[U-Boot] Ramdisk - allocation error
Hi, I am using ppc440 based customised board. While running the u-boot linux kernel uncompressed successfully but ramdisk end-up with following error: ERROR: Failed to allocate 0x800000 bytes below 0xffffffff. ramdisk - allocation error Regards,
Ronny D.
Dear Ronny D,
Which exact version of U-Boot are you running? And which board configuration is this? Is this mainline code, or some out-of-tree port?
Please provide the complete boot log with all commands you entered, full, information about Linux kernel and ramdisk image (Output of the respective "iminfo" commands), and all U-Boot messages.
I am using u-boot 2009.08 version. Issue has been resolved. Problem: I am using Dma to initialize DDR and minidma required cache bit enable for DDR, because of cache enabled I was getting lmb->memory.region[i].size = 0 and end-up with an error "ramdisk - allocation error" Solution: I have disabled the DDR cache just after DDR initialization by DMA.
--- On Thu, 23/9/10, Wolfgang Denk wd@denx.de wrote:
From: Wolfgang Denk wd@denx.de Subject: Re: Ramdisk - allocation error To: "Ronny D" ronny_d37@yahoo.com Cc: "Stefan Roese" sr@denx.de, "U-boot" u-boot@lists.denx.de Date: Thursday, 23 September, 2010, 9:41 AM
Dear Ronny D,
Ronny D
