[U-Boot] [PATCH v2 1/2] blackfin: bf609: implement soft switch
Set up soft switch pins properly in board init code.
Signed-off-by: Sonic Zhang sonic.zhang@analog.com Signed-off-by: Scott Jiang scott.jiang@analog.com Signed-off-by: Bob Liu lliubbo@gmail.com --- Changes in v2: None
board/bf609-ezkit/soft_switch.c | 180 ++++++++++++++++++++++++++++++++++++++++ board/bf609-ezkit/soft_switch.h | 71 ++++++++++++++++ 2 files changed, 251 insertions(+) create mode 100644 board/bf609-ezkit/soft_switch.c create mode 100644 board/bf609-ezkit/soft_switch.h
diff --git a/board/bf609-ezkit/soft_switch.c b/board/bf609-ezkit/soft_switch.c new file mode 100644 index 0000000..2e1404f --- /dev/null +++ b/board/bf609-ezkit/soft_switch.c @@ -0,0 +1,180 @@ +/* + * U-boot - main board file + * + * Copyright (c) 2008-2011 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#include <common.h> +#include <asm/blackfin.h> +#include <asm/io.h> +#include <i2c.h> +#include "soft_switch.h" + +#define SWITCH_ADDR 0x21 + +#define NUM_SWITCH 3 +#define IODIRA 0x0 +#define IODIRB 0x1 +#define OLATA 0x14 +#define OLATB 0x15 + +struct switch_config { + uchar dir0; /* IODIRA */ + uchar dir1; /* IODIRB */ + uchar value0; /* OLATA */ + uchar value1; /* OLATB */ +}; + +static struct switch_config switch_config_array[NUM_SWITCH] = { + { +/* + U45 Port A U45 Port B + + 7--------------- RMII_CLK_EN | 7--------------- ~TEMP_THERM_EN + | 6------------- ~CNT0ZM_EN | | 6------------- ~TEMP_IRQ_EN + | | 5----------- ~CNT0DG_EN | | | 5----------- ~UART0CTS_146_EN + | | | 4--------- ~CNT0UD_EN | | | | 4--------- ~UART0CTS_RST_EN + | | | | 3------- ~CAN0RX_EN | | | | | 3------- ~UART0CTS_RTS_LPBK + | | | | | 2----- ~CAN0_ERR_EN | | | | | | 2----- ~UART0CTS_EN + | | | | | | 1--- ~CAN_STB | | | | | | | 1--- ~UART0RX_EN + | | | | | | | 0- CAN_EN | | | | | | | | 0- ~UART0RTS_EN + | | | | | | | | | | | | | | | | | + O O O O O O O O | O O O O O O O O (I/O direction) + 1 0 0 0 0 0 1 1 | 1 1 1 1 1 0 0 0 (value being set) +*/ + .dir0 = 0x0, /* all output */ + .dir1 = 0x0, /* all output */ + .value0 = RMII_CLK_EN | CAN_STB | CAN_EN, + .value1 = TEMP_THERM_EN | TEMP_IRQ_EN | UART0CTS_146_EN + | UART0CTS_RST_EN | UART0CTS_RTS_LPBK, + }, + { +/* + U46 Port A U46 Port B + + 7--------------- ~LED4_GPIO_EN | 7--------------- EMPTY + | 6------------- ~LED3_GPIO_EN | | 6------------- ~SPI0D3_EN + | | 5----------- ~LED2_GPIO_EN | | | 5----------- ~SPI0D2_EN + | | | 4--------- ~LED1_GPIO_EN | | | | 4--------- ~SPIFLASH_CS_EN + | | | | 3------- SMC0_LP0_EN | | | | | 3------- ~SD_WP_EN + | | | | | 2----- EMPTY | | | | | | 2----- ~SD_CD_EN + | | | | | | 1--- SMC0_EPPI2 | | | | | | | 1--- ~PUSHBUTTON2_EN + _LP1_SWITCH + | | | | | | | 0- OVERRIDE_SMC0 | | | | | | | | 0- ~PUSHBUTTON1_EN + _LP0_BOOT + | | | | | | | | | | | | | | | | | + O O O O O O O O | O O O O O O O O (I/O direction) + 0 0 0 0 0 X 0 1 | X 0 0 0 0 0 0 0 (value being set) +*/ + .dir0 = 0x0, /* all output */ + .dir1 = 0x0, /* all output */ +#ifdef CONFIG_BFIN_LINKPORT + .value0 = OVERRIDE_SMC0_LP0_BOOT, +#else + .value0 = SMC0_EPPI2_LP1_SWITCH, +#endif + .value1 = 0x0, + }, + { +/* + U47 Port A U47 Port B + + 7--------------- ~PD2_SPI0MISO | 7--------------- EMPTY + _EI3_EN + | 6------------- ~PD1_SPI0D3 | | 6------------- EMPTY + _EPPI1D17 + _SPI0SEL2 + _EI3_EN + | | 5----------- ~PD0_SPI0D2 | | | 5----------- EMPTY + _EPPI1D16 + _SPI0SEL3 + _EI3_EN + | | | 4--------- ~WAKE_PUSH | | | | 4--------- EMPTY + BUTTON_EN + | | | | 3------- ~ETHERNET_EN | | | | | 3------- EMPTY + | | | | | 2----- PHYAD0 | | | | | | 2----- EMPTY + | | | | | | 1--- PHY_PWR | | | | | | | 1--- ~PD4_SPI0CK_EI3_EN + _DWN_INT + | | | | | | | 0- ~PHYINT_EN | | | | | | | | 0- ~PD3_SPI0MOSI_EI3_EN + | | | | | | | | | | | | | | | | | + O O O O O I I O | O O O O O O O O (I/O direction) + 1 1 1 0 0 0 0 0 | X X X X X X 1 1 (value being set) +*/ + .dir0 = 0x6, /* bits 1 and 2 input, all others output */ + .dir1 = 0x0, /* all output */ + .value0 = PD1_SPI0D3_EN | PD0_SPI0D2_EN, + .value1 = 0, + }, +}; + +static int setup_soft_switch(int addr, struct switch_config *config) +{ + int ret = 0; + + ret = i2c_write(addr, OLATA, 1, &config->value0, 1); + if (ret) + return ret; + ret = i2c_write(addr, OLATB, 1, &config->value1, 1); + if (ret) + return ret; + + ret = i2c_write(addr, IODIRA, 1, &config->dir0, 1); + if (ret) + return ret; + return i2c_write(addr, IODIRB, 1, &config->dir1, 1); +} + +int config_switch_bit(int num, int port, int bit, int dir, uchar value) +{ + int addr = SWITCH_ADDR + num; + int ret, data_reg, dir_reg; + uchar tmp; + + if (port == IO_PORT_A) { + data_reg = OLATA; + dir_reg = IODIRA; + } else { + data_reg = OLATB; + dir_reg = IODIRB; + } + + if (dir == IO_PORT_INPUT) { + ret = i2c_read(addr, dir_reg, 1, &tmp, 1); + if (ret) + return ret; + tmp |= bit; + return i2c_write(addr, dir_reg, 1, &tmp, 1); + } else { + ret = i2c_read(addr, data_reg, 1, &tmp, 1); + if (ret) + return ret; + if (value) + tmp |= bit; + else + tmp &= ~bit; + ret = i2c_write(addr, data_reg, 1, &tmp, 1); + if (ret) + return ret; + ret = i2c_read(addr, dir_reg, 1, &tmp, 1); + if (ret) + return ret; + tmp &= ~bit; + return i2c_write(addr, dir_reg, 1, &tmp, 1); + } +} + +int setup_board_switches(void) +{ + int ret; + int i; + + for (i = 0; i < NUM_SWITCH; i++) { + ret = setup_soft_switch(SWITCH_ADDR + i, + &switch_config_array[i]); + if (ret) + return ret; + } + return 0; +} diff --git a/board/bf609-ezkit/soft_switch.h b/board/bf609-ezkit/soft_switch.h new file mode 100644 index 0000000..8da0e44 --- /dev/null +++ b/board/bf609-ezkit/soft_switch.h @@ -0,0 +1,71 @@ +/* + * U-boot - main board file + * + * Copyright (c) 2008-2011 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#ifndef __SOFT_SWITCH_H__ +#define __SOFT_SWITCH_H__ + +/* switch 0 port A */ +#define CAN_EN 0x1 +#define CAN_STB 0x2 +#define CAN0_ERR_EN 0x4 +#define CAN0RX_EN 0x8 +#define CNT0UD_EN 0x10 +#define CNT0DG_EN 0x20 +#define CNT0ZM_EN 0x40 +#define RMII_CLK_EN 0x80 + +/* switch 0 port B */ +#define UART0RTS_EN 0x1 +#define UART0RX_EN 0x2 +#define UART0CTS_EN 0x4 +#define UART0CTS_RTS_LPBK 0x8 +#define UART0CTS_RST_EN 0x10 +#define UART0CTS_146_EN 0x20 +#define TEMP_IRQ_EN 0x40 +#define TEMP_THERM_EN 0x80 + +/* switch 1 port A */ +#define OVERRIDE_SMC0_LP0_BOOT 0x1 +#define SMC0_EPPI2_LP1_SWITCH 0x2 +#define SMC0_LP0_EN 0x8 +#define LED1_GPIO_EN 0x10 +#define LED2_GPIO_EN 0x20 +#define LED3_GPIO_EN 0x40 +#define LED4_GPIO_EN 0x80 + +/* switch 1 port B */ +#define PUSHBUTTON1_EN 0x1 +#define PUSHBUTTON2_EN 0x2 +#define SD_CD_EN 0x4 +#define SD_WP_EN 0x8 +#define SPIFLASH_CS_EN 0x10 +#define SPI0D2_EN 0x20 +#define SPI0D3_EN 0x40 + +/* switch 2 port A */ +#define PHYINT_EN 0x1 +#define PHY_PWR_DWN_INT 0x2 +#define PHYAD0 0x4 +#define ETHERNET_EN 0x8 +#define WAKE_PUSHBUTTON_EN 0x10 +#define PD0_SPI0D2_EN 0x20 +#define PD1_SPI0D3_EN 0x40 +#define PD2_SPI0MISO_EN 0x80 + +/* switch 2 port B */ +#define PD3_SPI0MOSI_EN 0x1 +#define PD4_SPI0CK_EN 0x2 + +#define IO_PORT_A 0 +#define IO_PORT_B 1 +#define IO_PORT_INPUT 0 +#define IO_PORT_OUTPUT 1 + +int config_switch_bit(int num, int port, int bit, int dir, uchar value); +int setup_board_switches(void); +#endif
Add softswitch_output command for bf609-ezkit to enable softswitches.
Signed-off-by: Bob Liu lliubbo@gmail.com Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- Changes in v2: - Add documentation for CONFIG_CMD_SOFTSWITCH to top-level README.
README | 1 + arch/blackfin/include/asm/soft_switch.h | 18 +++++++++++++++ board/bf609-ezkit/soft_switch.c | 11 +-------- board/bf609-ezkit/soft_switch.h | 25 +++++++++++++------- common/Makefile | 1 + common/cmd_softswitch.c | 41 +++++++++++++++++++++++++++++++++ include/configs/bf609-ezkit.h | 1 + 7 files changed, 80 insertions(+), 18 deletions(-) create mode 100644 arch/blackfin/include/asm/soft_switch.h create mode 100644 common/cmd_softswitch.c
diff --git a/README b/README index 0d37d56..defdedb 100644 --- a/README +++ b/README @@ -898,6 +898,7 @@ The following options need to be configured: CONFIG_CMD_SF * Read/write/erase SPI NOR flash CONFIG_CMD_SHA1SUM print sha1 memory digest (requires CONFIG_CMD_MEMORY) + CONFIG_CMD_SOFTSWITCH * Soft switch setting command for BF60x CONFIG_CMD_SOURCE "source" command Support CONFIG_CMD_SPI * SPI serial bus support CONFIG_CMD_TFTPSRV * TFTP transfer in server mode diff --git a/arch/blackfin/include/asm/soft_switch.h b/arch/blackfin/include/asm/soft_switch.h new file mode 100644 index 0000000..ff8e44d --- /dev/null +++ b/arch/blackfin/include/asm/soft_switch.h @@ -0,0 +1,18 @@ +/* + * U-boot - main board file + * + * Copyright (c) 2008-2012 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#ifndef __SOFT_SWITCH_H__ +#define __SOFT_SWITCH_H__ + +#define IO_PORT_A 0 +#define IO_PORT_B 1 +#define IO_PORT_INPUT 0 +#define IO_PORT_OUTPUT 1 + +int config_switch_bit(int num, int port, int bit, int dir, uchar value); +#endif diff --git a/board/bf609-ezkit/soft_switch.c b/board/bf609-ezkit/soft_switch.c index 2e1404f..e0c8d93 100644 --- a/board/bf609-ezkit/soft_switch.c +++ b/board/bf609-ezkit/soft_switch.c @@ -12,14 +12,6 @@ #include <i2c.h> #include "soft_switch.h"
-#define SWITCH_ADDR 0x21 - -#define NUM_SWITCH 3 -#define IODIRA 0x0 -#define IODIRB 0x1 -#define OLATA 0x14 -#define OLATB 0x15 - struct switch_config { uchar dir0; /* IODIRA */ uchar dir1; /* IODIRB */ @@ -126,9 +118,8 @@ static int setup_soft_switch(int addr, struct switch_config *config) return i2c_write(addr, IODIRB, 1, &config->dir1, 1); }
-int config_switch_bit(int num, int port, int bit, int dir, uchar value) +int config_switch_bit(int addr, int port, int bit, int dir, uchar value) { - int addr = SWITCH_ADDR + num; int ret, data_reg, dir_reg; uchar tmp;
diff --git a/board/bf609-ezkit/soft_switch.h b/board/bf609-ezkit/soft_switch.h index 8da0e44..d147fe1 100644 --- a/board/bf609-ezkit/soft_switch.h +++ b/board/bf609-ezkit/soft_switch.h @@ -6,8 +6,10 @@ * Licensed under the GPL-2 or later. */
-#ifndef __SOFT_SWITCH_H__ -#define __SOFT_SWITCH_H__ +#ifndef __BOARD_SOFT_SWITCH_H__ +#define __BOARD_SOFT_SWITCH_H__ + +#include <asm/soft_switch.h>
/* switch 0 port A */ #define CAN_EN 0x1 @@ -61,11 +63,18 @@ #define PD3_SPI0MOSI_EN 0x1 #define PD4_SPI0CK_EN 0x2
-#define IO_PORT_A 0 -#define IO_PORT_B 1 -#define IO_PORT_INPUT 0 -#define IO_PORT_OUTPUT 1 +#ifdef CONFIG_BFIN_BOARD_VERSION_1_0 +#define SWITCH_ADDR 0x21 +#else +#define SWITCH_ADDR 0x20 +#endif + +#define NUM_SWITCH 3 +#define IODIRA 0x0 +#define IODIRB 0x1 +#define OLATA 0x14 +#define OLATB 0x15
-int config_switch_bit(int num, int port, int bit, int dir, uchar value); int setup_board_switches(void); -#endif + +#endif /* __BOARD_SOFT_SWITCH_H__ */ diff --git a/common/Makefile b/common/Makefile index 0e0fff1..0429a3c 100644 --- a/common/Makefile +++ b/common/Makefile @@ -164,6 +164,7 @@ COBJS-$(CONFIG_CMD_SF) += cmd_sf.o COBJS-$(CONFIG_CMD_SCSI) += cmd_scsi.o COBJS-$(CONFIG_CMD_SHA1SUM) += cmd_sha1sum.o COBJS-$(CONFIG_CMD_SETEXPR) += cmd_setexpr.o +COBJS-$(CONFIG_CMD_SOFTSWITCH) += cmd_softswitch.o COBJS-$(CONFIG_CMD_SPI) += cmd_spi.o COBJS-$(CONFIG_CMD_SPIBOOTLDR) += cmd_spibootldr.o COBJS-$(CONFIG_CMD_STRINGS) += cmd_strings.o diff --git a/common/cmd_softswitch.c b/common/cmd_softswitch.c new file mode 100644 index 0000000..f75d926 --- /dev/null +++ b/common/cmd_softswitch.c @@ -0,0 +1,41 @@ +/* + * cmd_softswitch.c - set the softswitch for bf60x + * + * Copyright (c) 2012 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#include <common.h> +#include <command.h> +#include <asm/blackfin.h> +#include <asm/soft_switch.h> + +int do_softswitch(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int switchaddr, value, pin, port; + + if (argc != 5) + return CMD_RET_USAGE; + + if (strcmp(argv[2], "GPA") == 0) + port = IO_PORT_A; + else if (strcmp(argv[2], "GPB") == 0) + port = IO_PORT_B; + else + return CMD_RET_USAGE; + + switchaddr = simple_strtoul(argv[1], NULL, 16); + pin = simple_strtoul(argv[3], NULL, 16); + value = simple_strtoul(argv[4], NULL, 16); + + config_switch_bit(switchaddr, port, (1 << pin), IO_PORT_OUTPUT, value); + + return 0; +} + +U_BOOT_CMD( + softswitch_output, 5, 1, do_softswitch, + "switchaddr GPA/GPB pin_offset value", + "" +); diff --git a/include/configs/bf609-ezkit.h b/include/configs/bf609-ezkit.h index 8b90129..f0ac86b 100644 --- a/include/configs/bf609-ezkit.h +++ b/include/configs/bf609-ezkit.h @@ -144,6 +144,7 @@ #define CONFIG_UART_CONSOLE 0
#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_SOFTSWITCH
#define CONFIG_SYS_MEMTEST_END (CONFIG_STACKBASE - 20*1024*1024 + 4) #define CONFIG_BFIN_SOFT_SWITCH
Sonic Zhang
