[PATCH] ARM: dts: stm32: Add DHCOR based Testbench board
Add DT for DHCOR Testbench board, which is a testbench for testing of DHCOR SoM during manufacturing. This is effectively a trimmed down version of AV96 board with CSI-2 bridge, HDMI bridge, WiFi, Audio and LEDs removed and used as GPIOs instead. Furthermore, the PMIC Buck3 is always configured from PMIC NVM to cater for both 1V8 and 3V3 SoM variant.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com --- arch/arm/dts/Makefile | 3 +- .../stm32mp15xx-dhcor-testbench-u-boot.dtsi | 100 ++++++++++ arch/arm/dts/stm32mp15xx-dhcor-testbench.dts | 178 ++++++++++++++++++ board/dhelectronics/dh_stm32mp1/board.c | 40 ++-- .../dh_stm32mp1/u-boot-dhcor.its | 21 ++- 5 files changed, 325 insertions(+), 17 deletions(-) create mode 100644 arch/arm/dts/stm32mp15xx-dhcor-testbench-u-boot.dtsi create mode 100644 arch/arm/dts/stm32mp15xx-dhcor-testbench.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 965895bc2a3..4a2c0de74a0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1201,7 +1201,8 @@ dtb-$(CONFIG_STM32MP15x) += \ stm32mp15xx-dhcom-pdk2.dtb \ stm32mp15xx-dhcom-picoitx.dtb \ stm32mp15xx-dhcor-avenger96.dtb \ - stm32mp15xx-dhcor-drc-compact.dtb + stm32mp15xx-dhcor-drc-compact.dtb \ + stm32mp15xx-dhcor-testbench.dtb
dtb-$(CONFIG_SOC_K3_AM654) += \ k3-am654-base-board.dtb \ diff --git a/arch/arm/dts/stm32mp15xx-dhcor-testbench-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-testbench-u-boot.dtsi new file mode 100644 index 00000000000..5b051b8ac45 --- /dev/null +++ b/arch/arm/dts/stm32mp15xx-dhcor-testbench-u-boot.dtsi @@ -0,0 +1,100 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2022 Marek Vasut marex@denx.de + */ + +#include "stm32mp15xx-dhcor-u-boot.dtsi" + +/ { + aliases { + mmc0 = &sdmmc1; + mmc1 = &sdmmc2; + usb0 = &usbotg_hs; + }; + + config { + dh,board-coding-gpios = <&gpiog 13 0>, <&gpiod 9 0>; + }; +}; + +ðernet0 { + phy-reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>; + + mdio0 { + ethernet-phy@7 { + reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>; + reset-assert-us = <11000>; + reset-deassert-us = <1000>; + }; + }; +}; + +&sdmmc1 { + u-boot,dm-spl; + st,use-ckin; + st,cmd-gpios = <&gpiod 2 0>; + st,ck-gpios = <&gpioc 12 0>; + st,ckin-gpios = <&gpioe 4 0>; +}; + +&sdmmc1_b4_pins_a { + u-boot,dm-spl; + pins1 { + u-boot,dm-spl; + }; + pins2 { + u-boot,dm-spl; + }; +}; + +&sdmmc1_dir_pins_b { + u-boot,dm-spl; + pins1 { + u-boot,dm-spl; + }; + pins2 { + u-boot,dm-spl; + }; +}; + +&sdmmc2 { + u-boot,dm-spl; +}; + +&sdmmc2_b4_pins_a { + u-boot,dm-spl; + pins1 { + u-boot,dm-spl; + }; + pins2 { + u-boot,dm-spl; + }; +}; + +&sdmmc2_d47_pins_c { + u-boot,dm-spl; + pins { + u-boot,dm-spl; + }; +}; + +&uart4 { + u-boot,dm-pre-reloc; +}; + +&uart4_pins_b { + u-boot,dm-pre-reloc; + pins1 { + u-boot,dm-pre-reloc; + }; + pins2 { + u-boot,dm-pre-reloc; + /delete-property/ bias-disable; + bias-pull-up; + }; +}; + +&usbotg_hs { + u-boot,force-b-session-valid; + hnp-srp-disable; +}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-testbench.dts b/arch/arm/dts/stm32mp15xx-dhcor-testbench.dts new file mode 100644 index 00000000000..c9163e1c028 --- /dev/null +++ b/arch/arm/dts/stm32mp15xx-dhcor-testbench.dts @@ -0,0 +1,178 @@ +// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) +/* + * Copyright (C) 2022 Marek Vasut marex@denx.de + */ +/dts-v1/; + +#include "stm32mp151.dtsi" +#include "stm32mp15xx-dhcor-som.dtsi" + +/ { + model = "DH electronics STM32MP15xx DHCOR Testbench"; + compatible = "dh,stm32mp15xx-dhcor-testbench", "st,stm32mp1xx"; + + aliases { + ethernet0 = ðernet0; + mmc0 = &sdmmc1; + mmc1 = &sdmmc2; + serial0 = &uart4; + serial1 = &uart7; + spi0 = &qspi; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + sd_switch: regulator-sd_switch { + compatible = "regulator-gpio"; + regulator-name = "sd_switch"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <2900000>; + regulator-type = "voltage"; + regulator-always-on; + + gpios = <&gpioi 5 GPIO_ACTIVE_HIGH>; + gpios-states = <0>; + states = <1800000 0x1>, + <2900000 0x0>; + }; +}; + +&adc { + pinctrl-names = "default"; + pinctrl-0 = <&adc12_ain_pins_b>; + vdd-supply = <&vdd>; + vdda-supply = <&vdda>; + vref-supply = <&vdda>; + status = "okay"; + + adc1: adc@0 { + st,adc-channels = <0 1 6>; + st,min-sample-time-nsecs = <5000>; + status = "okay"; + }; + + adc2: adc@100 { + st,adc-channels = <0 1 2>; + st,min-sample-time-nsecs = <5000>; + status = "okay"; + }; +}; + +ðernet0 { + status = "okay"; + pinctrl-0 = <ðernet0_rgmii_pins_c>; + pinctrl-1 = <ðernet0_rgmii_sleep_pins_c>; + pinctrl-names = "default", "sleep"; + phy-mode = "rgmii"; + max-speed = <1000>; + phy-handle = <&phy0>; + + mdio0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>; + reset-delay-us = <1000>; + + phy0: ethernet-phy@7 { + reg = <7>; + + rxc-skew-ps = <1500>; + rxdv-skew-ps = <540>; + rxd0-skew-ps = <420>; + rxd1-skew-ps = <420>; + rxd2-skew-ps = <420>; + rxd3-skew-ps = <420>; + + txc-skew-ps = <1440>; + txen-skew-ps = <540>; + txd0-skew-ps = <420>; + txd1-skew-ps = <420>; + txd2-skew-ps = <420>; + txd3-skew-ps = <420>; + }; + }; +}; + +&sdmmc1 { + pinctrl-names = "default", "opendrain", "sleep"; + pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_b>; + pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_b>; + pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_b>; + cd-gpios = <&gpioi 8 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>; + disable-wp; + st,sig-dir; + st,neg-edge; + st,use-ckin; + bus-width = <4>; + vmmc-supply = <&vdd_sd>; + vqmmc-supply = <&sd_switch>; + status = "okay"; +}; + +&sdmmc2 { + pinctrl-names = "default", "opendrain", "sleep"; + pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_c>; + pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_c>; + pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_c>; + bus-width = <8>; + mmc-ddr-1_8v; + no-sd; + no-sdio; + non-removable; + st,neg-edge; + vmmc-supply = <&v3v3>; + vqmmc-supply = <&v3v3>; + status = "okay"; +}; + +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&uart4_pins_b>; + /delete-property/dmas; + /delete-property/dma-names; + status = "okay"; +}; + +&uart7 { + pinctrl-names = "default"; + pinctrl-0 = <&uart7_pins_a>; + uart-has-rtscts; + /delete-property/dmas; + /delete-property/dma-names; + status = "okay"; +}; + +&usbh_ehci { + phys = <&usbphyc_port0>; + phy-names = "usb"; + status = "okay"; +}; + +&usbotg_hs { + pinctrl-0 = <&usbotg_hs_pins_a>; + pinctrl-names = "default"; + phy-names = "usb2-phy"; + phys = <&usbphyc_port1 0>; + status = "okay"; + vbus-supply = <&vbus_otg>; +}; + +&usbphyc { + status = "okay"; +}; + +&usbphyc_port0 { + phy-supply = <&vdd_usb>; +}; + +&usbphyc_port1 { + phy-supply = <&vdd_usb>; +}; + +&vdd { + /delete-property/ regulator-always-on; + regulator-min-microvolt = <1200000>; +}; diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index b0284609183..a5afc64024c 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -547,7 +547,7 @@ static int board_get_regulator_buck3_nvm_uv_av96(int *uv) if (!prop || !len) return -ENODEV;
- if (!strstr(prop, "avenger96")) + if (!strstr(prop, "avenger96") && !strstr(prop, "dhcor-testbench")) return -EINVAL;
/* Read out STPMIC1 NVM and determine default Buck3 voltage. */ @@ -564,18 +564,32 @@ static int board_get_regulator_buck3_nvm_uv_av96(int *uv) bucks_vout >>= STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_OFFSET(3); bucks_vout &= STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_MASK;
- /* - * Avenger96 board comes in multiple regulator configurations: - * - rev.100 or rev.200 have Buck3 preconfigured to 3V3 operation on - * boot and contains extra Enpirion EP53A8LQI DCDC converter which - * supplies the IO. Reduce Buck3 voltage to 2V9 to not waste power. - * - rev.200L have Buck3 preconfigured to 1V8 operation and have no - * Enpirion EP53A8LQI DCDC anymore, the IO is supplied from Buck3. - */ - if (bucks_vout == STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V3) - *uv = 2900000; - else - *uv = 1800000; + if (strstr(prop, "avenger96")) { + /* + * Avenger96 board comes in multiple regulator configurations: + * - rev.100 or rev.200 have Buck3 preconfigured to + * 3V3 operation on boot and contains extra Enpirion + * EP53A8LQI DCDC converter which supplies the IO. + * Reduce Buck3 voltage to 2V9 to not waste power. + * - rev.200L have Buck3 preconfigured to 1V8 operation + * and have no Enpirion EP53A8LQI DCDC anymore, the + * IO is supplied from Buck3. + */ + if (bucks_vout == STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V3) + *uv = 2900000; + else + *uv = 1800000; + } else { + /* Testbench always respects Buck3 NVM settings */ + if (bucks_vout == STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V3) + *uv = 3300000; + else if (bucks_vout == STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_3V0) + *uv = 3000000; + else if (bucks_vout == STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_1V8) + *uv = 1800000; + else /* STPMIC_NVM_BUCKS_VOUT_SHR_BUCK_1V2 */ + *uv = 1200000; + }
return 0; } diff --git a/board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its b/board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its index de7dcb317f3..f9c1075616b 100644 --- a/board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its +++ b/board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its @@ -18,13 +18,21 @@
fdt-1 { description = ".dtb"; - data = /incbin/("arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtb"); + data = /incbin/("arch/arm/dts/stm32mp15xx-dhcor-testbench.dtb"); type = "flat_dt"; arch = "arm"; compression = "none"; };
fdt-2 { + description = ".dtb"; + data = /incbin/("arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtb"); + type = "flat_dt"; + arch = "arm"; + compression = "none"; + }; + + fdt-3 { description = ".dtb"; data = /incbin/("arch/arm/dts/stm32mp15xx-dhcor-drc-compact.dtb"); type = "flat_dt"; @@ -38,18 +46,25 @@
config-1 { /* DT+SoM+board model */ - description = "arrow,stm32mp15xx-avenger96_somrev0_boardrev1"; + description = "dh,stm32mp15xx-dhcor-testbench_somrev0_boardrev1"; firmware = "uboot"; fdt = "fdt-1"; };
config-2 { /* DT+SoM+board model */ - description = "dh,stm32mp15xx-dhcor-drc-compact_somrev0_boardrev0"; + description = "arrow,stm32mp15xx-avenger96_somrev0_boardrev1"; firmware = "uboot"; fdt = "fdt-2"; };
+ config-3 { + /* DT+SoM+board model */ + description = "dh,stm32mp15xx-dhcor-drc-compact_somrev0_boardrev0"; + firmware = "uboot"; + fdt = "fdt-3"; + }; + /* Add 586-200..586-400 with fdt-2..fdt-4 here */ }; };
Hi Marek
- stm32mp15xx-dhcor-drc-compact.dtb \
- stm32mp15xx-dhcor-testbench.dtb
- Copyright (C) 2022 Marek Vasut marex@denx.de
- aliases {
mmc0 = &sdmmc1;
mmc1 = &sdmmc2;
usb0 = &usbotg_hs;
- config {
+ðernet0 {
- phy-reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>;
- mdio0 {
ethernet-phy@7 {
+&sdmmc1 {
- u-boot,dm-spl;
- st,use-ckin;
- st,cmd-gpios = <&gpiod 2 0>;
- st,ck-gpios = <&gpioc 12 0>;
- st,ckin-gpios = <&gpioe 4 0>;
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
+&sdmmc2 {
- u-boot,dm-spl;
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&uart4 {
- u-boot,dm-pre-reloc;
+&uart4_pins_b {
- pins1 {
- pins2 {
bias-pull-up;
+&usbotg_hs {
- u-boot,force-b-session-valid;
- hnp-srp-disable;
+/dts-v1/;
- model = "DH electronics STM32MP15xx DHCOR Testbench";
- compatible = "dh,stm32mp15xx-dhcor-testbench", "st,stm32mp1xx";
- aliases {
mmc0 = &sdmmc1;
mmc1 = &sdmmc2;
serial0 = &uart4;
serial1 = &uart7;
spi0 = &qspi;
- chosen {
- sd_switch: regulator-sd_switch {
gpios-states = <0>;
<2900000 0x0>;
+&adc {
- pinctrl-names = "default";
- pinctrl-0 = <&adc12_ain_pins_b>;
- vdd-supply = <&vdd>;
- vdda-supply = <&vdda>;
- vref-supply = <&vdda>;
- status = "okay";
- adc1: adc@0 {
status = "okay";
- adc2: adc@100 {
status = "okay";
+ðernet0 {
- status = "okay";
- pinctrl-0 = <ðernet0_rgmii_pins_c>;
- pinctrl-1 = <ðernet0_rgmii_sleep_pins_c>;
- pinctrl-names = "default", "sleep";
- phy-mode = "rgmii";
- max-speed = <1000>;
- phy-handle = <&phy0>;
- mdio0 {
#size-cells = <0>;
reg = <7>;
+&sdmmc1 {
- pinctrl-names = "default", "opendrain", "sleep";
- pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_b>;
- pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_b>;
- pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_b>;
- cd-gpios = <&gpioi 8 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
- disable-wp;
- st,sig-dir;
- st,neg-edge;
- st,use-ckin;
- bus-width = <4>;
- vmmc-supply = <&vdd_sd>;
- vqmmc-supply = <&sd_switch>;
- status = "okay";
+&sdmmc2 {
- pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_c>;
- pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_c>;
- pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_c>;
- bus-width = <8>;
- mmc-ddr-1_8v;
- no-sd;
- no-sdio;
- non-removable;
- st,neg-edge;
- vmmc-supply = <&v3v3>;
- vqmmc-supply = <&v3v3>;
- status = "okay";
+&uart4 {
- pinctrl-0 = <&uart4_pins_b>;
- /delete-property/dmas;
- /delete-property/dma-names;
- status = "okay";
+&uart7 {
- pinctrl-0 = <&uart7_pins_a>;
- uart-has-rtscts;
- status = "okay";
+&usbh_ehci {
- phys = <&usbphyc_port0>;
- phy-names = "usb";
- status = "okay";
+&usbotg_hs {
- pinctrl-0 = <&usbotg_hs_pins_a>;
- phy-names = "usb2-phy";
- phys = <&usbphyc_port1 0>;
- status = "okay";
- vbus-supply = <&vbus_otg>;
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
- phy-supply = <&vdd_usb>;
+&usbphyc_port1 {
+&vdd {
- /delete-property/ regulator-always-on;
- regulator-min-microvolt = <1200000>;
*uv = 2900000;
- else
*uv = 1800000;
*uv = 2900000;
else
*uv = 1800000;
} else {
*uv = 3300000;
*uv = 3000000;
*uv = 1800000;
*uv = 1200000;
fdt-2 {
type = "flat_dt";
arch = "arm";
@@ -38,18 +46,25 @@
config-3 {
firmware = "uboot";
fdt = "fdt-3";
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
On 9/27/22 08:12, Patrice CHOTARD wrote:
Hi Marek
- aliases {
mmc0 = &sdmmc1;
mmc1 = &sdmmc2;
usb0 = &usbotg_hs;
- config {
+ðernet0 {
- mdio0 {
ethernet-phy@7 {
+&sdmmc1 {
- u-boot,dm-spl;
- st,use-ckin;
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
+&sdmmc2 {
- u-boot,dm-spl;
- u-boot,dm-spl;
- pins1 {
u-boot,dm-spl;
- pins2 {
u-boot,dm-spl;
- u-boot,dm-spl;
- pins {
u-boot,dm-spl;
+&uart4 {
+&uart4_pins_b {
- pins1 {
- pins2 {
bias-pull-up;
+&usbotg_hs {
- hnp-srp-disable;
+/dts-v1/;
- aliases {
mmc0 = &sdmmc1;
mmc1 = &sdmmc2;
serial0 = &uart4;
serial1 = &uart7;
spi0 = &qspi;
- chosen {
gpios-states = <0>;
<2900000 0x0>;
+&adc {
- status = "okay";
- adc1: adc@0 {
status = "okay";
- adc2: adc@100 {
status = "okay";
+ðernet0 {
- status = "okay";
- mdio0 {
#size-cells = <0>;
reg = <7>;
+&sdmmc1 {
- disable-wp;
- st,sig-dir;
- st,neg-edge;
- st,use-ckin;
- bus-width = <4>;
- status = "okay";
+&sdmmc2 {
- bus-width = <8>;
- mmc-ddr-1_8v;
- no-sd;
- no-sdio;
- non-removable;
- st,neg-edge;
- status = "okay";
+&uart4 {
- status = "okay";
+&uart7 {
- uart-has-rtscts;
- status = "okay";
+&usbh_ehci {
- status = "okay";
+&usbotg_hs {
- status = "okay";
+&usbphyc {
- status = "okay";
+&usbphyc_port0 {
+&usbphyc_port1 {
+&vdd {
*uv = 2900000;
- else
*uv = 1800000;
*uv = 2900000;
else
*uv = 1800000;
} else {
*uv = 3300000;
*uv = 3000000;
*uv = 1800000;
*uv = 1200000;
fdt-2 {
type = "flat_dt";
arch = "arm";
@@ -38,18 +46,25 @@
config-3 {
firmware = "uboot";
fdt = "fdt-3";
Thanks Patrice
Applied on u-boot-stm32/master
Thanks Patrice
Patrice CHOTARD
