[PATCH] mmc: Do not send status of send_status is false
Commit 44645f87de5 ("mmc: Fix mmc_switch excessive timeout") introduced a side effect where CMD13 SEND_STATUS is issued in case mmc_wait_dat0() does not return -ENOSYS and $send_status is not set. This happens on all hardware which does implement .mmc_wait_dat0 callback, e.g. i.MX8M .
This leads to lengthy timeout before booting OS in case of eMMC in one of the HS200/HS400 modes, since the card cannot respond to CMD13 while downgrading from HS200/HS400 to regular HS mode.
Fix this by adding the missing conditional.
Fixes: 44645f87de5 ("mmc: Fix mmc_switch excessive timeout") Signed-off-by: Marek Vasut marex@denx.de Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Kirill Kapranov kirill.kapranov@compulab.co.il Cc: Marek Behún marek.behun@nic.cz Cc: Pantelis Antoniou panto@antoniou-consulting.com Cc: Ye Li ye.li@nxp.com --- drivers/mmc/mmc.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 12d29da528a..b62baca8457 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -831,6 +831,9 @@ static int __mmc_switch(struct mmc *mmc, u8 set, u8 index, u8 value, return 0; }
+ if (!send_status) + return 0; + /* Finally wait until the card is ready or indicates a failure * to switch. It doesn't hurt to use CMD13 here even if send_status * is false, because by now (after 'timeout_ms' ms) the bus should be
Does the lenghty timeout occur even on xenon with the patch https://source.denx.de/u-boot/u-boot/-/commit/0f3466f52fbacce67e147b9234e632... ?
Marek
Unlikely, you will get -ENOSYS from wait on dat0 and bail out, i.e. you'd hit the condition before this one because wait on dat0 is not implemented.
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- if (!send_status)
- /* Finally wait until the card is ready or indicates a failure
- to switch. It doesn't hurt to use CMD13 here even if send_status
- is false, because by now (after 'timeout_ms' ms) the bus should be
Fixes: 44645f87de5 ("mmc: Fix mmc_switch excessive timeout") Signed-off-by: Marek Vasut marex@denx.de Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Kirill Kapranov kirill.kapranov@compulab.co.il Cc: Marek Behún marek.behun@nic.cz Cc: Pantelis Antoniou panto@antoniou-consulting.com Cc: Ye Li ye.li@nxp.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Jaehoon Chung
Marek Behún
