[U-Boot] [PATCH v3] net: macb: Not all the GEM are gigabit capable
During the initialization of PHY the gigabit bit capable is set if the controller is a GEM. However, for sama5d2 and sama5d4, the GEM is configured to support only 10/100.
Improperly setting the GBE capability leads to an unresponsive MAC controller. This patch fixes this behavior allowing using the gmac with these SoCs.
Suggested-by: Nicolas Ferre nicolas.ferre@atmel.com Signed-off-by: Gregory CLEMENT gregory.clement@free-electrons.com --- Hi,
in this v3, I fixed the sama5d2 typo and the missing brace.
I also took care of the cpu_is_* symbols which may not be defined depending of the choice of the SoC.
Gregory
drivers/net/macb.c | 21 +++++++++++++++++++-- 1 file changed, 19 insertions(+), 2 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index a5c1880..e801313 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -109,6 +109,23 @@ static int macb_is_gem(struct macb_device *macb) return MACB_BFEXT(IDNUM, macb_readl(macb, MID)) == 0x2; }
+#ifndef cpu_is_sama5d2 +#define cpu_is_sama5d2() 0 +#endif + +#ifndef cpu_is_sama5d4 +#define cpu_is_sama5d4() 0 +#endif + +static int gem_is_gigabit_capable(struct macb_device *macb) +{ + /* + * The GEM controllers embeded in SAMA5D2 and SAMA5D4 are + * configured to support only 10/100. + */ + return macb_is_gem(macb) && !cpu_is_sama5d2() && !cpu_is_sama5d4(); +} + static void macb_mdio_write(struct macb_device *macb, u8 reg, u16 value) { unsigned long netctl; @@ -480,8 +497,8 @@ static int macb_phy_init(struct macb_device *macb) return 0; }
- /* First check for GMAC */ - if (macb_is_gem(macb)) { + /* First check for GMAC and that it is GiB capable */ + if (gem_is_gigabit_capable(macb)){ lpa = macb_mdio_read(macb, MII_STAT1000);
if (lpa & (LPA_1000FULL | LPA_1000HALF)) {
Acked-by: Nicolas Ferre nicolas.ferre@atmel.com
Thanks,
Gregory
- return macb_is_gem(macb) && !cpu_is_sama5d2() && !cpu_is_sama5d4();
On Wed, Dec 16, 2015 at 7:50 AM, Gregory CLEMENT gregory.clement@free-electrons.com wrote:
It's a shame we are forced to have this PID hack, but I guess this will do until we discover some other sustainable way.
Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com
Gregory
Dear Gregory CLEMENT,
Gregory CLEMENT gregory.clement@free-electrons.com writes:
Suggested-by: Nicolas Ferre nicolas.ferre@atmel.com Signed-off-by: Gregory CLEMENT gregory.clement@free-electrons.com Acked-by: Nicolas Ferre nicolas.ferre@atmel.com Acked-by: Joe Hershberger joe.hershberger@ni.com Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com [fixed minor checkpatch warning] Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com
Gregory
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
Gregory CLEMENT
Joe Hershberger
Nicolas Ferre
