[PATCH 1/2] sunxi: mmc: Sort compatible strings numerically
commit 95168d77d391 ("sunxi: add Allwinner R528/T113 SoC support") added the new entry out of order.
Signed-off-by: Samuel Holland samuel@sholland.org ---
drivers/mmc/sunxi_mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 4d6351bf275..7caefa153dc 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -701,13 +701,13 @@ static const struct udevice_id sunxi_mmc_ids[] = { { .compatible = "allwinner,sun7i-a20-mmc" }, { .compatible = "allwinner,sun8i-a83t-emmc" }, { .compatible = "allwinner,sun9i-a80-mmc" }, + { .compatible = "allwinner,sun20i-d1-mmc" }, { .compatible = "allwinner,sun50i-a64-mmc" }, { .compatible = "allwinner,sun50i-a64-emmc" }, { .compatible = "allwinner,sun50i-h6-mmc" }, { .compatible = "allwinner,sun50i-h6-emmc" }, { .compatible = "allwinner,sun50i-a100-mmc" }, { .compatible = "allwinner,sun50i-a100-emmc" }, - { .compatible = "allwinner,sun20i-d1-mmc" }, { /* sentinel */ } };
The MMC controller driver is (and ought to be) the only user of these register definitions. Put them in a header next to the driver to remove the dependency on a specific ARM platform's headers.
Due to the sunxi_mmc_init() prototype, the file was not renamed. None of the register definitions were changed.
arch/arm/include/asm/arch-sunxi/mmc.h | 139 +------------------------- drivers/mmc/sunxi_mmc.c | 4 + drivers/mmc/sunxi_mmc.h | 138 +++++++++++++++++++++++++ 3 files changed, 146 insertions(+), 135 deletions(-) create mode 100644 drivers/mmc/sunxi_mmc.h
diff --git a/arch/arm/include/asm/arch-sunxi/mmc.h b/arch/arm/include/asm/arch-sunxi/mmc.h index 8ed3e0459c9..b8d91b5c64b 100644 --- a/arch/arm/include/asm/arch-sunxi/mmc.h +++ b/arch/arm/include/asm/arch-sunxi/mmc.h @@ -1,139 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2007-2011 - * Allwinner Technology Co., Ltd. <www.allwinnertech.com> - * Aaron leafy.myeh@allwinnertech.com - * - * MMC register definition for allwinner sunxi platform. - */
-#ifndef _SUNXI_MMC_H -#define _SUNXI_MMC_H - -#include <linux/types.h> - -struct sunxi_mmc { - u32 gctrl; /* 0x00 global control */ - u32 clkcr; /* 0x04 clock control */ - u32 timeout; /* 0x08 time out */ - u32 width; /* 0x0c bus width */ - u32 blksz; /* 0x10 block size */ - u32 bytecnt; /* 0x14 byte count */ - u32 cmd; /* 0x18 command */ - u32 arg; /* 0x1c argument */ - u32 resp0; /* 0x20 response 0 */ - u32 resp1; /* 0x24 response 1 */ - u32 resp2; /* 0x28 response 2 */ - u32 resp3; /* 0x2c response 3 */ - u32 imask; /* 0x30 interrupt mask */ - u32 mint; /* 0x34 masked interrupt status */ - u32 rint; /* 0x38 raw interrupt status */ - u32 status; /* 0x3c status */ - u32 ftrglevel; /* 0x40 FIFO threshold watermark*/ - u32 funcsel; /* 0x44 function select */ - u32 cbcr; /* 0x48 CIU byte count */ - u32 bbcr; /* 0x4c BIU byte count */ - u32 dbgc; /* 0x50 debug enable */ - u32 res0; /* 0x54 reserved */ - u32 a12a; /* 0x58 Auto command 12 argument */ - u32 ntsr; /* 0x5c New timing set register */ - u32 res1[8]; - u32 dmac; /* 0x80 internal DMA control */ - u32 dlba; /* 0x84 internal DMA descr list base address */ - u32 idst; /* 0x88 internal DMA status */ - u32 idie; /* 0x8c internal DMA interrupt enable */ - u32 chda; /* 0x90 */ - u32 cbda; /* 0x94 */ - u32 res2[26]; -#if defined(CONFIG_SUNXI_GEN_SUN6I) || defined(CONFIG_SUN50I_GEN_H6) || defined(CONFIG_SUNXI_GEN_NCAT2) - u32 res3[17]; - u32 samp_dl; - u32 res4[46]; -#endif - u32 fifo; /* 0x100 / 0x200 FIFO access address */ -}; - -#define SUNXI_MMC_CLK_POWERSAVE (0x1 << 17) -#define SUNXI_MMC_CLK_ENABLE (0x1 << 16) -#define SUNXI_MMC_CLK_DIVIDER_MASK (0xff) - -#define SUNXI_MMC_GCTRL_SOFT_RESET (0x1 << 0) -#define SUNXI_MMC_GCTRL_FIFO_RESET (0x1 << 1) -#define SUNXI_MMC_GCTRL_DMA_RESET (0x1 << 2) -#define SUNXI_MMC_GCTRL_RESET (SUNXI_MMC_GCTRL_SOFT_RESET|\ - SUNXI_MMC_GCTRL_FIFO_RESET|\ - SUNXI_MMC_GCTRL_DMA_RESET) -#define SUNXI_MMC_GCTRL_DMA_ENABLE (0x1 << 5) -#define SUNXI_MMC_GCTRL_ACCESS_BY_AHB (0x1 << 31) - -#define SUNXI_MMC_CMD_RESP_EXPIRE (0x1 << 6) -#define SUNXI_MMC_CMD_LONG_RESPONSE (0x1 << 7) -#define SUNXI_MMC_CMD_CHK_RESPONSE_CRC (0x1 << 8) -#define SUNXI_MMC_CMD_DATA_EXPIRE (0x1 << 9) -#define SUNXI_MMC_CMD_WRITE (0x1 << 10) -#define SUNXI_MMC_CMD_AUTO_STOP (0x1 << 12) -#define SUNXI_MMC_CMD_WAIT_PRE_OVER (0x1 << 13) -#define SUNXI_MMC_CMD_SEND_INIT_SEQ (0x1 << 15) -#define SUNXI_MMC_CMD_UPCLK_ONLY (0x1 << 21) -#define SUNXI_MMC_CMD_START (0x1 << 31) - -#define SUNXI_MMC_RINT_RESP_ERROR (0x1 << 1) -#define SUNXI_MMC_RINT_COMMAND_DONE (0x1 << 2) -#define SUNXI_MMC_RINT_DATA_OVER (0x1 << 3) -#define SUNXI_MMC_RINT_TX_DATA_REQUEST (0x1 << 4) -#define SUNXI_MMC_RINT_RX_DATA_REQUEST (0x1 << 5) -#define SUNXI_MMC_RINT_RESP_CRC_ERROR (0x1 << 6) -#define SUNXI_MMC_RINT_DATA_CRC_ERROR (0x1 << 7) -#define SUNXI_MMC_RINT_RESP_TIMEOUT (0x1 << 8) -#define SUNXI_MMC_RINT_DATA_TIMEOUT (0x1 << 9) -#define SUNXI_MMC_RINT_VOLTAGE_CHANGE_DONE (0x1 << 10) -#define SUNXI_MMC_RINT_FIFO_RUN_ERROR (0x1 << 11) -#define SUNXI_MMC_RINT_HARD_WARE_LOCKED (0x1 << 12) -#define SUNXI_MMC_RINT_START_BIT_ERROR (0x1 << 13) -#define SUNXI_MMC_RINT_AUTO_COMMAND_DONE (0x1 << 14) -#define SUNXI_MMC_RINT_END_BIT_ERROR (0x1 << 15) -#define SUNXI_MMC_RINT_SDIO_INTERRUPT (0x1 << 16) -#define SUNXI_MMC_RINT_CARD_INSERT (0x1 << 30) -#define SUNXI_MMC_RINT_CARD_REMOVE (0x1 << 31) -#define SUNXI_MMC_RINT_INTERRUPT_ERROR_BIT \ - (SUNXI_MMC_RINT_RESP_ERROR | \ - SUNXI_MMC_RINT_RESP_CRC_ERROR | \ - SUNXI_MMC_RINT_DATA_CRC_ERROR | \ - SUNXI_MMC_RINT_RESP_TIMEOUT | \ - SUNXI_MMC_RINT_DATA_TIMEOUT | \ - SUNXI_MMC_RINT_VOLTAGE_CHANGE_DONE | \ - SUNXI_MMC_RINT_FIFO_RUN_ERROR | \ - SUNXI_MMC_RINT_HARD_WARE_LOCKED | \ - SUNXI_MMC_RINT_START_BIT_ERROR | \ - SUNXI_MMC_RINT_END_BIT_ERROR) /* 0xbfc2 */ -#define SUNXI_MMC_RINT_INTERRUPT_DONE_BIT \ - (SUNXI_MMC_RINT_AUTO_COMMAND_DONE | \ - SUNXI_MMC_RINT_DATA_OVER | \ - SUNXI_MMC_RINT_COMMAND_DONE | \ - SUNXI_MMC_RINT_VOLTAGE_CHANGE_DONE) - -#define SUNXI_MMC_STATUS_RXWL_FLAG (0x1 << 0) -#define SUNXI_MMC_STATUS_TXWL_FLAG (0x1 << 1) -#define SUNXI_MMC_STATUS_FIFO_EMPTY (0x1 << 2) -#define SUNXI_MMC_STATUS_FIFO_FULL (0x1 << 3) -#define SUNXI_MMC_STATUS_CARD_PRESENT (0x1 << 8) -#define SUNXI_MMC_STATUS_CARD_DATA_BUSY (0x1 << 9) -#define SUNXI_MMC_STATUS_DATA_FSM_BUSY (0x1 << 10) -#define SUNXI_MMC_STATUS_FIFO_LEVEL(reg) (((reg) >> 17) & 0x3fff) - -#define SUNXI_MMC_NTSR_MODE_SEL_NEW (0x1 << 31) - -#define SUNXI_MMC_IDMAC_RESET (0x1 << 0) -#define SUNXI_MMC_IDMAC_FIXBURST (0x1 << 1) -#define SUNXI_MMC_IDMAC_ENABLE (0x1 << 7) - -#define SUNXI_MMC_IDIE_TXIRQ (0x1 << 0) -#define SUNXI_MMC_IDIE_RXIRQ (0x1 << 1) - -#define SUNXI_MMC_COMMON_CLK_GATE (1 << 16) -#define SUNXI_MMC_COMMON_RESET (1 << 18) - -#define SUNXI_MMC_CAL_DL_SW_EN (0x1 << 7) +#ifndef _ASM_ARCH_MMC_H_ +#define _ASM_ARCH_MMC_H_
struct mmc *sunxi_mmc_init(int sdc_no); -#endif /* _SUNXI_MMC_H */ + +#endif /* _ASM_ARCH_MMC_H_ */ diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 7caefa153dc..714706d2411 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -25,10 +25,14 @@ #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/cpu.h> +#if !CONFIG_IS_ENABLED(DM_MMC) #include <asm/arch/mmc.h> +#endif #include <linux/delay.h> #include <sunxi_gpio.h>
+#include "sunxi_mmc.h" + #ifndef CCM_MMC_CTRL_MODE_SEL_NEW #define CCM_MMC_CTRL_MODE_SEL_NEW 0 #endif diff --git a/drivers/mmc/sunxi_mmc.h b/drivers/mmc/sunxi_mmc.h new file mode 100644 index 00000000000..f4ae5a790c8 --- /dev/null +++ b/drivers/mmc/sunxi_mmc.h @@ -0,0 +1,138 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2007-2011 + * Allwinner Technology Co., Ltd. <www.allwinnertech.com> + * Aaron leafy.myeh@allwinnertech.com + * + * MMC register definition for allwinner sunxi platform. + */ + +#ifndef _SUNXI_MMC_H +#define _SUNXI_MMC_H + +#include <linux/types.h> + +struct sunxi_mmc { + u32 gctrl; /* 0x00 global control */ + u32 clkcr; /* 0x04 clock control */ + u32 timeout; /* 0x08 time out */ + u32 width; /* 0x0c bus width */ + u32 blksz; /* 0x10 block size */ + u32 bytecnt; /* 0x14 byte count */ + u32 cmd; /* 0x18 command */ + u32 arg; /* 0x1c argument */ + u32 resp0; /* 0x20 response 0 */ + u32 resp1; /* 0x24 response 1 */ + u32 resp2; /* 0x28 response 2 */ + u32 resp3; /* 0x2c response 3 */ + u32 imask; /* 0x30 interrupt mask */ + u32 mint; /* 0x34 masked interrupt status */ + u32 rint; /* 0x38 raw interrupt status */ + u32 status; /* 0x3c status */ + u32 ftrglevel; /* 0x40 FIFO threshold watermark*/ + u32 funcsel; /* 0x44 function select */ + u32 cbcr; /* 0x48 CIU byte count */ + u32 bbcr; /* 0x4c BIU byte count */ + u32 dbgc; /* 0x50 debug enable */ + u32 res0; /* 0x54 reserved */ + u32 a12a; /* 0x58 Auto command 12 argument */ + u32 ntsr; /* 0x5c New timing set register */ + u32 res1[8]; + u32 dmac; /* 0x80 internal DMA control */ + u32 dlba; /* 0x84 internal DMA descr list base address */ + u32 idst; /* 0x88 internal DMA status */ + u32 idie; /* 0x8c internal DMA interrupt enable */ + u32 chda; /* 0x90 */ + u32 cbda; /* 0x94 */ + u32 res2[26]; +#if defined(CONFIG_SUNXI_GEN_SUN6I) || defined(CONFIG_SUN50I_GEN_H6) || defined(CONFIG_SUNXI_GEN_NCAT2) + u32 res3[17]; + u32 samp_dl; + u32 res4[46]; +#endif + u32 fifo; /* 0x100 / 0x200 FIFO access address */ +}; + +#define SUNXI_MMC_CLK_POWERSAVE (0x1 << 17) +#define SUNXI_MMC_CLK_ENABLE (0x1 << 16) +#define SUNXI_MMC_CLK_DIVIDER_MASK (0xff) + +#define SUNXI_MMC_GCTRL_SOFT_RESET (0x1 << 0) +#define SUNXI_MMC_GCTRL_FIFO_RESET (0x1 << 1) +#define SUNXI_MMC_GCTRL_DMA_RESET (0x1 << 2) +#define SUNXI_MMC_GCTRL_RESET (SUNXI_MMC_GCTRL_SOFT_RESET|\ + SUNXI_MMC_GCTRL_FIFO_RESET|\ + SUNXI_MMC_GCTRL_DMA_RESET) +#define SUNXI_MMC_GCTRL_DMA_ENABLE (0x1 << 5) +#define SUNXI_MMC_GCTRL_ACCESS_BY_AHB (0x1 << 31) + +#define SUNXI_MMC_CMD_RESP_EXPIRE (0x1 << 6) +#define SUNXI_MMC_CMD_LONG_RESPONSE (0x1 << 7) +#define SUNXI_MMC_CMD_CHK_RESPONSE_CRC (0x1 << 8) +#define SUNXI_MMC_CMD_DATA_EXPIRE (0x1 << 9) +#define SUNXI_MMC_CMD_WRITE (0x1 << 10) +#define SUNXI_MMC_CMD_AUTO_STOP (0x1 << 12) +#define SUNXI_MMC_CMD_WAIT_PRE_OVER (0x1 << 13) +#define SUNXI_MMC_CMD_SEND_INIT_SEQ (0x1 << 15) +#define SUNXI_MMC_CMD_UPCLK_ONLY (0x1 << 21) +#define SUNXI_MMC_CMD_START (0x1 << 31) + +#define SUNXI_MMC_RINT_RESP_ERROR (0x1 << 1) +#define SUNXI_MMC_RINT_COMMAND_DONE (0x1 << 2) +#define SUNXI_MMC_RINT_DATA_OVER (0x1 << 3) +#define SUNXI_MMC_RINT_TX_DATA_REQUEST (0x1 << 4) +#define SUNXI_MMC_RINT_RX_DATA_REQUEST (0x1 << 5) +#define SUNXI_MMC_RINT_RESP_CRC_ERROR (0x1 << 6) +#define SUNXI_MMC_RINT_DATA_CRC_ERROR (0x1 << 7) +#define SUNXI_MMC_RINT_RESP_TIMEOUT (0x1 << 8) +#define SUNXI_MMC_RINT_DATA_TIMEOUT (0x1 << 9) +#define SUNXI_MMC_RINT_VOLTAGE_CHANGE_DONE (0x1 << 10) +#define SUNXI_MMC_RINT_FIFO_RUN_ERROR (0x1 << 11) +#define SUNXI_MMC_RINT_HARD_WARE_LOCKED (0x1 << 12) +#define SUNXI_MMC_RINT_START_BIT_ERROR (0x1 << 13) +#define SUNXI_MMC_RINT_AUTO_COMMAND_DONE (0x1 << 14) +#define SUNXI_MMC_RINT_END_BIT_ERROR (0x1 << 15) +#define SUNXI_MMC_RINT_SDIO_INTERRUPT (0x1 << 16) +#define SUNXI_MMC_RINT_CARD_INSERT (0x1 << 30) +#define SUNXI_MMC_RINT_CARD_REMOVE (0x1 << 31) +#define SUNXI_MMC_RINT_INTERRUPT_ERROR_BIT \ + (SUNXI_MMC_RINT_RESP_ERROR | \ + SUNXI_MMC_RINT_RESP_CRC_ERROR | \ + SUNXI_MMC_RINT_DATA_CRC_ERROR | \ + SUNXI_MMC_RINT_RESP_TIMEOUT | \ + SUNXI_MMC_RINT_DATA_TIMEOUT | \ + SUNXI_MMC_RINT_VOLTAGE_CHANGE_DONE | \ + SUNXI_MMC_RINT_FIFO_RUN_ERROR | \ + SUNXI_MMC_RINT_HARD_WARE_LOCKED | \ + SUNXI_MMC_RINT_START_BIT_ERROR | \ + SUNXI_MMC_RINT_END_BIT_ERROR) /* 0xbfc2 */ +#define SUNXI_MMC_RINT_INTERRUPT_DONE_BIT \ + (SUNXI_MMC_RINT_AUTO_COMMAND_DONE | \ + SUNXI_MMC_RINT_DATA_OVER | \ + SUNXI_MMC_RINT_COMMAND_DONE | \ + SUNXI_MMC_RINT_VOLTAGE_CHANGE_DONE) + +#define SUNXI_MMC_STATUS_RXWL_FLAG (0x1 << 0) +#define SUNXI_MMC_STATUS_TXWL_FLAG (0x1 << 1) +#define SUNXI_MMC_STATUS_FIFO_EMPTY (0x1 << 2) +#define SUNXI_MMC_STATUS_FIFO_FULL (0x1 << 3) +#define SUNXI_MMC_STATUS_CARD_PRESENT (0x1 << 8) +#define SUNXI_MMC_STATUS_CARD_DATA_BUSY (0x1 << 9) +#define SUNXI_MMC_STATUS_DATA_FSM_BUSY (0x1 << 10) +#define SUNXI_MMC_STATUS_FIFO_LEVEL(reg) (((reg) >> 17) & 0x3fff) + +#define SUNXI_MMC_NTSR_MODE_SEL_NEW (0x1 << 31) + +#define SUNXI_MMC_IDMAC_RESET (0x1 << 0) +#define SUNXI_MMC_IDMAC_FIXBURST (0x1 << 1) +#define SUNXI_MMC_IDMAC_ENABLE (0x1 << 7) + +#define SUNXI_MMC_IDIE_TXIRQ (0x1 << 0) +#define SUNXI_MMC_IDIE_RXIRQ (0x1 << 1) + +#define SUNXI_MMC_COMMON_CLK_GATE (1 << 16) +#define SUNXI_MMC_COMMON_RESET (1 << 18) + +#define SUNXI_MMC_CAL_DL_SW_EN (0x1 << 7) + +#endif /* _SUNXI_MMC_H */
-----Original Message----- From: Samuel Holland samuel@sholland.org Sent: Tuesday, October 31, 2023 2:23 PM To: u-boot@lists.denx.de; Jagan Teki jagan@amarulasolutions.com; Andre Przywara andre.przywara@arm.com Cc: Samuel Holland samuel@sholland.org; Jaehoon Chung jh80.chung@samsung.com; Peng Fan peng.fan@nxp.com Subject: [PATCH 2/2] sunxi: mmc: Move header to the driver directory
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- (C) Copyright 2007-2011
- Allwinner Technology Co., Ltd. <https://protect2.fireeye.com/v1/url?k=4cb2b925-2d39ac0a-4cb3326a-
74fe485cbfe7-043aa1e18727af33&q=1&e=c27b74b1-be1d-4124-b8c0- 7d4a5f8076a3&u=http%3A%2F%2Fwww.allwinnertech.com%2F>
- MMC register definition for allwinner sunxi platform.
-struct sunxi_mmc {
- u32 res1[8];
- u32 res2[26];
- u32 res3[17];
- u32 samp_dl;
- u32 res4[46];
-#endif
- Allwinner Technology Co., Ltd. <https://protect2.fireeye.com/v1/url?k=31fd542e-50764101-31fcdf61-
74fe485cbfe7-6b37535e8d2e0d96&q=1&e=c27b74b1-be1d-4124-b8c0- 7d4a5f8076a3&u=http%3A%2F%2Fwww.allwinnertech.com%2F>
+struct sunxi_mmc {
- u32 res1[8];
- u32 res2[26];
- u32 res3[17];
- u32 samp_dl;
- u32 res4[46];
2.41.0
-----Original Message----- From: Samuel Holland samuel@sholland.org Sent: Tuesday, October 31, 2023 2:23 PM To: u-boot@lists.denx.de; Jagan Teki jagan@amarulasolutions.com; Andre Przywara andre.przywara@arm.com Cc: Samuel Holland samuel@sholland.org; Jaehoon Chung jh80.chung@samsung.com; Peng Fan peng.fan@nxp.com Subject: [PATCH 1/2] sunxi: mmc: Sort compatible strings numerically
- { .compatible = "allwinner,sun20i-d1-mmc" }, { .compatible = "allwinner,sun50i-a64-mmc" }, { .compatible = "allwinner,sun50i-a64-emmc" }, { .compatible = "allwinner,sun50i-h6-mmc" }, { .compatible = "allwinner,sun50i-h6-emmc" }, { .compatible = "allwinner,sun50i-a100-mmc" }, { .compatible = "allwinner,sun50i-a100-emmc" },
-- 2.41.0
Jaehoon Chung
Samuel Holland
