Re: [U-Boot] [PATCH] serial: Make full device search optional
On Feb 15, 2018 9:00 AM, "Alexander Graf" agraf@suse.de wrote:
On 13.02.18 01:00, Derald Woods wrote:
On Mon, Feb 5, 2018 at 7:13 AM, Derald Woods <woods.technical@gmail.com mailto:woods.technical@gmail.com> wrote:
On Mon, Feb 5, 2018 at 3:42 AM, Alexander Graf <agraf@suse.de <mailto:agraf@suse.de>>wrote: On 05.02.18 01:39, Derald Woods wrote: > On Tue, Jan 30, 2018 at 7:34 AM, Alexander Graf <agraf@suse.de
> <mailto:agraf@suse.de <mailto:agraf@suse.de>>> wrote: > > On 01/30/2018 02:09 PM, Derald Woods wrote: > > On Jan 30, 2018 3:17 AM, "Alexander Graf" <agraf@suse.de
> <mailto:agraf@suse.de <mailto:agraf@suse.de>> <mailto:agraf@suse.de <mailto:agraf@suse.de> > <mailto:agraf@suse.de <mailto:agraf@suse.de>>>> wrote: > > On 01/30/2018 12:41 AM, Derald D. Woods wrote: > > On Mon, Jan 29, 2018 at 07:46:09AM -0600,
Derald Woods
> wrote: > > On Jan 29, 2018 6:57 AM, "Alexander Graf" > <agraf@suse.de <mailto:agraf@suse.de> <mailto:
agraf@suse.de
<mailto:agraf@suse.de>> > <mailto:agraf@suse.de <mailto:agraf@suse.de>
<mailto:agraf@suse.de>>>> wrote: > > Commit 608b0c4ad4e5ec0c ("serial: Use next
serial device
> if probing fails") > added code to search for more serial
devices if the
> default one was not > probed correctly. > > Unfortunately, that breaks omap3_evm. So
while
> investigating why that is > the case, let's disable the full search for
everyone but
> bcm283x where it > is needed. > > Fixes: 608b0c4ad4e5ec0c ("serial: Use next
serial device
> if probing fails") > Reported-by: Derald D. Woods > <woods.technical@gmail.com <mailto:
<mailto:woods.technical@gmail.com <mailto:woods.technical@gmail.com>> > <mailto:woods.technical@gmail.com <mailto:woods.technical@gmail.com> > <mailto:woods.technical@gmail.com <mailto:
woods.technical@gmail.com>>>>
> Signed-off-by: Alexander Graf <agraf@suse.de
> <mailto:agraf@suse.de <mailto:agraf@suse.de>> > <mailto:agraf@suse.de <mailto:agraf@suse.de> <mailto:agraf@suse.de <mailto:agraf@suse.de>>>> > > --- > > Derald, could you please test this patch and verify it > does indeed unbreak > omap3_evm? > > The omap3_evm boots now with this patch applied
on
> master. If > I enable > SERIAL_SEARCH_ALL, it does not boot. I always build cleanly > using the > default config only. On failure, there is no console > input/output and > the board unresponsive. > > > So SPL is already broken? Can you try a known working SPL with > SERIAL_SEARCH_ALL=y U-Boot payload on top? Does that work? > > > I will give that path a try and see what I can discover. Again, > it will be later today or tomorrow before I can get to this. > This is why I asked what should the board code actually look > like. As the omap3_evm is ahead of some other OMAP34XX boards > currently, a good working example would be helpful. If omap3_evm > becomes the example, let's make it a good one. > > > If you want to make it a good example, don't disable > CONFIG_EFI_LOADER :). > > But really, the only major difference I saw between beagle and evm > was the fact that evm used DM in SPL. I patched that up locally (had > to remove ext support as the binary became too big otherwise), but > that didn't show the issue either. So we'll have to wait on your test > s. > > > > It looks like some compiler issue is causing the problem. I was using > GCC 7.2.0. When I go back to GCC 6.4.0 the board boots with > SERIAL_SEARCH_ALL=y. I also verified this by enabling SPL_DM_SERIAL on > 'omap3_beagle' and booting with SERIAL_SEARCH_ALL=y. Both GCC versions > compiled without error. GCC 6.4.0 is the compiler version that
is
> working for me now. The actual offending generated code will take more > time, for me, to sort through. Can you somehow make it break with omap3_beagle? I have one of those and could then help debug. No. Not with the current default configurations. I have both the beagleboard(3530) and beagleboard-xM(3730) at home. Their configuration currently does not enable DM_SERIAL/SPL_DM_SERIAL. I just recently added OF_CONTROL for them on U-Boot master. The code path is different for without DM_SERIAL. Enabling DM_SERIAL will aid in comparison, but will require dropping some config options to make it fit into SRAM. The '-xM' does not have NAND. On the omap3_evm, I enable UBI in the default config. So their are at least a couple of options that would not apply to both beagle variants. There should probably be a separate default config file for each variant. The 3530 beagle variant would/should be identical to the omap3_evm. They are somewhat related from a historical perspective. I will put together an update to the default configurations this week. Once that is done, I will be able to make a true comparison. (omap3_evm has a 3730 variant also) Derald
The issue appears to have been related to the use of CONFIG_SPL_SYS_MALLOC_SIMPLE and CONFIG_SYS_MALLOC_F_LEN in the default config. The RFC patch series is given below:
https://lists.denx.de/pipermail/u-boot/2018-February/320152.html
The BeagleBoard config never attempted to use
CONFIG_SPL_SYS_MALLOC_SIMPLE.
So you're saying it's probably just running out of memory?
Alex
The configuration mix was the key difference. The patch series has the details. The default malloc length set by configuration is actually smaller. So there are likely a mix of factors.
Derald
On 15.02.18 18:02, Derald Woods wrote:
On Feb 15, 2018 9:00 AM, "Alexander Graf" <agraf@suse.de mailto:agraf@suse.de> wrote:
On 13.02.18 01:00, Derald Woods wrote: > On Mon, Feb 5, 2018 at 7:13 AM, Derald Woods <woods.technical@gmail.com <mailto:woods.technical@gmail.com> > <mailto:woods.technical@gmail.com <mailto:woods.technical@gmail.com>>> wrote: > > On Mon, Feb 5, 2018 at 3:42 AM, Alexander Graf <agraf@suse.de <mailto:agraf@suse.de> > <mailto:agraf@suse.de <mailto:agraf@suse.de>>>wrote: > > > > On 05.02.18 01:39, Derald Woods wrote: > > On Tue, Jan 30, 2018 at 7:34 AM, Alexander Graf <agraf@suse.de <mailto:agraf@suse.de> <mailto:agraf@suse.de <mailto:agraf@suse.de>> > > <mailto:agraf@suse.de <mailto:agraf@suse.de> <mailto:agraf@suse.de <mailto:agraf@suse.de>>>> wrote: > > > > On 01/30/2018 02:09 PM, Derald Woods wrote: > > > > On Jan 30, 2018 3:17 AM, "Alexander Graf" <agraf@suse.de <mailto:agraf@suse.de> <mailto:agraf@suse.de <mailto:agraf@suse.de>> > > <mailto:agraf@suse.de <mailto:agraf@suse.de> <mailto:agraf@suse.de <mailto:agraf@suse.de>>> > <mailto:agraf@suse.de <mailto:agraf@suse.de> <mailto:agraf@suse.de <mailto:agraf@suse.de>> > > <mailto:agraf@suse.de <mailto:agraf@suse.de> <mailto:agraf@suse.de <mailto:agraf@suse.de>>>>> wrote: > > > > On 01/30/2018 12:41 AM, Derald D. Woods wrote: > > > > On Mon, Jan 29, 2018 at 07:46:09AM -0600, Derald Woods > > wrote: > > > > On Jan 29, 2018 6:57 AM, "Alexander Graf" > > <agraf@suse.de <mailto:agraf@suse.de> <mailto:agraf@suse.de <mailto:agraf@suse.de>> <mailto:agraf@suse.de <mailto:agraf@suse.de> > <mailto:agraf@suse.de <mailto:agraf@suse.de>>> > > <mailto:agraf@suse.de <mailto:agraf@suse.de> <mailto:agraf@suse.de <mailto:agraf@suse.de>> <mailto:agraf@suse.de <mailto:agraf@suse.de> > <mailto:agraf@suse.de <mailto:agraf@suse.de>>>>> wrote: > > > > Commit 608b0c4ad4e5ec0c ("serial: Use next serial device > > if probing fails") > > added code to search for more serial devices if the > > default one was not > > probed correctly. > > > > Unfortunately, that breaks omap3_evm. So while > > investigating why that is > > the case, let's disable the full search for everyone but > > bcm283x where it > > is needed. > > > > Fixes: 608b0c4ad4e5ec0c ("serial: Use next serial device > > if probing fails") > > Reported-by: Derald D. Woods > > <woods.technical@gmail.com <mailto:woods.technical@gmail.com> <mailto:woods.technical@gmail.com <mailto:woods.technical@gmail.com>> > <mailto:woods.technical@gmail.com <mailto:woods.technical@gmail.com> > <mailto:woods.technical@gmail.com <mailto:woods.technical@gmail.com>>> > > <mailto:woods.technical@gmail.com <mailto:woods.technical@gmail.com> > <mailto:woods.technical@gmail.com <mailto:woods.technical@gmail.com>> > > <mailto:woods.technical@gmail.com <mailto:woods.technical@gmail.com> <mailto:woods.technical@gmail.com <mailto:woods.technical@gmail.com>>>>> > > Signed-off-by: Alexander Graf <agraf@suse.de <mailto:agraf@suse.de> <mailto:agraf@suse.de <mailto:agraf@suse.de>> > > <mailto:agraf@suse.de <mailto:agraf@suse.de> <mailto:agraf@suse.de <mailto:agraf@suse.de>>> > > <mailto:agraf@suse.de <mailto:agraf@suse.de> > <mailto:agraf@suse.de <mailto:agraf@suse.de>> <mailto:agraf@suse.de <mailto:agraf@suse.de> > <mailto:agraf@suse.de <mailto:agraf@suse.de>>>>> > > > > --- > > > > Derald, could you please test this patch > and verify it > > does indeed unbreak > > omap3_evm? > > > > The omap3_evm boots now with this patch applied on > > master. If > > I enable > > SERIAL_SEARCH_ALL, it does not boot. I always > build cleanly > > using the > > default config only. On failure, there is no > console > > input/output and > > the board unresponsive. > > > > > > So SPL is already broken? Can you try a known > working SPL with > > SERIAL_SEARCH_ALL=y U-Boot payload on top? Does > that work? > > > > > > I will give that path a try and see what I can > discover. Again, > > it will be later today or tomorrow before I can get to > this. > > This is why I asked what should the board code > actually look > > like. As the omap3_evm is ahead of some other OMAP34XX > boards > > currently, a good working example would be helpful. If > omap3_evm > > becomes the example, let's make it a good one. > > > > > > If you want to make it a good example, don't disable > > CONFIG_EFI_LOADER :). > > > > But really, the only major difference I saw between beagle > and evm > > was the fact that evm used DM in SPL. I patched that up > locally (had > > to remove ext support as the binary became too big > otherwise), but > > that didn't show the issue either. So we'll have to wait > on your test > > s. > > > > > > > > It looks like some compiler issue is causing the problem. I > was using > > GCC 7.2.0. When I go back to GCC 6.4.0 the board boots with > > SERIAL_SEARCH_ALL=y. I also verified this by enabling > SPL_DM_SERIAL on > > 'omap3_beagle' and booting with SERIAL_SEARCH_ALL=y. Both GCC > versions > > compiled without error. GCC 6.4.0 is the compiler version that is > > working for me now. The actual offending generated code will > take more > > time, for me, to sort through. > > Can you somehow make it break with omap3_beagle? I have one of > those and > could then help debug. > > > > No. Not with the current default configurations. I have both the > beagleboard(3530) and beagleboard-xM(3730) at home. Their > configuration currently does not enable DM_SERIAL/SPL_DM_SERIAL. I > just recently added OF_CONTROL for them on U-Boot master. The code > path is different for without DM_SERIAL. Enabling DM_SERIAL will aid > in comparison, but will require dropping some config options to make > it fit into SRAM. The '-xM' does not have NAND. On the omap3_evm, I > enable UBI in the default config. So their are at least a couple of > options that would not apply to both beagle variants. There should > probably be a separate default config file for each variant. The > 3530 beagle variant would/should be identical to the omap3_evm. They > are somewhat related from a historical perspective. I will put > together an update to the default configurations this week. Once > that is done, I will be able to make a true comparison. (omap3_evm > has a 3730 variant also) > > Derald > > > > The issue appears to have been related to the use of > CONFIG_SPL_SYS_MALLOC_SIMPLE and CONFIG_SYS_MALLOC_F_LEN in the default > config. The RFC patch series is given below: > > https://lists.denx.de/pipermail/u-boot/2018-February/320152.html <https://lists.denx.de/pipermail/u-boot/2018-February/320152.html> > > The BeagleBoard config never attempted to use CONFIG_SPL_SYS_MALLOC_SIMPLE. So you're saying it's probably just running out of memory? Alex
Ah, so you're saying with your changes you can reproduce the problem on the beagleboard?
I still fail to see the exact connection between the serial bug and the patch set :)
Alex
Alexander Graf
Derald Woods
