[U-Boot] [PATCH v3 1/2] spl: rk3399: disable DDR security regions for SPL (for DMA in dw_mmc)
The RK3399 hangs during DMA of the Designware MMC controller, when performing DMA-based transactions in SPL due to the DDR security settings left behind by the BootROM (i.e. accesses to the first MB of DRAM are restricted... however, the DMA is likely to target this first MB, as it transfers from/to the stack).
System security is not affected, as the final security configuration is performed by the ATF, which is executed after the SPL stage.
With this fix in place, we can now drop 'fifo-mode' in the DTS for the RK3399-Q7 (Puma).
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v3: - replaces the work-around (i.e. falling back to fifo-mode in SPL) with a permanent fix
arch/arm/mach-rockchip/rk3399-board-spl.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3399-board-spl.c b/arch/arm/mach-rockchip/rk3399-board-spl.c index 3bfc2d9..c5e32c4 100644 --- a/arch/arm/mach-rockchip/rk3399-board-spl.c +++ b/arch/arm/mach-rockchip/rk3399-board-spl.c @@ -186,6 +186,7 @@ void board_debug_uart_init(void) }
#define GRF_EMMCCORE_CON11 0xff77f02c +#define SGRF_DDR_RGN_CON16 0xff330040 void board_init_f(ulong dummy) { struct udevice *pinctrl; @@ -214,6 +215,17 @@ void board_init_f(ulong dummy) hang(); }
+ /* + * Disable DDR security regions. + * + * As we are entered from the BootROM, the region from + * 0x0 through 0xfffff (i.e. the first MB of memory) will + * be protected. This will cause issues with the DW_MMC + * driver, which tries to DMA from/to the stack (likely) + * located in this range. + */ + rk_clrsetreg(SGRF_DDR_RGN_CON16, 0x1FF, 0); + secure_timer_init();
ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); @@ -251,6 +263,7 @@ void spl_board_init(void) #ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM back_to_bootrom(); #endif + return; err: printf("spl_board_init: Error %d\n", ret);
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
Changes in v3: None
arch/arm/dts/rk3399-puma.dts | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/dts/rk3399-puma.dts b/arch/arm/dts/rk3399-puma.dts index 09b3858..50e43c7 100644 --- a/arch/arm/dts/rk3399-puma.dts +++ b/arch/arm/dts/rk3399-puma.dts @@ -91,7 +91,6 @@ &sdmmc { u-boot,dm-pre-reloc; bus-width = <4>; - fifo-mode; /* until we fix DMA in SPL */ status = "okay"; };
On 29 March 2017 at 13:20, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Always nice to have a commit message. Also, please can you always add a 'rockchip: ' tag?
Changes in v3: None
Changes in v3: None
Added rockchip tag and:
Applied to u-boot-rockchip, thanks!
Hi Philipp,
Changes in v3:
- return; err: printf("spl_board_init: Error %d\n", ret);
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes in v3:
Changes in v3:
Added rockchip: tag and
Kever Yang
Philipp Tomsich
