[U-Boot] [PATCH v2 01/30] arm: socfpga: arria10: add additional i2c nodes for Arria10
Add remaining 3 I2C base addresses for the Arria10.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com Reviewed-by: Stefan Roese sr@denx.de --- arch/arm/mach-socfpga/include/mach/base_addr_a10.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_a10.h b/arch/arm/mach-socfpga/include/mach/base_addr_a10.h index a7056d4..902c321 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_a10.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_a10.h @@ -29,6 +29,9 @@ #define SOCFPGA_MPUL2_ADDRESS 0xfffff000 #define SOCFPGA_I2C0_ADDRESS 0xffc02200 #define SOCFPGA_I2C1_ADDRESS 0xffc02300 +#define SOCFPGA_I2C2_ADDRESS 0xffc02400 +#define SOCFPGA_I2C3_ADDRESS 0xffc02500 +#define SOCFPGA_I2C4_ADDRESS 0xffc02600
#define SOCFPGA_ECC_OCRAM_ADDRESS 0xff8c3000 #define SOCFPGA_UART0_ADDRESS 0xffc02000
Add the structures for the SDRAM controller on Arria10.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- arch/arm/mach-socfpga/include/mach/sdram_a10.h | 380 +++++++++++++++++++++++++ 1 file changed, 380 insertions(+) create mode 100644 arch/arm/mach-socfpga/include/mach/sdram_a10.h
diff --git a/arch/arm/mach-socfpga/include/mach/sdram_a10.h b/arch/arm/mach-socfpga/include/mach/sdram_a10.h new file mode 100644 index 0000000..0403531 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/sdram_a10.h @@ -0,0 +1,380 @@ +/* + * Copyright (C) 2015 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _SOCFPGA_SDRAM_A10_H_ +#define _SOCFPGA_SDRAM_A10_H_ + +#ifndef __ASSEMBLY__ + +struct socfpga_ecc_hmc { + u32 ip_rev_id; + u32 _pad_0x4_0x7; + u32 ddrioctrl; + u32 ddrcalstat; + u32 mpr_0beat1; + u32 mpr_1beat1; + u32 mpr_2beat1; + u32 mpr_3beat1; + u32 mpr_4beat1; + u32 mpr_5beat1; + u32 mpr_6beat1; + u32 mpr_7beat1; + u32 mpr_8beat1; + u32 mpr_0beat2; + u32 mpr_1beat2; + u32 mpr_2beat2; + u32 mpr_3beat2; + u32 mpr_4beat2; + u32 mpr_5beat2; + u32 mpr_6beat2; + u32 mpr_7beat2; + u32 mpr_8beat2; + u32 _pad_0x58_0x5f[2]; + u32 auto_precharge; + u32 _pad_0x64_0xff[39]; + u32 eccctrl; + u32 eccctrl2; + u32 _pad_0x108_0x10f[2]; + u32 errinten; + u32 errintens; + u32 errintenr; + u32 intmode; + u32 intstat; + u32 diaginttest; + u32 modstat; + u32 derraddra; + u32 serraddra; + u32 _pad_0x134_0x137; + u32 autowb_corraddr; + u32 serrcntreg; + u32 autowb_drop_cntreg; + u32 _pad_0x144_0x147; + u32 ecc_reg2wreccdatabus; + u32 ecc_rdeccdata2regbus; + u32 ecc_reg2rdeccdatabus; + u32 _pad_0x154_0x15f[3]; + u32 ecc_diagon; + u32 ecc_decstat; + u32 _pad_0x168_0x16f[2]; + u32 ecc_errgenaddr_0; + u32 ecc_errgenaddr_1; + u32 ecc_errgenaddr_2; + u32 ecc_errgenaddr_3; +}; + +struct socfpga_noc_ddr_scheduler { + u32 ddr_t_main_scheduler_id_coreid; + u32 ddr_t_main_scheduler_id_revisionid; + u32 ddr_t_main_scheduler_ddrconf; + u32 ddr_t_main_scheduler_ddrtiming; + u32 ddr_t_main_scheduler_ddrmode; + u32 ddr_t_main_scheduler_readlatency; + u32 _pad_0x20_0x34[8]; + u32 ddr_t_main_scheduler_activate; + u32 ddr_t_main_scheduler_devtodev; +}; + +/* + * OCRAM firewall + */ +struct socfpga_noc_fw_ocram { + u32 enable; + u32 enable_set; + u32 enable_clear; + u32 region0; + u32 region1; + u32 region2; + u32 region3; + u32 region4; + u32 region5; +}; + +/* for master such as MPU and FPGA */ +struct socfpga_noc_fw_ddr_mpu_fpga2sdram { + u32 enable; + u32 enable_set; + u32 enable_clear; + u32 _pad_0xc_0xf; + u32 mpuregion0addr; + u32 mpuregion1addr; + u32 mpuregion2addr; + u32 mpuregion3addr; + u32 fpga2sdram0region0addr; + u32 fpga2sdram0region1addr; + u32 fpga2sdram0region2addr; + u32 fpga2sdram0region3addr; + u32 fpga2sdram1region0addr; + u32 fpga2sdram1region1addr; + u32 fpga2sdram1region2addr; + u32 fpga2sdram1region3addr; + u32 fpga2sdram2region0addr; + u32 fpga2sdram2region1addr; + u32 fpga2sdram2region2addr; + u32 fpga2sdram2region3addr; +}; + +/* for L3 master */ +struct socfpga_noc_fw_ddr_l3 { + u32 enable; + u32 enable_set; + u32 enable_clear; + u32 hpsregion0addr; + u32 hpsregion1addr; + u32 hpsregion2addr; + u32 hpsregion3addr; + u32 hpsregion4addr; + u32 hpsregion5addr; + u32 hpsregion6addr; + u32 hpsregion7addr; +}; + +struct socfpga_io48_mmr { + u32 dbgcfg0; + u32 dbgcfg1; + u32 dbgcfg2; + u32 dbgcfg3; + u32 dbgcfg4; + u32 dbgcfg5; + u32 dbgcfg6; + u32 reserve0; + u32 reserve1; + u32 reserve2; + u32 ctrlcfg0; + u32 ctrlcfg1; + u32 ctrlcfg2; + u32 ctrlcfg3; + u32 ctrlcfg4; + u32 ctrlcfg5; + u32 ctrlcfg6; + u32 ctrlcfg7; + u32 ctrlcfg8; + u32 ctrlcfg9; + u32 dramtiming0; + u32 dramodt0; + u32 dramodt1; + u32 sbcfg0; + u32 sbcfg1; + u32 sbcfg2; + u32 sbcfg3; + u32 sbcfg4; + u32 sbcfg5; + u32 sbcfg6; + u32 sbcfg7; + u32 caltiming0; + u32 caltiming1; + u32 caltiming2; + u32 caltiming3; + u32 caltiming4; + u32 caltiming5; + u32 caltiming6; + u32 caltiming7; + u32 caltiming8; + u32 caltiming9; + u32 caltiming10; + u32 dramaddrw; + u32 sideband0; + u32 sideband1; + u32 sideband2; + u32 sideband3; + u32 sideband4; + u32 sideband5; + u32 sideband6; + u32 sideband7; + u32 sideband8; + u32 sideband9; + u32 sideband10; + u32 sideband11; + u32 sideband12; + u32 sideband13; + u32 sideband14; + u32 sideband15; + u32 dramsts; + u32 dbgdone; + u32 dbgsignals; + u32 dbgreset; + u32 dbgmatch; + u32 counter0mask; + u32 counter1mask; + u32 counter0match; + u32 counter1match; + u32 niosreserve0; + u32 niosreserve1; + u32 niosreserve2; +}; +#endif /*__ASSEMBLY__*/ + +#define IO48_MMR_CTRLCFG0_DB2_BURST_LENGTH_MASK 0x1F000000 +#define IO48_MMR_CTRLCFG0_DB2_BURST_LENGTH_SHIFT 24 +#define IO48_MMR_CTRLCFG0_DB1_BURST_LENGTH_MASK 0x00F80000 +#define IO48_MMR_CTRLCFG0_DB1_BURST_LENGTH_SHIFT 19 +#define IO48_MMR_CTRLCFG0_DB0_BURST_LENGTH_MASK 0x0007C000 +#define IO48_MMR_CTRLCFG0_DB0_BURST_LENGTH_SHIFT 14 +#define IO48_MMR_CTRLCFG0_CTRL_BURST_LENGTH_MASK 0x00003E00 +#define IO48_MMR_CTRLCFG0_CTRL_BURST_LENGTH_SHIFT 9 +#define IO48_MMR_CTRLCFG0_AC_POS_MASK 0x00000180 +#define IO48_MMR_CTRLCFG0_AC_POS_SHIFT 7 +#define IO48_MMR_CTRLCFG0_DIMM_TYPE_MASK 0x00000070 +#define IO48_MMR_CTRLCFG0_DIM_TYPE_SHIFT 4 +#define IO48_MMR_CTRLCFG0_MEM_TYPE_MASK 0x0000000F +#define IO48_MMR_CTRLCFG0_MEM_TYPE_SHIFT 0 + +#define IO48_MMR_CTRLCFG1_DBC3_ENABLE_DM (1 << 30) +#define IO48_MMR_CTRLCFG1_DBC2_ENABLE_DM (1 << 29) +#define IO48_MMR_CTRLCFG1_DBC1_ENABLE_DM (1 << 28) +#define IO48_MMR_CTRLCFG1_DBC0_ENABLE_DM (1 << 27) +#define IO48_MMR_CTRLCFG1_CTRL_ENABLE_DM (1 << 26) +#define IO48_MMR_CTRLCFG1_DQSTRK_EN (1 << 25) +#define IO48_MMR_CTRLCFG1_STARVE_LIMIT_MASK 0x01F80000 +#define IO48_MMR_CTRLCFG1_STARVE_LIMIT_SHIFT 19 +#define IO48_MMR_CTRLCFG1_REORDER_READ (1 << 18) +#define IO48_MMR_CTRLCFG1_DBC3_REORDER_RDATA (1 << 17) +#define IO48_MMR_CTRLCFG1_DBC2_REORDER_RDATA (1 << 16) +#define IO48_MMR_CTRLCFG1_DBC1_REORDER_RDATA (1 << 15) +#define IO48_MMR_CTRLCFG1_DBC0_REORDER_RDATA (1 << 14) +#define IO48_MMR_CTRLCFG1_CTRL_REORDER_RDATA (1 << 13) +#define IO48_MMR_CTRLCFG1_REORDER_DATA (1 << 12) +#define IO48_MMR_CTRLCFG1_DBC3_ENABLE_ECC (1 << 11) +#define IO48_MMR_CTRLCFG1_DBC2_ENABLE_ECC (1 << 10) +#define IO48_MMR_CTRLCFG1_DBC1_ENABLE_ECC (1 << 9) +#define IO48_MMR_CTRLCFG1_DBC0_ENABLE_ECC (1 << 8) +#define IO48_MMR_CTRLCFG1_CTRL_ENABLE_ECC (1 << 7) +#define IO48_MMR_CTRLCFG1_ADDR_ORDER_MASK 0x00000060 +#define IO48_MMR_CTRLCFG1_ADDR_ORDER_SHIFT 5 +#define IO48_MMR_CTRLCFG1_DBC3_BURST_LENGTH_MASK 0x0000001F +#define IO48_MMR_CTRLCFG1_DBC3_BURST_LENGTH_SHIFT 0 + +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_DIFF_BG_MASK 0x3F000000 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_DIFF_BG_SHIFT 24 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_DIFF_BANK_MASK 0x00FC0000 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_DIFF_BANK_SHIFT 18 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_MASK 0x0003F000 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_ACT_SHIFT 12 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_PCH_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_PCH_SHIFT 6 +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_RDWR_MASK 0x0000003F +#define IO48_MMR_CALTIMING0_CFG_ACT_TO_RDWR_SHIFT 0 + +#define IO48_MMR_CALTIMING1_CFG_RD_TO_WR_DIFF_CHIP_MASK 0x3F000000 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_WR_DIFF_CHIP_SHIFT 24 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_WR_MASK 0x00FC0000 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_WR_SHIFT 18 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_DB_MASK 0x0003F000 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_DB_SHIFT 12 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_DC_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_DC_SHIFT 6 +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_MASK 0x0000003F +#define IO48_MMR_CALTIMING1_CFG_RD_TO_RD_SHIFT 0 + +#define IO48_MMR_CALTIMING2_CFG_WR_TO_WR_DIFF_CHIP_MASK 0x3F000000 +#define IO48_MMR_CALTIMING2_CFG_WR_TO_WR_DIFF_CHIP_SHIFT 24 +#define IO48_MMR_CALTIMING2_CFG_WR_TO_WR_MASK 0x00FC0000 +#define IO48_MMR_CALTIMING2_CFG_WR_TO_WR_SHIFT 18 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_AP_VALID_MASK 0x0003F000 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_AP_VALID_SHIFT 12 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_PCH_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_PCH_SHIFT 6 +#define IO48_MMR_CALTIMING2_CFG_RD_TO_WR_DIFF_BG_MASK 0x0000003F +#define IO48_MMR_CALTIMING2_CFG_RD_TO_WR_DIFF_BG_SHIFT 0 + +#define IO48_MMR_CALTIMING3_CFG_WR_TO_PCH_MASK 0x3F000000 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_PCH_SHIFT 24 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_DIFF_BG_MASK 0x00FC0000 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_DIFF_BG_SHIFT 18 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_DIFF_CHIP_MASK 0x0003F000 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_DIFF_CHIP_SHIFT 12 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_RD_SHIFT 6 +#define IO48_MMR_CALTIMING3_CFG_WR_TO_WR_DIFF_BG_MASK 0x0000003F +#define IO48_MMR_CALTIMING3_CFG_WR_TO_WR_DIFF_BG_SHIFT 0 + +#define IO48_MMR_CALTIMING4_CFG_PDN_TO_VALID_MASK 0xFC000000 +#define IO48_MMR_CALTIMING4_CFG_PDN_TO_VALID_SHIFT 26 +#define IO48_MMR_CALTIMING4_CFG_ARF_TO_VALID_MASK 0x03FC0000 +#define IO48_MMR_CALTIMING4_CFG_ARF_TO_VALID_SHIFT 18 +#define IO48_MMR_CALTIMING4_CFG_PCH_ALL_TO_VALID_MASK 0x0003F000 +#define IO48_MMR_CALTIMING4_CFG_PCH_ALL_TO_VALID_SHIFT 12 +#define IO48_MMR_CALTIMING4_CFG_PCH_TO_VALID_MASK 0x00000FC0 +#define IO48_MMR_CALTIMING4_CFG_PCH_TO_VALID_SHIFT 6 +#define IO48_MMR_CALTIMING4_CFG_WR_AP_TO_VALID_MASK 0x0000003F +#define IO48_MMR_CALTIMING4_CFG_WR_AP_TO_VALID_SHIFT 0 + +#define IO48_MMR_CALTIMING9_CFG_WR_4_ACT_TO_ACT_MASK 0x000000FF +#define IO48_MMR_CALTIMING9_CFG_WR_4_ACT_TO_ACT_SHIFT 0 + +#define IO48_MMR_DRAMADDRW_CFG_CS_ADDR_WIDTH_MASK 0x00070000 +#define IO48_MMR_DRAMADDRW_CFG_CS_ADDR_WIDTH_SHIFT 16 +#define IO48_MMR_DRAMADDRW_CFG_BANK_GROUP_ADDR_WIDTH_MASK 0x0000C000 +#define IO48_MMR_DRAMADDRW_CFG_BANK_GROUP_ADDR_WIDTH_SHIFT 14 +#define IO48_MMR_DRAMADDRW_CFG_BANK_ADDR_WIDTH_MASK 0x00003C00 +#define IO48_MMR_DRAMADDRW_CFG_BANK_ADDR_WIDTH_SHIFT 10 +#define IO48_MMR_DRAMADDRW_CFG_ROW_ADDR_WIDTH_MASK 0x000003E0 +#define IO48_MMR_DRAMADDRW_CFG_ROW_ADDR_WIDTH_SHIFT 5 +#define IO48_MMR_DRAMADDRW_CFG_COL_ADDR_WIDTH_MASK 0x0000001F +#define IO48_MMR_DRAMADDRW_CFG_COL_ADDR_WIDTH_SHIFT 0 + +#define ALT_ECC_HMC_OCP_DDRIOCTRL_IO_SIZE_MSK 0x00000003 + +#define ALT_ECC_HMC_OCP_INTSTAT_SERRPENA_SET_MSK 0x00000001 +#define ALT_ECC_HMC_OCP_INTSTAT_DERRPENA_SET_MSK 0x00000002 +#define ALT_ECC_HMC_OCP_ERRINTEN_SERRINTEN_SET_MSK 0x00000001 +#define ALT_ECC_HMC_OCP_ERRINTEN_DERRINTEN_SET_MSK 0x00000002 +#define ALT_ECC_HMC_OCP_INTMOD_INTONCMP_SET_MSK 0x00010000 +#define ALT_ECC_HMC_OCP_ECCCTL_AWB_CNT_RST_SET_MSK 0x00010000 +#define ALT_ECC_HMC_OCP_ECCCTL_CNT_RST_SET_MSK 0x00000100 +#define ALT_ECC_HMC_OCP_ECCCTL_ECC_EN_SET_MSK 0x00000001 +#define ALT_ECC_HMC_OCP_ECCCTL2_RMW_EN_SET_MSK 0x00000100 +#define ALT_ECC_HMC_OCP_ECCCTL2_AWB_EN_SET_MSK 0x00000001 + +#define ALT_ECC_HMC_OCP_SERRCNTREG_VALUE 8 + +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_ACTTOACT_LSB 0 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_RDTOMISS_LSB 6 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_WRTOMISS_LSB 12 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_BURSTLEN_LSB 18 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_RDTOWR_LSB 21 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_WRTORD_LSB 26 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_BWRATIO_LSB 31 + +#define ALT_NOC_MPU_DDR_T_SCHED_DDRMOD_AUTOPRECHARGE_LSB 0 +#define ALT_NOC_MPU_DDR_T_SCHED_DDRMOD_BWRATIOEXTENDED_LSB 1 + +#define ALT_NOC_MPU_DDR_T_SCHED_ACTIVATE_RRD_LSB 0 +#define ALT_NOC_MPU_DDR_T_SCHED_ACTIVATE_FAW_LSB 4 +#define ALT_NOC_MPU_DDR_T_SCHED_ACTIVATE_FAWBANK_LSB 10 + +#define ALT_NOC_MPU_DDR_T_SCHED_DEVTODEV_BUSRDTORD_LSB 0 +#define ALT_NOC_MPU_DDR_T_SCHED_DEVTODEV_BUSRDTOWR_LSB 2 +#define ALT_NOC_MPU_DDR_T_SCHED_DEVTODEV_BUSWRTORD_LSB 4 + +#define ALT_NOC_FW_DDR_END_ADDR_LSB 16 +#define ALT_NOC_FW_DDR_ADDR_MASK 0xFFFF +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG0EN_SET_MSK 0x00000001 +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG1EN_SET_MSK 0x00000002 +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG2EN_SET_MSK 0x00000004 +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG3EN_SET_MSK 0x00000008 +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG4EN_SET_MSK 0x00000010 +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG5EN_SET_MSK 0x00000020 +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG6EN_SET_MSK 0x00000040 +#define ALT_NOC_FW_DDR_SCR_EN_HPSREG7EN_SET_MSK 0x00000080 +#define ALT_NOC_FW_DDR_SCR_EN_MPUREG0EN_SET_MSK 0x00000001 +#define ALT_NOC_FW_DDR_SCR_EN_MPUREG1EN_SET_MSK 0x00000002 +#define ALT_NOC_FW_DDR_SCR_EN_MPUREG2EN_SET_MSK 0x00000004 +#define ALT_NOC_FW_DDR_SCR_EN_MPUREG3EN_SET_MSK 0x00000008 +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG0EN_SET_MSK 0x00000010 +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG1EN_SET_MSK 0x00000020 +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG2EN_SET_MSK 0x00000040 +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG3EN_SET_MSK 0x00000080 +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG0EN_SET_MSK 0x00000100 +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG1EN_SET_MSK 0x00000200 +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG2EN_SET_MSK 0x00000400 +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG3EN_SET_MSK 0x00000800 +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG0EN_SET_MSK 0x00001000 +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG1EN_SET_MSK 0x00002000 +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG2EN_SET_MSK 0x00004000 +#define ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG3EN_SET_MSK 0x00008000 + +#define ALT_IO48_DRAMTIME_MEM_READ_LATENCY_MASK 0x0000003F +#endif /* _SOCFPGA_SDRAM_A10_H_ */
Add minimal support for the Arria10 SoCDK.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- board/altera/arria10-socdk/Kconfig | 18 ++++++++++++++++++ board/altera/arria10-socdk/Makefile | 7 +++++++ board/altera/arria10-socdk/socfpga.c | 24 ++++++++++++++++++++++++ 3 files changed, 49 insertions(+) create mode 100644 board/altera/arria10-socdk/Kconfig create mode 100644 board/altera/arria10-socdk/Makefile create mode 100644 board/altera/arria10-socdk/socfpga.c
diff --git a/board/altera/arria10-socdk/Kconfig b/board/altera/arria10-socdk/Kconfig new file mode 100644 index 0000000..b80cc6d --- /dev/null +++ b/board/altera/arria10-socdk/Kconfig @@ -0,0 +1,18 @@ +if TARGET_SOCFPGA_ARRIA10 + +config SYS_CPU + default "armv7" + +config SYS_BOARD + default "socfpga_arria10" + +config SYS_VENDOR + default "altera" + +config SYS_SOC + default "socfpga_arria10" + +config SYS_CONFIG_NAME + default "socfpga_arria10" + +endif diff --git a/board/altera/arria10-socdk/Makefile b/board/altera/arria10-socdk/Makefile new file mode 100644 index 0000000..1d885ce --- /dev/null +++ b/board/altera/arria10-socdk/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2015 Altera Corporation <www.altera.com> +# +# SPDX-License-Identifier: GPL-2.0 +# + +obj-y := socfpga.o diff --git a/board/altera/arria10-socdk/socfpga.c b/board/altera/arria10-socdk/socfpga.c new file mode 100644 index 0000000..abedc22 --- /dev/null +++ b/board/altera/arria10-socdk/socfpga.c @@ -0,0 +1,24 @@ +/* + * Copyright (C) 2015 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +void s_init(void) +{ +} + +/* + * Miscellaneous platform dependent initialisations + */ +int board_init(void) +{ + /* Address of boot parameters for ATAG (if ATAG is used) */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + return 0; +}
Add system manager defines for Arria10.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- .../arm/mach-socfpga/include/mach/system_manager.h | 122 +++++++++++++++++++++ 1 file changed, 122 insertions(+)
diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index c45edea..e688c50 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -15,6 +15,7 @@ void sysmgr_config_warmrstcfgio(int enable); void sysmgr_get_pinmux_table(const u8 **table, unsigned int *table_len); #endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) struct socfpga_system_manager { /* System Manager Module */ u32 siliconid1; /* 0x00 */ @@ -115,6 +116,77 @@ struct socfpga_system_manager { u32 _pad_0x734; u32 spim0usefpga; /* 0x738 */ }; +#else /* Arria10 System Manager */ +struct socfpga_system_manager { + u32 siliconid1; + u32 siliconid2; + u32 wddbg; + u32 bootinfo; + u32 mpu_ctrl_l2_ecc; + u32 _pad_0x14_0x1f[3]; + u32 dma; + u32 dma_periph; + u32 sdmmcgrp_ctrl; + u32 sdmmc_l3master; + u32 nand_bootstrap; + u32 nand_l3master; + u32 usb0_l3master; + u32 usb1_l3master; + u32 emac_global; + u32 emac0; + u32 emac1; + u32 emac2; + u32 _pad_0x50_0x5f[4]; + u32 fpgaintf_en_global; + u32 fpgaintf_en_0; + u32 fpgaintf_en_1; + u32 fpgaintf_en_2; + u32 fpgaintf_en_3; + u32 _pad_0x74_0x7f[3]; + u32 noc_addr_remap_value; + u32 noc_addr_remap_set; + u32 noc_addr_remap_clear; + u32 _pad_0x8c_0x8f; + u32 ecc_intmask_value; + u32 ecc_intmask_set; + u32 ecc_intmask_clr; + u32 ecc_intstatus_serr; + u32 ecc_intstatus_derr; + u32 mpu_status_l2_ecc; + u32 mpu_clear_l2_ecc; + u32 mpu_status_l1_parity; + u32 mpu_clear_l1_parity; + u32 mpu_set_l1_parity; + u32 _pad_0xb8_0xbf[2]; + u32 noc_timeout; + u32 noc_idlereq_set; + u32 noc_idlereq_clr; + u32 noc_idlereq_value; + u32 noc_idleack; + u32 noc_idlestatus; + u32 fpga2soc_ctrl; + u32 _pad_0xdc_0xff[9]; + u32 tsmc_tsel_0; + u32 tsmc_tsel_1; + u32 tsmc_tsel_2; + u32 tsmc_tsel_3; + u32 _pad_0x110_0x200[60]; + u32 romhw_ctrl; + u32 romcode_ctrl; + u32 romcode_cpu1startaddr; + u32 romcode_initswstate; + u32 romcode_initswlastld; + u32 _pad_0x214_0x217; + u32 warmram_enable; + u32 warmram_datastart; + u32 warmram_length; + u32 warmram_execution; + u32 warmram_crc; + u32 _pad_0x22c_0x22f; + u32 isw_handoff[8]; + u32 romcode_bootromswstate[8]; +}; +#endif
#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGPINMUX (1 << 0) #define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO (1 << 1) @@ -146,4 +218,54 @@ struct socfpga_system_manager { #define SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB 2 #define SYSMGR_EMACGRP_CTRL_PHYSEL_MASK 0x3
+/* For dedicated IO configuration */ +/* Voltage select enums */ +#define VOLTAGE_SEL_3V 0x0 +#define VOLTAGE_SEL_1P8V 0x1 +#define VOLTAGE_SEL_2P5V 0x2 + +/* Input buffer enable */ +#define INPUT_BUF_DISABLE 0 +#define INPUT_BUF_1P8V 1 +#define INPUT_BUF_2P5V3V 2 + +/* Weak pull up enable */ +#define WK_PU_DISABLE 0 +#define WK_PU_ENABLE 1 + +/* Pull up slew rate control */ +#define PU_SLW_RT_SLOW 0 +#define PU_SLW_RT_FAST 1 +#define PU_SLW_RT_DEFAULT PU_SLW_RT_SLOW + +/* Pull down slew rate control */ +#define PD_SLW_RT_SLOW 0 +#define PD_SLW_RT_FAST 1 +#define PD_SLW_RT_DEFAULT PD_SLW_RT_SLOW + +/* Drive strength control */ +#define PU_DRV_STRG_DEFAULT 0x10 +#define PD_DRV_STRG_DEFAULT 0x10 + +/* bit position */ +#define PD_DRV_STRG_LSB 0 +#define PD_SLW_RT_LSB 5 +#define PU_DRV_STRG_LSB 8 +#define PU_SLW_RT_LSB 13 +#define WK_PU_LSB 16 +#define INPUT_BUF_LSB 17 +#define BIAS_TRIM_LSB 19 +#define VOLTAGE_SEL_LSB 0 + +#define ALT_SYSMGR_NOC_H2F_SET_MSK 0x00000001 +#define ALT_SYSMGR_NOC_LWH2F_SET_MSK 0x00000010 +#define ALT_SYSMGR_NOC_F2H_SET_MSK 0x00000100 +#define ALT_SYSMGR_NOC_F2SDR0_SET_MSK 0x00010000 +#define ALT_SYSMGR_NOC_F2SDR1_SET_MSK 0x00100000 +#define ALT_SYSMGR_NOC_F2SDR2_SET_MSK 0x01000000 +#define ALT_SYSMGR_NOC_TMO_EN_SET_MSK 0x00000001 + +#define ALT_SYSMGR_ECC_INTSTAT_SERR_OCRAM_SET_MSK 0x00000002 +#define ALT_SYSMGR_ECC_INTSTAT_DERR_OCRAM_SET_MSK 0x00000002 + #endif /* _SYSTEM_MANAGER_H_ */
Add arch_early_init_r function. The Arria10 has a firewall protection around the SDRAM and OCRAM. These firewalls are to be disabled in order for U-Boot to function.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- arch/arm/mach-socfpga/misc.c | 51 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 51 insertions(+)
diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index dd6b53b..c1e5969 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -15,6 +15,7 @@ #include <watchdog.h> #include <asm/arch/reset_manager.h> #include <asm/arch/scan_manager.h> +#include <asm/arch/sdram_a10.h> #include <asm/arch/system_manager.h> #include <asm/arch/nic301.h> #include <asm/arch/scu.h> @@ -30,8 +31,15 @@ static struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; static struct socfpga_reset_manager *reset_manager_base = (struct socfpga_reset_manager *)SOCFPGA_RSTMGR_ADDRESS; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct nic301_registers *nic301_regs = (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; +#else +static const struct socfpga_noc_fw_ocram *noc_fw_ocram_base = + (void *)SOCFPGA_SDR_FIREWALL_OCRAM_ADDRESS; +static const struct socfpga_noc_fw_ddr_l3 *noc_fw_ddr_l3_base = + (void *)SOCFPGA_SDR_FIREWALL_L3_ADDRESS; +#endif static struct scu_registers *scu_regs = (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS;
@@ -253,9 +261,14 @@ static int socfpga_fpga_id(const bool print_id) #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; puts("CPU: Altera SoCFPGA Platform\n"); socfpga_fpga_id(1); +#else + const u32 bsel = (readl(&sysmgr_regs->bootinfo) >> 12) & 0x7; + puts("CPU: Altera SoCFPGA Arria 10\n"); +#endif printf("BOOT: %s\n", bsel_str[bsel].name); return 0; } @@ -338,6 +351,7 @@ int arch_cpu_init(void) return 0; }
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* * Convert all NIC-301 AMBA slaves from secure to non-secure */ @@ -461,6 +475,43 @@ int do_bridge(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return 0; } +#else +/* ++ * This function initializes security policies to be consistent across ++ * all logic units in the Arria 10. ++ * ++ * The idea is to set all security policies to be normal, nonsecure ++ * for all units. ++ */ +static void initialize_security_policies(void) +{ + /* Put OCRAM in non-secure */ + writel(0x003f0000, &noc_fw_ocram_base->region0); + writel(0x1, &noc_fw_ocram_base->enable); + + /* Put DDR in non-secure */ + writel(0xffff0000, &noc_fw_ddr_l3_base->hpsregion0addr); + writel(0x1, &noc_fw_ddr_l3_base->enable); +} + +int arch_early_init_r(void) +{ + initialize_security_policies(); + + /* Configure the L2 controller to make SDRAM start at 0 */ + writel(0x1, &pl310->pl310_addr_filter_start); + + /* assert reset to all except L4WD0 and L4TIMER0 */ + socfpga_per_reset_all(); + + /* configuring the clock based on handoff */ + /* TODO: Add call to cm_basic_init() */ + + /* Add device descriptor to FPGA device table */ + socfpga_fpga_add(); + return 0; +} +#endif
U_BOOT_CMD( bridge, 2, 1, do_bridge,
Add config for the Arria10 SoC Development Kit.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com Acked-by: Marek Vasut marex@denx.de --- include/configs/socfpga_arria10_socdk.h | 94 +++++++++++++++++++++++++++++++++ 1 file changed, 94 insertions(+) create mode 100644 include/configs/socfpga_arria10_socdk.h
diff --git a/include/configs/socfpga_arria10_socdk.h b/include/configs/socfpga_arria10_socdk.h new file mode 100644 index 0000000..577f60f --- /dev/null +++ b/include/configs/socfpga_arria10_socdk.h @@ -0,0 +1,94 @@ +/* + * Copyright (C) 2015 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __CONFIG_SOCFGPA_ARRIA10_H__ +#define __CONFIG_SOCFGPA_ARRIA10_H__ + +#include <asm/arch/base_addr_a10.h> +/* U-Boot Commands */ +#define CONFIG_SYS_NO_FLASH +#define CONFIG_DOS_PARTITION +#define CONFIG_FAT_WRITE +#define CONFIG_HW_WATCHDOG + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_EXT4_WRITE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_GREPENV +#define CONFIG_CMD_MMC +#define CONFIG_CMD_PING + +/* + * Memory configurations + */ +#define PHYS_SDRAM_1_SIZE 0x2000000 + +/* Booting Linux */ +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTFILE "zImage" +#define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) +#define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" +#define CONFIG_LOADADDR 0x01000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* + * Display CPU and Board Info + */ +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_DISPLAY_BOARDINFO_LATE + +/* Ethernet on SoC (EMAC) */ +#if defined(CONFIG_CMD_NET) + +/* PHY */ +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9031 + +#endif + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0/* device 0 */ +#define CONFIG_ENV_OFFSET 512/* just after the MBR */ + +/* + * arguments passed to the bootz command. The value of + * CONFIG_BOOTARGS goes into the environment value "bootargs". + * Do note the value will overide also the chosen node in FDT blob. + */ +#define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "verify=n\0" \ + "loadaddr= " __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \ + "bootm ${loadaddr} - ${fdt_addr}\0" \ + "bootimage=zImage\0" \ + "fdt_addr=100\0" \ + "fdtimage=socfpga.dtb\0" \ + "fsloadcmd=ext2load\0" \ + "bootm ${loadaddr} - ${fdt_addr}\0" \ + "mmcroot=/dev/mmcblk0p2\0" \ + "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${mmcroot} rw rootwait;" \ + "bootz ${loadaddr} - ${fdt_addr}\0" \ + "mmcload=mmc rescan;" \ + "load mmc 0:1 ${loadaddr} ${bootimage};" \ + "load mmc 0:1 ${fdt_addr} ${fdtimage}\0" \ + "qspiroot=/dev/mtdblock0\0" \ + "qspirootfstype=jffs2\0" \ + "qspiboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${qspiroot} rw rootfstype=${qspirootfstype};"\ + "bootm ${loadaddr} - ${fdt_addr}\0" + +/* The rest of the configuration is shared */ +#include <configs/socfpga_common.h> +#endif /* __CONFIG_H */
Add a defconfig file for Arria10, which does not include enabling SPL.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com Acked-by: Marek Vasut marex@denx.de --- configs/socfpga_arria10_defconfig | 16 ++++++++++++++++ 1 file changed, 16 insertions(+) create mode 100644 configs/socfpga_arria10_defconfig
diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig new file mode 100644 index 0000000..422261b --- /dev/null +++ b/configs/socfpga_arria10_defconfig @@ -0,0 +1,16 @@ +CONFIG_ARM=y +CONFIG_ARCH_SOCFPGA=y +CONFIG_TARGET_SOCFPGA_ARRIA10=y +CONFIG_DM_GPIO=y +CONFIG_TARGET_SOCFPGA_ARRIA10_SOCDK=y +CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria10_socdk" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_DWAPB_GPIO=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_SYS_NS16550=y +CONFIG_CADENCE_QSPI=y +CONFIG_DESIGNWARE_SPI=y +CONFIG_DM_MMC=y
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- arch/arm/Kconfig | 4 ++-- arch/arm/mach-socfpga/Kconfig | 10 ++++++++++ 2 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d871a45..74b769f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -554,9 +554,9 @@ config ARCH_SNAPDRAGON config ARCH_SOCFPGA bool "Altera SOCFPGA family" select CPU_V7 - select SUPPORT_SPL + select SUPPORT_SPL if !TARGET_SOCFPGA_ARRIA10 select OF_CONTROL - select SPL_OF_CONTROL + select SPL_OF_CONTROL if !TARGET_SOCFPGA_ARRIA10 select DM select DM_SPI_FLASH select DM_SPI diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 6991af8..d9a5178 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -31,6 +31,9 @@ config TARGET_SOCFPGA_ARRIA5 bool select TARGET_SOCFPGA_GEN5
+config TARGET_SOCFPGA_ARRIA10 + bool + config TARGET_SOCFPGA_CYCLONE5 bool select TARGET_SOCFPGA_GEN5 @@ -50,6 +53,10 @@ config TARGET_SOCFPGA_CYCLONE5_SOCDK bool "Altera SOCFPGA SoCDK (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
+config TARGET_SOCFPGA_ARRIA10_SOCDK + bool "Altera SOCFPGA SoCDK (Arria 10)" + select TARGET_SOCFPGA_ARRIA10 + config TARGET_SOCFPGA_DENX_MCVEVK bool "DENX MCVEVK (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5 @@ -86,6 +93,7 @@ endchoice
config SYS_BOARD default "arria5-socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "arria10-socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK default "cyclone5-socdk" if TARGET_SOCFPGA_CYCLONE5_SOCDK default "de0-nano-soc" if TARGET_SOCFPGA_TERASIC_DE0_NANO default "de1-soc" if TARGET_SOCFPGA_TERASIC_DE1_SOC @@ -98,6 +106,7 @@ config SYS_BOARD
config SYS_VENDOR default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "altera" if TARGET_SOCFPGA_ARRIA10_SOCDK default "altera" if TARGET_SOCFPGA_CYCLONE5_SOCDK default "denx" if TARGET_SOCFPGA_DENX_MCVEVK default "ebv" if TARGET_SOCFPGA_EBV_SOCRATES @@ -111,6 +120,7 @@ config SYS_SOC
config SYS_CONFIG_NAME default "socfpga_arria5_socdk" if TARGET_SOCFPGA_ARRIA5_SOCDK + default "socfpga_arria10_socdk" if TARGET_SOCFPGA_ARRIA10_SOCDK default "socfpga_cyclone5_socdk" if TARGET_SOCFPGA_CYCLONE5_SOCDK default "socfpga_de0_nano_soc" if TARGET_SOCFPGA_TERASIC_DE0_NANO default "socfpga_de1_soc" if TARGET_SOCFPGA_TERASIC_DE1_SOC
On arria5/cyclone5 parts, the bsel bits are at shift 0, while for arria10, the bsel bits are at shift 12. Add SYSMGR_BOOTINFO_BSEL_SHIFT define so that the reading the bsel can generic.
Suggested-by: Marek Vasut marex@denx.de Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- arch/arm/mach-socfpga/include/mach/system_manager.h | 2 ++ arch/arm/mach-socfpga/misc.c | 4 ++-- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index e688c50..9ca889a 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -203,8 +203,10 @@ struct socfpga_system_manager {
#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define SYSMGR_SDMMC_SMPLSEL_SHIFT 3 +#define SYSMGR_BOOTINFO_BSEL_SHIFT 0 #else #define SYSMGR_SDMMC_SMPLSEL_SHIFT 4 +#define SYSMGR_BOOTINFO_BSEL_SHIFT 12 #endif
#define SYSMGR_SDMMC_DRVSEL_SHIFT 0 diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index c1e5969..2645129 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -261,12 +261,12 @@ static int socfpga_fpga_id(const bool print_id) #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { + const u32 bsel = (readl(&sysmgr_regs->bootinfo) >> + SYSMGR_BOOTINFO_BSEL_SHIFT) & 0x7; #if defined(CONFIG_TARGET_SOCFPGA_GEN5) - const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; puts("CPU: Altera SoCFPGA Platform\n"); socfpga_fpga_id(1); #else - const u32 bsel = (readl(&sysmgr_regs->bootinfo) >> 12) & 0x7; puts("CPU: Altera SoCFPGA Arria 10\n"); #endif printf("BOOT: %s\n", bsel_str[bsel].name);
Add the defines for the reset manager and some basic reset functionality.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- arch/arm/mach-socfpga/include/mach/reset_manager.h | 65 ++++++++++++++++++++++ arch/arm/mach-socfpga/reset_manager.c | 24 +++++++- 2 files changed, 88 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index 2f070f2..6225118 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -15,6 +15,7 @@ void socfpga_bridges_reset(int enable); void socfpga_per_reset(u32 reset, int set); void socfpga_per_reset_all(void);
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) struct socfpga_reset_manager { u32 status; u32 ctrl; @@ -28,6 +29,42 @@ struct socfpga_reset_manager { u32 padding2[12]; u32 tstscratch; }; +#else +struct socfpga_reset_manager { + u32 stat; + u32 ramstat; + u32 miscstat; + u32 ctrl; + u32 hdsken; + u32 hdskreq; + u32 hdskack; + u32 counts; + u32 mpu_mod_reset; + u32 per_mod_reset; /* stated as per0_mod_reset in A10 datasheet */ + u32 per2_mod_reset; /* stated as per1_mod_reset in A10 datasheet */ + u32 brg_mod_reset; + u32 misc_mod_reset; /* stated as sys_mod_reset in A10 datasheet */ + u32 coldmodrst; + u32 nrstmodrst; + u32 dbgmodrst; + u32 mpuwarmmask; + u32 per0warmmask; + u32 per1warmmask; + u32 brgwarmmask; + u32 syswarmmask; + u32 nrstwarmmask; + u32 l3warmmask; + u32 tststa; + u32 tstscratch; + u32 hdsktimeout; + u32 hmcintr; + u32 hmcintren; + u32 hmcintrens; + u32 hmcintrenr; + u32 hmcgpout; + u32 hmcgpin; +}; +#endif
#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) #define RSTMGR_CTRL_SWWARMRSTREQ_LSB 2 @@ -55,6 +92,7 @@ struct socfpga_reset_manager { #define RSTMGR_BANK(_reset) \ (((_reset) >> RSTMGR_BANK_OFFSET) & RSTMGR_BANK_MASK)
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* * SocFPGA Cyclone V/Arria V reset IDs, bank mapping is as follows: * 0 ... mpumodrst @@ -75,6 +113,33 @@ struct socfpga_reset_manager { #define RSTMGR_SDMMC RSTMGR_DEFINE(1, 22) #define RSTMGR_DMA RSTMGR_DEFINE(1, 28) #define RSTMGR_SDR RSTMGR_DEFINE(1, 29) +#else +/* + * SocFPGA Arria10 reset IDs, bank mapping is as follows: + * 0 ... mpumodrst + * 1 ... per0modrst + * 2 ... per1modrst + * 3 ... brgmodrst + * 4 ... sysmodrst + */ +#define RSTMGR_EMAC0 RSTMGR_DEFINE(1, 0) +#define RSTMGR_EMAC1 RSTMGR_DEFINE(1, 1) +#define RSTMGR_EMAC2 RSTMGR_DEFINE(1, 2) +#define RSTMGR_L4WD0 RSTMGR_DEFINE(2, 0) +#define RSTMGR_L4WD1 RSTMGR_DEFINE(2, 1) +#define RSTMGR_L4SYSTIMER0 RSTMGR_DEFINE(2, 2) +#define RSTMGR_L4SYSTIMER1 RSTMGR_DEFINE(2, 3) +#define RSTMGR_SPTIMER0 RSTMGR_DEFINE(2, 4) +#define RSTMGR_SPTIMER1 RSTMGR_DEFINE(2, 5) +#define RSTMGR_UART0 RSTMGR_DEFINE(2, 16) +#define RSTMGR_UART1 RSTMGR_DEFINE(2, 17) +#define RSTMGR_SPIM0 RSTMGR_DEFINE(1, 17) +#define RSTMGR_SPIM1 RSTMGR_DEFINE(1, 18) +#define RSTMGR_QSPI RSTMGR_DEFINE(1, 6) +#define RSTMGR_SDMMC RSTMGR_DEFINE(1, 7) +#define RSTMGR_DMA RSTMGR_DEFINE(1, 16) +#define RSTMGR_DDRSCH RSTMGR_DEFINE(3, 6) +#endif
/* Create a human-readable reference to SoCFPGA reset. */ #define SOCFPGA_RESET(_name) RSTMGR_##_name diff --git a/arch/arm/mach-socfpga/reset_manager.c b/arch/arm/mach-socfpga/reset_manager.c index b6beaa2..d0ff6c4 100644 --- a/arch/arm/mach-socfpga/reset_manager.c +++ b/arch/arm/mach-socfpga/reset_manager.c @@ -18,7 +18,9 @@ static const struct socfpga_reset_manager *reset_manager_base = static struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
-/* Assert or de-assert SoCFPGA reset manager reset. */ +/* + * Assert or de-assert SoCFPGA reset manager reset. + */ void socfpga_per_reset(u32 reset, int set) { const void *reg; @@ -46,13 +48,29 @@ void socfpga_per_reset(u32 reset, int set) * Assert reset on every peripheral but L4WD0. * Watchdog must be kept intact to prevent glitches * and/or hangs. + * For the Arria10, we disable all the peripherals except L4 watchdog0, + * L4 Timer 0, and ECC. */ void socfpga_per_reset_all(void) { +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) const u32 l4wd0 = 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0));
writel(~l4wd0, &reset_manager_base->per_mod_reset); writel(0xffffffff, &reset_manager_base->per2_mod_reset); +#else + const u32 l4wd0 = (1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)) | + (1 << RSTMGR_RESET(SOCFPGA_RESET(L4SYSTIMER0)))); + + unsigned mask_ecc_ocp = 0x0000FF00; + + /* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */ + writel(~l4wd0, &reset_manager_base->per1_mod_reset); + setbits_le32(&reset_manager_base->per0_mod_reset, ~mask_ecc_ocp); + + /* Finally disable the ECC_OCP */ + setbits_le32(&reset_manager_base->per0_mod_reset, mask_ecc_ocp); +#endif }
/* @@ -71,6 +89,7 @@ void reset_cpu(ulong addr) ; }
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* * Release peripherals from reset based on handoff */ @@ -78,6 +97,7 @@ void reset_deassert_peripherals_handoff(void) { writel(0, &reset_manager_base->per_mod_reset); } +#endif
#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) void socfpga_bridges_reset(int enable) @@ -92,6 +112,7 @@ void socfpga_bridges_reset(int enable)
void socfpga_bridges_reset(int enable) { +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) const uint32_t l3mask = L3REGS_REMAP_LWHPS2FPGA_MASK | L3REGS_REMAP_HPS2FPGA_MASK | L3REGS_REMAP_OCRAM_MASK; @@ -116,5 +137,6 @@ void socfpga_bridges_reset(int enable) /* Remap the bridges into memory map */ writel(l3mask, SOCFPGA_L3REGS_ADDRESS); } +#endif } #endif
The system manager on Arria10 is not used for pin muxing duties, so wrap these functions for GEN5 devices only.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- arch/arm/mach-socfpga/system_manager.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-socfpga/system_manager.c b/arch/arm/mach-socfpga/system_manager.c index 75a65f3..9e1c3fd 100644 --- a/arch/arm/mach-socfpga/system_manager.c +++ b/arch/arm/mach-socfpga/system_manager.c @@ -19,6 +19,7 @@ static struct socfpga_system_manager *sysmgr_regs = * The value is not wrote to SYSMGR.FPGAINTF.MODULE but * CONFIG_SYSMGR_ISWGRP_HANDOFF. */ +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static void populate_sysmgr_fpgaintf_module(void) { uint32_t handoff_val = 0; @@ -83,3 +84,4 @@ void sysmgr_config_warmrstcfgio(int enable) clrbits_le32(&sysmgr_regs->romcodegrp_ctrl, SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO); } +#endif /* CONFIG_TARGET_SOCFPGA_GEN5 */
The Arria10 device will not be able to re-use the GEN5 SDRAM controller, so we shouldn't build the driver. Move CONFIG_ALTERA_SDRAM to Kconfig option in drivers/ddr/altera/Kconfig.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- drivers/Kconfig | 2 ++ drivers/ddr/Kconfig | 1 + drivers/ddr/altera/Kconfig | 6 ++++++ include/configs/socfpga_common.h | 5 ----- 4 files changed, 9 insertions(+), 5 deletions(-) create mode 100644 drivers/ddr/Kconfig create mode 100644 drivers/ddr/altera/Kconfig
diff --git a/drivers/Kconfig b/drivers/Kconfig index e8c9e0a..0178498 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -14,6 +14,8 @@ source "drivers/cpu/Kconfig"
source "drivers/crypto/Kconfig"
+source "drivers/ddr/Kconfig" + source "drivers/demo/Kconfig"
source "drivers/dfu/Kconfig" diff --git a/drivers/ddr/Kconfig b/drivers/ddr/Kconfig new file mode 100644 index 0000000..b764add --- /dev/null +++ b/drivers/ddr/Kconfig @@ -0,0 +1 @@ +source "drivers/ddr/altera/Kconfig" diff --git a/drivers/ddr/altera/Kconfig b/drivers/ddr/altera/Kconfig new file mode 100644 index 0000000..9554da7 --- /dev/null +++ b/drivers/ddr/altera/Kconfig @@ -0,0 +1,6 @@ +config ALTERA_SDRAM + bool "SoCFPGA SDRAM for Arria5/Cyclone5 devices" + default y if TARGET_SOCFPGA_GEN5 + help + This is for building the SDRAM controller for the Arria5/Cyclone5 + devices. diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 58a6550..f6a2f8d 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -77,11 +77,6 @@ #define CONFIG_SYS_PL310_BASE SOCFPGA_MPUL2_ADDRESS
/* - * SDRAM controller - */ -#define CONFIG_ALTERA_SDRAM - -/* * EPCS/EPCQx1 Serial Flash Controller */ #ifdef CONFIG_ALTERA_SPI
On the Arria10 device, the bridges are not mapped through the interconnect.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- drivers/fpga/socfpga.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/fpga/socfpga.c b/drivers/fpga/socfpga.c index f1b2f2c..bfefafd 100644 --- a/drivers/fpga/socfpga.c +++ b/drivers/fpga/socfpga.c @@ -278,8 +278,10 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) /* Disable all axi bridge (hps2fpga, lwhps2fpga & fpga2hps) */ socfpga_bridges_reset(1);
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* Unmap the bridges from NIC-301 */ writel(0x1, SOCFPGA_L3REGS_ADDRESS); +#endif
/* Initialize the FPGA Manager */ status = fpgamgr_program_init();
These functions are already in arch/arm/mach-socfpga/board.c
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- board/altera/arria10-socdk/socfpga.c | 17 ----------------- 1 file changed, 17 deletions(-)
diff --git a/board/altera/arria10-socdk/socfpga.c b/board/altera/arria10-socdk/socfpga.c index abedc22..8516633 100644 --- a/board/altera/arria10-socdk/socfpga.c +++ b/board/altera/arria10-socdk/socfpga.c @@ -5,20 +5,3 @@ */
#include <common.h> -#include <asm/io.h> - -DECLARE_GLOBAL_DATA_PTR; - -void s_init(void) -{ -} - -/* - * Miscellaneous platform dependent initialisations - */ -int board_init(void) -{ - /* Address of boot parameters for ATAG (if ATAG is used) */ - gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; - return 0; -}
There is no dependency on doing a separate clrbits first in the dwmac_deassert_reset function. Combine them into a single clrsetbits call.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- arch/arm/mach-socfpga/misc.c | 9 +++------ 1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 2645129..c97caea 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -100,13 +100,10 @@ static void dwmac_deassert_reset(const unsigned int of_reset_id, return; }
- /* Clearing emac0 PHY interface select to 0 */ - clrbits_le32(&sysmgr_regs->emacgrp_ctrl, - SYSMGR_EMACGRP_CTRL_PHYSEL_MASK << physhift); - /* configure to PHY interface select choosed */ - setbits_le32(&sysmgr_regs->emacgrp_ctrl, - phymode << physhift); + clrsetbits_le32(&sysmgr_regs->emacgrp_ctrl, + SYSMGR_EMACGRP_CTRL_PHYSEL_MASK << physhift, + phymode << physhift);
/* Release the EMAC controller from reset */ socfpga_per_reset(reset, 0);
Add the Arria10 reset manager defines that is used in Linux. Change the license to SPDX.
[commit 007bb689b3dbad83cdab0ad192bc6ed0162451e0 from the Linux kernel]
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- include/dt-bindings/reset/altr,rst-mgr-a10.h | 103 +++++++++++++++++++++++++++ 1 file changed, 103 insertions(+) create mode 100644 include/dt-bindings/reset/altr,rst-mgr-a10.h
diff --git a/include/dt-bindings/reset/altr,rst-mgr-a10.h b/include/dt-bindings/reset/altr,rst-mgr-a10.h new file mode 100644 index 0000000..7619ca2 --- /dev/null +++ b/include/dt-bindings/reset/altr,rst-mgr-a10.h @@ -0,0 +1,103 @@ +/* + * Copyright (c) 2014, Steffen Trumtrar s.trumtrar@pengutronix.de + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _DT_BINDINGS_RESET_ALTR_RST_MGR_A10_H +#define _DT_BINDINGS_RESET_ALTR_RST_MGR_A10_H + +/* MPUMODRST */ +#define CPU0_RESET 0 +#define CPU1_RESET 1 +#define WDS_RESET 2 +#define SCUPER_RESET 3 + +/* PER0MODRST */ +#define EMAC0_RESET 32 +#define EMAC1_RESET 33 +#define EMAC2_RESET 34 +#define USB0_RESET 35 +#define USB1_RESET 36 +#define NAND_RESET 37 +#define QSPI_RESET 38 +#define SDMMC_RESET 39 +#define EMAC0_OCP_RESET 40 +#define EMAC1_OCP_RESET 41 +#define EMAC2_OCP_RESET 42 +#define USB0_OCP_RESET 43 +#define USB1_OCP_RESET 44 +#define NAND_OCP_RESET 45 +#define QSPI_OCP_RESET 46 +#define SDMMC_OCP_RESET 47 +#define DMA_RESET 48 +#define SPIM0_RESET 49 +#define SPIM1_RESET 50 +#define SPIS0_RESET 51 +#define SPIS1_RESET 52 +#define DMA_OCP_RESET 53 +#define EMAC_PTP_RESET 54 +/* 55 is empty*/ +#define DMAIF0_RESET 56 +#define DMAIF1_RESET 57 +#define DMAIF2_RESET 58 +#define DMAIF3_RESET 59 +#define DMAIF4_RESET 60 +#define DMAIF5_RESET 61 +#define DMAIF6_RESET 62 +#define DMAIF7_RESET 63 + +/* PER1MODRST */ +#define L4WD0_RESET 64 +#define L4WD1_RESET 65 +#define L4SYSTIMER0_RESET 66 +#define L4SYSTIMER1_RESET 67 +#define SPTIMER0_RESET 68 +#define SPTIMER1_RESET 69 +/* 70-71 is reserved */ +#define I2C0_RESET 72 +#define I2C1_RESET 73 +#define I2C2_RESET 74 +#define I2C3_RESET 75 +#define I2C4_RESET 76 +/* 77-79 is reserved */ +#define UART0_RESET 80 +#define UART1_RESET 81 +/* 82-87 is reserved */ +#define GPIO0_RESET 88 +#define GPIO1_RESET 89 +#define GPIO2_RESET 90 + +/* BRGMODRST */ +#define HPS2FPGA_RESET 96 +#define LWHPS2FPGA_RESET 97 +#define FPGA2HPS_RESET 98 +#define F2SSDRAM0_RESET 99 +#define F2SSDRAM1_RESET 100 +#define F2SSDRAM2_RESET 101 +#define DDRSCH_RESET 102 + +/* SYSMODRST*/ +#define ROM_RESET 128 +#define OCRAM_RESET 129 +/* 130 is reserved */ +#define FPGAMGR_RESET 131 +#define S2F_RESET 132 +#define SYSDBG_RESET 133 +#define OCRAM_OCP_RESET 134 + +/* COLDMODRST */ +#define CLKMGRCOLD_RESET 160 +/* 161-162 is reserved */ +#define S2FCOLD_RESET 163 +#define TIMESTAMPCOLD_RESET 164 +#define TAPCOLD_RESET 165 +#define HMCCOLD_RESET 166 +#define IOMGRCOLD_RESET 167 + +/* NRSTMODRST */ +#define NRSTPINOE_RESET 192 + +/* DBGMODRST */ +#define DBG_RESET 224 +#endif
On the Arria10, the EMAC phy mode configuration for each EMACs is located in separate registers versus being in 1 register for the GEN5 devices. The Arria10 also has 3 EMACs compared to 2 for the GEN5 devices.
Update the dwmac_deassert_reset function to support both GEN5 and Arria10 devices.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- arch/arm/mach-socfpga/include/mach/system_manager.h | 4 +--- arch/arm/mach-socfpga/misc.c | 14 ++++++++++++++ 2 files changed, 15 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index 9ca889a..831ba4a 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -133,9 +133,7 @@ struct socfpga_system_manager { u32 usb0_l3master; u32 usb1_l3master; u32 emac_global; - u32 emac0; - u32 emac1; - u32 emac2; + u32 emac[3]; u32 _pad_0x50_0x5f[4]; u32 fpgaintf_en_global; u32 fpgaintf_en_0; diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index c97caea..510aa1d 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -21,7 +21,11 @@ #include <asm/arch/scu.h> #include <asm/pl310.h>
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #include <dt-bindings/reset/altr,rst-mgr.h> +#else +#include <dt-bindings/reset/altr,rst-mgr-a10.h> +#endif
@@ -95,15 +99,25 @@ static void dwmac_deassert_reset(const unsigned int of_reset_id, } else if (of_reset_id == EMAC1_RESET) { physhift = SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB; reset = SOCFPGA_RESET(EMAC1); +#ifndef CONFIG_TARGET_SOCFPGA_GEN5 + } else if (of_reset_id == EMAC2_RESET) { + reset = SOCFPGA_RESET(EMAC2); +#endif } else { printf("GMAC: Invalid reset ID (%i)!\n", of_reset_id); return; }
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* configure to PHY interface select choosed */ clrsetbits_le32(&sysmgr_regs->emacgrp_ctrl, SYSMGR_EMACGRP_CTRL_PHYSEL_MASK << physhift, phymode << physhift); +#else + clrsetbits_le32(&sysmgr_regs->emac[of_reset_id - EMAC0_RESET], + SYSMGR_EMACGRP_CTRL_PHYSEL_MASK, + phymode); +#endif
Chee Tien Fong
