[U-Boot] [PULL] u-boot-stm32 for v2019.07 (round 5)
Hi Tom
This pull request include 6 series for the stm32mp157 support in U-Boot: _ Add watchdog support for STM32MP1 : http://patchwork.ozlabs.org/user/todo/uboot/?series=105424
_ Add SPI driver suport for STM32MP1 : http://patchwork.ozlabs.org/user/todo/uboot/?series=105432
_ board: stm32mp1: Update power supply check via USB TYPE-C : http://patchwork.ozlabs.org/user/todo/uboot/?series=105434
_ Add Avenger96 board support : http://patchwork.ozlabs.org/user/todo/uboot/?series=105679
_ Add saveenv support for STM32MP1 : http://patchwork.ozlabs.org/user/todo/uboot/?series=107249
_ Add Ethernet support for stm32mpu : http://patchwork.ozlabs.org/user/todo/uboot/?series=108401
Travis CI status: https://travis-ci.org/pchotard/u-boot/builds/542350853?utm_medium=notificati...
The following changes since commit 2253e40caef5b45bcae2ccdb238f9cf037eefc0b:
Merge branch '2019-06-05-master-imports' (2019-06-05 15:49:09 -0400)
https://github.com/pchotard/u-boot.git tags/u-boot-stm32-20190606
for you to fetch changes up to f90b3f5b68ed5e8d7f84aba0550d24326693524d:
configs: stm32mp15: Enable Ethernet feature (2019-06-06 17:40:19 +0200)
---------------------------------------------------------------- - Add Ethernet support for STM32MP1 - Add saveenv support for STM32MP1 - Add STM32MP1 Avenger96 board support - Add SPI driver suport for STM32MP1 - Add watchdog support for STM32MP1 - Update power supply check via USB TYPE-C for STM32MP1 discovery board
---------------------------------------------------------------- Christophe Roullier (5): board: stm32mp1: Add board_interface_eth_init net: dwc_eth_qos: add Ethernet stm32mp1 support ARM: dts: stm32: Add Ethernet support on stm32mp1 stm32mp1: Add Ethernet support for stm32mp1 board configs: stm32mp15: Enable Ethernet feature
Manivannan Sadhasivam (3): arm: dts: stm32mp157: Add missing pinctrl definitions board: stm32mp1: Add Avenger96 board support arm: mach-stm32mp: Add newline to the MAC error message
Patrice Chotard (18): stm32mp1: support dynamic MTDPARTS env: ext4: Allow overriding interface, device and partition board: stm32mp1: Add env_ext4_get_dev_part() and env_ext4_get_intf() env: allow ENV_IS_NOWHERE with other storage target stm32mp1: Add env_get_location() mtd: Fix get_mtdparts() stm32mp1: Increase ENV_SIZE configs: stm32mp15: Enable ENV_IS_IN_UBI configs: stm32mp15: Enable ENV_IS_SPI_FLASH stm32mp1: Update env_get_location for NOR support watchdog: Kconfig: Sort entry alphabetically ARM: dts: stm32mp: Add iwdg2 support for stm32mp157c watchdog: stm32mp: Add watchdog driver configs: stm32mp15: Enable WDT flags board: stm32mp1: Update power supply check via USB TYPE-C clk: stm32mp1: Add SPI1 clock entry spi: stm32: Add Serial Peripheral Interface driver for STM32MP configs: stm32mp15: Enable SPI relative flags
Patrick Delaunay (4): stm32mp1: activate NAND and NOR support on EV1 env: enable saveenv command when one CONFIG_ENV_IS_IN is activated configs: stm32mp15: Enable ENV_IS_IN_EXT4 and all relative flags stm32mp1: clk: use the correct identifier for ethck
MAINTAINERS | 2 + arch/arm/dts/Makefile | 1 + arch/arm/dts/stm32mp157-pinctrl.dtsi | 116 ++++- arch/arm/dts/stm32mp157-u-boot.dtsi | 4 + arch/arm/dts/stm32mp157a-avenger96-u-boot.dtsi | 191 ++++++++ arch/arm/dts/stm32mp157a-avenger96.dts | 362 +++++++++++++++ arch/arm/dts/stm32mp157c-ev1.dts | 18 +- arch/arm/dts/stm32mp157c.dtsi | 31 +- arch/arm/mach-stm32mp/Kconfig | 3 +- arch/arm/mach-stm32mp/cpu.c | 2 +- board/st/stm32mp1/README | 23 + board/st/stm32mp1/stm32mp1.c | 273 ++++++++++- cmd/nvedit.c | 36 +- configs/stm32mp15_basic_defconfig | 33 ++ configs/stm32mp15_trusted_defconfig | 33 ++ drivers/clk/clk_stm32mp1.c | 9 +- drivers/mtd/mtd_uboot.c | 5 +- drivers/net/dwc_eth_qos.c | 435 ++++++++++++++--- drivers/spi/Kconfig | 8 + drivers/spi/Makefile | 1 + drivers/spi/stm32_spi.c | 615 +++++++++++++++++++++++++ drivers/watchdog/Kconfig | 101 ++-- drivers/watchdog/Makefile | 1 + drivers/watchdog/stm32mp_wdt.c | 135 ++++++ env/Kconfig | 18 +- env/ext4.c | 34 +- include/configs/stm32mp1.h | 33 +- 27 files changed, 2352 insertions(+), 171 deletions(-) create mode 100644 arch/arm/dts/stm32mp157a-avenger96-u-boot.dtsi create mode 100644 arch/arm/dts/stm32mp157a-avenger96.dts create mode 100644 drivers/spi/stm32_spi.c create mode 100644 drivers/watchdog/stm32mp_wdt.c
On Tue, Jun 11, 2019 at 07:22:42AM +0000, Patrice CHOTARD wrote:
Hi Tom
Patrice CHOTARD
