[PATCH v3 00/10] rockchip: Fixes for RK3568 and RK3588
This re-send series contains fixes for RK3568 and RK3588 that never made it into v2023.04 and is needed to generate a bootable rockchip-u-boot.bin image for RK3568 and RK3588.
I have folded all my pending fixes into this series. Some have r-b tags others seem to have been missed :-)
Patch 1 imply use of ROCKCHIP_TPL for RK3588 to generate a bootable rockchip-u-boot.bin image. Patch 2 fixes sdmmc boot on rk3588-rock-5b. Patch 3 fixes boot of rk3568-rock-3a, an issue introduced in v1. Patch 4 add fdtoverlay and compressed kernel addresses to env. Patch 5-7 fixes support for sdmmc clocks in SPL on RK3588. Patch 8 fixes IO mux selection on RK3568. Patch 9 adds support for RK3568 and RK3588 gpio banks. Patch 10 fixes probe of pmic and missing regulators on rk3568-evb and rk3568-rock-3a.
Please consider these fixes for v2023.07.
Changes in v3: - Change u-boot,dm-spl to bootph-pre-ram - Include patches from [2], [3], [4] and [5] - Collect r-b tags
Changes in v2: - Drop applied patches - Add the pre-req patch from [1] - Add patch to fix an issue introduced in v1 - Collect r-b tags
This series can also be found at [6]
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230228213822.3583989-1-jo... [2] https://patchwork.ozlabs.org/project/uboot/cover/20230317191638.2558279-1-jo... [3] https://patchwork.ozlabs.org/project/uboot/patch/20230318233039.799975-1-jon... [4] https://patchwork.ozlabs.org/project/uboot/patch/20230319183949.1375997-1-jo... [5] https://patchwork.ozlabs.org/project/uboot/patch/20230402155816.1312383-1-jo... [6] https://github.com/Kwiboo/u-boot-rockchip/commits/rk35xx-fixes-v3
Jonas Karlman (10): rockchip: Use an external TPL binary on RK3588 rockchip: rk3588-rock-5b: Fix sdmmc boot rockchip: rk35xx: Fix boot with a large fdt blob rockchip: rk35xx: Enable fdtoverlay and kernel compression clk: scmi: Add Kconfig option for SPL rockchip: rk3588: Add support for sdmmc clocks in SPL rockchip: rk3588: Sync sdmmc node from linux-next pinctrl: rockchip: Fix IO mux selection on RK3568 gpio: rockchip: Add support for RK3568 and RK3588 banks clk: rockchip: rk3568: Add dummy I2S1_MCLKOUT_TX clock support
.../dts/rk3588-edgeble-neu6a-io-u-boot.dtsi | 2 - arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 3 +- arch/arm/dts/rk3588s-u-boot.dtsi | 27 ++-- arch/arm/dts/rk3588s.dtsi | 15 +++ arch/arm/include/asm/arch-rockchip/clock.h | 1 - .../include/asm/arch-rockchip/cru_rk3588.h | 19 ++- arch/arm/mach-rockchip/Kconfig | 8 +- configs/neu6a-io-rk3588_defconfig | 1 - configs/rock-3a-rk3568_defconfig | 1 - configs/rock5b-rk3588_defconfig | 2 - doc/board/rockchip/rockchip.rst | 9 ++ drivers/clk/Kconfig | 8 ++ drivers/clk/Makefile | 2 +- drivers/clk/rockchip/clk_rk3568.c | 2 + drivers/clk/rockchip/clk_rk3588.c | 125 ++++++++++++++++++ drivers/firmware/scmi/scmi_agent-uclass.c | 2 +- drivers/gpio/rk_gpio.c | 112 +++++++++++----- drivers/pinctrl/rockchip/pinctrl-rk3568.c | 66 +++++---- include/configs/rk3568_common.h | 7 +- include/configs/rk3588_common.h | 7 +- 20 files changed, 326 insertions(+), 93 deletions(-)
There is no support to initialize DRAM on RK3588 SoCs using U-Boot TPL and instead an external TPL binary must be used to generate a bootable u-boot-rockchip.bin image.
Enable ROCKCHIP_EXTERNAL_TPL by default for RK3588, add build steps for RK3588 to documentation and clean up CONFIG_BINMAN_FDT options.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Jagan Teki jagan@edgeble.ai --- v3: - No change
v2: - Pre-req patch picked from [1] - Collect r-b tag
arch/arm/mach-rockchip/Kconfig | 2 +- configs/neu6a-io-rk3588_defconfig | 1 - configs/rock-3a-rk3568_defconfig | 1 - configs/rock5b-rk3588_defconfig | 1 - doc/board/rockchip/rockchip.rst | 9 +++++++++ 5 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 0390431601f9..e5ac58ae60b5 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -428,7 +428,7 @@ config TPL_ROCKCHIP_COMMON_BOARD
config ROCKCHIP_EXTERNAL_TPL bool "Use external TPL binary" - default y if ROCKCHIP_RK3568 + default y if ROCKCHIP_RK3568 || ROCKCHIP_RK3588 help Some Rockchip SoCs require an external TPL to initialize DRAM. Enable this option and build with ROCKCHIP_TPL=/path/to/ddr.bin to diff --git a/configs/neu6a-io-rk3588_defconfig b/configs/neu6a-io-rk3588_defconfig index c9b22525315a..fb1ce4c1746f 100644 --- a/configs/neu6a-io-rk3588_defconfig +++ b/configs/neu6a-io-rk3588_defconfig @@ -62,5 +62,4 @@ CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y -# CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y diff --git a/configs/rock-3a-rk3568_defconfig b/configs/rock-3a-rk3568_defconfig index e75383218320..af1374549ddc 100644 --- a/configs/rock-3a-rk3568_defconfig +++ b/configs/rock-3a-rk3568_defconfig @@ -69,5 +69,4 @@ CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y -# CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index f3026c7ea166..66199387195a 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -68,5 +68,4 @@ CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_SYSRESET=y -# CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index b5563b8f7f9e..1f88d15aad2a 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -185,6 +185,15 @@ To build rk3568 boards: make evb-rk3568_defconfig make CROSS_COMPILE=aarch64-linux-gnu-
+To build rk3588 boards: + +.. code-block:: bash + + export BL31=../rkbin/bin/rk35/rk3588_bl31_v1.27.elf + export ROCKCHIP_TPL=../rkbin/bin/rk35/rk3588_ddr_lp4_2112MHz_lp5_2736MHz_v1.08.bin + make rock5b-rk3588_defconfig + make CROSS_COMPILE=aarch64-linux-gnu- + Flashing --------
Running U-Boot from a SD-card on ROCK 5 Model B fails to load atf using DMA and prints debug_uart messages.
<debug_uart>
<debug_uart>
U-Boot SPL 2023.04-rc3 (Mar 12 2023 - 00:30:16 +0000) Trying to boot from MMC1 ## Checking hash(es) for config config-1 ... OK ## Checking hash(es) for Image atf-1 ... sha256 error! Bad hash value for 'hash' hash node in 'atf-1' image node mmc_load_image_raw_sector: mmc block read error SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
Use fifo-mode to disable DMA in SPL, add same-as-spl to boot-order and remove DEBUG_UART_ANNOUNCE option to fix this.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v3: - Change u-boot,dm-spl to bootph-pre-ram
v2: - Collect r-b tag
arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 3 ++- configs/rock5b-rk3588_defconfig | 1 - 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi index bee4c32e8965..b61d6e0fdbfc 100644 --- a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi +++ b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi @@ -11,12 +11,13 @@ };
chosen { - u-boot,spl-boot-order = &sdmmc; + u-boot,spl-boot-order = "same-as-spl", &sdmmc; }; };
&sdmmc { bus-width = <4>; bootph-pre-ram; + u-boot,spl-fifo-mode; status = "okay"; }; diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index 66199387195a..3fcc6a26bb51 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -66,6 +66,5 @@ CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 -CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_SYSRESET=y CONFIG_ERRNO_STR=y
The TF-A blobs used to boot RK3568 and RK3588 boards is based on atf v2.3. Mainline atf v2.3 contains an issue that could lead to a crash when it fails to parse the fdt blob being passed as the platform param. An issue that was fixed in atf v2.4.
The vendor TF-A seem to suffer from a similar issue, and this prevents booting when fdt blob is large enough to trigger this condition.
Fix this by implying SPL_ATF_NO_PLATFORM_PARAM to let u-boot pass a NULL pointer instead of the fdt blob as the platform param.
This fixes booting Radxa ROCK 3A after recent sync of device tree.
Fixes: 073d911ae64a ("rockchip: rk3568-rock-3a: Sync device tree from linux") Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v3: - No change
v2: - New patch
arch/arm/mach-rockchip/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index e5ac58ae60b5..d7e3784ba113 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -288,6 +288,7 @@ config ROCKCHIP_RK3568 select BOARD_LATE_INIT select DM_REGULATOR_FIXED select DM_RESET + imply SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF imply ROCKCHIP_COMMON_BOARD imply ROCKCHIP_OTP imply MISC_INIT_R @@ -309,6 +310,7 @@ config ROCKCHIP_RK3588 select REGMAP select SYSCON select BOARD_LATE_INIT + imply SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF imply ROCKCHIP_COMMON_BOARD imply ROCKCHIP_OTP imply MISC_INIT_R
Thanks, - Kever
v3:
- No change
v2:
New patch
- imply SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF imply ROCKCHIP_COMMON_BOARD imply ROCKCHIP_OTP imply MISC_INIT_R
Add fdtoverlay_addr_r, kernel_comp_addr_r and imply use of OF_LIBFDT_OVERLAY on RK3568 and RK3588 to support fdtoverlay and kernel compression.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Simon Glass sjg@chromium.org --- v3: - No change
v2: - Drop parts that convert to use bootstd - Collect r-b tag
arch/arm/mach-rockchip/Kconfig | 2 ++ include/configs/rk3568_common.h | 7 ++++++- include/configs/rk3588_common.h | 7 ++++++- 3 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index d7e3784ba113..517326c8c5be 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -290,6 +290,7 @@ config ROCKCHIP_RK3568 select DM_RESET imply SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF imply ROCKCHIP_COMMON_BOARD + imply OF_LIBFDT_OVERLAY imply ROCKCHIP_OTP imply MISC_INIT_R help @@ -312,6 +313,7 @@ config ROCKCHIP_RK3588 select BOARD_LATE_INIT imply SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF imply ROCKCHIP_COMMON_BOARD + imply OF_LIBFDT_OVERLAY imply ROCKCHIP_OTP imply MISC_INIT_R help diff --git a/include/configs/rk3568_common.h b/include/configs/rk3568_common.h index a5e1dde50888..d6b5e7d89022 100644 --- a/include/configs/rk3568_common.h +++ b/include/configs/rk3568_common.h @@ -17,10 +17,15 @@
#define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x00c00000\0" \ + "script_offset_f=0xffe000\0" \ + "script_size_f=0x2000\0" \ "pxefile_addr_r=0x00e00000\0" \ "fdt_addr_r=0x0a100000\0" \ + "fdtoverlay_addr_r=0x02000000\0" \ "kernel_addr_r=0x02080000\0" \ - "ramdisk_addr_r=0x0a200000\0" + "ramdisk_addr_r=0x0a200000\0" \ + "kernel_comp_addr_r=0x08000000\0" \ + "kernel_comp_size=0x2000000\0"
#include <config_distro_bootcmd.h> #define CFG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/rk3588_common.h b/include/configs/rk3588_common.h index abd20139aaf3..b9f42717b751 100644 --- a/include/configs/rk3588_common.h +++ b/include/configs/rk3588_common.h @@ -16,10 +16,15 @@
Building U-Boot SPL with CLK_SCMI and SCMI_FIRMWARE Kconfig options enabled and SPL_FIRMWARE disabled result in the following error.
drivers/clk/clk_scmi.o: in function `scmi_clk_gate': drivers/clk/clk_scmi.c:84: undefined reference to `devm_scmi_process_msg' drivers/clk/clk_scmi.c:88: undefined reference to `scmi_to_linux_errno' drivers/clk/clk_scmi.o: in function `scmi_clk_get_rate': drivers/clk/clk_scmi.c:113: undefined reference to `devm_scmi_process_msg' drivers/clk/clk_scmi.c:117: undefined reference to `scmi_to_linux_errno' drivers/clk/clk_scmi.o: in function `scmi_clk_set_rate': drivers/clk/clk_scmi.c:139: undefined reference to `devm_scmi_process_msg' drivers/clk/clk_scmi.c:143: undefined reference to `scmi_to_linux_errno' drivers/clk/clk_scmi.o: in function `scmi_clk_probe': drivers/clk/clk_scmi.c:157: undefined reference to `devm_scmi_of_get_channel' make[1]: *** [scripts/Makefile.spl:527: spl/u-boot-spl] Error 1 make: *** [Makefile:2043: spl/u-boot-spl] Error 2
Add Kconfig option so that CLK_SCMI can be disabled in SPL to fix this.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v3: - Patch picked from [1] - Collect r-b tag
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230317191638.2558279-2-jo...
drivers/clk/Kconfig | 8 ++++++++ drivers/clk/Makefile | 2 +- drivers/firmware/scmi/scmi_agent-uclass.c | 2 +- 3 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 42280cbf83a7..19269c7fd4d6 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -166,6 +166,14 @@ config CLK_SCMI by a SCMI agent based on SCMI clock protocol communication with a SCMI server.
+config SPL_CLK_SCMI + bool "Enable SCMI clock driver in SPL" + depends on SCMI_FIRMWARE && SPL_FIRMWARE + help + Enable this option if you want to support clock devices exposed + by a SCMI agent based on SCMI clock protocol communication + with a SCMI server in SPL. + config CLK_HSDK bool "Enable cgu clock driver for HSDK boards" depends on CLK && TARGET_HSDK diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index c274cda77c6a..c1347774b58c 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -39,7 +39,7 @@ obj-$(CONFIG_CLK_MVEBU) += mvebu/ obj-$(CONFIG_CLK_OCTEON) += clk_octeon.o obj-$(CONFIG_CLK_OWL) += owl/ obj-$(CONFIG_CLK_RENESAS) += renesas/ -obj-$(CONFIG_CLK_SCMI) += clk_scmi.o +obj-$(CONFIG_$(SPL_TPL_)CLK_SCMI) += clk_scmi.o obj-$(CONFIG_CLK_SIFIVE) += sifive/ obj-$(CONFIG_CLK_UNIPHIER) += uniphier/ obj-$(CONFIG_CLK_VERSACLOCK) += clk_versaclock.o diff --git a/drivers/firmware/scmi/scmi_agent-uclass.c b/drivers/firmware/scmi/scmi_agent-uclass.c index 9a32678617d7..54d563d929b8 100644 --- a/drivers/firmware/scmi/scmi_agent-uclass.c +++ b/drivers/firmware/scmi/scmi_agent-uclass.c @@ -75,7 +75,7 @@ static int scmi_bind_protocols(struct udevice *dev) name = ofnode_get_name(node); switch (protocol_id) { case SCMI_PROTOCOL_ID_CLOCK: - if (IS_ENABLED(CONFIG_CLK_SCMI)) + if (CONFIG_IS_ENABLED(CLK_SCMI)) drv = DM_DRIVER_GET(scmi_clock); break; case SCMI_PROTOCOL_ID_RESET_DOMAIN:
Booting from sdmmc on RK3588 currently works because of a workaround in the device tree, clocks are reordered so that the driver use ciu-sample instead of ciu, and the BootRom initializes sdmmc clocks before SPL is loaded into DRAM.
The sdmmc clocks are normally controlled by TF-A using SCMI. However, there is a need to control these clocks in SPL, before TF-A has started.
This adds a rk3588_scru driver to control the sdmmc clocks in SPL before TF-A has started, using scru regs. It also adds a small glue driver to bind the scmi clock node to the rk3588_scru driver in SPL.
Fixes: 7a474df74023 ("clk: rockchip: Add rk3588 clk support") Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v3: - Patch picked from [1] - Collect r-b tag
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230317191638.2558279-3-jo...
arch/arm/include/asm/arch-rockchip/clock.h | 1 - .../include/asm/arch-rockchip/cru_rk3588.h | 19 ++- drivers/clk/rockchip/clk_rk3588.c | 125 ++++++++++++++++++ 3 files changed, 143 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/clock.h b/arch/arm/include/asm/arch-rockchip/clock.h index 90e66c7da049..f002ebcb7ac1 100644 --- a/arch/arm/include/asm/arch-rockchip/clock.h +++ b/arch/arm/include/asm/arch-rockchip/clock.h @@ -194,6 +194,5 @@ int rockchip_get_clk(struct udevice **devp); * Return: 0 success, or error value */ int rockchip_reset_bind(struct udevice *pdev, u32 reg_offset, u32 reg_number); -int rockchip_get_scmi_clk(struct udevice **devp);
#endif diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3588.h b/arch/arm/include/asm/arch-rockchip/cru_rk3588.h index 3ea59e900861..7f4a90853929 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3588.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3588.h @@ -11,12 +11,12 @@ #define KHz 1000 #define OSC_HZ (24 * MHz)
-#define CPU_PVTPLL_HZ (1008 * MHz) #define LPLL_HZ (816 * MHz) #define GPLL_HZ (1188 * MHz) #define CPLL_HZ (1500 * MHz) #define NPLL_HZ (850 * MHz) #define PPLL_HZ (1100 * MHz) +#define SPLL_HZ (702 * MHz)
/* RK3588 pll id */ enum rk3588_pll_id { @@ -447,5 +447,22 @@ enum { CLK_I2C0_SEL_MASK = 1 << CLK_I2C0_SEL_SHIFT, CLK_I2C_SEL_200M = 0, CLK_I2C_SEL_100M, + + /* SECURECRU_CLKSEL_CON01 */ + SCMI_HCLK_SD_SEL_SHIFT = 2, + SCMI_HCLK_SD_SEL_MASK = 3 << SCMI_HCLK_SD_SEL_SHIFT, + SCMI_HCLK_SD_SEL_150M = 0, + SCMI_HCLK_SD_SEL_100M, + SCMI_HCLK_SD_SEL_50M, + SCMI_HCLK_SD_SEL_24M, + + /* SECURECRU_CLKSEL_CON03 */ + SCMI_CCLK_SD_SEL_SHIFT = 12, + SCMI_CCLK_SD_SEL_MASK = 3 << SCMI_CCLK_SD_SEL_SHIFT, + SCMI_CCLK_SD_SEL_GPLL = 0, + SCMI_CCLK_SD_SEL_SPLL, + SCMI_CCLK_SD_SEL_24M, + SCMI_CCLK_SD_DIV_SHIFT = 6, + SCMI_CCLK_SD_DIV_MASK = 0x3f << SCMI_CCLK_SD_DIV_SHIFT, }; #endif diff --git a/drivers/clk/rockchip/clk_rk3588.c b/drivers/clk/rockchip/clk_rk3588.c index a7df553e8750..41e31b61a55b 100644 --- a/drivers/clk/rockchip/clk_rk3588.c +++ b/drivers/clk/rockchip/clk_rk3588.c @@ -9,6 +9,7 @@ #include <clk-uclass.h> #include <dm.h> #include <errno.h> +#include <scmi_protocols.h> #include <syscon.h> #include <asm/arch-rockchip/cru_rk3588.h> #include <asm/arch-rockchip/clock.h> @@ -1994,3 +1995,127 @@ U_BOOT_DRIVER(rockchip_rk3588_cru) = { .bind = rk3588_clk_bind, .probe = rk3588_clk_probe, }; + +#ifdef CONFIG_SPL_BUILD +#define SCRU_BASE 0xfd7d0000 + +static ulong rk3588_scru_clk_get_rate(struct clk *clk) +{ + u32 con, div, sel, parent; + + switch (clk->id) { + case SCMI_CCLK_SD: + con = readl(SCRU_BASE + RK3588_CLKSEL_CON(3)); + sel = (con & SCMI_CCLK_SD_SEL_MASK) >> SCMI_CCLK_SD_SEL_SHIFT; + div = (con & SCMI_CCLK_SD_DIV_MASK) >> SCMI_CCLK_SD_DIV_SHIFT; + if (sel == SCMI_CCLK_SD_SEL_GPLL) + parent = GPLL_HZ; + else if (sel == SCMI_CCLK_SD_SEL_SPLL) + parent = SPLL_HZ; + else + parent = OSC_HZ; + return DIV_TO_RATE(parent, div); + case SCMI_HCLK_SD: + con = readl(SCRU_BASE + RK3588_CLKSEL_CON(1)); + sel = (con & SCMI_HCLK_SD_SEL_MASK) >> SCMI_HCLK_SD_SEL_SHIFT; + if (sel == SCMI_HCLK_SD_SEL_150M) + return 150 * MHz; + else if (sel == SCMI_HCLK_SD_SEL_100M) + return 100 * MHz; + else if (sel == SCMI_HCLK_SD_SEL_50M) + return 50 * MHz; + else + return OSC_HZ; + default: + return -ENOENT; + } +} + +static ulong rk3588_scru_clk_set_rate(struct clk *clk, ulong rate) +{ + u32 div, sel; + + switch (clk->id) { + case SCMI_CCLK_SD: + if ((OSC_HZ % rate) == 0) { + sel = SCMI_CCLK_SD_SEL_24M; + div = DIV_ROUND_UP(OSC_HZ, rate); + } else if ((SPLL_HZ % rate) == 0) { + sel = SCMI_CCLK_SD_SEL_SPLL; + div = DIV_ROUND_UP(SPLL_HZ, rate); + } else { + sel = SCMI_CCLK_SD_SEL_GPLL; + div = DIV_ROUND_UP(GPLL_HZ, rate); + } + rk_clrsetreg(SCRU_BASE + RK3588_CLKSEL_CON(3), + SCMI_CCLK_SD_SEL_MASK | SCMI_CCLK_SD_DIV_MASK, + sel << SCMI_CCLK_SD_SEL_SHIFT | + (div - 1) << SCMI_CCLK_SD_DIV_SHIFT); + break; + case SCMI_HCLK_SD: + if (rate >= 150 * MHz) + sel = SCMI_HCLK_SD_SEL_150M; + else if (rate >= 100 * MHz) + sel = SCMI_HCLK_SD_SEL_100M; + else if (rate >= 50 * MHz) + sel = SCMI_HCLK_SD_SEL_50M; + else + sel = SCMI_HCLK_SD_SEL_24M; + rk_clrsetreg(SCRU_BASE + RK3588_CLKSEL_CON(1), + SCMI_HCLK_SD_SEL_MASK, + sel << SCMI_HCLK_SD_SEL_SHIFT); + break; + default: + return -ENOENT; + } + + return rk3588_scru_clk_get_rate(clk); +} + +static const struct clk_ops rk3588_scru_clk_ops = { + .get_rate = rk3588_scru_clk_get_rate, + .set_rate = rk3588_scru_clk_set_rate, +}; + +U_BOOT_DRIVER(rockchip_rk3588_scru) = { + .name = "rockchip_rk3588_scru", + .id = UCLASS_CLK, + .ops = &rk3588_scru_clk_ops, +}; + +static int rk3588_scmi_spl_glue_bind(struct udevice *dev) +{ + ofnode node; + u32 protocol_id; + const char *name; + + dev_for_each_subnode(node, dev) { + if (!ofnode_is_enabled(node)) + continue; + + if (ofnode_read_u32(node, "reg", &protocol_id)) + continue; + + if (protocol_id != SCMI_PROTOCOL_ID_CLOCK) + continue; + + name = ofnode_get_name(node); + return device_bind_driver_to_node(dev, "rockchip_rk3588_scru", + name, node, NULL); + } + + return -ENOENT; +} + +static const struct udevice_id rk3588_scmi_spl_glue_ids[] = { + { .compatible = "arm,scmi-smc" }, + { } +}; + +U_BOOT_DRIVER(rk3588_scmi_spl_glue) = { + .name = "rk3588_scmi_spl_glue", + .id = UCLASS_NOP, + .of_match = rk3588_scmi_spl_glue_ids, + .bind = rk3588_scmi_spl_glue_bind, +}; +#endif
Sync the sdmmc node from linux-next, include required nodes in SPL and imply Kconfig options required for functional sdmmc clk in SPL and U-Boot proper.
This make it possible for both SPL and U-Boot proper to configure sdmmc clocks. In SPL, before TF-A is loaded, scru regs is configured, in U-Boot proper a SCMI message is sent to TF-A.
Fixes: 95c8656b72dc ("ARM: dts: rockchip: rk3588s-u-boot: Add sdmmc node") Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v3: - Patch picked from [1] - Collect r-b tag
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230317191638.2558279-4-jo...
.../dts/rk3588-edgeble-neu6a-io-u-boot.dtsi | 2 -- arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 2 -- arch/arm/dts/rk3588s-u-boot.dtsi | 27 +++++++++---------- arch/arm/dts/rk3588s.dtsi | 15 +++++++++++ arch/arm/mach-rockchip/Kconfig | 2 ++ 5 files changed, 30 insertions(+), 18 deletions(-)
diff --git a/arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi b/arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi index 3235bd36e4c8..373f369c6556 100644 --- a/arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi +++ b/arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi @@ -18,7 +18,5 @@
&sdmmc { bus-width = <4>; - bootph-all; - u-boot,spl-fifo-mode; status = "okay"; }; diff --git a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi index b61d6e0fdbfc..4c6f0311d6a1 100644 --- a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi +++ b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi @@ -17,7 +17,5 @@
&sdmmc { bus-width = <4>; - bootph-pre-ram; - u-boot,spl-fifo-mode; status = "okay"; }; diff --git a/arch/arm/dts/rk3588s-u-boot.dtsi b/arch/arm/dts/rk3588s-u-boot.dtsi index 1e225d71efc2..3cb22f35420e 100644 --- a/arch/arm/dts/rk3588s-u-boot.dtsi +++ b/arch/arm/dts/rk3588s-u-boot.dtsi @@ -18,20 +18,6 @@ reg = <0x0 0xfd58a000 0x0 0x2000>; };
- sdmmc: mmc@fe2c0000 { - compatible = "rockchip,rk3588-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0x0 0xfe2c0000 0x0 0x4000>; - interrupts = <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>, - <&scmi_clk SCMI_HCLK_SD>, <&scmi_clk SCMI_CCLK_SD>; - clock-names = "ciu-drive", "ciu-sample", "biu", "ciu"; - fifo-depth = <0x100>; - max-frequency = <200000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_det &sdmmc_bus4>; - status = "disabled"; - }; - otp: nvmem@fecc0000 { compatible = "rockchip,rk3588-otp"; reg = <0x0 0xfecc0000 0x0 0x400>; @@ -60,6 +46,19 @@ status = "okay"; };
+&scmi { + bootph-pre-ram; +}; + +&scmi_clk { + bootph-pre-ram; +}; + +&sdmmc { + bootph-pre-ram; + u-boot,spl-fifo-mode; +}; + &uart2 { clock-frequency = <24000000>; bootph-pre-ram; diff --git a/arch/arm/dts/rk3588s.dtsi b/arch/arm/dts/rk3588s.dtsi index 005cde61b4b2..fca8503aed8c 100644 --- a/arch/arm/dts/rk3588s.dtsi +++ b/arch/arm/dts/rk3588s.dtsi @@ -1099,6 +1099,21 @@ }; };
+ sdmmc: mmc@fe2c0000 { + compatible = "rockchip,rk3588-dw-mshc", "rockchip,rk3288-dw-mshc"; + reg = <0x0 0xfe2c0000 0x0 0x4000>; + interrupts = <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&scmi_clk SCMI_HCLK_SD>, <&scmi_clk SCMI_CCLK_SD>, + <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; + fifo-depth = <0x100>; + max-frequency = <200000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_det &sdmmc_bus4>; + power-domains = <&power RK3588_PD_SDMMC>; + status = "disabled"; + }; + sdhci: mmc@fe2e0000 { compatible = "rockchip,rk3588-dwcmshc"; reg = <0x0 0xfe2e0000 0x0 0x10000>; diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 517326c8c5be..59dd8ba5c663 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -316,6 +316,8 @@ config ROCKCHIP_RK3588 imply OF_LIBFDT_OVERLAY imply ROCKCHIP_OTP imply MISC_INIT_R + imply CLK_SCMI + imply SCMI_FIRMWARE help The Rockchip RK3588 is a ARM-based SoC with quad-core Cortex-A76 and quad-core Cortex-A55 including NEON and GPU, 6TOPS NPU, Mali-G610 MP4,
IO mux selection is not working correctly for all pins. Sync mux route data from linux to add any missing and update wrong trigger pins to fix this. Also apply the pull-up fix needed for GPIO0 D3-D6.
Fixes: 1977d746aa54 ("rockchip: rk3568: add rk3568 pinctrl driver") Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v3: - Patch picked from [1]
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230318233039.799975-1-jon...
drivers/pinctrl/rockchip/pinctrl-rk3568.c | 66 +++++++++++++---------- 1 file changed, 38 insertions(+), 28 deletions(-)
diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3568.c b/drivers/pinctrl/rockchip/pinctrl-rk3568.c index 935aed9efc62..314edb5a6064 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3568.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3568.c @@ -13,6 +13,12 @@ #include "pinctrl-rockchip.h"
static struct rockchip_mux_route_data rk3568_mux_route_data[] = { + MR_PMUGRF(RK_GPIO0, RK_PB7, RK_FUNC_1, 0x0110, RK_GENMASK_VAL(1, 0, 0)), /* PWM0 IO mux selection M0 */ + MR_PMUGRF(RK_GPIO0, RK_PC7, RK_FUNC_2, 0x0110, RK_GENMASK_VAL(1, 0, 1)), /* PWM0 IO mux selection M1 */ + MR_PMUGRF(RK_GPIO0, RK_PC0, RK_FUNC_1, 0x0110, RK_GENMASK_VAL(3, 2, 0)), /* PWM1 IO mux selection M0 */ + MR_PMUGRF(RK_GPIO0, RK_PB5, RK_FUNC_4, 0x0110, RK_GENMASK_VAL(3, 2, 1)), /* PWM1 IO mux selection M1 */ + MR_PMUGRF(RK_GPIO0, RK_PC1, RK_FUNC_1, 0x0110, RK_GENMASK_VAL(5, 4, 0)), /* PWM2 IO mux selection M0 */ + MR_PMUGRF(RK_GPIO0, RK_PB6, RK_FUNC_4, 0x0110, RK_GENMASK_VAL(5, 4, 1)), /* PWM2 IO mux selection M1 */ MR_TOPGRF(RK_GPIO0, RK_PB3, RK_FUNC_2, 0x0300, RK_GENMASK_VAL(0, 0, 0)), /* CAN0 IO mux selection M0 */ MR_TOPGRF(RK_GPIO2, RK_PA1, RK_FUNC_4, 0x0300, RK_GENMASK_VAL(0, 0, 1)), /* CAN0 IO mux selection M1 */ MR_TOPGRF(RK_GPIO1, RK_PA1, RK_FUNC_3, 0x0300, RK_GENMASK_VAL(2, 2, 0)), /* CAN1 IO mux selection M0 */ @@ -33,30 +39,22 @@ static struct rockchip_mux_route_data rk3568_mux_route_data[] = { MR_TOPGRF(RK_GPIO2, RK_PB1, RK_FUNC_2, 0x0304, RK_GENMASK_VAL(2, 2, 1)), /* I2C4 IO mux selection M1 */ MR_TOPGRF(RK_GPIO3, RK_PB4, RK_FUNC_4, 0x0304, RK_GENMASK_VAL(4, 4, 0)), /* I2C5 IO mux selection M0 */ MR_TOPGRF(RK_GPIO4, RK_PD0, RK_FUNC_2, 0x0304, RK_GENMASK_VAL(4, 4, 1)), /* I2C5 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0304, RK_GENMASK_VAL(6, 6, 0)), /* PWM4 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0304, RK_GENMASK_VAL(6, 6, 1)), /* PWM4 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0304, RK_GENMASK_VAL(8, 8, 0)), /* PWM5 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0304, RK_GENMASK_VAL(8, 8, 1)), /* PWM5 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0304, RK_GENMASK_VAL(10, 10, 0)), /* PWM6 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0304, RK_GENMASK_VAL(10, 10, 1)), /* PWM6 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0304, RK_GENMASK_VAL(12, 12, 0)), /* PWM7 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0304, RK_GENMASK_VAL(12, 12, 1)), /* PWM7 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0304, RK_GENMASK_VAL(14, 14, 0)), /* PWM8 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0304, RK_GENMASK_VAL(14, 14, 1)), /* PWM8 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(0, 0, 0)), /* PWM9 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(0, 0, 1)), /* PWM9 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(2, 2, 0)), /* PWM10 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(2, 2, 1)), /* PWM10 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(4, 4, 0)), /* PWM11 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(4, 4, 1)), /* PWM11 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(6, 6, 0)), /* PWM12 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(6, 6, 1)), /* PWM12 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(8, 8, 0)), /* PWM13 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(8, 8, 1)), /* PWM13 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(10, 10, 0)), /* PWM14 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(10, 10, 1)), /* PWM14 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(12, 12, 0)), /* PWM15 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(12, 12, 1)), /* PWM15 IO mux selection M1 */ + MR_TOPGRF(RK_GPIO3, RK_PB1, RK_FUNC_5, 0x0304, RK_GENMASK_VAL(14, 14, 0)), /* PWM8 IO mux selection M0 */ + MR_TOPGRF(RK_GPIO1, RK_PD5, RK_FUNC_4, 0x0304, RK_GENMASK_VAL(14, 14, 1)), /* PWM8 IO mux selection M1 */ + MR_TOPGRF(RK_GPIO3, RK_PB2, RK_FUNC_5, 0x0308, RK_GENMASK_VAL(0, 0, 0)), /* PWM9 IO mux selection M0 */ + MR_TOPGRF(RK_GPIO1, RK_PD6, RK_FUNC_4, 0x0308, RK_GENMASK_VAL(0, 0, 1)), /* PWM9 IO mux selection M1 */ + MR_TOPGRF(RK_GPIO3, RK_PB5, RK_FUNC_5, 0x0308, RK_GENMASK_VAL(2, 2, 0)), /* PWM10 IO mux selection M0 */ + MR_TOPGRF(RK_GPIO2, RK_PA1, RK_FUNC_2, 0x0308, RK_GENMASK_VAL(2, 2, 1)), /* PWM10 IO mux selection M1 */ + MR_TOPGRF(RK_GPIO3, RK_PB6, RK_FUNC_5, 0x0308, RK_GENMASK_VAL(4, 4, 0)), /* PWM11 IO mux selection M0 */ + MR_TOPGRF(RK_GPIO4, RK_PC0, RK_FUNC_3, 0x0308, RK_GENMASK_VAL(4, 4, 1)), /* PWM11 IO mux selection M1 */ + MR_TOPGRF(RK_GPIO3, RK_PB7, RK_FUNC_2, 0x0308, RK_GENMASK_VAL(6, 6, 0)), /* PWM12 IO mux selection M0 */ + MR_TOPGRF(RK_GPIO4, RK_PC5, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(6, 6, 1)), /* PWM12 IO mux selection M1 */ + MR_TOPGRF(RK_GPIO3, RK_PC0, RK_FUNC_2, 0x0308, RK_GENMASK_VAL(8, 8, 0)), /* PWM13 IO mux selection M0 */ + MR_TOPGRF(RK_GPIO4, RK_PC6, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(8, 8, 1)), /* PWM13 IO mux selection M1 */ + MR_TOPGRF(RK_GPIO3, RK_PC4, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(10, 10, 0)), /* PWM14 IO mux selection M0 */ + MR_TOPGRF(RK_GPIO4, RK_PC2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(10, 10, 1)), /* PWM14 IO mux selection M1 */ + MR_TOPGRF(RK_GPIO3, RK_PC5, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(12, 12, 0)), /* PWM15 IO mux selection M0 */ + MR_TOPGRF(RK_GPIO4, RK_PC3, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(12, 12, 1)), /* PWM15 IO mux selection M1 */ MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_3, 0x0308, RK_GENMASK_VAL(14, 14, 0)), /* SDMMC2 IO mux selection M0 */ MR_TOPGRF(RK_GPIO3, RK_PA5, RK_FUNC_5, 0x0308, RK_GENMASK_VAL(14, 14, 1)), /* SDMMC2 IO mux selection M1 */ MR_TOPGRF(RK_GPIO0, RK_PB5, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(0, 0, 0)), /* SPI0 IO mux selection M0 */ @@ -68,7 +66,7 @@ static struct rockchip_mux_route_data rk3568_mux_route_data[] = { MR_TOPGRF(RK_GPIO4, RK_PB3, RK_FUNC_4, 0x030c, RK_GENMASK_VAL(6, 6, 0)), /* SPI3 IO mux selection M0 */ MR_TOPGRF(RK_GPIO4, RK_PC2, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(6, 6, 1)), /* SPI3 IO mux selection M1 */ MR_TOPGRF(RK_GPIO2, RK_PB4, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(8, 8, 0)), /* UART1 IO mux selection M0 */ - MR_TOPGRF(RK_GPIO0, RK_PD1, RK_FUNC_1, 0x030c, RK_GENMASK_VAL(8, 8, 1)), /* UART1 IO mux selection M1 */ + MR_TOPGRF(RK_GPIO3, RK_PD6, RK_FUNC_4, 0x030c, RK_GENMASK_VAL(8, 8, 1)), /* UART1 IO mux selection M1 */ MR_TOPGRF(RK_GPIO0, RK_PD1, RK_FUNC_1, 0x030c, RK_GENMASK_VAL(10, 10, 0)), /* UART2 IO mux selection M0 */ MR_TOPGRF(RK_GPIO1, RK_PD5, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(10, 10, 1)), /* UART2 IO mux selection M1 */ MR_TOPGRF(RK_GPIO1, RK_PA1, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(12, 12, 0)), /* UART3 IO mux selection M0 */ @@ -81,7 +79,7 @@ static struct rockchip_mux_route_data rk3568_mux_route_data[] = { MR_TOPGRF(RK_GPIO1, RK_PD5, RK_FUNC_3, 0x0310, RK_GENMASK_VAL(2, 2, 1)), /* UART6 IO mux selection M1 */ MR_TOPGRF(RK_GPIO2, RK_PA6, RK_FUNC_3, 0x0310, RK_GENMASK_VAL(5, 4, 0)), /* UART7 IO mux selection M0 */ MR_TOPGRF(RK_GPIO3, RK_PC4, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(5, 4, 1)), /* UART7 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_1, 0x0310, RK_GENMASK_VAL(5, 4, 2)), /* UART7 IO mux selection M2 */ + MR_TOPGRF(RK_GPIO4, RK_PA2, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(5, 4, 2)), /* UART7 IO mux selection M2 */ MR_TOPGRF(RK_GPIO2, RK_PC5, RK_FUNC_3, 0x0310, RK_GENMASK_VAL(6, 6, 0)), /* UART8 IO mux selection M0 */ MR_TOPGRF(RK_GPIO2, RK_PD7, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(6, 6, 1)), /* UART8 IO mux selection M1 */ MR_TOPGRF(RK_GPIO2, RK_PB0, RK_FUNC_3, 0x0310, RK_GENMASK_VAL(9, 8, 0)), /* UART9 IO mux selection M0 */ @@ -94,8 +92,11 @@ static struct rockchip_mux_route_data rk3568_mux_route_data[] = { MR_TOPGRF(RK_GPIO4, RK_PB6, RK_FUNC_5, 0x0310, RK_GENMASK_VAL(12, 12, 1)), /* I2S2 IO mux selection M1 */ MR_TOPGRF(RK_GPIO3, RK_PA2, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(14, 14, 0)), /* I2S3 IO mux selection M0 */ MR_TOPGRF(RK_GPIO4, RK_PC2, RK_FUNC_5, 0x0310, RK_GENMASK_VAL(14, 14, 1)), /* I2S3 IO mux selection M1 */ - MR_TOPGRF(RK_GPIO1, RK_PA6, RK_FUNC_3, 0x0314, RK_GENMASK_VAL(0, 0, 0)), /* PDM IO mux selection M0 */ - MR_TOPGRF(RK_GPIO3, RK_PD6, RK_FUNC_5, 0x0314, RK_GENMASK_VAL(0, 0, 1)), /* PDM IO mux selection M1 */ + MR_TOPGRF(RK_GPIO1, RK_PA4, RK_FUNC_3, 0x0314, RK_GENMASK_VAL(1, 0, 0)), /* PDM IO mux selection M0 */ + MR_TOPGRF(RK_GPIO1, RK_PA6, RK_FUNC_3, 0x0314, RK_GENMASK_VAL(1, 0, 0)), /* PDM IO mux selection M0 */ + MR_TOPGRF(RK_GPIO3, RK_PD6, RK_FUNC_5, 0x0314, RK_GENMASK_VAL(1, 0, 1)), /* PDM IO mux selection M1 */ + MR_TOPGRF(RK_GPIO4, RK_PA0, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(1, 0, 1)), /* PDM IO mux selection M1 */ + MR_TOPGRF(RK_GPIO3, RK_PC4, RK_FUNC_5, 0x0314, RK_GENMASK_VAL(1, 0, 2)), /* PDM IO mux selection M2 */ MR_TOPGRF(RK_GPIO0, RK_PA5, RK_FUNC_3, 0x0314, RK_GENMASK_VAL(3, 2, 0)), /* PCIE20 IO mux selection M0 */ MR_TOPGRF(RK_GPIO2, RK_PD0, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(3, 2, 1)), /* PCIE20 IO mux selection M1 */ MR_TOPGRF(RK_GPIO1, RK_PB0, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(3, 2, 2)), /* PCIE20 IO mux selection M2 */ @@ -237,6 +238,15 @@ static int rk3568_set_pull(struct rockchip_pin_bank *bank, return ret; }
+ /* + * In the TRM, pull-up being 1 for everything except the GPIO0_D3-D6, + * where that pull up value becomes 3. + */ + if (bank->bank_num == 0 && pin_num >= 27 && pin_num <= 30) { + if (ret == 1) + ret = 3; + } + /* enable the write to the equivalent lower bits */ data = ((1 << ROCKCHIP_PULL_BITS_PER_PIN) - 1) << (bit + 16);
Thanks, - Kever
v3:
- MR_PMUGRF(RK_GPIO0, RK_PB7, RK_FUNC_1, 0x0110, RK_GENMASK_VAL(1, 0, 0)), /* PWM0 IO mux selection M0 */
- MR_PMUGRF(RK_GPIO0, RK_PC7, RK_FUNC_2, 0x0110, RK_GENMASK_VAL(1, 0, 1)), /* PWM0 IO mux selection M1 */
- MR_PMUGRF(RK_GPIO0, RK_PC0, RK_FUNC_1, 0x0110, RK_GENMASK_VAL(3, 2, 0)), /* PWM1 IO mux selection M0 */
- MR_PMUGRF(RK_GPIO0, RK_PB5, RK_FUNC_4, 0x0110, RK_GENMASK_VAL(3, 2, 1)), /* PWM1 IO mux selection M1 */
- MR_PMUGRF(RK_GPIO0, RK_PC1, RK_FUNC_1, 0x0110, RK_GENMASK_VAL(5, 4, 0)), /* PWM2 IO mux selection M0 */
- MR_PMUGRF(RK_GPIO0, RK_PB6, RK_FUNC_4, 0x0110, RK_GENMASK_VAL(5, 4, 1)), /* PWM2 IO mux selection M1 */ MR_TOPGRF(RK_GPIO0, RK_PB3, RK_FUNC_2, 0x0300, RK_GENMASK_VAL(0, 0, 0)), /* CAN0 IO mux selection M0 */ MR_TOPGRF(RK_GPIO2, RK_PA1, RK_FUNC_4, 0x0300, RK_GENMASK_VAL(0, 0, 1)), /* CAN0 IO mux selection M1 */ MR_TOPGRF(RK_GPIO1, RK_PA1, RK_FUNC_3, 0x0300, RK_GENMASK_VAL(2, 2, 0)), /* CAN1 IO mux selection M0 */
- MR_TOPGRF(RK_GPIO3, RK_PB1, RK_FUNC_5, 0x0304, RK_GENMASK_VAL(14, 14, 0)), /* PWM8 IO mux selection M0 */
- MR_TOPGRF(RK_GPIO1, RK_PD5, RK_FUNC_4, 0x0304, RK_GENMASK_VAL(14, 14, 1)), /* PWM8 IO mux selection M1 */
- MR_TOPGRF(RK_GPIO3, RK_PB2, RK_FUNC_5, 0x0308, RK_GENMASK_VAL(0, 0, 0)), /* PWM9 IO mux selection M0 */
- MR_TOPGRF(RK_GPIO1, RK_PD6, RK_FUNC_4, 0x0308, RK_GENMASK_VAL(0, 0, 1)), /* PWM9 IO mux selection M1 */
- MR_TOPGRF(RK_GPIO3, RK_PB5, RK_FUNC_5, 0x0308, RK_GENMASK_VAL(2, 2, 0)), /* PWM10 IO mux selection M0 */
- MR_TOPGRF(RK_GPIO2, RK_PA1, RK_FUNC_2, 0x0308, RK_GENMASK_VAL(2, 2, 1)), /* PWM10 IO mux selection M1 */
- MR_TOPGRF(RK_GPIO3, RK_PB6, RK_FUNC_5, 0x0308, RK_GENMASK_VAL(4, 4, 0)), /* PWM11 IO mux selection M0 */
- MR_TOPGRF(RK_GPIO4, RK_PC0, RK_FUNC_3, 0x0308, RK_GENMASK_VAL(4, 4, 1)), /* PWM11 IO mux selection M1 */
- MR_TOPGRF(RK_GPIO3, RK_PB7, RK_FUNC_2, 0x0308, RK_GENMASK_VAL(6, 6, 0)), /* PWM12 IO mux selection M0 */
- MR_TOPGRF(RK_GPIO4, RK_PC5, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(6, 6, 1)), /* PWM12 IO mux selection M1 */
- MR_TOPGRF(RK_GPIO3, RK_PC0, RK_FUNC_2, 0x0308, RK_GENMASK_VAL(8, 8, 0)), /* PWM13 IO mux selection M0 */
- MR_TOPGRF(RK_GPIO4, RK_PC6, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(8, 8, 1)), /* PWM13 IO mux selection M1 */
- MR_TOPGRF(RK_GPIO3, RK_PC4, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(10, 10, 0)), /* PWM14 IO mux selection M0 */
- MR_TOPGRF(RK_GPIO4, RK_PC2, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(10, 10, 1)), /* PWM14 IO mux selection M1 */
- MR_TOPGRF(RK_GPIO3, RK_PC5, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(12, 12, 0)), /* PWM15 IO mux selection M0 */
- MR_TOPGRF(RK_GPIO4, RK_PC3, RK_FUNC_1, 0x0308, RK_GENMASK_VAL(12, 12, 1)), /* PWM15 IO mux selection M1 */ MR_TOPGRF(RK_GPIO3, RK_PD2, RK_FUNC_3, 0x0308, RK_GENMASK_VAL(14, 14, 0)), /* SDMMC2 IO mux selection M0 */ MR_TOPGRF(RK_GPIO3, RK_PA5, RK_FUNC_5, 0x0308, RK_GENMASK_VAL(14, 14, 1)), /* SDMMC2 IO mux selection M1 */ MR_TOPGRF(RK_GPIO0, RK_PB5, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(0, 0, 0)), /* SPI0 IO mux selection M0 */
- MR_TOPGRF(RK_GPIO3, RK_PD6, RK_FUNC_4, 0x030c, RK_GENMASK_VAL(8, 8, 1)), /* UART1 IO mux selection M1 */ MR_TOPGRF(RK_GPIO0, RK_PD1, RK_FUNC_1, 0x030c, RK_GENMASK_VAL(10, 10, 0)), /* UART2 IO mux selection M0 */ MR_TOPGRF(RK_GPIO1, RK_PD5, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(10, 10, 1)), /* UART2 IO mux selection M1 */ MR_TOPGRF(RK_GPIO1, RK_PA1, RK_FUNC_2, 0x030c, RK_GENMASK_VAL(12, 12, 0)), /* UART3 IO mux selection M0 */
- MR_TOPGRF(RK_GPIO4, RK_PA2, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(5, 4, 2)), /* UART7 IO mux selection M2 */ MR_TOPGRF(RK_GPIO2, RK_PC5, RK_FUNC_3, 0x0310, RK_GENMASK_VAL(6, 6, 0)), /* UART8 IO mux selection M0 */ MR_TOPGRF(RK_GPIO2, RK_PD7, RK_FUNC_4, 0x0310, RK_GENMASK_VAL(6, 6, 1)), /* UART8 IO mux selection M1 */ MR_TOPGRF(RK_GPIO2, RK_PB0, RK_FUNC_3, 0x0310, RK_GENMASK_VAL(9, 8, 0)), /* UART9 IO mux selection M0 */
- MR_TOPGRF(RK_GPIO1, RK_PA4, RK_FUNC_3, 0x0314, RK_GENMASK_VAL(1, 0, 0)), /* PDM IO mux selection M0 */
- MR_TOPGRF(RK_GPIO1, RK_PA6, RK_FUNC_3, 0x0314, RK_GENMASK_VAL(1, 0, 0)), /* PDM IO mux selection M0 */
- MR_TOPGRF(RK_GPIO3, RK_PD6, RK_FUNC_5, 0x0314, RK_GENMASK_VAL(1, 0, 1)), /* PDM IO mux selection M1 */
- MR_TOPGRF(RK_GPIO4, RK_PA0, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(1, 0, 1)), /* PDM IO mux selection M1 */
- MR_TOPGRF(RK_GPIO3, RK_PC4, RK_FUNC_5, 0x0314, RK_GENMASK_VAL(1, 0, 2)), /* PDM IO mux selection M2 */ MR_TOPGRF(RK_GPIO0, RK_PA5, RK_FUNC_3, 0x0314, RK_GENMASK_VAL(3, 2, 0)), /* PCIE20 IO mux selection M0 */ MR_TOPGRF(RK_GPIO2, RK_PD0, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(3, 2, 1)), /* PCIE20 IO mux selection M1 */ MR_TOPGRF(RK_GPIO1, RK_PB0, RK_FUNC_4, 0x0314, RK_GENMASK_VAL(3, 2, 2)), /* PCIE20 IO mux selection M2 */
- if (bank->bank_num == 0 && pin_num >= 27 && pin_num <= 30) {
if (ret == 1)
ret = 3;
- /* enable the write to the equivalent lower bits */ data = ((1 << ROCKCHIP_PULL_BITS_PER_PIN) - 1) << (bit + 16);
The GPIO V2 controller on RK3568 and RK3588 works very similar to prior generation, main difference is the use of a write mask in the upper 16 bits and register address offset have changed.
GPIO_VER_ID is a new register at 0x0078 that is used to determine when the driver should use new or old register offsets and values. Earlier generation return 0x0 from this offset.
Refactor code and add support for the GPIO V2 controller used in RK3568 and RK3588.
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230319183949.1375997-1-jo...
drivers/gpio/rk_gpio.c | 112 ++++++++++++++++++++++++++++------------- 1 file changed, 76 insertions(+), 36 deletions(-)
diff --git a/drivers/gpio/rk_gpio.c b/drivers/gpio/rk_gpio.c index f7ad4d68b452..d9bde8f4f034 100644 --- a/drivers/gpio/rk_gpio.c +++ b/drivers/gpio/rk_gpio.c @@ -13,83 +13,118 @@ #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/gpio.h> #include <dm/pinctrl.h> -#include <dt-bindings/clock/rk3288-cru.h> +#include <dm/read.h> +#include <dt-bindings/pinctrl/rockchip.h> + +#define SWPORT_DR 0x0000 +#define SWPORT_DDR 0x0004 +#define EXT_PORT 0x0050 +#define SWPORT_DR_L 0x0000 +#define SWPORT_DR_H 0x0004 +#define SWPORT_DDR_L 0x0008 +#define SWPORT_DDR_H 0x000C +#define EXT_PORT_V2 0x0070 +#define VER_ID_V2 0x0078
enum { ROCKCHIP_GPIOS_PER_BANK = 32, };
-#define OFFSET_TO_BIT(bit) (1UL << (bit)) - struct rockchip_gpio_priv { - struct rockchip_gpio_regs *regs; + void __iomem *regs; struct udevice *pinctrl; int bank; char name[2]; + u32 version; };
-static int rockchip_gpio_direction_input(struct udevice *dev, unsigned offset) +static int rockchip_gpio_get_value(struct udevice *dev, unsigned offset) { struct rockchip_gpio_priv *priv = dev_get_priv(dev); - struct rockchip_gpio_regs *regs = priv->regs; + u32 mask = BIT(offset), data;
- clrbits_le32(®s->swport_ddr, OFFSET_TO_BIT(offset)); + if (priv->version) + data = readl(priv->regs + EXT_PORT_V2); + else + data = readl(priv->regs + EXT_PORT);
- return 0; + return (data & mask) ? 1 : 0; }
-static int rockchip_gpio_direction_output(struct udevice *dev, unsigned offset, - int value) +static int rockchip_gpio_set_value(struct udevice *dev, unsigned offset, + int value) { struct rockchip_gpio_priv *priv = dev_get_priv(dev); - struct rockchip_gpio_regs *regs = priv->regs; - int mask = OFFSET_TO_BIT(offset); + u32 mask = BIT(offset), data = value ? mask : 0;
- clrsetbits_le32(®s->swport_dr, mask, value ? mask : 0); - setbits_le32(®s->swport_ddr, mask); + if (priv->version && offset >= 16) + rk_clrsetreg(priv->regs + SWPORT_DR_H, mask >> 16, data >> 16); + else if (priv->version) + rk_clrsetreg(priv->regs + SWPORT_DR_L, mask, data); + else + clrsetbits_le32(priv->regs + SWPORT_DR, mask, data);
return 0; }
-static int rockchip_gpio_get_value(struct udevice *dev, unsigned offset) +static int rockchip_gpio_direction_input(struct udevice *dev, unsigned offset) { struct rockchip_gpio_priv *priv = dev_get_priv(dev); - struct rockchip_gpio_regs *regs = priv->regs; + u32 mask = BIT(offset); + + if (priv->version && offset >= 16) + rk_clrreg(priv->regs + SWPORT_DDR_H, mask >> 16); + else if (priv->version) + rk_clrreg(priv->regs + SWPORT_DDR_L, mask); + else + clrbits_le32(priv->regs + SWPORT_DDR, mask);
- return readl(®s->ext_port) & OFFSET_TO_BIT(offset) ? 1 : 0; + return 0; }
-static int rockchip_gpio_set_value(struct udevice *dev, unsigned offset, - int value) +static int rockchip_gpio_direction_output(struct udevice *dev, unsigned offset, + int value) { struct rockchip_gpio_priv *priv = dev_get_priv(dev); - struct rockchip_gpio_regs *regs = priv->regs; - int mask = OFFSET_TO_BIT(offset); + u32 mask = BIT(offset); + + rockchip_gpio_set_value(dev, offset, value);
- clrsetbits_le32(®s->swport_dr, mask, value ? mask : 0); + if (priv->version && offset >= 16) + rk_setreg(priv->regs + SWPORT_DDR_H, mask >> 16); + else if (priv->version) + rk_setreg(priv->regs + SWPORT_DDR_L, mask); + else + setbits_le32(priv->regs + SWPORT_DDR, mask);
return 0; }
static int rockchip_gpio_get_function(struct udevice *dev, unsigned offset) { -#ifdef CONFIG_SPL_BUILD - return -ENODATA; -#else struct rockchip_gpio_priv *priv = dev_get_priv(dev); - struct rockchip_gpio_regs *regs = priv->regs; - bool is_output; + u32 mask = BIT(offset), data; int ret;
- ret = pinctrl_get_gpio_mux(priv->pinctrl, priv->bank, offset); - if (ret) - return ret; - is_output = readl(®s->swport_ddr) & OFFSET_TO_BIT(offset); + if (CONFIG_IS_ENABLED(PINCTRL)) { + ret = pinctrl_get_gpio_mux(priv->pinctrl, priv->bank, offset); + if (ret < 0) + return ret; + else if (ret != RK_FUNC_GPIO) + return GPIOF_FUNC; + } + + if (priv->version && offset >= 16) + data = readl(priv->regs + SWPORT_DDR_H) << 16; + else if (priv->version) + data = readl(priv->regs + SWPORT_DDR_L); + else + data = readl(priv->regs + SWPORT_DDR);
- return is_output ? GPIOF_OUTPUT : GPIOF_INPUT; -#endif + return (data & mask) ? GPIOF_OUTPUT : GPIOF_INPUT; }
/* Simple SPL interface to GPIOs */ @@ -147,9 +182,12 @@ static int rockchip_gpio_probe(struct udevice *dev) int ret;
priv->regs = dev_read_addr_ptr(dev); - ret = uclass_first_device_err(UCLASS_PINCTRL, &priv->pinctrl); - if (ret) - return ret; + + if (CONFIG_IS_ENABLED(PINCTRL)) { + ret = uclass_first_device_err(UCLASS_PINCTRL, &priv->pinctrl); + if (ret) + return ret; + }
/* * If "gpio-ranges" is present in the devicetree use it to parse @@ -170,6 +208,8 @@ static int rockchip_gpio_probe(struct udevice *dev) priv->name[0] = 'A' + priv->bank; uc_priv->bank_name = priv->name;
+ priv->version = readl(priv->regs + VER_ID_V2); + return 0; }
A RK3568 device tree pmic node can reference the I2S1_MCLKOUT_TX clock in assigned-clocks, add dummy support to set parent of this clock to the rk3568 cru driver.
Fixes probe of pmic driver and missing regulators on affected boards, rk3568-evb and rk3568-rock-3a.
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230402155816.1312383-1-jo...
drivers/clk/rockchip/clk_rk3568.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3568.c b/drivers/clk/rockchip/clk_rk3568.c index 1c6adc56f913..cefc263971a6 100644 --- a/drivers/clk/rockchip/clk_rk3568.c +++ b/drivers/clk/rockchip/clk_rk3568.c @@ -2838,6 +2838,8 @@ static int rk3568_clk_set_parent(struct clk *clk, struct clk *parent) case ACLK_RKVDEC_PRE: case CLK_RKVDEC_CORE: return rk3568_rkvdec_set_parent(clk, parent); + case I2S1_MCLKOUT_TX: + break; default: return -ENOENT; }
Jonas Karlman
Kever Yang
