[U-Boot] [PATCH] blk: dm: make blk_create_device() take a number of block instead of a size
There is an overflow problem when taking the size instead of the number of blocks in blk_create_device(). This results in a wrong device size: the device apparent size is its real size modulo 4GB. Using the number of blocks instead of the device size fixes the problem and is more coherent with the internals of the block layer.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com --- common/scsi.c | 2 +- drivers/block/blk-uclass.c | 8 ++++---- drivers/block/sandbox.c | 2 +- include/blk.h | 8 ++++---- test/dm/blk.c | 6 +++--- 5 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/common/scsi.c b/common/scsi.c index c456f5a..da15c05 100644 --- a/common/scsi.c +++ b/common/scsi.c @@ -572,7 +572,7 @@ static int do_scsi_scan_one(struct udevice *dev, int id, int lun, int mode) */ snprintf(str, sizeof(str), "id%dlun%d", id, lun); ret = blk_create_devicef(dev, "scsi_blk", str, IF_TYPE_SCSI, -1, - bd.blksz, bd.blksz * bd.lba, &bdev); + bd.blksz, bd.lba, &bdev); if (ret) { debug("Can't create device\n"); return ret; diff --git a/drivers/block/blk-uclass.c b/drivers/block/blk-uclass.c index 6145675..c4ae2f4 100644 --- a/drivers/block/blk-uclass.c +++ b/drivers/block/blk-uclass.c @@ -513,7 +513,7 @@ static int blk_claim_devnum(enum if_type if_type, int devnum)
int blk_create_device(struct udevice *parent, const char *drv_name, const char *name, int if_type, int devnum, int blksz, - lbaint_t size, struct udevice **devp) + lbaint_t lba, struct udevice **devp) { struct blk_desc *desc; struct udevice *dev; @@ -534,7 +534,7 @@ int blk_create_device(struct udevice *parent, const char *drv_name, desc = dev_get_uclass_platdata(dev); desc->if_type = if_type; desc->blksz = blksz; - desc->lba = size / blksz; + desc->lba = lba; desc->part_type = PART_TYPE_UNKNOWN; desc->bdev = dev; desc->devnum = devnum; @@ -545,7 +545,7 @@ int blk_create_device(struct udevice *parent, const char *drv_name,
int blk_create_devicef(struct udevice *parent, const char *drv_name, const char *name, int if_type, int devnum, int blksz, - lbaint_t size, struct udevice **devp) + lbaint_t lba, struct udevice **devp) { char dev_name[30], *str; int ret; @@ -556,7 +556,7 @@ int blk_create_devicef(struct udevice *parent, const char *drv_name, return -ENOMEM;
ret = blk_create_device(parent, drv_name, str, if_type, devnum, - blksz, size, devp); + blksz, lba, devp); if (ret) { free(str); return ret; diff --git a/drivers/block/sandbox.c b/drivers/block/sandbox.c index 34d1c63..98df6b3 100644 --- a/drivers/block/sandbox.c +++ b/drivers/block/sandbox.c @@ -129,7 +129,7 @@ int host_dev_bind(int devnum, char *filename) } ret = blk_create_device(gd->dm_root, "sandbox_host_blk", str, IF_TYPE_HOST, devnum, 512, - os_lseek(fd, 0, OS_SEEK_END), &dev); + os_lseek(fd, 0, OS_SEEK_END) / 512, &dev); if (ret) goto err_file; ret = device_probe(dev); diff --git a/include/blk.h b/include/blk.h index a128ee4..984491c 100644 --- a/include/blk.h +++ b/include/blk.h @@ -310,12 +310,12 @@ int blk_next_device(struct udevice **devp); * @devnum: Device number, specific to the interface type, or -1 to * allocate the next available number * @blksz: Block size of the device in bytes (typically 512) - * @size: Total size of the device in bytes + * @lba: Total number of blocks of the device * @devp: the new device (which has not been probed) */ int blk_create_device(struct udevice *parent, const char *drv_name, const char *name, int if_type, int devnum, int blksz, - lbaint_t size, struct udevice **devp); + lbaint_t lba, struct udevice **devp);
/** * blk_create_devicef() - Create a new named block device @@ -327,12 +327,12 @@ int blk_create_device(struct udevice *parent, const char *drv_name, * @devnum: Device number, specific to the interface type, or -1 to * allocate the next available number * @blksz: Block size of the device in bytes (typically 512) - * @size: Total size of the device in bytes + * @lba: Total number of blocks of the device * @devp: the new device (which has not been probed) */ int blk_create_devicef(struct udevice *parent, const char *drv_name, const char *name, int if_type, int devnum, int blksz, - lbaint_t size, struct udevice **devp); + lbaint_t lba, struct udevice **devp);
/** * blk_prepare_device() - Prepare a block device for use diff --git a/test/dm/blk.c b/test/dm/blk.c index 5c5eb82..28790e9 100644 --- a/test/dm/blk.c +++ b/test/dm/blk.c @@ -23,9 +23,9 @@ static int dm_test_blk_base(struct unit_test_state *uts)
/* Create two, one the parent of the other */ ut_assertok(blk_create_device(gd->dm_root, "sandbox_host_blk", "test", - IF_TYPE_HOST, 1, 512, 1024, &blk)); + IF_TYPE_HOST, 1, 512, 2, &blk)); ut_assertok(blk_create_device(blk, "usb_storage_blk", "test", - IF_TYPE_USB, 3, 512, 1024, &usb_blk)); + IF_TYPE_USB, 3, 512, 2, &usb_blk));
/* Check we can find them */ ut_asserteq(-ENODEV, blk_get_device(IF_TYPE_HOST, 0, &dev)); @@ -101,7 +101,7 @@ static int dm_test_blk_find(struct unit_test_state *uts) struct udevice *blk, *dev;
ut_assertok(blk_create_device(gd->dm_root, "sandbox_host_blk", "test", - IF_TYPE_HOST, 1, 512, 1024, &blk)); + IF_TYPE_HOST, 1, 512, 2, &blk)); ut_asserteq(-ENODEV, blk_find_device(IF_TYPE_HOST, 0, &dev)); ut_assertok(blk_find_device(IF_TYPE_HOST, 1, &dev)); ut_asserteq_ptr(blk, dev);
Jean-Jacques Hiblot
