[U-Boot] [PATCH 1/2 v2] usb: r8a66597: Fix initialization hub that using R8A66597_MAX_ROOT_HUB
This driver is processed as two USB hub despite one. The number of root hub is defined in R8A66597_MAX_ROOT_HUB. This fixes that register is accessed by using the definition of R8A66597_MAX_ROOT_HUB.
Signed-off-by: Yasuhisa Umano yasuhisa.umano.zc@renesas.com --- v2 : No changes
drivers/usb/host/r8a66597-hcd.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/r8a66597-hcd.c b/drivers/usb/host/r8a66597-hcd.c index dfe5423..c58d2a9 100644 --- a/drivers/usb/host/r8a66597-hcd.c +++ b/drivers/usb/host/r8a66597-hcd.c @@ -164,8 +164,8 @@ static int enable_controller(struct r8a66597 *r8a66597)
r8a66597_bset(r8a66597, INTL, SOFCFG); r8a66597_write(r8a66597, 0, INTENB0); - r8a66597_write(r8a66597, 0, INTENB1); - r8a66597_write(r8a66597, 0, INTENB2); + for (port = 0; port < R8A66597_MAX_ROOT_HUB; port++) + r8a66597_write(r8a66597, 0, get_intenb_reg(port));
r8a66597_bset(r8a66597, CONFIG_R8A66597_ENDIAN & BIGEND, CFIFOSEL); r8a66597_bset(r8a66597, CONFIG_R8A66597_ENDIAN & BIGEND, D0FIFOSEL);
Yasuhisa Umano
