[U-Boot] Dynamically sized CFI flash.
I'm porting support for a Phytec PCM030 (mpc5200) from 1.2 up to current head so that I can get it merged. These boards can be populated with a variety of flash chips, there is code to compute the size of these chips and fix up bank_base[] in cfi_flash.c In u-boot 1.3.4 bank_base[] was rewritten. What is the correct way to do these calculations?
extern ulong bank_base[CFG_MAX_FLASH_BANKS];
int board_early_init_r (void) { int width, id; ulong mb, dev_size; ulong base = 0xff000000; ulong lpb;
lpb = *(vu_long *)MPC5XXX_LPB;
*(vu_long *)MPC5XXX_BOOTCS_START = START_REG(base); *(vu_long *)MPC5XXX_BOOTCS_STOP = STOP_REG(base, 16 * 1024 * 1024); /* * we run the PCI bus with 33 1/3 MHz. The flash requires 75ns accesstime. * 2 base waitstates plus one additional waitstate makes the access as fast * as possible (=90ns) */ lpb &= 0x0000dfc0; /* make it writable and mask out wait stages */ lpb |= 0x0001d000; /* adjust wait stages */ *(vu_long *)MPC5XXX_LPB = lpb;
/* get flash width */ width = (lpb >> 8) & 0x3;
switch (width) { case 0: /* 8 bit */ *(vu_char *)base = 0x90; id = *(vu_char *)(base + 3); *(vu_char *)base = 0xff; break; case 1: /* 16 bit */ *(vu_short *)base = 0x90; id = *(vu_short *)(base + 2) & 0xff; *(vu_short *)base = 0xff; break; case 3: /* 32 bit */ *(vu_short *)base = 0x90; id = *(vu_short *)(base + 4) & 0xff; *(vu_short *)base = 0xff; break; }
switch (id) { case 0x16: mb = 4; break; case 0x17: mb = 8; break; case 0x18: mb = 16; break; case 0x20: mb = 8; break; case 0x21: mb = 16; break; case 0x22: mb = 32; break; }
/* On these boards everything which is 32bit wide consists * of two 16bit Flashes */ if (width == 3) mb <<= 1;
/* * On this platform one chip select can only handle up to 32MiB. * So we must limit boot cs's baseaddress to 0xfe000000 and above */ if (mb > 32) dev_size = 32; else dev_size = mb;
*(vu_long *)MPC5XXX_BOOTCS_START = START_REG(0x0u - (dev_size << 20)); *(vu_long *)MPC5XXX_BOOTCS_STOP = STOP_REG(0x0u - (dev_size << 20), (dev_size << 20));
/* * the developer is responsible to setup other chip select lines to * reach other parts of the device if its larger than 32MiB */ bank_base[0] = 0x0u - (mb << 20);
return 0; }
Hello Jon,
I suggest to activate CONFIG_SYS_UPDATE_FLASH_SIZE Then you get the update_flash_size (int flash_size) function called after the cfi driver counted the flash size.
examples: [hs@pollux u-boot]$ grep -lr update_flash_size . ./board/jupiter/jupiter.c ./board/tqc/tqm8272/tqm8272.c ./lib_ppc/board.c [hs@pollux u-boot]$
bye Heiko
Sascha, didn't you write this?
I see how to add update_flash_size(). But how is update_flash_size() going to know the size if it doesn't know where the flash starts? Don't I need this code that manipulate bootcs to determine the starting address of the flash?
lpb = *(vu_long *)MPC5XXX_LPB; *(vu_long *)MPC5XXX_BOOTCS_START = START_REG(base); *(vu_long *)MPC5XXX_BOOTCS_STOP = STOP_REG(base, 16 * 1024 * 1024); /* * we run the PCI bus with 33 1/3 MHz. The flash requires 75ns accesstime. * 2 base waitstates plus one additional waitstate makes the access as fast * as possible (=90ns) */ lpb &= 0x0000dfc0; /* make it writable and mask out wait stages */ lpb |= 0x0001d000; /* adjust wait stages */ *(vu_long *)MPC5XXX_LPB = lpb; /* get flash width */ width = (lpb >> 8) & 0x3; switch (width) { case 0: /* 8 bit */ *(vu_char *)base = 0x90; id = *(vu_char *)(base + 3); *(vu_char *)base = 0xff; break; case 1: /* 16 bit */ *(vu_short *)base = 0x90; id = *(vu_short *)(base + 2) & 0xff; *(vu_short *)base = 0xff; break; case 3: /* 32 bit */ *(vu_short *)base = 0x90; id = *(vu_short *)(base + 4) & 0xff; *(vu_short *)base = 0xff; break; } switch (id) { case 0x16: mb = 4; break; case 0x17: mb = 8; break; case 0x18: mb = 16; break; case 0x20: mb = 8; break; case 0x21: mb = 16; break; case 0x22: mb = 32; break; } /* On these boards everything which is 32bit wide consists * of two 16bit Flashes */ if (width == 3) mb <<= 1; /* * On this platform one chip select can only handle up to 32MiB. * So we must limit boot cs's baseaddress to 0xfe000000 and above */ if (mb > 32) dev_size = 32; else dev_size = mb; *(vu_long *)MPC5XXX_BOOTCS_START = START_REG(0x0u - (dev_size << 20)); *(vu_long *)MPC5XXX_BOOTCS_STOP = STOP_REG(0x0u - (dev_size << 20),
(dev_size << 20));
/* * the developer is responsible to setup other chip select lines to * reach other parts of the device if its larger than 32MiB */ bank_base[0] = 0x0u - (mb << 20); return 0;
-- Jon Smirl jonsmirl@gmail.com
Heiko Schocher
Jon Smirl
