[U-Boot] [PATCH] spi: add NXP FlexSPI driver
Add NXP Flexspi driver for i.MX8 Family usage. Flexible Serial Peripheral Interface (FlexSPI) host controller supports two SPI channels and up to 4 external devices. Each channel supports Single/Dual/Quad/Octal mode data transfer (1/2/4/8 bidirectional data lines).
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/spi/Kconfig | 19 + drivers/spi/Makefile | 1 + drivers/spi/fsl_fspi.c | 1291 ++++++++++++++++++++++++++++++++++++++++++++++++ drivers/spi/fsl_fspi.h | 170 +++++++ 4 files changed, 1481 insertions(+) create mode 100644 drivers/spi/fsl_fspi.c create mode 100644 drivers/spi/fsl_fspi.h
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index f459c0a411..b71f289fb7 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -372,6 +372,25 @@ config FSL_ESPI access the SPI interface and SPI NOR flash on platforms embedding this Freescale eSPI IP core.
+config FSL_FSPI + bool "NXP FlexSPI driver" + help + Enable the NXP FlexSPI (FSPI) driver. This driver can be + used to access the SPI NOR flash on platforms embedding this + NXP IP core. + +if FSL_FSPI +config FSPI_QUAD_SUPPORT + bool "FlexSPI QUAD support" + help + Enable Quad Read/write + +config FSPI_AHB + bool "FlexSPI AHB support" + help + Enable AHB buffer read +endif + config FSL_QSPI bool "Freescale QSPI driver" imply SPI_FLASH_BAR diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index ae4f2958f8..867feb994b 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -30,6 +30,7 @@ obj-$(CONFIG_DESIGNWARE_SPI) += designware_spi.o obj-$(CONFIG_EXYNOS_SPI) += exynos_spi.o obj-$(CONFIG_FSL_DSPI) += fsl_dspi.o obj-$(CONFIG_FSL_ESPI) += fsl_espi.o +obj-$(CONFIG_FSL_FSPI) += fsl_fspi.o obj-$(CONFIG_FSL_QSPI) += fsl_qspi.o obj-$(CONFIG_ICH_SPI) += ich.o obj-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o diff --git a/drivers/spi/fsl_fspi.c b/drivers/spi/fsl_fspi.c new file mode 100644 index 0000000000..7f9d2f0b45 --- /dev/null +++ b/drivers/spi/fsl_fspi.c @@ -0,0 +1,1291 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +#include <common.h> +#include <asm/io.h> +#include <clk.h> +#include <dm.h> +#include <errno.h> +#include <linux/sizes.h> +#include <malloc.h> +#include <spi.h> +#include <watchdog.h> + +#include "fsl_fspi.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define RX_BUFFER_SIZE 0x200 +#define TX_BUFFER_SIZE 0x400 +#define AHB_BUFFER_SIZE 0x800 + +/* SEQID */ +#define SEQID_READ 0 +#define SEQID_WREN 1 +#define SEQID_FAST_READ 2 +#define SEQID_RDSR 3 +#define SEQID_SE 4 +#define SEQID_CHIP_ERASE 5 +#define SEQID_PP 6 +#define SEQID_RDID 7 +#define SEQID_BE_4K 8 +#ifdef CONFIG_SPI_FLASH_BAR +#define SEQID_BRRD 9 +#define SEQID_BRWR 10 +#define SEQID_RDEAR 11 +#define SEQID_WREAR 12 +#endif +#define SEQID_RDEVCR 13 +#define SEQID_WREVCR 14 +#define SEQID_QUAD_OUTPUT 15 +#define SEQID_RDFSR 16 +#define SEQID_EN4B 17 +#define SEQID_CRFSR 18 + +/* FSPI CMD */ +#define FSPI_CMD_PP 0x02 /* Page program (up to 256 bytes) */ +#define FSPI_CMD_RDSR 0x05 /* Read status register */ +#define FSPI_CMD_WREN 0x06 /* Write enable */ +#define FSPI_CMD_FAST_READ 0x0b /* Read data bytes (high frequency) */ +#define FSPI_CMD_READ 0x03 /* Read data bytes */ +#define FSPI_CMD_BE_4K 0x20 /* 4K erase */ +#define FSPI_CMD_CHIP_ERASE 0xc7 /* Erase whole flash chip */ +#define FSPI_CMD_SE 0xd8 /* Sector erase (usually 64KiB) */ +#define FSPI_CMD_RDID 0x9f /* Read JEDEC ID */ + +/* Used for Micron, winbond and Macronix flashes */ +#define FSPI_CMD_WREAR 0xc5 /* EAR register write */ +#define FSPI_CMD_RDEAR 0xc8 /* EAR reigster read */ + +/* Used for Spansion flashes only. */ +#define FSPI_CMD_BRRD 0x16 /* Bank register read */ +#define FSPI_CMD_BRWR 0x17 /* Bank register write */ + +/* 4-byte address FSPI CMD - used on Spansion and some Macronix flashes */ +#define FSPI_CMD_FAST_READ_4B 0x0c /* Read data bytes (high frequency) */ +#define FSPI_CMD_PP_4B 0x12 /* Page program (up to 256 bytes) */ +#define FSPI_CMD_SE_4B 0xdc /* Sector erase (usually 64KiB) */ +#define FSPI_CMD_BE_4K_4B 0x21 /* 4K erase */ + +#define FSPI_CMD_RD_EVCR 0x65 /* Read EVCR register */ +#define FSPI_CMD_WR_EVCR 0x61 /* Write EVCR register */ + +#define FSPI_CMD_EN4B 0xB7 + +/* 1-1-4 READ CMD */ +#define FSPI_CMD_QUAD_OUTPUT 0x6b +#define FSPI_CMD_DDR_QUAD_OUTPUT 0x6d + +/* read flag status register */ +#define FSPI_CMD_RDFSR 0x70 +#define FSPI_CMD_CRFSR 0x50 + +/* fsl_fspi_platdata flags */ +#define FSPI_FLAG_REGMAP_ENDIAN_BIG BIT(0) + +/* default SCK frequency, unit: HZ */ +#define FSL_FSPI_DEFAULT_SCK_FREQ 50000000 + +/* FSPI max chipselect signals number */ +#define FSL_FSPI_MAX_CHIPSELECT_NUM 4 + +#define FSPI_AHB_BASE_ADDR 0x08000000 + +/** + * struct fsl_fspi_platdata - platform data for NXP FSPI + * + * @flags: Flags for FSPI FSPI_FLAG_... + * @speed_hz: Default SCK frequency + * @reg_base: Base address of FSPI registers + * @amba_base: Base address of FSPI memory mapping + * @amba_total_size: size of FSPI memory mapping + * @flash_num: Number of active slave devices + * @num_chipselect: Number of FSPI chipselect signals + */ +struct fsl_fspi_platdata { + u32 flags; + u32 speed_hz; + u32 reg_base; + u32 amba_base; + u32 amba_total_size; + u32 flash_num; + u32 num_chipselect; +}; + +/** + * struct fsl_fspi_priv - private data for NXP FSPI + * + * @flags: Flags for FSPI FSPI_FLAG_... + * @bus_clk: FSPI input clk frequency + * @speed_hz: Default SCK frequency + * @cur_seqid: current LUT table sequence id + * @sf_addr: flash access offset + * @amba_base: Base address of FSPI memory mapping of every CS + * @amba_total_size: size of FSPI memory mapping + * @cur_amba_base: Base address of FSPI memory mapping of current CS + * @flash_num: Number of active slave devices + * @num_chipselect: Number of FSPI chipselect signals + * @regs: Point to FSPI register structure for I/O access + */ +struct fsl_fspi_priv { + u32 flags; + u32 bus_clk; + u32 speed_hz; + u32 cur_seqid; + u32 sf_addr; + u32 amba_base[FSL_FSPI_MAX_CHIPSELECT_NUM]; + u32 amba_total_size; + u32 cur_amba_base; + u32 flash_num; + u32 num_chipselect; + struct fsl_fspi_regs *regs; +}; + +static u32 fspi_read32(u32 flags, u32 *addr) +{ + return flags & FSPI_FLAG_REGMAP_ENDIAN_BIG ? + in_be32(addr) : in_le32(addr); +} + +static void fspi_write32(u32 flags, u32 *addr, u32 val) +{ + flags & FSPI_FLAG_REGMAP_ENDIAN_BIG ? + out_be32(addr, val) : out_le32(addr, val); +} + +static void fspi_set_lut(struct fsl_fspi_priv *priv) +{ + struct fsl_fspi_regs *regs = priv->regs; + u32 lut_base; + + /* Unlock the LUT */ + fspi_write32(priv->flags, ®s->lutkey, FLEXSPI_LUTKEY_VALUE); + fspi_write32(priv->flags, ®s->lutcr, FLEXSPI_LCKER_UNLOCK); + + /* READ */ + lut_base = SEQID_READ * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_READ) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(ADDR32BIT) | + PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], + OPRND0(0) | PAD0(LUT_PAD1) | + INSTR0(LUT_READ)); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + /* Write Enable */ + lut_base = SEQID_WREN * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_WREN) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + /* Fast Read */ + lut_base = SEQID_FAST_READ * 4; +#ifdef CONFIG_SPI_FLASH_BAR + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_FAST_READ) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | + PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); +#else + if (FSL_FSPI_FLASH_SIZE <= SZ_16M) + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_FAST_READ) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | + PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); + else + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_FAST_READ_4B) | + PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | + OPRND1(ADDR32BIT) | PAD1(LUT_PAD1) | + INSTR1(LUT_ADDR)); +#endif + fspi_write32(priv->flags, ®s->lut[lut_base + 1], + OPRND0(8) | PAD0(LUT_PAD1) | INSTR0(LUT_DUMMY) | + OPRND1(0) | PAD1(LUT_PAD1) | + INSTR1(LUT_READ)); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + /* Read Status */ + lut_base = SEQID_RDSR * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_RDSR) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(1) | PAD1(LUT_PAD1) | + INSTR1(LUT_READ)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + /* Erase a sector */ + lut_base = SEQID_SE * 4; +#ifdef CONFIG_SPI_FLASH_BAR + fspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(FSPI_CMD_SE) | + PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | + PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); +#else + if (FSL_FSPI_FLASH_SIZE <= SZ_16M) + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_SE) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | + PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); + else + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_SE_4B) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(ADDR32BIT) | + PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); +#endif + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + /* Erase the whole chip */ + lut_base = SEQID_CHIP_ERASE * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_CHIP_ERASE) | + PAD0(LUT_PAD1) | INSTR0(LUT_CMD)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + /* Page Program */ + lut_base = SEQID_PP * 4; +#ifdef CONFIG_SPI_FLASH_BAR + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_PP) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | PAD1(LUT_PAD1) | + INSTR1(LUT_ADDR)); +#else + if (FSL_FSPI_FLASH_SIZE <= SZ_16M) + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_PP) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | + PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); + else + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_PP_4B) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(ADDR32BIT) | + PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); +#endif + fspi_write32(priv->flags, ®s->lut[lut_base + 1], + OPRND0(0) | + PAD0(LUT_PAD1) | INSTR0(LUT_WRITE)); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + /* READ ID */ + lut_base = SEQID_RDID * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_RDID) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(8) | PAD1(LUT_PAD1) | + INSTR1(LUT_READ)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + /* SUB SECTOR 4K ERASE */ + lut_base = SEQID_BE_4K * 4; +#ifdef CONFIG_SPI_FLASH_BAR + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_BE_4K) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | PAD1(LUT_PAD1) | + INSTR1(LUT_ADDR)); +#else + if (FSL_FSPI_FLASH_SIZE <= SZ_16M) + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_BE_4K) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | + PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); + else + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_BE_4K_4B) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(ADDR32BIT) | + PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); +#endif + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + +#ifdef CONFIG_SPI_FLASH_BAR + /* + * BRRD BRWR RDEAR WREAR are all supported, because it is hard to + * dynamically check whether to set BRRD BRWR or RDEAR WREAR during + * initialization. + */ + lut_base = SEQID_BRRD * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_BRRD) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(1) | PAD1(LUT_PAD1) | + INSTR1(LUT_READ)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + lut_base = SEQID_BRWR * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_BRWR) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(1) | PAD1(LUT_PAD1) | + INSTR1(LUT_WRITE)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + lut_base = SEQID_RDEAR * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_RDEAR) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(1) | PAD1(LUT_PAD1) | + INSTR1(LUT_READ)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + lut_base = SEQID_WREAR * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_WREAR) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(1) | PAD1(LUT_PAD1) | + INSTR1(LUT_WRITE)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); +#endif + lut_base = SEQID_RDEVCR * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_RD_EVCR) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + lut_base = SEQID_WREVCR * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_WR_EVCR) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + +#ifdef CONFIG_FSPI_QUAD_SUPPORT + /* QUAD OUTPUT READ */ + lut_base = SEQID_QUAD_OUTPUT * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_DDR_QUAD_OUTPUT) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | + PAD1(LUT_PAD1) | INSTR1(LUT_ADDR_DDR)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], + OPRND0(0xc) | PAD0(LUT_PAD4) | + INSTR0(LUT_DUMMY_DDR) | OPRND1(0) | + PAD1(LUT_PAD4) | INSTR1(LUT_READ_DDR)); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); +#endif + + /* Read Flag Status */ + lut_base = SEQID_RDFSR * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_RDFSR) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD) | OPRND1(1) | PAD1(LUT_PAD1) | + INSTR1(LUT_READ)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + /* Enter 4 bytes address mode */ + lut_base = SEQID_EN4B * 4; + fspi_write32(priv->flags, ®s->lut[lut_base], + OPRND0(FSPI_CMD_EN4B) | PAD0(LUT_PAD1) | + INSTR0(LUT_CMD)); + fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); + fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); + + /* Lock the LUT */ + fspi_write32(priv->flags, ®s->lutkey, FLEXSPI_LUTKEY_VALUE); + fspi_write32(priv->flags, ®s->lutcr, FLEXSPI_LCKER_LOCK); +} + +#if defined(CONFIG_FSI_AHB) +/* + * If we have changed the content of the flash by writing or erasing, + * we need to invalidate the AHB buffer. If we do not do so, we may read out + * the wrong data. The spec tells us reset the AHB domain and Serial Flash + * domain at the same time. + */ +static inline void fspi_ahb_invalid(struct fsl_fspi_priv *priv) +{ + struct fsl_fspi_regs *regs = priv->regs; + u32 reg; + + reg = fspi_read32(priv->flags, ®s->mcr0); + reg |= FLEXSPI_MCR0_SWRST_MASK; + fspi_write32(priv->flags, ®s->mcr0, reg); + + while ((fspi_read32(priv->flags, ®s->mcr0) & 1)) + ; +} + +/* Read out the data from the AHB buffer. */ +static inline void fspi_ahb_read(struct fsl_fspi_priv *priv, u8 *rxbuf, + int len) +{ + /* Read out the data directly from the AHB buffer. */ + memcpy(rxbuf, (u8 *)(FSPI_AHB_BASE_ADDR + + (uintptr_t)priv->sf_addr), len); +} + +/* + * There are two different ways to read out the data from the flash: + * the "IP Command Read" and the "AHB Command Read". + * + * The IC guy suggests we use the "AHB Command Read" which is faster + * then the "IP Command Read". (What's more is that there is a bug in + * the "IP Command Read" in the Vybrid.) + * + * After we set up the registers for the "AHB Command Read", we can use + * the memcpy to read the data directly. A "missed" access to the buffer + * causes the controller to clear the buffer, and use the sequence pointed + * by the QUADSPI_BFGENCR[SEQID] to initiate a read from the flash. + */ +static void fspi_init_ahb_read(struct fsl_fspi_priv *priv) +{ + struct fsl_fspi_regs *regs = priv->regs; + int i; + + /* AHB configuration for access buffer 0~7 .*/ + for (i = 0; i < 7; i++) + fspi_write32(priv->flags, ®s->ahbrxbuf0cr0 + i, 0); + + /* + * Set ADATSZ with the maximum AHB buffer size to improve the read + * performance + */ + fspi_write32(priv->flags, ®s->ahbrxbuf7cr0, AHB_BUFFER_SIZE / 8 | + FLEXSPI_AHBRXBUF0CR7_PREF_MASK); + + fspi_write32(priv->flags, ®s->ahbcr, FLEXSPI_AHBCR_PREF_EN_MASK); + /* + * Set the default lut sequence for AHB Read. + * Parallel mode is disabled. + */ +#ifdef CONFIG_FSPI_QUAD_SUPPORT + fspi_write32(priv->flags, ®s->flsha1cr2, SEQID_QUAD_OUTPUT); +#else + fspi_write32(priv->flags, ®s->flsha1cr2, SEQID_FAST_READ); +#endif +} +#endif + +#ifdef CONFIG_SPI_FLASH_BAR +/* Bank register read/write, EAR register read/write */ +static void fspi_op_rdbank(struct fsl_fspi_priv *priv, u8 *rxbuf, u32 len) +{ + struct fsl_fspi_regs *regs = priv->regs; + u32 data, seqid; + + /* invalid the RXFIFO first */ + fspi_write32(priv->flags, ®s->iprxfcr, FLEXSPI_IPRXFCR_CLR_MASK); + + fspi_write32(priv->flags, ®s->ipcr0, priv->cur_amba_base); + + if (priv->cur_seqid == FSPI_CMD_BRRD) + seqid = SEQID_BRRD; + else + seqid = SEQID_RDEAR; + + fspi_write32(priv->flags, ®s->ipcr1, + (seqid << FLEXSPI_IPCR1_SEQID_SHIFT) | len); + + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + /* Wait for command done */ + while (!(fspi_read32(priv->flags, ®s->intr) & + FLEXSPI_INTR_IPCMDDONE_MASK)) + ; + + while (1) { + data = fspi_read32(priv->flags, ®s->rfdr[0]); + memcpy(rxbuf, &data, len); + break; + } + + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPRXWA_MASK); + fspi_write32(priv->flags, ®s->iprxfcr, FLEXSPI_IPRXFCR_CLR_MASK); + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPCMDDONE_MASK); +} +#endif + +static void fspi_op_rdevcr(struct fsl_fspi_priv *priv, u8 *rxbuf, u32 len) +{ + struct fsl_fspi_regs *regs = priv->regs; + u32 data; + + /* invalid the RXFIFO first */ + fspi_write32(priv->flags, ®s->iprxfcr, FLEXSPI_IPRXFCR_CLR_MASK); + + fspi_write32(priv->flags, ®s->ipcr0, priv->cur_amba_base); + + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_RDEVCR << FLEXSPI_IPCR1_SEQID_SHIFT) | len); + + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + /* Wait for command done */ + while (!(fspi_read32(priv->flags, ®s->intr) + & FLEXSPI_INTR_IPCMDDONE_MASK)) + ; + + while (1) { + data = fspi_read32(priv->flags, ®s->rfdr[0]); + memcpy(rxbuf, &data, len); + break; + } + + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPRXWA_MASK); + fspi_write32(priv->flags, ®s->iprxfcr, FLEXSPI_IPRXFCR_CLR_MASK); + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPCMDDONE_MASK); +} + +static void fspi_op_wrevcr(struct fsl_fspi_priv *priv, u8 *txbuf, u32 len) +{ + struct fsl_fspi_regs *regs = priv->regs; + + /* invalid the TXFIFO first */ + fspi_write32(priv->flags, ®s->iptxfcr, FLEXSPI_IPTXFCR_CLR_MASK); + + fspi_write32(priv->flags, ®s->ipcr0, priv->cur_amba_base); + + /* Wait for TXFIFO empty*/ + while (!(fspi_read32(priv->flags, ®s->intr) & + FLEXSPI_INTR_IPTXWE_MASK)) + ; + + /* write the data to TXFIFO */ + memcpy(®s->tfdr, txbuf, len); + + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPTXWE_MASK); + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_WREVCR << FLEXSPI_IPCR1_SEQID_SHIFT) | len); + + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + /* Wait for command done */ + while (!(fspi_read32(priv->flags, ®s->intr) & + FLEXSPI_INTR_IPCMDDONE_MASK)) + ; + + /* invalid the TXFIFO first */ + fspi_write32(priv->flags, ®s->iptxfcr, FLEXSPI_IPTXFCR_CLR_MASK); + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPCMDDONE_MASK); +} + +static void fspi_op_rdid(struct fsl_fspi_priv *priv, u32 *rxbuf, u32 len) +{ + struct fsl_fspi_regs *regs = priv->regs; + u32 data, size; + int i; + + /* invalid the RXFIFO first */ + fspi_write32(priv->flags, ®s->iprxfcr, FLEXSPI_IPRXFCR_CLR_MASK); + + fspi_write32(priv->flags, ®s->ipcr0, priv->cur_amba_base); + + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_RDID << FLEXSPI_IPCR1_SEQID_SHIFT) | len); + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + /* Wait for command done */ + while (!(fspi_read32(priv->flags, ®s->intr) & + FLEXSPI_INTR_IPCMDDONE_MASK)) + ; + + i = 0; + while ((len <= RX_BUFFER_SIZE) && (len > 0)) { + data = fspi_read32(priv->flags, ®s->rfdr[i]); + size = (len < 4) ? len : 4; + memcpy(rxbuf, &data, size); + len -= size; + rxbuf++; + i++; + } + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPRXWA_MASK); + + fspi_write32(priv->flags, ®s->iprxfcr, FLEXSPI_IPRXFCR_CLR_MASK); + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPCMDDONE_MASK); +} + +#ifndef CONFIG_FSI_AHB +/* If not use AHB read, read data from ip interface */ +static void fspi_op_read(struct fsl_fspi_priv *priv, u32 *rxbuf, u32 len) +{ + struct fsl_fspi_regs *regs = priv->regs; + int i, size, rx_size; + u32 to_or_from; + + to_or_from = priv->sf_addr + priv->cur_amba_base; + + /* invalid the RXFIFO */ + fspi_write32(priv->flags, ®s->iprxfcr, FLEXSPI_IPRXFCR_CLR_MASK); + + while (len > 0) { + WATCHDOG_RESET(); + + fspi_write32(priv->flags, ®s->ipcr0, to_or_from); + + rx_size = (len > RX_BUFFER_SIZE) ? + RX_BUFFER_SIZE : len; + +#ifdef CONFIG_FSPI_QUAD_SUPPORT + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_QUAD_OUTPUT << FLEXSPI_IPCR1_SEQID_SHIFT) | + rx_size); +#else + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_FAST_READ << FLEXSPI_IPCR1_SEQID_SHIFT) | + rx_size); +#endif + + to_or_from += rx_size; + len -= rx_size; + + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + size = rx_size / 8; + for (i = 0; i < size; ++i) { + /* Wait for RXFIFO available*/ + while (!(fspi_read32(priv->flags, ®s->intr) + & FLEXSPI_INTR_IPRXWA_MASK)) + ; + + memcpy(rxbuf, ®s->rfdr, 8); + rxbuf += 2; + + /* move the FIFO pointer */ + fspi_write32(priv->flags, ®s->intr, + FLEXSPI_INTR_IPRXWA_MASK); + } + + size = rx_size % 8; + + if (size) { + /* Wait for data filled*/ + while (!(fspi_read32(priv->flags, ®s->iprxfsts) + & FLEXSPI_IPRXFSTS_FILL_MASK)) + ; + memcpy(rxbuf, ®s->rfdr, size); + } + + /* invalid the RXFIFO */ + fspi_write32(priv->flags, ®s->iprxfcr, + FLEXSPI_IPRXFCR_CLR_MASK); + fspi_write32(priv->flags, ®s->intr, + FLEXSPI_INTR_IPCMDDONE_MASK); + } +} +#endif + +static void fspi_op_write(struct fsl_fspi_priv *priv, u8 *txbuf, u32 len) +{ + struct fsl_fspi_regs *regs = priv->regs; + u32 seqid; + int i, size, tx_size; + u32 to_or_from = 0; + + /* invalid the TXFIFO first */ + fspi_write32(priv->flags, ®s->iptxfcr, FLEXSPI_IPTXFCR_CLR_MASK); + + fspi_write32(priv->flags, ®s->ipcr0, priv->cur_amba_base); + + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_WREN << FLEXSPI_IPCR1_SEQID_SHIFT) | 0); + + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + /* Wait for command done */ + while (!(fspi_read32(priv->flags, ®s->intr) + & FLEXSPI_INTR_IPCMDDONE_MASK)) + ; + + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPCMDDONE_MASK); + + /* invalid the TXFIFO first */ + fspi_write32(priv->flags, ®s->iptxfcr, FLEXSPI_IPTXFCR_CLR_MASK); + + to_or_from = priv->sf_addr + priv->cur_amba_base; + + while (len > 0) { + /* Default is page programming */ + seqid = SEQID_PP; +#ifdef CONFIG_SPI_FLASH_BAR + if (priv->cur_seqid == FSPI_CMD_BRWR) + seqid = SEQID_BRWR; + else if (priv->cur_seqid == FSPI_CMD_WREAR) + seqid = SEQID_WREAR; +#endif + + fspi_write32(priv->flags, ®s->ipcr0, to_or_from); + + tx_size = (len > TX_BUFFER_SIZE) ? + TX_BUFFER_SIZE : len; + + to_or_from += tx_size; + len -= tx_size; + + size = tx_size / 8; + for (i = 0; i < size; i++) { + /* Wait for TXFIFO empty*/ + while (!(fspi_read32(priv->flags, ®s->intr) + & FLEXSPI_INTR_IPTXWE_MASK)) + ; + + memcpy(®s->tfdr, txbuf, 8); + txbuf += 8; + fspi_write32(priv->flags, ®s->intr, + FLEXSPI_INTR_IPTXWE_MASK); + } + + size = tx_size % 8; + if (size) { + /* Wait for TXFIFO empty*/ + while (!(fspi_read32(priv->flags, ®s->intr) + & FLEXSPI_INTR_IPTXWE_MASK)) + ; + + memcpy(®s->tfdr, txbuf, size); + fspi_write32(priv->flags, ®s->intr, + FLEXSPI_INTR_IPTXWE_MASK); + } + + fspi_write32(priv->flags, ®s->ipcr1, + (seqid << FLEXSPI_IPCR1_SEQID_SHIFT) | tx_size); + + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + /* Wait for command done */ + while (!(fspi_read32(priv->flags, ®s->intr) & + FLEXSPI_INTR_IPCMDDONE_MASK)) + ; + + /* invalid the TXFIFO first */ + fspi_write32(priv->flags, ®s->iptxfcr, + FLEXSPI_IPTXFCR_CLR_MASK); + fspi_write32(priv->flags, ®s->intr, + FLEXSPI_INTR_IPCMDDONE_MASK); + } +} + +static void fspi_op_rdsr(struct fsl_fspi_priv *priv, void *rxbuf, u32 len) +{ + struct fsl_fspi_regs *regs = priv->regs; + u32 data; + + /* invalid the RXFIFO first */ + fspi_write32(priv->flags, ®s->iprxfcr, FLEXSPI_IPRXFCR_CLR_MASK); + + fspi_write32(priv->flags, ®s->ipcr0, priv->cur_amba_base); + + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_RDSR << FLEXSPI_IPCR1_SEQID_SHIFT) | len); + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + /* Wait for command done */ + while (!(fspi_read32(priv->flags, ®s->intr) + & FLEXSPI_INTR_IPCMDDONE_MASK)) + ; + + data = fspi_read32(priv->flags, ®s->rfdr[0]); + memcpy(rxbuf, &data, len); + + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPRXWA_MASK); + fspi_write32(priv->flags, ®s->iprxfcr, FLEXSPI_IPRXFCR_CLR_MASK); + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPCMDDONE_MASK); +} + +static void fspi_op_rdfsr(struct fsl_fspi_priv *priv, void *rxbuf, u32 len) +{ + struct fsl_fspi_regs *regs = priv->regs; + u32 data; + + /* invalid the RXFIFO first */ + fspi_write32(priv->flags, ®s->iprxfcr, FLEXSPI_IPRXFCR_CLR_MASK); + + fspi_write32(priv->flags, ®s->ipcr0, priv->cur_amba_base); + + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_RDFSR << FLEXSPI_IPCR1_SEQID_SHIFT) | len); + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + /* Wait for command done */ + while (!(fspi_read32(priv->flags, ®s->intr) + & FLEXSPI_INTR_IPCMDDONE_MASK)) + ; + + data = fspi_read32(priv->flags, ®s->rfdr[0]); + memcpy(rxbuf, &data, len); + + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPRXWA_MASK); + fspi_write32(priv->flags, ®s->iprxfcr, FLEXSPI_IPRXFCR_CLR_MASK); + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPCMDDONE_MASK); +} + +static void fspi_op_erase(struct fsl_fspi_priv *priv) +{ + struct fsl_fspi_regs *regs = priv->regs; + u32 to_or_from = 0; + + to_or_from = priv->sf_addr + priv->cur_amba_base; + + fspi_write32(priv->flags, ®s->ipcr0, to_or_from); + + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_WREN << FLEXSPI_IPCR1_SEQID_SHIFT) | 0); + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + while (!(fspi_read32(priv->flags, ®s->intr) + & FLEXSPI_INTR_IPCMDDONE_MASK)) + ; + + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPCMDDONE_MASK); + + if (priv->cur_seqid == FSPI_CMD_SE || + priv->cur_seqid == FSPI_CMD_SE_4B) { + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_SE << FLEXSPI_IPCR1_SEQID_SHIFT) | 0); + } else if (priv->cur_seqid == FSPI_CMD_BE_4K || + priv->cur_seqid == FSPI_CMD_BE_4K_4B) { + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_BE_4K << FLEXSPI_IPCR1_SEQID_SHIFT) | 0); + } + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + while (!(fspi_read32(priv->flags, ®s->intr) + & FLEXSPI_INTR_IPCMDDONE_MASK)) + ; + + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPCMDDONE_MASK); +} + +static void fspi_op_crfsr(struct fsl_fspi_priv *priv) +{ + struct fsl_fspi_regs *regs = priv->regs; + + /* invalid the TXFIFO first */ + fspi_write32(priv->flags, ®s->iptxfcr, FLEXSPI_IPTXFCR_CLR_MASK); + + fspi_write32(priv->flags, ®s->ipcr0, priv->cur_amba_base); + + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_CRFSR << FLEXSPI_IPCR1_SEQID_SHIFT) | 0); + + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + /* Wait for command done */ + while (!(fspi_read32(priv->flags, ®s->intr) + & FLEXSPI_INTR_IPCMDDONE_MASK)) + ; + + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPCMDDONE_MASK); +} + +static void fspi_op_enter_4bytes(struct fsl_fspi_priv *priv) +{ + struct fsl_fspi_regs *regs = priv->regs; + + /* invalid the TXFIFO first */ + fspi_write32(priv->flags, ®s->iptxfcr, FLEXSPI_IPTXFCR_CLR_MASK); + + fspi_write32(priv->flags, ®s->ipcr0, priv->cur_amba_base); + + fspi_write32(priv->flags, ®s->ipcr1, + (SEQID_EN4B << FLEXSPI_IPCR1_SEQID_SHIFT) | 0); + + /* Trigger the command */ + fspi_write32(priv->flags, ®s->ipcmd, 1); + + /* Wait for command done */ + while (!(fspi_read32(priv->flags, ®s->intr) + & FLEXSPI_INTR_IPCMDDONE_MASK)) + ; + + fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPCMDDONE_MASK); +} + +int fspi_xfer(struct fsl_fspi_priv *priv, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + u32 bytes = DIV_ROUND_UP(bitlen, 8); + static u32 wr_sfaddr; + u32 txbuf = 0; + + if (dout) { + if (flags & SPI_XFER_BEGIN) { + priv->cur_seqid = *(u8 *)dout; + if (bytes > 1) { + int i, addr_bytes; + + if (FSL_FSPI_FLASH_SIZE <= SZ_16M) + addr_bytes = 3; + else +#ifdef CONFIG_SPI_FLASH_BAR + addr_bytes = 3; +#else + addr_bytes = 4; +#endif + + dout = (u8 *)dout + 1; + txbuf = *(u8 *)dout; + for (i = 1; i < addr_bytes; i++) { + txbuf <<= 8; + txbuf |= *(((u8 *)dout) + i); + } + + debug("seqid 0x%x addr 0x%x\n", + priv->cur_seqid, txbuf); + } + } + + if (flags == SPI_XFER_END) { + if (priv->cur_seqid == FSPI_CMD_WR_EVCR) { + fspi_op_wrevcr(priv, (u8 *)dout, bytes); + return 0; + } else if ((priv->cur_seqid == FSPI_CMD_SE) || + (priv->cur_seqid == FSPI_CMD_BE_4K) || + (priv->cur_seqid == FSPI_CMD_SE_4B) || + (priv->cur_seqid == FSPI_CMD_BE_4K_4B)) { + int i; + + txbuf = *(u8 *)dout; + for (i = 1; i < bytes; i++) { + txbuf <<= 8; + txbuf |= *(((u8 *)dout) + i); + } + + priv->sf_addr = txbuf; + fspi_op_erase(priv); +#ifdef CONFIG_FSI_AHB + fspi_ahb_invalid(priv); +#endif + return 0; + } + priv->sf_addr = wr_sfaddr; + fspi_op_write(priv, (u8 *)dout, bytes); + return 0; + } + + if (priv->cur_seqid == FSPI_CMD_QUAD_OUTPUT || + priv->cur_seqid == FSPI_CMD_FAST_READ || + priv->cur_seqid == FSPI_CMD_FAST_READ_4B) { + priv->sf_addr = txbuf; + } else if (priv->cur_seqid == FSPI_CMD_PP || + priv->cur_seqid == FSPI_CMD_PP_4B) { + wr_sfaddr = txbuf; + } else if (priv->cur_seqid == FSPI_CMD_WR_EVCR) { + wr_sfaddr = 0; + } else if ((priv->cur_seqid == FSPI_CMD_BRWR) || + (priv->cur_seqid == FSPI_CMD_WREAR)) { +#ifdef CONFIG_SPI_FLASH_BAR + wr_sfaddr = 0; +#endif + } else if (priv->cur_seqid == FSPI_CMD_EN4B) { + fspi_op_enter_4bytes(priv); + } else if (priv->cur_seqid == FSPI_CMD_CRFSR) { + fspi_op_crfsr(priv); + } + } + + if (din) { + if (priv->cur_seqid == FSPI_CMD_QUAD_OUTPUT || + priv->cur_seqid == FSPI_CMD_FAST_READ || + priv->cur_seqid == FSPI_CMD_FAST_READ_4B) { +#ifdef CONFIG_FSI_AHB + fspi_ahb_read(priv, din, bytes); +#else + fspi_op_read(priv, din, bytes); +#endif + } else if (priv->cur_seqid == FSPI_CMD_RDID) + fspi_op_rdid(priv, din, bytes); + else if (priv->cur_seqid == FSPI_CMD_RDSR) + fspi_op_rdsr(priv, din, bytes); + else if (priv->cur_seqid == FSPI_CMD_RDFSR) + fspi_op_rdfsr(priv, din, bytes); + else if (priv->cur_seqid == FSPI_CMD_RD_EVCR) + fspi_op_rdevcr(priv, din, bytes); +#ifdef CONFIG_SPI_FLASH_BAR + else if (priv->cur_seqid == FSPI_CMD_BRRD || + priv->cur_seqid == FSPI_CMD_RDEAR) { + priv->sf_addr = 0; + fspi_op_rdbank(priv, din, bytes); + } +#endif + } + +#ifdef CONFIG_FSI_AHB + if (priv->cur_seqid == FSPI_CMD_SE || + priv->cur_seqid == FSPI_CMD_SE_4B || + priv->cur_seqid == FSPI_CMD_PP || + priv->cur_seqid == FSPI_CMD_PP_4B || + priv->cur_seqid == FSPI_CMD_BE_4K || + priv->cur_seqid == FSPI_CMD_BE_4K_4B || + priv->cur_seqid == FSPI_CMD_WREAR || + priv->cur_seqid == FSPI_CMD_BRWR) + fspi_ahb_invalid(priv); +#endif + + return 0; +} + +void fspi_module_disable(struct fsl_fspi_priv *priv, u8 disable) +{ + u32 mcr_val; + + mcr_val = fspi_read32(priv->flags, &priv->regs->mcr0); + if (disable) + mcr_val |= FLEXSPI_MCR0_MDIS_MASK; + else + mcr_val &= ~FLEXSPI_MCR0_MDIS_MASK; + fspi_write32(priv->flags, &priv->regs->mcr0, mcr_val); +} + +__weak void init_clk_fspi(int index) +{ +} + +static int fsl_fspi_child_pre_probe(struct udevice *dev) +{ + struct spi_slave *slave = dev_get_parent_priv(dev); + + slave->max_write_size = TX_BUFFER_SIZE; + +#ifdef CONFIG_FSPI_QUAD_SUPPORT + slave->mode |= SPI_RX_QUAD; +#endif + + return 0; +} + +static int fsl_fspi_probe(struct udevice *bus) +{ + u32 total_size; + struct fsl_fspi_platdata *plat = dev_get_platdata(bus); + struct fsl_fspi_priv *priv = dev_get_priv(bus); + struct dm_spi_bus *dm_spi_bus; + + if (CONFIG_IS_ENABLED(CLK)) { + /* Assigned clock already set clock */ + struct clk fspi_clk; + int ret; + + ret = clk_get_by_name(bus, "fspi", &fspi_clk); + if (ret < 0) { + printf("Can't get fspi clk: %d\n", ret); + return ret; + } + + ret = clk_enable(&fspi_clk); + if (ret < 0) { + printf("Can't enable fspi clk: %d\n", ret); + return ret; + } + } else { + init_clk_fspi(bus->seq); + } + dm_spi_bus = bus->uclass_priv; + + dm_spi_bus->max_hz = plat->speed_hz; + + priv->regs = (struct fsl_fspi_regs *)(uintptr_t)plat->reg_base; + priv->flags = plat->flags; + + priv->speed_hz = plat->speed_hz; + priv->amba_base[0] = plat->amba_base; + priv->amba_total_size = plat->amba_total_size; + priv->flash_num = plat->flash_num; + priv->num_chipselect = plat->num_chipselect; + + fspi_write32(priv->flags, &priv->regs->mcr0, FLEXSPI_MCR0_SWRST_MASK); + do { + udelay(1); + } while (0x1 & fspi_read32(priv->flags, &priv->regs->mcr0)); + + /* Disable the module */ + fspi_module_disable(priv, 1); + + /* Enable the module and set to proper value*/ +#ifdef CONFIG_FSPI_DQS_LOOPBACK + fspi_write32(priv->flags, &priv->regs->mcr0, 0xFFFF0010); +#else + fspi_write32(priv->flags, &priv->regs->mcr0, 0xFFFF0000); +#endif + + /* Reset the DLL register to default value */ + fspi_write32(priv->flags, &priv->regs->dllacr, 0x0100); + fspi_write32(priv->flags, &priv->regs->dllbcr, 0x0100); + + /* Flash Size in KByte */ + total_size = FSL_FSPI_FLASH_SIZE * FSL_FSPI_FLASH_NUM >> 10; + + /* + * Any read access to non-implemented addresses will provide + * undefined results. + * + * In case single die flash devices, TOP_ADDR_MEMA2 and + * TOP_ADDR_MEMB2 should be initialized/programmed to + * TOP_ADDR_MEMA1 and TOP_ADDR_MEMB1 respectively - in effect, + * setting the size of these devices to 0. This would ensure + * that the complete memory map is assigned to only one flash device. + */ + + fspi_write32(priv->flags, &priv->regs->flsha1cr0, + total_size); + fspi_write32(priv->flags, &priv->regs->flsha2cr0, + 0); + fspi_write32(priv->flags, &priv->regs->flshb1cr0, + 0); + fspi_write32(priv->flags, &priv->regs->flshb2cr0, + 0); + + fspi_set_lut(priv); + +#ifdef CONFIG_FSI_AHB + fspi_init_ahb_read(priv); +#endif + + fspi_module_disable(priv, 0); + + return 0; +} + +static int fsl_fspi_ofdata_to_platdata(struct udevice *bus) +{ + struct fdt_resource res_regs, res_mem; + struct fsl_fspi_platdata *plat = bus->platdata; + const void *blob = gd->fdt_blob; + int node = ofnode_to_offset(bus->node); + int ret, flash_num = 0, subnode; + + if (fdtdec_get_bool(blob, node, "big-endian")) + plat->flags |= FSPI_FLAG_REGMAP_ENDIAN_BIG; + + ret = fdt_get_named_resource(blob, node, "reg", "reg-names", + "FlexSPI", &res_regs); + if (ret) { + debug("Error: can't get regs base addresses(ret = %d)!\n", ret); + return -ENOMEM; + } + ret = fdt_get_named_resource(blob, node, "reg", "reg-names", + "FlexSPI-memory", &res_mem); + if (ret) { + debug("Error: can't get AMBA base addresses(ret = %d)!\n", ret); + return -ENOMEM; + } + + /* Count flash numbers */ + fdt_for_each_subnode(subnode, blob, node) + ++flash_num; + + if (flash_num == 0) { + debug("Error: Missing flashes!\n"); + return -ENODEV; + } + + plat->speed_hz = fdtdec_get_int(blob, node, "spi-max-frequency", + FSL_FSPI_DEFAULT_SCK_FREQ); + plat->num_chipselect = fdtdec_get_int(blob, node, "num-cs", + FSL_FSPI_MAX_CHIPSELECT_NUM); + + plat->reg_base = res_regs.start; + plat->amba_base = 0; + plat->amba_total_size = res_mem.end - res_mem.start + 1; + plat->flash_num = flash_num; + + debug("%s: regs=<0x%x> <0x%x, 0x%x>, max-frequency=%d, endianness=%s\n", + __func__, plat->reg_base, plat->amba_base, + plat->amba_total_size, plat->speed_hz, + plat->flags & FSPI_FLAG_REGMAP_ENDIAN_BIG ? "be" : "le"); + + return 0; +} + +static int fsl_fspi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct fsl_fspi_priv *priv; + + priv = dev_get_priv(dev->parent); + + return fspi_xfer(priv, bitlen, dout, din, flags); +} + +static int fsl_fspi_claim_bus(struct udevice *dev) +{ + struct fsl_fspi_priv *priv; + struct udevice *bus; + struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); + + bus = dev->parent; + priv = dev_get_priv(bus); + + priv->cur_amba_base = + priv->amba_base[0] + FSL_FSPI_FLASH_SIZE * slave_plat->cs; + + return 0; +} + +static int fsl_fspi_release_bus(struct udevice *dev) +{ + return 0; +} + +static int fsl_fspi_set_speed(struct udevice *bus, uint speed) +{ + /* Nothing to do */ + return 0; +} + +static int fsl_fspi_set_mode(struct udevice *bus, uint mode) +{ + /* Nothing to do */ + return 0; +} + +static const struct dm_spi_ops fsl_fspi_ops = { + .claim_bus = fsl_fspi_claim_bus, + .release_bus = fsl_fspi_release_bus, + .xfer = fsl_fspi_xfer, + .set_speed = fsl_fspi_set_speed, + .set_mode = fsl_fspi_set_mode, +}; + +static const struct udevice_id fsl_fspi_ids[] = { + { .compatible = "fsl,imx8qm-flexspi" }, + { .compatible = "fsl,imx8qxp-flexspi" }, + { .compatible = "fsl,imx8mm-flexspi" }, + { } +}; + +U_BOOT_DRIVER(fsl_fspi) = { + .name = "fsl_fspi", + .id = UCLASS_SPI, + .of_match = fsl_fspi_ids, + .ops = &fsl_fspi_ops, + .ofdata_to_platdata = fsl_fspi_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct fsl_fspi_platdata), + .priv_auto_alloc_size = sizeof(struct fsl_fspi_priv), + .probe = fsl_fspi_probe, + .child_pre_probe = fsl_fspi_child_pre_probe, +}; diff --git a/drivers/spi/fsl_fspi.h b/drivers/spi/fsl_fspi.h new file mode 100644 index 0000000000..bff13b9bd8 --- /dev/null +++ b/drivers/spi/fsl_fspi.h @@ -0,0 +1,170 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + * + * Register definitions for NXP FLEXSPI + */ + +#ifndef _FSL_FSPI_H_ +#define _FSL_FSPI_H_ + +#include <linux/bitops.h> + +struct fsl_fspi_regs { + u32 mcr0; + u32 mcr1; + u32 mcr2; + u32 ahbcr; + u32 inten; + u32 intr; + u32 lutkey; + u32 lutcr; + u32 ahbrxbuf0cr0; + u32 ahbrxbuf1cr0; + u32 ahbrxbuf2cr0; + u32 ahbrxbuf3cr0; + u32 ahbrxbuf4cr0; + u32 ahbrxbuf5cr0; + u32 ahbrxbuf6cr0; + u32 ahbrxbuf7cr0; + u32 ahbrxbuf0cr1; + u32 ahbrxbuf1cr1; + u32 ahbrxbuf2cr1; + u32 ahbrxbuf3cr1; + u32 ahbrxbuf4cr1; + u32 ahbrxbuf5cr1; + u32 ahbrxbuf6cr1; + u32 ahbrxbuf7cr1; + u32 flsha1cr0; + u32 flsha2cr0; + u32 flshb1cr0; + u32 flshb2cr0; + u32 flsha1cr1; + u32 flsha2cr1; + u32 flshb1cr1; + u32 flshb2cr1; + u32 flsha1cr2; + u32 flsha2cr2; + u32 flshb1cr2; + u32 flshb2cr2; + u32 flshcr3; + u32 flshcr4; + u32 flshcr5; + u32 flshcr6; + u32 ipcr0; + u32 ipcr1; + u32 ipcr2; + u32 ipcr3; + u32 ipcmd; + u32 dlpr; + u32 iprxfcr; + u32 iptxfcr; + u32 dllacr; + u32 dllbcr; + u32 soccr; + u32 misccr2; + u32 misccr3; + u32 misccr4; + u32 misccr5; + u32 misccr6; + u32 sts0; + u32 sts1; + u32 sts2; + u32 ahbspndsts; + u32 iprxfsts; + u32 iptxfsts; + u32 rsvd[2]; + u32 rfdr[32]; + u32 tfdr[32]; + u32 lut[128]; +}; + +/* The registers */ +#define FLEXSPI_MCR0_MDIS_SHIFT 1 +#define FLEXSPI_MCR0_MDIS_MASK BIT(1) +#define FLEXSPI_MCR0_SWRST_SHIFT 0 +#define FLEXSPI_MCR0_SWRST_MASK BIT(0) + +#define FLEXSPI_AHBCR_PREF_EN_SHIFT 5 +#define FLEXSPI_AHBCR_PREF_EN_MASK BIT(5) + +#define FLEXSPI_INTR_IPTXWE_SHIFT 6 +#define FLEXSPI_INTR_IPTXWE_MASK BIT(6) +#define FLEXSPI_INTR_IPRXWA_SHIFT 5 +#define FLEXSPI_INTR_IPRXWA_MASK BIT(5) +#define FLEXSPI_INTR_IPCMDDONE_SHIFT 0 +#define FLEXSPI_INTR_IPCMDDONE_MASK BIT(0) + +#define FLEXSPI_LUTKEY_VALUE 0x5AF05AF0 + +#define FLEXSPI_LCKER_LOCK 0x1 +#define FLEXSPI_LCKER_UNLOCK 0x2 + +#define FLEXSPI_BUFXCR_INVALID_MSTRID 0xe +#define FLEXSPI_AHBRXBUF0CR7_PREF_SHIFT 31 +#define FLEXSPI_AHBRXBUF0CR7_PREF_MASK BIT(31) + +#define FLEXSPI_IPCR1_SEQID_SHIFT 16 + +#define FLEXSPI_IPRXFCR_CLR_SHIFT 0 +#define FLEXSPI_IPRXFCR_CLR_MASK BIT(0) + +#define FLEXSPI_IPTXFCR_CLR_SHIFT 0 +#define FLEXSPI_IPTXFCR_CLR_MASK BIT(0) + +#define FLEXSPI_IPRXFSTS_FILL_SHIFT 0 +#define FLEXSPI_IPRXFSTS_FILL_MASK (0xFF << FLEXSPI_IPRXFSTS_FILL_SHIFT) + +/* register map end */ + +#define OPRND0_SHIFT 0 +#define OPRND0(x) ((x) << OPRND0_SHIFT) +#define PAD0_SHIFT 8 +#define PAD0(x) ((x) << PAD0_SHIFT) +#define INSTR0_SHIFT 10 +#define INSTR0(x) ((x) << INSTR0_SHIFT) +#define OPRND1_SHIFT 16 +#define OPRND1(x) ((x) << OPRND1_SHIFT) +#define PAD1_SHIFT 24 +#define PAD1(x) ((x) << PAD1_SHIFT) +#define INSTR1_SHIFT 26 +#define INSTR1(x) ((x) << INSTR1_SHIFT) + +#define LUT_STOP 0x00 +#define LUT_CMD 0x01 +#define LUT_ADDR 0x02 +#define LUT_CADDR_SDR 0x03 +#define LUT_MODE 0x04 +#define LUT_MODE2 0x05 +#define LUT_MODE4 0x06 +#define LUT_MODE8 0x07 +#define LUT_WRITE 0x08 +#define LUT_READ 0x09 +#define LUT_LEARN_SDR 0x0A +#define LUT_DATSZ_SDR 0x0B +#define LUT_DUMMY 0x0C +#define LUT_DUMMY_RWDS_SDR 0x0D +#define LUT_JMP_ON_CS 0x1F +#define LUT_CMD_DDR 0x21 +#define LUT_ADDR_DDR 0x22 +#define LUT_CADDR_DDR 0x23 +#define LUT_MODE_DDR 0x24 +#define LUT_MODE2_DDR 0x25 +#define LUT_MODE4_DDR 0x26 +#define LUT_MODE8_DDR 0x27 +#define LUT_WRITE_DDR 0x28 +#define LUT_READ_DDR 0x29 +#define LUT_LEARN_DDR 0x2A +#define LUT_DATSZ_DDR 0x2B +#define LUT_DUMMY_DDR 0x2C +#define LUT_DUMMY_RWDS_DDR 0x2D + +#define LUT_PAD1 0 +#define LUT_PAD2 1 +#define LUT_PAD4 2 +#define LUT_PAD8 3 + +#define ADDR24BIT 0x18 +#define ADDR32BIT 0x20 + +#endif /* _FSL_FSPI_H_ */
Subject: [PATCH] spi: add NXP FlexSPI driver
Please ignore this patch.
Thanks, Peng.
+config FSL_FSPI
- bool "NXP FlexSPI driver"
- help
NXP IP core.
- bool "FlexSPI QUAD support"
- help
+config FSPI_AHB
- bool "FlexSPI AHB support"
- help
+endif
- Copyright 2019 NXP
- struct fsl_fspi_platdata - platform data for NXP FSPI
- @flags: Flags for FSPI FSPI_FLAG_...
- @speed_hz: Default SCK frequency
- @reg_base: Base address of FSPI registers
- @amba_base: Base address of FSPI memory mapping
- @amba_total_size: size of FSPI memory mapping
- @flash_num: Number of active slave devices
- @num_chipselect: Number of FSPI chipselect signals */ struct
+fsl_fspi_platdata {
- u32 flags;
- u32 speed_hz;
- u32 reg_base;
- u32 amba_base;
- u32 amba_total_size;
- u32 flash_num;
- u32 num_chipselect;
- struct fsl_fspi_priv - private data for NXP FSPI
- @bus_clk: FSPI input clk frequency
- @cur_seqid: current LUT table sequence id
- @sf_addr: flash access offset
- @amba_base: Base address of FSPI memory mapping of every CS
- @cur_amba_base: Base address of FSPI memory mapping of current CS
- @regs: Point to FSPI register structure for I/O access */ struct
+fsl_fspi_priv {
- u32 flags;
- u32 bus_clk;
- u32 speed_hz;
- u32 cur_seqid;
- u32 sf_addr;
- u32 amba_base[FSL_FSPI_MAX_CHIPSELECT_NUM];
- u32 cur_amba_base;
- u32 flash_num;
- struct fsl_fspi_regs *regs;
+static u32 fspi_read32(u32 flags, u32 *addr) {
- return flags & FSPI_FLAG_REGMAP_ENDIAN_BIG ?
+static void fspi_write32(u32 flags, u32 *addr, u32 val) {
- flags & FSPI_FLAG_REGMAP_ENDIAN_BIG ?
out_be32(addr, val) : out_le32(addr, val); }
+static void fspi_set_lut(struct fsl_fspi_priv *priv) {
- struct fsl_fspi_regs *regs = priv->regs;
- u32 lut_base;
- /* Unlock the LUT */
- fspi_write32(priv->flags, ®s->lutkey, FLEXSPI_LUTKEY_VALUE);
- fspi_write32(priv->flags, ®s->lutcr, FLEXSPI_LCKER_UNLOCK);
- /* READ */
- lut_base = SEQID_READ * 4;
- fspi_write32(priv->flags, ®s->lut[lut_base],
- fspi_write32(priv->flags, ®s->lut[lut_base + 1],
INSTR0(LUT_READ));
- fspi_write32(priv->flags, ®s->lut[lut_base + 2], 0);
- fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0);
- /* Write Enable */
- lut_base = SEQID_WREN * 4;
INSTR0(LUT_CMD));
- fspi_write32(priv->flags, ®s->lut[lut_base + 1], 0);
- /* Fast Read */
- lut_base = SEQID_FAST_READ * 4;
PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); #else
- if (FSL_FSPI_FLASH_SIZE <= SZ_16M)
- else
INSTR1(LUT_ADDR));
INSTR1(LUT_READ));
- /* Read Status */
- lut_base = SEQID_RDSR * 4;
INSTR1(LUT_READ));
- /* Erase a sector */
- lut_base = SEQID_SE * 4;
- fspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(FSPI_CMD_SE) |
- else
PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); #endif
- /* Erase the whole chip */
- lut_base = SEQID_CHIP_ERASE * 4;
- /* Page Program */
- lut_base = SEQID_PP * 4;
INSTR1(LUT_ADDR));
+#else
- else
OPRND0(0) |
- /* READ ID */
- lut_base = SEQID_RDID * 4;
INSTR1(LUT_READ));
- /* SUB SECTOR 4K ERASE */
- lut_base = SEQID_BE_4K * 4;
INSTR1(LUT_ADDR));
+#else
- else
during
* initialization.
- lut_base = SEQID_BRRD * 4;
INSTR1(LUT_READ));
- lut_base = SEQID_BRWR * 4;
INSTR1(LUT_WRITE));
- lut_base = SEQID_RDEAR * 4;
INSTR1(LUT_READ));
- lut_base = SEQID_WREAR * 4;
INSTR1(LUT_WRITE));
- fspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); #endif
- lut_base = SEQID_RDEVCR * 4;
INSTR0(LUT_CMD));
- lut_base = SEQID_WREVCR * 4;
INSTR0(LUT_CMD));
- /* QUAD OUTPUT READ */
- lut_base = SEQID_QUAD_OUTPUT * 4;
PAD0(LUT_PAD1) |
- /* Read Flag Status */
- lut_base = SEQID_RDFSR * 4;
INSTR1(LUT_READ));
- /* Enter 4 bytes address mode */
- lut_base = SEQID_EN4B * 4;
INSTR0(LUT_CMD));
- /* Lock the LUT */
- fspi_write32(priv->flags, ®s->lutcr, FLEXSPI_LCKER_LOCK); }
- If we have changed the content of the flash by writing or erasing,
- we need to invalidate the AHB buffer. If we do not do so, we may
+read out
- the wrong data. The spec tells us reset the AHB domain and Serial
+Flash
- domain at the same time.
+static inline void fspi_ahb_invalid(struct fsl_fspi_priv *priv) {
- u32 reg;
- reg = fspi_read32(priv->flags, ®s->mcr0);
- reg |= FLEXSPI_MCR0_SWRST_MASK;
- fspi_write32(priv->flags, ®s->mcr0, reg);
- while ((fspi_read32(priv->flags, ®s->mcr0) & 1))
+/* Read out the data from the AHB buffer. */ static inline void +fspi_ahb_read(struct fsl_fspi_priv *priv, u8 *rxbuf,
int len)
- /* Read out the data directly from the AHB buffer. */
- memcpy(rxbuf, (u8 *)(FSPI_AHB_BASE_ADDR +
(uintptr_t)priv->sf_addr), len); }
- There are two different ways to read out the data from the flash:
- the "IP Command Read" and the "AHB Command Read".
- The IC guy suggests we use the "AHB Command Read" which is faster
- then the "IP Command Read". (What's more is that there is a bug in
- the "IP Command Read" in the Vybrid.)
- After we set up the registers for the "AHB Command Read", we can use
- the memcpy to read the data directly. A "missed" access to the
+buffer
- causes the controller to clear the buffer, and use the sequence
+pointed
- by the QUADSPI_BFGENCR[SEQID] to initiate a read from the flash.
+static void fspi_init_ahb_read(struct fsl_fspi_priv *priv) {
- int i;
- /* AHB configuration for access buffer 0~7 .*/
- for (i = 0; i < 7; i++)
* performance
- fspi_write32(priv->flags, ®s->ahbrxbuf7cr0, AHB_BUFFER_SIZE / 8 |
- fspi_write32(priv->flags, ®s->ahbcr,
- fspi_write32(priv->flags, ®s->flsha1cr2, SEQID_QUAD_OUTPUT);
#else
- fspi_write32(priv->flags, ®s->flsha1cr2, SEQID_FAST_READ); #endif }
+#ifdef CONFIG_SPI_FLASH_BAR +/* Bank register read/write, EAR register read/write */ static void +fspi_op_rdbank(struct fsl_fspi_priv *priv, u8 *rxbuf, u32 len) {
- u32 data, seqid;
- /* invalid the RXFIFO first */
- fspi_write32(priv->flags, ®s->iprxfcr, FLEXSPI_IPRXFCR_CLR_MASK);
- fspi_write32(priv->flags, ®s->ipcr0, priv->cur_amba_base);
- if (priv->cur_seqid == FSPI_CMD_BRRD)
seqid = SEQID_BRRD;
- else
- fspi_write32(priv->flags, ®s->ipcr1,
- /* Trigger the command */
- fspi_write32(priv->flags, ®s->ipcmd, 1);
- /* Wait for command done */
- while (!(fspi_read32(priv->flags, ®s->intr) &
- while (1) {
break;
- fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPRXWA_MASK);
FLEXSPI_INTR_IPCMDDONE_MASK); } +#endif
+static void fspi_op_rdevcr(struct fsl_fspi_priv *priv, u8 *rxbuf, u32 +len) {
- u32 data;
- while (1) {
break;
+static void fspi_op_wrevcr(struct fsl_fspi_priv *priv, u8 *txbuf, u32 +len) {
- /* invalid the TXFIFO first */
- fspi_write32(priv->flags, ®s->iptxfcr, FLEXSPI_IPTXFCR_CLR_MASK);
- /* Wait for TXFIFO empty*/
- /* write the data to TXFIFO */
- memcpy(®s->tfdr, txbuf, len);
- fspi_write32(priv->flags, ®s->intr, FLEXSPI_INTR_IPTXWE_MASK);
+static void fspi_op_rdid(struct fsl_fspi_priv *priv, u32 *rxbuf, u32 +len) {
- u32 data, size;
- int i;
- i = 0;
- while ((len <= RX_BUFFER_SIZE) && (len > 0)) {
len -= size;
rxbuf++;
i++;
+#ifndef CONFIG_FSI_AHB +/* If not use AHB read, read data from ip interface */ static void +fspi_op_read(struct fsl_fspi_priv *priv, u32 *rxbuf, u32 len) {
- int i, size, rx_size;
- u32 to_or_from;
- to_or_from = priv->sf_addr + priv->cur_amba_base;
- /* invalid the RXFIFO */
- while (len > 0) {
WATCHDOG_RESET();
rx_size);
+#else
rx_size);
len -= rx_size;
size = rx_size / 8;
rxbuf += 2;
size = rx_size % 8;
if (size) {
+} +#endif
+static void fspi_op_write(struct fsl_fspi_priv *priv, u8 *txbuf, u32 +len) {
- u32 seqid;
- int i, size, tx_size;
- u32 to_or_from = 0;
- while (len > 0) {
seqid = SEQID_PP;
seqid = SEQID_BRWR;
len -= tx_size;
size = tx_size / 8;
txbuf += 8;
size = tx_size % 8;
if (size) {
+static void fspi_op_rdsr(struct fsl_fspi_priv *priv, void *rxbuf, u32 +len) {
- u32 data;
- data = fspi_read32(priv->flags, ®s->rfdr[0]);
- memcpy(rxbuf, &data, len);
+static void fspi_op_rdfsr(struct fsl_fspi_priv *priv, void *rxbuf, u32 +len) {
- u32 data;
+static void fspi_op_erase(struct fsl_fspi_priv *priv) {
- fspi_write32(priv->flags, ®s->ipcr0, to_or_from);
- if (priv->cur_seqid == FSPI_CMD_SE ||
- } else if (priv->cur_seqid == FSPI_CMD_BE_4K ||
+static void fspi_op_crfsr(struct fsl_fspi_priv *priv) {
+static void fspi_op_enter_4bytes(struct fsl_fspi_priv *priv) {
const void *dout, void *din, unsigned long flags) {
- u32 bytes = DIV_ROUND_UP(bitlen, 8);
- static u32 wr_sfaddr;
- u32 txbuf = 0;
- if (dout) {
if (bytes > 1) {
int i, addr_bytes;
addr_bytes = 3;
else
addr_bytes = 3;
+#else
addr_bytes = 4;
txbuf <<= 8;
int i;
txbuf <<= 8;
wr_sfaddr = txbuf;
wr_sfaddr = 0;
(priv->cur_seqid == FSPI_CMD_WREAR)) { #ifdef
wr_sfaddr = 0;
- if (din) {
priv->cur_seqid == FSPI_CMD_FAST_READ_4B) { #ifdef
CONFIG_FSI_AHB
+#else
priv->sf_addr = 0;
+void fspi_module_disable(struct fsl_fspi_priv *priv, u8 disable) {
- u32 mcr_val;
- mcr_val = fspi_read32(priv->flags, &priv->regs->mcr0);
- if (disable)
- else
- fspi_write32(priv->flags, &priv->regs->mcr0, mcr_val); }
+static int fsl_fspi_child_pre_probe(struct udevice *dev) {
- struct spi_slave *slave = dev_get_parent_priv(dev);
- slave->max_write_size = TX_BUFFER_SIZE;
- slave->mode |= SPI_RX_QUAD;
+static int fsl_fspi_probe(struct udevice *bus) {
- u32 total_size;
- struct fsl_fspi_platdata *plat = dev_get_platdata(bus);
- struct fsl_fspi_priv *priv = dev_get_priv(bus);
- struct dm_spi_bus *dm_spi_bus;
- if (CONFIG_IS_ENABLED(CLK)) {
int ret;
if (ret < 0) {
return ret;
if (ret < 0) {
return ret;
- } else {
- dm_spi_bus = bus->uclass_priv;
- dm_spi_bus->max_hz = plat->speed_hz;
- priv->regs = (struct fsl_fspi_regs *)(uintptr_t)plat->reg_base;
- priv->flags = plat->flags;
- priv->speed_hz = plat->speed_hz;
- priv->amba_base[0] = plat->amba_base;
- priv->amba_total_size = plat->amba_total_size;
- priv->flash_num = plat->flash_num;
- priv->num_chipselect = plat->num_chipselect;
- do {
udelay(1);
- } while (0x1 & fspi_read32(priv->flags, &priv->regs->mcr0));
- /* Disable the module */
- fspi_module_disable(priv, 1);
- /* Enable the module and set to proper value*/ #ifdef
+CONFIG_FSPI_DQS_LOOPBACK
- fspi_write32(priv->flags, &priv->regs->mcr0, 0xFFFF0010); #else
- fspi_write32(priv->flags, &priv->regs->mcr0, 0xFFFF0000); #endif
- /* Reset the DLL register to default value */
- fspi_write32(priv->flags, &priv->regs->dllacr, 0x0100);
- fspi_write32(priv->flags, &priv->regs->dllbcr, 0x0100);
- /* Flash Size in KByte */
- total_size = FSL_FSPI_FLASH_SIZE * FSL_FSPI_FLASH_NUM >> 10;
- fspi_write32(priv->flags, &priv->regs->flsha1cr0,
total_size);
- fspi_write32(priv->flags, &priv->regs->flsha2cr0,
0);
- fspi_write32(priv->flags, &priv->regs->flshb1cr0,
0);
- fspi_write32(priv->flags, &priv->regs->flshb2cr0,
0);
- fspi_set_lut(priv);
- fspi_init_ahb_read(priv);
- fspi_module_disable(priv, 0);
+static int fsl_fspi_ofdata_to_platdata(struct udevice *bus) {
- struct fdt_resource res_regs, res_mem;
- struct fsl_fspi_platdata *plat = bus->platdata;
- const void *blob = gd->fdt_blob;
- int node = ofnode_to_offset(bus->node);
- int ret, flash_num = 0, subnode;
- if (fdtdec_get_bool(blob, node, "big-endian"))
- ret = fdt_get_named_resource(blob, node, "reg", "reg-names",
- if (ret) {
return -ENOMEM;
- if (ret) {
return -ENOMEM;
- /* Count flash numbers */
- fdt_for_each_subnode(subnode, blob, node)
++flash_num;
- if (flash_num == 0) {
return -ENODEV;
- plat->speed_hz = fdtdec_get_int(blob, node, "spi-max-frequency",
- plat->num_chipselect = fdtdec_get_int(blob, node, "num-cs",
- plat->reg_base = res_regs.start;
- plat->amba_base = 0;
- plat->amba_total_size = res_mem.end - res_mem.start + 1;
- plat->flash_num = flash_num;
- debug("%s: regs=<0x%x> <0x%x, 0x%x>, max-frequency=%d,
endianness=%s\n",
- struct fsl_fspi_priv *priv;
- priv = dev_get_priv(dev->parent);
- return fspi_xfer(priv, bitlen, dout, din, flags); }
+static int fsl_fspi_claim_bus(struct udevice *dev) {
- struct udevice *bus;
- struct dm_spi_slave_platdata *slave_plat =
+dev_get_parent_platdata(dev);
- bus = dev->parent;
- priv = dev_get_priv(bus);
- priv->cur_amba_base =
+static int fsl_fspi_release_bus(struct udevice *dev) {
+static int fsl_fspi_set_speed(struct udevice *bus, uint speed) {
- /* Nothing to do */
+static int fsl_fspi_set_mode(struct udevice *bus, uint mode) {
- .claim_bus = fsl_fspi_claim_bus,
- .release_bus = fsl_fspi_release_bus,
- .xfer = fsl_fspi_xfer,
- .set_speed = fsl_fspi_set_speed,
- .set_mode = fsl_fspi_set_mode,
- { .compatible = "fsl,imx8qm-flexspi" },
- { .compatible = "fsl,imx8qxp-flexspi" },
- { .compatible = "fsl,imx8mm-flexspi" },
- .name = "fsl_fspi",
- .id = UCLASS_SPI,
- .of_match = fsl_fspi_ids,
- .ops = &fsl_fspi_ops,
- .ofdata_to_platdata = fsl_fspi_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct fsl_fspi_platdata),
- .priv_auto_alloc_size = sizeof(struct fsl_fspi_priv),
- .probe = fsl_fspi_probe,
- .child_pre_probe = fsl_fspi_child_pre_probe, };
- Register definitions for NXP FLEXSPI */
- u32 mcr0;
- u32 mcr1;
- u32 mcr2;
- u32 ahbcr;
- u32 inten;
- u32 intr;
- u32 lutkey;
- u32 lutcr;
- u32 ahbrxbuf0cr0;
- u32 ahbrxbuf1cr0;
- u32 ahbrxbuf2cr0;
- u32 ahbrxbuf3cr0;
- u32 ahbrxbuf4cr0;
- u32 ahbrxbuf5cr0;
- u32 ahbrxbuf6cr0;
- u32 ahbrxbuf7cr0;
- u32 ahbrxbuf0cr1;
- u32 ahbrxbuf1cr1;
- u32 ahbrxbuf2cr1;
- u32 ahbrxbuf3cr1;
- u32 ahbrxbuf4cr1;
- u32 ahbrxbuf5cr1;
- u32 ahbrxbuf6cr1;
- u32 ahbrxbuf7cr1;
- u32 flsha1cr0;
- u32 flsha2cr0;
- u32 flshb1cr0;
- u32 flshb2cr0;
- u32 flsha1cr1;
- u32 flsha2cr1;
- u32 flshb1cr1;
- u32 flshb2cr1;
- u32 flsha1cr2;
- u32 flsha2cr2;
- u32 flshb1cr2;
- u32 flshb2cr2;
- u32 flshcr3;
- u32 flshcr4;
- u32 flshcr5;
- u32 flshcr6;
- u32 ipcr0;
- u32 ipcr1;
- u32 ipcr2;
- u32 ipcr3;
- u32 ipcmd;
- u32 dlpr;
- u32 iprxfcr;
- u32 iptxfcr;
- u32 dllacr;
- u32 dllbcr;
- u32 soccr;
- u32 misccr2;
- u32 misccr3;
- u32 misccr4;
- u32 misccr5;
- u32 misccr6;
- u32 sts0;
- u32 sts1;
- u32 sts2;
- u32 ahbspndsts;
- u32 iprxfsts;
- u32 iptxfsts;
- u32 rsvd[2];
- u32 rfdr[32];
- u32 tfdr[32];
- u32 lut[128];
2.16.4
Peng Fan
