[PATCH] arm: snapdragon: Use correct GICC register on APQ8016
The GICC register used by u-boot is 0x0a20c000, which is actually a GICC for WCNSS, the WLAN processor. U-boot runs on the Application Processor, therefore it should use APCS GICC instead. Hence, correct it with APCS GICC register address.
Signed-off-by: Sheep Sun sunxiaoyang2003@gmail.com ---
arch/arm/mach-snapdragon/include/mach/sysmap-apq8016.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-snapdragon/include/mach/sysmap-apq8016.h b/arch/arm/mach-snapdragon/include/mach/sysmap-apq8016.h index 520e2e6bd7..d9a3b1af98 100644 --- a/arch/arm/mach-snapdragon/include/mach/sysmap-apq8016.h +++ b/arch/arm/mach-snapdragon/include/mach/sysmap-apq8016.h @@ -8,7 +8,7 @@ #define _MACH_SYSMAP_APQ8016_H
#define GICD_BASE (0x0b000000) -#define GICC_BASE (0x0a20c000) +#define GICC_BASE (0x0b002000)
/* Clocks: (from CLK_CTL_BASE) */ #define GPLL0_STATUS (0x2101C)
2.30.2
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Ramon Fried
Sheep Sun
