[PATCH 0/3] boards: ls1088aqds: transition to CONFIG_DM_ETH
This patch set targets to add support for CONFIG_DM_ETH for the NXP LS1088AQDS board.
The main focus is on changing the DTS based on the SERDES protocol used. In order to accomplish this, the MULTI_DTB_FIT feature is employed and the appropriate DTS is chosed on boot from a list of predefined files.
Any unnecessary configurations made for the DPAA2 ethernet devices in the board files are compiled out when CONFIG_DM_ETH is enabled. This is because any information necessary is available in its associated DTS node.
This patch set depends on another series that adds support for DM_ETH in the ldpaa_eth driver and the RDB boards: https://patchwork.ozlabs.org/project/uboot/list/?series=165158&state=*
For the moment, when CONFIG_DM_ETH is enabled DPAA2 networking is supported only for the SERDES block #1 protocol 21 (0x15) and protocol 29 (0x1d).
Ioana Ciornei (3): arm: dts: ls1088aqds: add CONFIG_MULTI_DTB_FIT support board: ls1088aqds: transition to DM_ETH configs: ls1088aqds_tfa_defconfig: enable DM_ETH and related
arch/arm/dts/Makefile | 2 + arch/arm/dts/fsl-ls1088a-qds-21-x.dts | 16 ++ arch/arm/dts/fsl-ls1088a-qds-29-x.dts | 16 ++ arch/arm/dts/fsl-ls1088a-qds-sd1-21.dtsi | 30 ++++ arch/arm/dts/fsl-ls1088a-qds-sd1-29.dtsi | 19 +++ arch/arm/dts/fsl-ls1088a-qds.dts | 124 +-------------- arch/arm/dts/fsl-ls1088a-qds.dtsi | 187 +++++++++++++++++++++++ board/freescale/ls1088a/eth_ls1088aqds.c | 89 +++++++++++ configs/ls1088aqds_tfa_defconfig | 11 +- include/configs/ls1088aqds.h | 2 + 10 files changed, 373 insertions(+), 123 deletions(-) create mode 100644 arch/arm/dts/fsl-ls1088a-qds-21-x.dts create mode 100644 arch/arm/dts/fsl-ls1088a-qds-29-x.dts create mode 100644 arch/arm/dts/fsl-ls1088a-qds-sd1-21.dtsi create mode 100644 arch/arm/dts/fsl-ls1088a-qds-sd1-29.dtsi create mode 100644 arch/arm/dts/fsl-ls1088a-qds.dtsi
Add support for selecting the appropriate DTS file depending on the SERDES protocol used. The fsl-ls2088a-qds DTS will be used by default if there isn't a DTS file specifically made for the current SERDES protocol.
This patch adds support for the on-board ports (DPMAC 1,2 and 4,5) found on the SERDES protocols 21(0x15) and 29(0x1d) for SD#1.
On the LS1088AQDS board EMDIO1 is used with two onboard RGMII PHYs (Realtek RTL8211FD-CG), as well as 2 input/output connectors for mezzanine cards. Configuration signals from the Qixis FPGA control the routing of the external MDIOs.
Register 0x54 of the Qixis FPGA controls the routing of the EMDIO1 one of the 2 IO slots. As a consequence, a new node is added to describe register 0x54 as a MDIO mux controlled with child nodes describing all the IO slots as MDIO buses.
Also, in case CONFIG_DM_ETH and CONFIG_MULTI_DTB_FIT are enabled implement the board_fit_config_name_match() function in order to choose the appropriate DTS.
Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com --- arch/arm/dts/Makefile | 2 + arch/arm/dts/fsl-ls1088a-qds-21-x.dts | 16 ++ arch/arm/dts/fsl-ls1088a-qds-29-x.dts | 16 ++ arch/arm/dts/fsl-ls1088a-qds-sd1-21.dtsi | 30 ++++ arch/arm/dts/fsl-ls1088a-qds-sd1-29.dtsi | 19 +++ arch/arm/dts/fsl-ls1088a-qds.dts | 124 +-------------- arch/arm/dts/fsl-ls1088a-qds.dtsi | 187 +++++++++++++++++++++++ board/freescale/ls1088a/eth_ls1088aqds.c | 87 +++++++++++ 8 files changed, 359 insertions(+), 122 deletions(-) create mode 100644 arch/arm/dts/fsl-ls1088a-qds-21-x.dts create mode 100644 arch/arm/dts/fsl-ls1088a-qds-29-x.dts create mode 100644 arch/arm/dts/fsl-ls1088a-qds-sd1-21.dtsi create mode 100644 arch/arm/dts/fsl-ls1088a-qds-sd1-29.dtsi create mode 100644 arch/arm/dts/fsl-ls1088a-qds.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b6df24fdb2ac..ad2e975a9b66 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -375,6 +375,8 @@ dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-ls2088a-rdb-qspi.dtb \ fsl-ls1088a-rdb.dtb \ fsl-ls1088a-qds.dtb \ + fsl-ls1088a-qds-21-x.dtb \ + fsl-ls1088a-qds-29-x.dtb \ fsl-ls1028a-rdb.dtb \ fsl-ls1028a-qds.dtb \ fsl-lx2160a-rdb.dtb \ diff --git a/arch/arm/dts/fsl-ls1088a-qds-21-x.dts b/arch/arm/dts/fsl-ls1088a-qds-21-x.dts new file mode 100644 index 000000000000..a87796451199 --- /dev/null +++ b/arch/arm/dts/fsl-ls1088a-qds-21-x.dts @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LS1088AQDS device tree source for SERDES protocol 21.x + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-ls1088a-qds-sd1-21.dtsi" + +/ { + model = "NXP Layerscape 1088a QDS Board (DTS 21-x)"; + compatible = "fsl,ls1088a-qds", "fsl,ls1088a"; +}; diff --git a/arch/arm/dts/fsl-ls1088a-qds-29-x.dts b/arch/arm/dts/fsl-ls1088a-qds-29-x.dts new file mode 100644 index 000000000000..29c4ec59fe50 --- /dev/null +++ b/arch/arm/dts/fsl-ls1088a-qds-29-x.dts @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LS1088AQDS device tree source for SERDES protocol 29.x + * + * Copyright 2020 NXP + * + */ + +/dts-v1/; + +#include "fsl-ls1088a-qds-sd1-29.dtsi" + +/ { + model = "NXP Layerscape 1088a QDS Board (DTS 29-x)"; + compatible = "fsl,ls1088a-qds", "fsl,ls1088a"; +}; diff --git a/arch/arm/dts/fsl-ls1088a-qds-sd1-21.dtsi b/arch/arm/dts/fsl-ls1088a-qds-sd1-21.dtsi new file mode 100644 index 000000000000..e0a6c04835bf --- /dev/null +++ b/arch/arm/dts/fsl-ls1088a-qds-sd1-21.dtsi @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LS1088AQDS device tree source for SERDES block #1 - protocol 21 (0x15) + * + * Copyright 2020 NXP + */ + +#include "fsl-ls1088a-qds.dtsi" + +&dpmac1 { + status = "okay"; + phy-connection-type = "xfi"; +}; + +&dpmac2 { + status = "okay"; + phy-connection-type = "xfi"; +}; + +&dpmac4 { + status = "okay"; + phy-handle = <&rgmii_phy1>; + phy-connection-type = "rgmii-id"; +}; + +&dpmac5 { + status = "okay"; + phy-handle = <&rgmii_phy2>; + phy-connection-type = "rgmii-id"; +}; diff --git a/arch/arm/dts/fsl-ls1088a-qds-sd1-29.dtsi b/arch/arm/dts/fsl-ls1088a-qds-sd1-29.dtsi new file mode 100644 index 000000000000..25a6af875eef --- /dev/null +++ b/arch/arm/dts/fsl-ls1088a-qds-sd1-29.dtsi @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP LS1088AQDS device tree source for SERDES block #1 - protocol 29 (0x1d) + * + * Copyright 2020 NXP + */ + +#include "fsl-ls1088a-qds.dtsi" + +&dpmac1 { + status = "okay"; + phy-connection-type = "xfi"; +}; + +&dpmac2 { + status = "okay"; + phy-connection-type = "xfi"; +}; + diff --git a/arch/arm/dts/fsl-ls1088a-qds.dts b/arch/arm/dts/fsl-ls1088a-qds.dts index f07d0c6f2748..4ec688081f76 100644 --- a/arch/arm/dts/fsl-ls1088a-qds.dts +++ b/arch/arm/dts/fsl-ls1088a-qds.dts @@ -1,133 +1,13 @@ // SPDX-License-Identifier: GPL-2.0+ OR X11 /* - * NXP ls1088a QDS board device tree source + * NXP ls1088a QDS default board device tree source * - * Copyright 2017 NXP + * Copyright 2020 NXP */
/dts-v1/;
-#include "fsl-ls1088a.dtsi" - / { model = "NXP Layerscape 1088a QDS Board"; compatible = "fsl,ls1088a-qds", "fsl,ls1088a"; - aliases { - spi0 = &qspi; - spi1 = &dspi; - }; -}; - -&i2c0 { - status = "okay"; - u-boot,dm-pre-reloc; - - i2c-mux@77 { - compatible = "nxp,pca9547"; - reg = <0x77>; - #address-cells = <1>; - #size-cells = <0>; - - i2c@3 { - #address-cells = <1>; - #size-cells = <0>; - reg = <0x3>; - - rtc@51 { - compatible = "pcf2127-rtc"; - reg = <0x51>; - }; - }; - }; -}; - -&ifc { - #address-cells = <2>; - #size-cells = <1>; - /* NOR, NAND Flashes and FPGA on board */ - ranges = <0 0 0x5 0x80000000 0x08000000 - 2 0 0x5 0x30000000 0x00010000 - 3 0 0x5 0x20000000 0x00010000>; - status = "okay"; - - nor@0,0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "cfi-flash"; - reg = <0x0 0x0 0x8000000>; - bank-width = <2>; - device-width = <1>; - }; - - nand@2,0 { - compatible = "fsl,ifc-nand"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x1 0x0 0x10000>; - }; - - fpga: board-control@3,0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "simple-bus", "fsl,ls1088aqds-fpga", - "fsl,fpga-qixis"; - reg = <0x2 0x0 0x0000100>; - bank-width = <1>; - device-width = <1>; - ranges = <0 2 0 0x100>; - }; -}; - -&dspi { - bus-num = <0>; - status = "okay"; - - dflash0: n25q128a { - #address-cells = <1>; - #size-cells = <1>; - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <1000000>; /* input clock */ - }; - - dflash1: sst25wf040b { - #address-cells = <1>; - #size-cells = <1>; - compatible = "jedec,spi-nor"; - spi-max-frequency = <3500000>; - reg = <1>; - }; - - dflash2: en25s64 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "jedec,spi-nor"; - spi-max-frequency = <3500000>; - reg = <2>; - }; -}; - -&qspi { - bus-num = <0>; - status = "okay"; - - qflash0: s25fs512s@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "jedec,spi-nor"; - spi-max-frequency = <50000000>; - reg = <0>; - }; - - qflash1: s25fs512s@1 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "jedec,spi-nor"; - spi-max-frequency = <50000000>; - reg = <1>; - }; -}; - -&sata { - status = "okay"; }; diff --git a/arch/arm/dts/fsl-ls1088a-qds.dtsi b/arch/arm/dts/fsl-ls1088a-qds.dtsi new file mode 100644 index 000000000000..13e16d573863 --- /dev/null +++ b/arch/arm/dts/fsl-ls1088a-qds.dtsi @@ -0,0 +1,187 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * NXP ls1088a QDS common board device tree source + * + * Copyright 2017-2020 NXP + */ + +#include "fsl-ls1088a.dtsi" + +/ { + aliases { + spi0 = &qspi; + spi1 = &dspi; + }; +}; + +&emdio1 { + status = "okay"; +}; + +&emdio2 { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + u-boot,dm-pre-reloc; + + fpga@66 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "simple-mfd"; + reg = <0x66>; + + mux-mdio@54 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "mdio-mux-i2creg"; + reg = <0x54>; + #mux-control-cells = <1>; + mux-reg-masks = <0x54 0xe0>; // reg 0x54, bits 7:5 + mdio-parent-bus = <&emdio1>; + + mdio@00 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x00>; + + rgmii_phy1: ethernet-phy@1 { + reg = <0x1>; + }; + }; + mdio@20 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x20>; + + rgmii_phy2: ethernet-phy@2 { + reg = <0x2>; + }; + }; + + emdio1_slot1: mdio@40 { /* I/O Slot #1 */ + reg = <0x40>; + device-name = "emdio1_slot1"; + #address-cells = <1>; + #size-cells = <0>; + }; + + emdio1_slot3: mdio@60 { /* I/O Slot #3 */ + reg = <0x60>; + device-name = "emdio1_slot3"; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + }; + + i2c-mux@77 { + compatible = "nxp,pca9547"; + reg = <0x77>; + #address-cells = <1>; + #size-cells = <0>; + + i2c@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x3>; + + rtc@51 { + compatible = "pcf2127-rtc"; + reg = <0x51>; + }; + }; + }; +}; + +&ifc { + #address-cells = <2>; + #size-cells = <1>; + /* NOR, NAND Flashes and FPGA on board */ + ranges = <0 0 0x5 0x80000000 0x08000000 + 2 0 0x5 0x30000000 0x00010000 + 3 0 0x5 0x20000000 0x00010000>; + status = "okay"; + + nor@0,0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "cfi-flash"; + reg = <0x0 0x0 0x8000000>; + bank-width = <2>; + device-width = <1>; + }; + + nand@2,0 { + compatible = "fsl,ifc-nand"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x1 0x0 0x10000>; + }; + + fpga: board-control@3,0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus", "fsl,ls1088aqds-fpga", + "fsl,fpga-qixis"; + reg = <0x2 0x0 0x0000100>; + bank-width = <1>; + device-width = <1>; + ranges = <0 2 0 0x100>; + }; +}; + +&dspi { + bus-num = <0>; + status = "okay"; + + dflash0: n25q128a { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <1000000>; /* input clock */ + }; + + dflash1: sst25wf040b { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <3500000>; + reg = <1>; + }; + + dflash2: en25s64 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <3500000>; + reg = <2>; + }; +}; + +&qspi { + bus-num = <0>; + status = "okay"; + + qflash0: s25fs512s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <50000000>; + reg = <0>; + }; + + qflash1: s25fs512s@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <50000000>; + reg = <1>; + }; +}; + +&sata { + status = "okay"; +}; diff --git a/board/freescale/ls1088a/eth_ls1088aqds.c b/board/freescale/ls1088a/eth_ls1088aqds.c index 54ef75347f60..c0bcf7129929 100644 --- a/board/freescale/ls1088a/eth_ls1088aqds.c +++ b/board/freescale/ls1088a/eth_ls1088aqds.c @@ -742,3 +742,90 @@ void reset_phy(void) mc_env_boot(); } #endif /* CONFIG_RESET_PHY_R */ + +#if defined(CONFIG_DM_ETH) && defined(CONFIG_MULTI_DTB_FIT) + +/* Structure to hold SERDES protocols supported in case of + * CONFIG_DM_ETH enabled (network interfaces are described in the DTS). + * + * @serdes_block: the index of the SERDES block + * @serdes_protocol: the decimal value of the protocol supported + * @dts_needed: DTS notes describing the current configuration are needed + * + * When dts_needed is true, the board_fit_config_name_match() function + * will try to exactly match the current configuration of the block with a DTS + * name provided. + */ +static struct serdes_configuration { + u8 serdes_block; + u32 serdes_protocol; + bool dts_needed; +} supported_protocols[] = { + /* Serdes block #1 */ + {1, 21, true}, + {1, 29, true}, +}; + +#define SUPPORTED_SERDES_PROTOCOLS ARRAY_SIZE(supported_protocols) + +static bool protocol_supported(u8 serdes_block, u32 protocol) +{ + struct serdes_configuration serdes_conf; + int i; + + for (i = 0; i < SUPPORTED_SERDES_PROTOCOLS; i++) { + serdes_conf = supported_protocols[i]; + if (serdes_conf.serdes_block == serdes_block && + serdes_conf.serdes_protocol == protocol) + return true; + } + + return false; +} + +static void get_str_protocol(u8 serdes_block, u32 protocol, char *str) +{ + struct serdes_configuration serdes_conf; + int i; + + for (i = 0; i < SUPPORTED_SERDES_PROTOCOLS; i++) { + serdes_conf = supported_protocols[i]; + if (serdes_conf.serdes_block == serdes_block && + serdes_conf.serdes_protocol == protocol) { + if (serdes_conf.dts_needed == true) + sprintf(str, "%u", protocol); + else + sprintf(str, "x"); + return; + } + } +} + +int board_fit_config_name_match(const char *name) +{ + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + char expected_dts[100]; + char srds_s1_str[2]; + u32 srds_s1, cfg; + + cfg = in_le32(&gur->rcwsr[FSL_CHASSIS3_SRDS1_REGSR - 1]) & + FSL_CHASSIS3_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS3_SRDS1_PRTCL_SHIFT; + srds_s1 = serdes_get_number(FSL_SRDS_1, cfg); + + /* Check for supported protocols. The default DTS will be used + * in this case + */ + if (!protocol_supported(1, srds_s1)) + return -1; + + get_str_protocol(1, srds_s1, srds_s1_str); + + sprintf(expected_dts, "fsl-ls1088a-qds-%s-x", srds_s1_str); + + if (!strcmp(name, expected_dts)) + return 0; + + return -1; +} +#endif
In case CONFIG_DM_ETH is enabled, no hardcoding is necessary for DPAA2 Ethernet devices. Compile out any unnecessary setup when CONFIG_DM_ETH is activated. Also, force the PCI devices to be enumerated at probe time.
Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com --- board/freescale/ls1088a/eth_ls1088aqds.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/freescale/ls1088a/eth_ls1088aqds.c b/board/freescale/ls1088a/eth_ls1088aqds.c index c0bcf7129929..7456f67f3d60 100644 --- a/board/freescale/ls1088a/eth_ls1088aqds.c +++ b/board/freescale/ls1088a/eth_ls1088aqds.c @@ -24,6 +24,7 @@
#include "ls1088a_qixis.h"
+#ifndef CONFIG_DM_ETH #ifdef CONFIG_FSL_MC_ENET
#define SFP_TX 0 @@ -735,6 +736,7 @@ int board_eth_init(bd_t *bis) error = pci_eth_init(bis); return error; } +#endif // !CONFIG_DM_ETH
#if defined(CONFIG_RESET_PHY_R) void reset_phy(void)
Enable CONFIG_DM_ETH and CONFIG_DM_MDIO and related configs for the LS1088AQDS board.
Signed-off-by: Ioana Ciornei ioana.ciornei@nxp.com --- configs/ls1088aqds_tfa_defconfig | 11 ++++++++++- include/configs/ls1088aqds.h | 2 ++ 2 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 1144cba983c6..a1f3d14980dc 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -4,8 +4,8 @@ CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ENV_OFFSET=0x500000 +CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 @@ -24,6 +24,7 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_DM=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -31,6 +32,8 @@ CONFIG_CMD_USB=y CONFIG_MP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" +CONFIG_OF_LIST="fsl-ls1088a-qds-21-x fsl-ls1088a-qds-29-x" +CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_NAND=y @@ -57,8 +60,14 @@ CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_MDIO_MUX_I2CREG=y +CONFIG_FSL_LS_MDIO=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index 4ac4a8d85686..122504fb407e 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -549,7 +549,9 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_FSL_MC_ENET #define CONFIG_FSL_MEMAC +#ifndef CONFIG_TARGET_LS1088AQDS #define CONFIG_PHYLIB +#endif #define CONFIG_PHYLIB_10G #define CONFIG_PHY_VITESSE #define CONFIG_PHY_REALTEK
Ioana Ciornei
