[PATCH 0/2] mmc: fsl_esdhc: fix up for eMMC HS400
This patch-set provides fix up for eMMC HS400 for a potential DLL lock issue during mmc rescan.
Yangbo Lu (2): mmc: fsl_esdhc: set sysctl register for clock initialization mmc: fsl_esdhc: make sure delay chain locked for HS400
drivers/mmc/fsl_esdhc.c | 30 ++++++++++++++++++++++++++---- include/fsl_esdhc.h | 4 ++++ 2 files changed, 30 insertions(+), 4 deletions(-)
The initial clock setting should be through sysctl register only, while the mmc_set_clock() will call mmc_set_ios() introduce other configurations like bus width, mode, and so on.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- drivers/mmc/fsl_esdhc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 642784e..68130ee 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -715,7 +715,7 @@ static int esdhc_init_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) esdhc_setbits32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN);
/* Set the initial clock speed */ - mmc_set_clock(mmc, 400000, MMC_CLK_ENABLE); + set_sysctl(priv, mmc, 400000);
/* Disable the BRR and BWR bits in IRQSTAT */ esdhc_clrbits32(®s->irqstaten, IRQSTATEN_BRR | IRQSTATEN_BWR);
Dear Yangbo,
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
For eMMC HS400 mode, the DLL reset is a required step for mmc rescan. This step has not been documented in reference manual, but the RM will be fixed sooner or later.
This patch is to add the step of DLL reset, and make sure delay chain locked for HS400.
Fixes: db8f93672b42 ("mmc: fsl_esdhc: support eMMC HS400 mode") Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- drivers/mmc/fsl_esdhc.c | 28 +++++++++++++++++++++++++--- include/fsl_esdhc.h | 4 ++++ 2 files changed, 29 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 68130ee..a18316e 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -70,7 +70,9 @@ struct fsl_esdhc { uint sdtimingctl; /* SD timing control register */ char reserved8[20]; /* reserved */ uint dllcfg0; /* DLL config 0 register */ - char reserved9[680]; /* reserved */ + char reserved9[12]; /* reserved */ + uint dllstat0; /* DLL status 0 register */ + char reserved10[664];/* reserved */ uint esdhcctl; /* eSDHC control register */ };
@@ -617,9 +619,11 @@ static void esdhc_exit_hs400(struct fsl_esdhc_priv *priv) esdhc_tuning_block_enable(priv, false); }
-static void esdhc_set_timing(struct fsl_esdhc_priv *priv, enum bus_mode mode) +static int esdhc_set_timing(struct fsl_esdhc_priv *priv, enum bus_mode mode) { struct fsl_esdhc *regs = priv->esdhc_regs; + ulong start; + u32 val;
/* Exit HS400 mode before setting any other mode */ if (esdhc_read32(®s->tbctl) & HS400_MODE && @@ -640,17 +644,33 @@ static void esdhc_set_timing(struct fsl_esdhc_priv *priv, enum bus_mode mode) esdhc_setbits32(®s->dllcfg0, DLL_FREQ_SEL);
esdhc_setbits32(®s->dllcfg0, DLL_ENABLE); + + esdhc_setbits32(®s->dllcfg0, DLL_RESET); + udelay(1); + esdhc_clrbits32(®s->dllcfg0, DLL_RESET); + + start = get_timer(0); + val = DLL_STS_SLV_LOCK; + while (!(esdhc_read32(®s->dllstat0) & val)) { + if (get_timer(start) > 1000) { + printf("fsl_esdhc: delay chain lock timeout\n"); + return -ETIMEDOUT; + } + } + esdhc_setbits32(®s->tbctl, HS400_WNDW_ADJUST);
esdhc_clock_control(priv, false); esdhc_flush_async_fifo(priv); } esdhc_clock_control(priv, true); + return 0; }
static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) { struct fsl_esdhc *regs = priv->esdhc_regs; + int ret;
if (priv->is_sdhc_per_clk) { /* Select to use peripheral clock */ @@ -667,7 +687,9 @@ static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) set_sysctl(priv, mmc, mmc->clock);
/* Set timing */ - esdhc_set_timing(priv, mmc->selected_mode); + ret = esdhc_set_timing(priv, mmc->selected_mode); + if (ret) + return ret;
/* Set the bus width */ esdhc_clrbits32(®s->proctl, PROCTL_DTW_4 | PROCTL_DTW_8); diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index e6f1c75..850a304 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -187,8 +187,12 @@
/* DLL config 0 register */ #define DLL_ENABLE 0x80000000 +#define DLL_RESET 0x40000000 #define DLL_FREQ_SEL 0x08000000
+/* DLL status 0 register */ +#define DLL_STS_SLV_LOCK 0x08000000 + #define MAX_TUNING_LOOP 40
#define HOSTVER_VENDOR(x) (((x) >> 8) & 0xff)
Dear Yangbo,
Just added minor comments.
- char reserved9[12]; /* reserved */
- uint dllstat0; /* DLL status 0 register */
- char reserved10[664];/* reserved */ uint esdhcctl; /* eSDHC control register */
ulong start;
u32 val;
udelay(1);
Could you add a light comment why need to put udelay(1)?
return -ETIMEDOUT;
int ret;
/* Set timing */
if (ret)
return ret;
Hi Jaehoon,
-----Original Message----- From: Jaehoon Chung jh80.chung@samsung.com Sent: Tuesday, October 20, 2020 5:52 AM To: Y.b. Lu yangbo.lu@nxp.com; u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com Subject: Re: [PATCH 2/2] mmc: fsl_esdhc: make sure delay chain locked for HS400
Dear Yangbo,
*priv)
mode)
mode)
ulong start;
u32 val;
esdhc_setbits32(®s->dllcfg0, DLL_FREQ_SEL); esdhc_setbits32(®s->dllcfg0, DLL_ENABLE);
udelay(1);
Actually this is just per fixed reference manual. I sent out v2 patch, to explain in commit message in case some one what to know why.
" In previous commit to support eMMC HS400, db8f936 mmc: fsl_esdhc: support eMMC HS400 mode
the steps to configure DLL could be found in commit message, 13. Set DLLCFG0[DLL_ENABLE] and DLLCFG0[DLL_FREQ_SEL]. 14. Wait for delay chain to lock.
these would be fixed as, 13. Set DLLCFG0[DLL_ENABLE] and DLLCFG0[DLL_FREQ_SEL]. 13.1 Write DLLCFG0[DLL_RESET] to 1 and wait for 1us, then write DLLCFG0[DLL_RESET] 14. Wait for delay chain to lock."
Thanks.
return -ETIMEDOUT;
*mmc)
int ret;
/* Set timing */
if (ret)
return ret;
On 10/20/20 12:20 PM, Y.b. Lu wrote:
Hi Jaehoon,
Dear Yangbo,
*priv)
mode)
mode)
ulong start;
u32 val;
udelay(1);
the steps to configure DLL could be found in commit message, 13. Set DLLCFG0[DLL_ENABLE] and DLLCFG0[DLL_FREQ_SEL]. 14. Wait for delay chain to lock. these would be fixed as, 13. Set DLLCFG0[DLL_ENABLE] and DLLCFG0[DLL_FREQ_SEL]. 13.1 Write DLLCFG0[DLL_RESET] to 1 and wait for 1us, then write DLLCFG0[DLL_RESET] 14. Wait for delay chain to lock."
Thanks.
Thanks you for kindly explanation.
return -ETIMEDOUT;
*mmc)
int ret;
/* Set timing */
if (ret)
return ret;
Jaehoon Chung
Y.b. Lu
Yangbo Lu
