_init.S deleted file mode 100644 index f4f0cdce9b3..00000000000 --- a/arch/arm/cpu/armv8/lowlevel_init.S +++ /dev/null @@ -1,43 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * A lowlevel_init function that sets up the stack to call a C function to - * perform further init. - */ - -#include <asm-offsets.h> -#include <config.h> -#include <linux/linkage.h> - -ENTRY(lowlevel_init) - /* - * Setup a temporary stack. Global data is not available yet. - */ -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) - ldr w0, =CONFIG_SPL_STACK -#else - ldr w0, =CONFIG_SYS_INIT_SP_ADDR -#endif - bic sp, x0, #0xf /* 16-byte alignment for ABI compliance */ - - /* - * Save the old LR(passed in x29) and the current LR to stack - */ - stp x29, x30, [sp, #-16]! - - /* - * Call the very early init function. This should do only the - * absolute bare minimum to get started. It should not: - * - * - set up DRAM - * - use global_data - * - clear BSS - * - try to start a console - * - * For boards with SPL this should be empty since SPL can do all of - * this init in the SPL board_init_f() function which is called - * immediately after this. - */ - bl s_init - ldp x29, x30, [sp] - ret -ENDPROC(lowlevel_init) diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 42ec02d96e3..a60dc6b299c 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -184,10 +184,6 @@ static int spl_board_load_image(struct spl_image_info *spl_image, SPL_LOAD_IMAGE_METHOD("FEL", 0, BOOT_DEVICE_BOARD, spl_board_load_image); #endif
-void s_init(void) -{ -} - #define SUNXI_INVALID_BOOT_SOURCE -1
static int sunxi_get_boot_source(void)
Well, we are removing lowlevel_init.S anyway. There is still a weak definition of lowlevel_init in arch/arm/cpu/armv8/start.S, which we are now picking up.
- A lowlevel_init function that sets up the stack to call a C function to
- perform further init.
-#else
-#endif
* - set up DRAM
* - use global_data
* - clear BSS
- bl s_init
- ret
Remove some pointless #ifdefs from this file, as there are quite too many of them already.
Some definitions don't really hurt to have in any case, so remove the pointless CONFIG_MMC guard around CONFIG_MMC_SUNXI_SLOT.
The BOARD_SIZE_LIMIT applies regardless of ARM64 or not (now), so remove that guard as well. The maximum number of MMC devices does not depend on CONFIG_ENV_IS_IN_MMC, so move that out to simplify the file.
Last but not least CONFIG_SPL_BOARD_LOAD_IMAGE serves no real purpose anymore: it's unconditionally defined for all sunxi boards, and protects nothing applicable outside of sunxi code anymore. Just remove it.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- include/configs/sunxi-common.h | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 7260eb72a40..01c3cfced20 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -93,13 +93,9 @@ #endif
/* mmc config */ -#ifdef CONFIG_MMC #define CONFIG_MMC_SUNXI_SLOT 0 -#endif
#if defined(CONFIG_ENV_IS_IN_MMC) - -#ifdef CONFIG_ARM64 /* * This is actually (CONFIG_ENV_OFFSET - * (CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)), but the value will be used @@ -109,7 +105,6 @@ #endif
#define CONFIG_SYS_MMC_MAX_DEVICE 4 -#endif
/* * Miscellaneous configurable options @@ -124,8 +119,6 @@
#define CONFIG_SYS_MONITOR_LEN (768 << 10) /* 768 KiB */
-#define CONFIG_SPL_BOARD_LOAD_IMAGE - /* * We cannot use expressions here, because expressions won't be evaluated in * autoconf.mk.
Thanks, Andre
Tested-By: Jesse Taube Mr.Bossman075@gmail.com
Tested on Lamobo_R1_defconfig.
Thanks, Jesse Taube
Thanks, Andre
Tested on Lamobo_R1_defconfig and f1c100s.
Thanks, Jesse Taube
Andre Przywara
Jesse Taube
Samuel Holland
