[PATCH] arm64: zynqmp: Check firmware node when driver is enabled
ZynqMP mini configurations works without PMU firmware that's why there is no reason to enable the driver and check if it was probed properly.
board/xilinx/zynqmp/zynqmp.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index ba1a126fbf88..c6c55caa1ce0 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -341,11 +341,13 @@ static int multi_boot(void)
int board_init(void) { +#if defined(CONFIG_ZYNQMP_FIRMWARE) struct udevice *dev;
uclass_get_device_by_name(UCLASS_FIRMWARE, "zynqmp-power", &dev); if (!dev) panic("PMU Firmware device not found - Enable it"); +#endif
#if defined(CONFIG_SPL_BUILD) /* Check *at build time* if the filename is an non-empty string */
st 4. 3. 2020 v 8:58 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
#if defined(CONFIG_SPL_BUILD) /* Check *at build time* if the filename is an non-empty string */ -- 2.25.1
Applied. M
Michal Simek
Michal Simek
