[U-Boot] [PATCH v3 1/4] sf: ops: Unify read_ops bank configuration
Unified the bar code from read_ops into a spi_flash_bar()
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- drivers/mtd/spi/sf_ops.c | 13 +++++-------- 1 file changed, 5 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index af345fe..d039cc5 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -127,7 +127,7 @@ static int spi_flash_bank(struct spi_flash *flash, u32 offset) return ret; }
- return 0; + return bank_sel; } #endif
@@ -321,8 +321,9 @@ int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, size_t len, void *data) { - u8 *cmd, bank_sel = 0; + u8 *cmd; u32 remain_len, read_len; + int bank_sel = 0; int ret = -1;
/* Handle memory-mapped SPI */ @@ -345,13 +346,9 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset,
while (len) { #ifdef CONFIG_SPI_FLASH_BAR - bank_sel = offset / SPI_FLASH_16MB_BOUN; - - ret = spi_flash_cmd_bankaddr_write(flash, bank_sel); - if (ret) { - debug("SF: fail to set bank%d\n", bank_sel); + bank_sel = spi_flash_bank(flash, offset); + if (bank_sel < 0) return ret; - } #endif remain_len = (SPI_FLASH_16MB_BOUN * (bank_sel + 1)) - offset; if (len < remain_len)
