[U-Boot] [GIT PULL] Zynq changes
Hi Tom,
please pull these changes to your tree. Network patches have been Ack by Joe. mkimage, mii patches were reviewed by you.
There is one problem with U-Boot SPL for Zynq because one patch break it (not compilation) "board_init: Change the logic to setup malloc_base" (sha1: 9ac4fc82071ce346e3885118242ff45d22f69b82)
There is also one compilation warning from gem driver. I will send the patch to fix it.
Thanks, Michal
The following changes since commit 736d1746fb7b8f7cd70657a4a72db2b6bd8de40e:
itest: add missing break statements to evalexp() (2015-11-18 15:29:00 -0500)
git://www.denx.de/git/u-boot-microblaze.git zynq
for you to fetch changes up to bdaeb8f23c6d5d11829072baaf0c0fe37c09f26a:
common: mii: Do not allow to exceed max phy limit (2015-11-19 14:03:05 +0100)
---------------------------------------------------------------- Edgar E. Iglesias (2): net: phy: Add support for Texas Instruments DP83867 net: zynq: Disable secondary queues
Michal Simek (17): zynqmp: mp: Add support for booting R5 from any address ARM: zynq: Choose boot image based on OF_SEPARATE macro ARM64: zynqmp: Enable TI phy by default net: zynq: Add debug message to phyread/phywrite net: zynq: Add support for different PHY interface types net: zynq: Extend register description with offsets net: zynq: Fix clearing statistic net: zynq: Allocate BD_SPACE in connection to RX_BUF net: zynq: Setup BD when structures are filled net: zynq: Do not report TX underrun net: zynq: Add dummy packet to fix packet duplication issue net: zynq: Wait till packet is sent net: zynq: Fix mdc clock division setting for 100Mbit/s net: zynq: Remove unused MDCCLKDIV2 macro net: zynq: Fix MDC setting for zynq zynq: sdhci: Define max clock by macro common: mii: Do not allow to exceed max phy limit
Nathan Rossi (2): tools: zynqimage: Add Xilinx Zynq boot header generation to mkimage ARM: zynq: Add target for building bootable SPL image for Zynq
Makefile | 3 +++ arch/arm/cpu/armv8/zynqmp/mp.c | 38 ++++++++++++++++++++++++++--- common/cmd_mii.c | 5 ++++ common/image.c | 1 + drivers/mmc/zynq_sdhci.c | 2 +- drivers/net/phy/Makefile | 1 + drivers/net/phy/phy.c | 3 +++ drivers/net/phy/ti.c | 200 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/zynq_gem.c | 143 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------------- include/configs/xilinx_zynqmp.h | 4 +++ include/configs/xilinx_zynqmp_ep.h | 1 + include/configs/zynq-common.h | 3 ++- include/image.h | 3 ++- include/phy.h | 1 + scripts/Makefile.spl | 11 +++++++++ tools/Makefile | 1 + tools/zynqimage.c | 257 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 17 files changed, 638 insertions(+), 39 deletions(-) create mode 100644 drivers/net/phy/ti.c create mode 100644 tools/zynqimage.c
On Thu, Nov 19, 2015 at 03:09:59PM +0100, Michal Simek wrote:
Hi Tom,
Thanks, Michal
Michal Simek
