[U-Boot] [PATCH] ppc4xx: Remove some testing hacks from ppc4xx.h
I accidentally left these hacks in the code while doing the big header cleanup. Let's remove it now.
Signed-off-by: Stefan Roese sr@denx.de --- arch/powerpc/include/asm/ppc4xx.h | 17 ----------------- 1 files changed, 0 insertions(+), 17 deletions(-)
diff --git a/arch/powerpc/include/asm/ppc4xx.h b/arch/powerpc/include/asm/ppc4xx.h index 87a16ec..ff6034e 100644 --- a/arch/powerpc/include/asm/ppc4xx.h +++ b/arch/powerpc/include/asm/ppc4xx.h @@ -82,7 +82,6 @@ /* * Configure which SDRAM/DDR/DDR2 controller is equipped */ -// test-only: what to do with these??? #if defined(CONFIG_AP1000) || defined(CONFIG_ML2) #define CONFIG_SDRAM_PPC4xx_IBM_SDRAM /* IBM SDRAM controller */ #endif @@ -202,22 +201,6 @@ #define GPT0_DCT0 0x00000110 #define GPT0_DCIS 0x0000011C
-#if 0 // test-only -/* - * All PPC4xx share the same NS16550 UART(s). Only base addresses - * may differ. We define here the integration of the common NS16550 - * driver for all PPC4xx SoC's. The board config header must specify - * on which UART the console should be located via CONFIG_CONS_INDEX. - */ -#if 0 /* test-only */ -#define CONFIG_SERIAL_MULTI -#endif -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_serial_clock() -#endif - #if defined(CONFIG_440) #include <asm/ppc440.h> #else
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
