[GIT PULL] xilinx patches for v2023.01-rc1 (round 2)
Hi Tom,
please pull the following patches to your tree. It is the second round with small updates but especially adding new Xilinx SOC. CI loop doesn't show any issue.
Thanks, Michal
The following changes since commit ebdd6afa543324648138f780a648b8fb65d488eb:
Merge branch 'next' of https://source.denx.de/u-boot/custodians/u-boot-marvell into next (2022-09-20 08:50:07 -0400)
git@source.denx.de:u-boot/custodians/u-boot-microblaze.git tags/xilinx-for-v2023.01-rc1-v2
for you to fetch changes up to f2641f066b53a2bbb933bccffd696a875fd9adf5:
arm64: versal-net: Add support for mini configuration (2022-09-26 14:23:30 +0200)
---------------------------------------------------------------- Xilinx changes for v2023.01-rc1 (round 2)
xilinx: - Add support for new Versal NET SOC
zynqmp: - Use mdio bus for ethernet phy description - Wire ethernet phy reset via i2c-gpio
versal: - Config cleanup
---------------------------------------------------------------- Jay Buddhabhatti (4): clk: versal: Enable clock driver for Versal NET firmware: zynqmp: Add Versal NET compatible string mailbox: zynqmp: Enable ipi mailbox driver for Versal NET reset: zynqmp: Enable reset driver for Versal NET
Michal Simek (8): xilinx: versal: Remove unused comments from xilinx_versal.h arm64: zynqmp: Describe TI phy as ethernet-phy-id arm64: zynqmp: Wire GEM reset gpio arm64: versal-net: Add support for Versal NET platform spi: cadence_qspi: Add support for Versal NET platform spi: zynqmp_gqspi: Add support for Versal NET arm64: versal-net: Add defconfig for Versal NET arm64: versal-net: Add support for mini configuration
Kconfig | 2 +- MAINTAINERS | 7 + arch/arm/Kconfig | 14 ++ arch/arm/Makefile | 1 + arch/arm/dts/Makefile | 3 + arch/arm/dts/versal-net-mini.dts | 67 ++++++++ arch/arm/dts/xilinx-versal-net-virt.dts | 11 ++ arch/arm/dts/zynqmp-zcu102-revA.dts | 20 ++- arch/arm/dts/zynqmp-zcu104-revA.dts | 19 ++- arch/arm/dts/zynqmp-zcu104-revC.dts | 19 ++- arch/arm/dts/zynqmp-zcu111-revA.dts | 19 ++- arch/arm/dts/zynqmp-zcu208-revA.dts | 19 ++- arch/arm/dts/zynqmp-zcu216-revA.dts | 20 ++- arch/arm/mach-versal-net/Kconfig | 43 +++++ arch/arm/mach-versal-net/Makefile | 10 ++ arch/arm/mach-versal-net/clk.c | 35 ++++ arch/arm/mach-versal-net/cpu.c | 89 ++++++++++ arch/arm/mach-versal-net/include/mach/hardware.h | 31 ++++ arch/arm/mach-versal-net/include/mach/sys_proto.h | 16 ++ board/xilinx/Kconfig | 6 +- board/xilinx/versal-net/Kconfig | 9 ++ board/xilinx/versal-net/MAINTAINERS | 8 + board/xilinx/versal-net/Makefile | 9 ++ board/xilinx/versal-net/board.c | 170 ++++++++++++++++++++ configs/xilinx_versal_net_mini_defconfig | 72 +++++++++ configs/xilinx_versal_net_virt_defconfig | 131 +++++++++++++++ drivers/clk/Kconfig | 2 +- drivers/clk/clk_versal.c | 1 + drivers/firmware/firmware-zynqmp.c | 1 + drivers/mailbox/Kconfig | 2 +- drivers/reset/reset-zynqmp.c | 1 + drivers/spi/Kconfig | 2 +- drivers/spi/cadence_ospi_versal.c | 3 +- drivers/spi/zynqmp_gqspi.c | 3 +- env/Kconfig | 6 +- include/configs/xilinx_versal.h | 4 - include/configs/xilinx_versal_net.h | 134 +++++++++++++++ include/configs/xilinx_versal_net_mini.h | 21 +++ 38 files changed, 976 insertions(+), 54 deletions(-) create mode 100644 arch/arm/dts/versal-net-mini.dts create mode 100644 arch/arm/dts/xilinx-versal-net-virt.dts create mode 100644 arch/arm/mach-versal-net/Kconfig create mode 100644 arch/arm/mach-versal-net/Makefile create mode 100644 arch/arm/mach-versal-net/clk.c create mode 100644 arch/arm/mach-versal-net/cpu.c create mode 100644 arch/arm/mach-versal-net/include/mach/hardware.h create mode 100644 arch/arm/mach-versal-net/include/mach/sys_proto.h create mode 100644 board/xilinx/versal-net/Kconfig create mode 100644 board/xilinx/versal-net/MAINTAINERS create mode 100644 board/xilinx/versal-net/Makefile create mode 100644 board/xilinx/versal-net/board.c create mode 100644 configs/xilinx_versal_net_mini_defconfig create mode 100644 configs/xilinx_versal_net_virt_defconfig create mode 100644 include/configs/xilinx_versal_net.h create mode 100644 include/configs/xilinx_versal_net_mini.h
On Mon, Sep 26, 2022 at 04:03:28PM +0200, Michal Simek wrote:
Hi Tom,
Thanks, Michal
Michal Simek
