Re: [PATCH 2/6] board: freescale: p1_p2_rdb_pc: Add weak function p1_p2_rdb_pc_fix_fdt_model() for fixing DT model string
On 6/7/24 1:32 AM, Sinan Akman wrote:
On 2024-06-06 12:33 p.m., Marek Mojík wrote:
This allows boards to fixup / overwrite DT model string when booting OS.
Signed-off-by: Pali Rohár pali@kernel.org Signed-off-by: Marek Mojík marek.mojik@nic.cz
board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c index 399ff72072..336d274cdb 100644 --- a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c +++ b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c @@ -364,6 +364,8 @@ int board_early_init_r(void) return 0; }
+__weak void p1_p2_rdb_pc_fix_fdt_model(void *blob) {}
#if defined(CONFIG_OF_BOARD_SETUP) || defined(CONFIG_OF_BOARD_FIXUP) static void fix_max6370_watchdog(void *blob) { @@ -407,6 +409,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) sizeof("okay"), 0); #endif
+ p1_p2_rdb_pc_fix_fdt_model(blob); fix_max6370_watchdog(blob);
#if defined(CONFIG_HAS_FSL_DR_USB) @@ -464,6 +467,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) #ifdef CONFIG_OF_BOARD_FIXUP int board_fix_fdt(void *blob) { + p1_p2_rdb_pc_fix_fdt_model(blob); fix_max6370_watchdog(blob); return 0; }
Hi Marek
I have a P2020-RDB board and last time I tried to test ToT (couple months ago)
I needed to remove a watchdog patch that was added by Pali (a year+ ago). I
believe because of the differences in CPLD that patch kept resetting on my board.
I am traveling (again) but when I am back on July 10th I can give a try to
test this if you prefer.
Best regards
Sinan Akman
Hi Sinan,
What do you mean by ToT? Regardless, I don't have access to P2020-RDB, so you will have to test it yourself.
Best regards, Marek
Hi Marek
Best regards
Sinan Akman
Hi Sinan,
Hi Marek
I meant tip of the tree.
... Regardless, I don't have access to P2020-RDB, so you will have to test it yourself.
Will do.
Thanks Sinan Akman
Marek Mojík
Sinan Akman
