[PATCH v2] net: sun8i-emac: Add support for fixed-link phy
Make the "phy-handle" property optional, which allows support for a fixed-link phy configuration.
Thus if the "phy-handle" is present in a DT, then driver will work as before. Otherwise, phyaddr initialization will not be necessary, as it is not needed in case of a fixed-link config.
Signed-off-by: Maksim Kiselev bigunclemax@gmail.com --- drivers/net/sun8i_emac.c | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index a12f7e32e8..8bff4fe9a9 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -833,11 +833,8 @@ static int sun8i_emac_eth_of_to_plat(struct udevice *dev) priv->use_internal_phy = false;
offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "phy-handle"); - if (offset < 0) { - debug("%s: Cannot find PHY address\n", __func__); - return -EINVAL; - } - priv->phyaddr = fdtdec_get_int(gd->fdt_blob, offset, "reg", -1); + if (offset >= 0) + priv->phyaddr = fdtdec_get_int(gd->fdt_blob, offset, "reg", -1);
pdata->phy_interface = dev_read_phy_mode(dev); debug("phy interface %d\n", pdata->phy_interface);
On Sat, 20 Jan 2024 19:26:24 +0300 Maksim Kiselev bigunclemax@gmail.com wrote:
Thanks, looks good now:
Reviewed-by: Andre Przywara andre.przywara@arm.com
Queued for the first PR.
Cheers, Andre
- if (offset < 0) {
return -EINVAL;
if (offset >= 0)
Andre Przywara
Maksim Kiselev
