[U-Boot] [PATCH 0/6] Blackfin fixes for 2009.08
A few fixes and tweaks to use latest code in master.
Mike Frysinger (4): Blackfin: bf548-ezkit: bump up monitor size Blackfin: enable -O2 in lib_generic/ for ADI/Bluetechnix boards Blackfin: fix SPI flash speed define name Blackfin: move ALL += u-boot.ldr to blackfin_config.mk
Vivi Li (2): Blackfin: bump up default JTAG console timeout Blackfin: bf533-stamp/bf537-stamp: fix env settings for SPI flash
Makefile | 4 +--- blackfin_config.mk | 6 ++++-- board/bf518f-ezbrd/config.mk | 3 +++ board/bf526-ezbrd/config.mk | 3 +++ board/bf527-ezkit/config.mk | 3 +++ board/bf533-ezkit/config.mk | 3 +++ board/bf533-stamp/config.mk | 3 +++ board/bf537-stamp/config.mk | 3 +++ board/bf538f-ezkit/config.mk | 3 +++ board/bf548-ezkit/config.mk | 3 +++ board/bf561-ezkit/config.mk | 3 +++ board/cm-bf527/config.mk | 3 +++ board/cm-bf533/config.mk | 3 +++ board/cm-bf537e/config.mk | 3 +++ board/cm-bf548/config.mk | 3 +++ board/cm-bf561/config.mk | 3 +++ board/tcm-bf537/config.mk | 3 +++ cpu/blackfin/jtag-console.c | 2 +- include/configs/bf518f-ezbrd.h | 2 +- include/configs/bf526-ezbrd.h | 2 +- include/configs/bf527-ezkit.h | 2 +- include/configs/bf533-stamp.h | 6 +++--- include/configs/bf537-minotaur.h | 2 +- include/configs/bf537-pnav.h | 2 +- include/configs/bf537-srv1.h | 2 +- include/configs/bf537-stamp.h | 6 +++--- include/configs/bf538f-ezkit.h | 2 +- include/configs/bf548-ezkit.h | 4 ++-- include/configs/blackstamp.h | 2 +- 29 files changed, 67 insertions(+), 22 deletions(-)
The debug tools that interface with the other side of the JTAG console got much slower when generalizing things, so bump up the default timeout value on the U-Boot side to cope. Hopefully at some point we can improve the debug tools to speed things back up.
Signed-off-by: Vivi Li vivi.li@analog.com Signed-off-by: Mike Frysinger vapier@gentoo.org --- cpu/blackfin/jtag-console.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/cpu/blackfin/jtag-console.c b/cpu/blackfin/jtag-console.c index d58582f..c995d96 100644 --- a/cpu/blackfin/jtag-console.c +++ b/cpu/blackfin/jtag-console.c @@ -11,7 +11,7 @@ #include <asm/blackfin.h>
#ifndef CONFIG_JTAG_CONSOLE_TIMEOUT -# define CONFIG_JTAG_CONSOLE_TIMEOUT 100 +# define CONFIG_JTAG_CONSOLE_TIMEOUT 500 #endif
/* The Blackfin tends to be much much faster than the JTAG hardware. */
The current kallsyms code is using \0 to escape the backslash in the awk code, but the shell too needs escaping. This way we make sure gcc is passed the \0. Then gcc itself will consume this as an octal, so we have to use 000 so gcc will create the final NUL.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- Makefile | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/Makefile b/Makefile index d01cc48..8471828 100644 --- a/Makefile +++ b/Makefile @@ -312,7 +312,7 @@ GEN_UBOOT = \ $(obj)u-boot: depend $(SUBDIRS) $(OBJS) $(LIBBOARD) $(LIBS) $(LDSCRIPT) $(GEN_UBOOT) ifeq ($(CONFIG_KALLSYMS),y) - smap=`$(call SYSTEM_MAP,u-boot) | awk '$$2 ~ /[tTwW]/ {printf $$1 $$3 "\0"}'` ; \ + smap=`$(call SYSTEM_MAP,u-boot) | awk '$$2 ~ /[tTwW]/ {printf $$1 $$3 "\\000"}'` ; \ $(CC) $(CFLAGS) -DSYSTEM_MAP=""$${smap}"" -c common/system_map.c -o $(obj)common/system_map.o $(GEN_UBOOT) $(obj)common/system_map.o endif
erp, globbed too many files when sending out -mike
Dear Mike Frysinger,
What does that mean?
it means this patch isnt part of this small series -mike
Ah, OK - but the patch as submitted is ok, right?
yeah, the patch should be merged :) -mike
Applied, thanks.
The SPI flash layer is much stricter about sector usage than the eeprom layer we used to use, so update the env settings to better match the sector alignment of the flashes we use.
Signed-off-by: Vivi Li vivi.li@analog.com Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/configs/bf533-stamp.h | 4 ++-- include/configs/bf537-stamp.h | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index 579540e..9b22f2d 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -102,9 +102,9 @@ */ #if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_SPI_MASTER) #define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_OFFSET 0x4000 +#define CONFIG_ENV_OFFSET 0x10000 #define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x10000 #else #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OFFSET 0x4000 diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index e883f2e..8e06844 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -100,9 +100,9 @@ */ #if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_SPI_MASTER) #define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_OFFSET 0x4000 +#define CONFIG_ENV_OFFSET 0x10000 #define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x10000 #else #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OFFSET 0x4000
The latest version of U-Boot got a bit fatter in the BSS section which caused overflows in the RAM region, so increase the monitor size.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/configs/bf548-ezkit.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/bf548-ezkit.h b/include/configs/bf548-ezkit.h index 4e2ee62..fa90f91 100644 --- a/include/configs/bf548-ezkit.h +++ b/include/configs/bf548-ezkit.h @@ -61,7 +61,7 @@ #define CONFIG_EBIU_FCTL_VAL (BCLK_4) #define CONFIG_EBIU_MODE_VAL (B0MODE_FLASH)
-#define CONFIG_SYS_MONITOR_LEN (768 * 1024) +#define CONFIG_SYS_MONITOR_LEN (1024 * 1024) #define CONFIG_SYS_MALLOC_LEN (768 * 1024)
Building the compression code in lib_generic/ with -O2 rather than -Os gives a nice speed boost without too much code size increase.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf518f-ezbrd/config.mk | 3 +++ board/bf526-ezbrd/config.mk | 3 +++ board/bf527-ezkit/config.mk | 3 +++ board/bf533-ezkit/config.mk | 3 +++ board/bf533-stamp/config.mk | 3 +++ board/bf537-stamp/config.mk | 3 +++ board/bf538f-ezkit/config.mk | 3 +++ board/bf548-ezkit/config.mk | 3 +++ board/bf561-ezkit/config.mk | 3 +++ board/cm-bf527/config.mk | 3 +++ board/cm-bf533/config.mk | 3 +++ board/cm-bf537e/config.mk | 3 +++ board/cm-bf548/config.mk | 3 +++ board/cm-bf561/config.mk | 3 +++ board/tcm-bf537/config.mk | 3 +++ 15 files changed, 45 insertions(+), 0 deletions(-)
diff --git a/board/bf518f-ezbrd/config.mk b/board/bf518f-ezbrd/config.mk index eaa09ff..f85bef5 100644 --- a/board/bf518f-ezbrd/config.mk +++ b/board/bf518f-ezbrd/config.mk @@ -26,5 +26,8 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/bf526-ezbrd/config.mk b/board/bf526-ezbrd/config.mk index eaa09ff..f85bef5 100644 --- a/board/bf526-ezbrd/config.mk +++ b/board/bf526-ezbrd/config.mk @@ -26,5 +26,8 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/bf527-ezkit/config.mk b/board/bf527-ezkit/config.mk index eaa09ff..f85bef5 100644 --- a/board/bf527-ezkit/config.mk +++ b/board/bf527-ezkit/config.mk @@ -26,5 +26,8 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/bf533-ezkit/config.mk b/board/bf533-ezkit/config.mk index 9847924..3c0b46f 100644 --- a/board/bf533-ezkit/config.mk +++ b/board/bf533-ezkit/config.mk @@ -26,6 +26,9 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/bf533-stamp/config.mk b/board/bf533-stamp/config.mk index 9847924..3c0b46f 100644 --- a/board/bf533-stamp/config.mk +++ b/board/bf533-stamp/config.mk @@ -26,6 +26,9 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/bf537-stamp/config.mk b/board/bf537-stamp/config.mk index d9e884e..bc14257 100644 --- a/board/bf537-stamp/config.mk +++ b/board/bf537-stamp/config.mk @@ -26,6 +26,9 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 LDR_FLAGS-BFIN_BOOT_UART := --port g --gpio 6 diff --git a/board/bf538f-ezkit/config.mk b/board/bf538f-ezkit/config.mk index 9847924..3c0b46f 100644 --- a/board/bf538f-ezkit/config.mk +++ b/board/bf538f-ezkit/config.mk @@ -26,6 +26,9 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/bf548-ezkit/config.mk b/board/bf548-ezkit/config.mk index 95ab6b3..42ff946 100644 --- a/board/bf548-ezkit/config.mk +++ b/board/bf548-ezkit/config.mk @@ -26,6 +26,9 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --dma 6 LDR_FLAGS-BFIN_BOOT_FIFO := --dma 1 diff --git a/board/bf561-ezkit/config.mk b/board/bf561-ezkit/config.mk index 77c888b..cfad21a 100644 --- a/board/bf561-ezkit/config.mk +++ b/board/bf561-ezkit/config.mk @@ -26,6 +26,9 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/cm-bf527/config.mk b/board/cm-bf527/config.mk index eaa09ff..f85bef5 100644 --- a/board/cm-bf527/config.mk +++ b/board/cm-bf527/config.mk @@ -26,5 +26,8 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/cm-bf533/config.mk b/board/cm-bf533/config.mk index 9847924..3c0b46f 100644 --- a/board/cm-bf533/config.mk +++ b/board/cm-bf533/config.mk @@ -26,6 +26,9 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/cm-bf537e/config.mk b/board/cm-bf537e/config.mk index 9847924..3c0b46f 100644 --- a/board/cm-bf537e/config.mk +++ b/board/cm-bf537e/config.mk @@ -26,6 +26,9 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/cm-bf548/config.mk b/board/cm-bf548/config.mk index 396f20a..0c95b39 100644 --- a/board/cm-bf548/config.mk +++ b/board/cm-bf548/config.mk @@ -26,6 +26,9 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --dma 6 LDR_FLAGS-BFIN_BOOT_FIFO := --dma 1 diff --git a/board/cm-bf561/config.mk b/board/cm-bf561/config.mk index 77c888b..cfad21a 100644 --- a/board/cm-bf561/config.mk +++ b/board/cm-bf561/config.mk @@ -26,6 +26,9 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
+CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/tcm-bf537/config.mk b/board/tcm-bf537/config.mk index 9847924..3c0b46f 100644 --- a/board/tcm-bf537/config.mk +++ b/board/tcm-bf537/config.mk @@ -26,6 +26,9 @@ # This is not actually used for Blackfin boards so do not change it #TEXT_BASE = do-not-use-me
The SPI flash define is named CONFIG_SF_DEFAULT_SPEED, not CONFIG_SF_DEFAULT_HZ, so fix the typos in the Blackfin boards.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/configs/bf518f-ezbrd.h | 2 +- include/configs/bf526-ezbrd.h | 2 +- include/configs/bf527-ezkit.h | 2 +- include/configs/bf533-stamp.h | 2 +- include/configs/bf537-minotaur.h | 2 +- include/configs/bf537-pnav.h | 2 +- include/configs/bf537-srv1.h | 2 +- include/configs/bf537-stamp.h | 2 +- include/configs/bf538f-ezkit.h | 2 +- include/configs/bf548-ezkit.h | 2 +- include/configs/blackstamp.h | 2 +- 11 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/include/configs/bf518f-ezbrd.h b/include/configs/bf518f-ezbrd.h index bc7ac5d..3db8171 100644 --- a/include/configs/bf518f-ezbrd.h +++ b/include/configs/bf518f-ezbrd.h @@ -88,7 +88,7 @@ */ #define CONFIG_BFIN_SPI #define CONFIG_ENV_SPI_MAX_HZ 30000000 -#define CONFIG_SF_DEFAULT_HZ 30000000 +#define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_SST #define CONFIG_SPI_FLASH_STMICRO diff --git a/include/configs/bf526-ezbrd.h b/include/configs/bf526-ezbrd.h index db68a7b..97853af 100644 --- a/include/configs/bf526-ezbrd.h +++ b/include/configs/bf526-ezbrd.h @@ -106,7 +106,7 @@ */ #define CONFIG_BFIN_SPI #define CONFIG_ENV_SPI_MAX_HZ 30000000 -#define CONFIG_SF_DEFAULT_HZ 30000000 +#define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_SST
diff --git a/include/configs/bf527-ezkit.h b/include/configs/bf527-ezkit.h index f481c79..0d02354 100644 --- a/include/configs/bf527-ezkit.h +++ b/include/configs/bf527-ezkit.h @@ -105,7 +105,7 @@ */ #define CONFIG_BFIN_SPI #define CONFIG_ENV_SPI_MAX_HZ 30000000 -#define CONFIG_SF_DEFAULT_HZ 30000000 +#define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_STMICRO
diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index 9b22f2d..c03561c 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -89,7 +89,7 @@ */ #define CONFIG_BFIN_SPI #define CONFIG_ENV_SPI_MAX_HZ 30000000 -#define CONFIG_SF_DEFAULT_HZ 30000000 +#define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_ATMEL #define CONFIG_SPI_FLASH_SPANSION diff --git a/include/configs/bf537-minotaur.h b/include/configs/bf537-minotaur.h index b01197b..23c2d33 100644 --- a/include/configs/bf537-minotaur.h +++ b/include/configs/bf537-minotaur.h @@ -104,7 +104,7 @@ */ #define CONFIG_BFIN_SPI #define CONFIG_ENV_SPI_MAX_HZ 30000000 -#define CONFIG_SF_DEFAULT_HZ 30000000 +#define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_STMICRO
diff --git a/include/configs/bf537-pnav.h b/include/configs/bf537-pnav.h index 284c7fc..0f908ef 100644 --- a/include/configs/bf537-pnav.h +++ b/include/configs/bf537-pnav.h @@ -85,7 +85,7 @@ */ #define CONFIG_BFIN_SPI #define CONFIG_ENV_SPI_MAX_HZ 30000000 -#define CONFIG_SF_DEFAULT_HZ 30000000 +#define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_STMICRO
diff --git a/include/configs/bf537-srv1.h b/include/configs/bf537-srv1.h index c1bff3e..727b7e7 100644 --- a/include/configs/bf537-srv1.h +++ b/include/configs/bf537-srv1.h @@ -104,7 +104,7 @@ */ #define CONFIG_BFIN_SPI #define CONFIG_ENV_SPI_MAX_HZ 30000000 -#define CONFIG_SF_DEFAULT_HZ 30000000 +#define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_STMICRO
diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index 8e06844..0a86e83 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -87,7 +87,7 @@ */ #define CONFIG_BFIN_SPI #define CONFIG_ENV_SPI_MAX_HZ 30000000 -#define CONFIG_SF_DEFAULT_HZ 30000000 +#define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_ATMEL #define CONFIG_SPI_FLASH_SPANSION diff --git a/include/configs/bf538f-ezkit.h b/include/configs/bf538f-ezkit.h index 91622e3..535687f 100644 --- a/include/configs/bf538f-ezkit.h +++ b/include/configs/bf538f-ezkit.h @@ -83,7 +83,7 @@ */ #define CONFIG_BFIN_SPI #define CONFIG_ENV_SPI_MAX_HZ 30000000 -#define CONFIG_SF_DEFAULT_HZ 30000000 +#define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_ATMEL #define CONFIG_SPI_FLASH_SPANSION diff --git a/include/configs/bf548-ezkit.h b/include/configs/bf548-ezkit.h index fa90f91..dbcd2af 100644 --- a/include/configs/bf548-ezkit.h +++ b/include/configs/bf548-ezkit.h @@ -93,7 +93,7 @@ */ #define CONFIG_BFIN_SPI #define CONFIG_ENV_SPI_MAX_HZ 30000000 -#define CONFIG_SF_DEFAULT_HZ 30000000 +#define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_STMICRO
diff --git a/include/configs/blackstamp.h b/include/configs/blackstamp.h index 9cbc17a..1e4c716 100644 --- a/include/configs/blackstamp.h +++ b/include/configs/blackstamp.h @@ -247,7 +247,7 @@ #define CONFIG_BFIN_SPI /* For the M25P64 SCK Should be Kept < 20Mhz */ #define CONFIG_ENV_SPI_MAX_HZ 20000000 -#define CONFIG_SF_DEFAULT_HZ 20000000 +#define CONFIG_SF_DEFAULT_SPEED 20000000 #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_STMICRO
The way the ALL variable is used allows for config.mk's to add more targets themselves without having to clutter up the top level Makefile.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- Makefile | 4 +--- blackfin_config.mk | 6 ++++-- 2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/Makefile b/Makefile index acec1a0..bcc81c9 100644 --- a/Makefile +++ b/Makefile @@ -306,10 +306,8 @@ __LIBS := $(subst $(obj),,$(LIBS)) $(subst $(obj),,$(LIBBOARD)) ######################################################################### #########################################################################
+# Always append ALL so that arch config.mk's can add custom ones ALL += $(obj)u-boot.srec $(obj)u-boot.bin $(obj)System.map $(U_BOOT_NAND) $(U_BOOT_ONENAND) -ifeq ($(ARCH),blackfin) -ALL += $(obj)u-boot.ldr -endif
all: $(ALL)
diff --git a/blackfin_config.mk b/blackfin_config.mk index 989e976..821f082 100644 --- a/blackfin_config.mk +++ b/blackfin_config.mk @@ -36,6 +36,10 @@ ifneq (,$(CONFIG_BFIN_CPU)) PLATFORM_RELFLAGS += -mcpu=$(CONFIG_BFIN_CPU) endif
+ifneq ($(CONFIG_BFIN_BOOT_MODE),BFIN_BOOT_BYPASS) +ALL += $(obj)u-boot.ldr +endif + SYM_PREFIX = _
LDR_FLAGS-y := @@ -43,14 +47,12 @@ LDR_FLAGS-$(CONFIG_BFIN_BOOTROM_USES_EVT1) += -J
LDR_FLAGS += --bmode $(subst BFIN_BOOT_,,$(CONFIG_BFIN_BOOT_MODE)) LDR_FLAGS += --use-vmas -ifneq ($(CONFIG_BFIN_BOOT_MODE),BFIN_BOOT_BYPASS) LDR_FLAGS += --initcode $(obj)cpu/$(CPU)/initcode.o ifneq ($(CONFIG_BFIN_BOOT_MODE),BFIN_BOOT_UART) ifneq ($(ENV_IS_EMBEDDED_CUSTOM),ENV_IS_EMBEDDED_CUSTOM) LDR_FLAGS += --punchit $$(($(CONFIG_ENV_OFFSET))):$$(($(CONFIG_ENV_SIZE))):$(obj)env-ldr.o endif endif -endif ifneq (,$(findstring s,$(MAKEFLAGS))) LDR_FLAGS += --quiet endif
Mike Frysinger
