[U-Boot] [PATCH] ARM: socfpga: Fix EMIF clear timeout
The current EMIF clear timeout handling code was applying bitwise operations to signed data types and as it was, was extremely hard to read. Replace it with simple wait_for_bit(). Expand the error handling to make it more readable too.
This patch also changes the timeout for emif_clear() from 14 hours to 1 second.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Cc: Tien Fong Chee tien.fong.chee@intel.com --- drivers/ddr/altera/sdram_arria10.c | 24 +++++++++++------------- 1 file changed, 11 insertions(+), 13 deletions(-)
diff --git a/drivers/ddr/altera/sdram_arria10.c b/drivers/ddr/altera/sdram_arria10.c index be5ce778e8..6e6938fdb0 100644 --- a/drivers/ddr/altera/sdram_arria10.c +++ b/drivers/ddr/altera/sdram_arria10.c @@ -133,22 +133,16 @@ static unsigned char ddr_wait_bit(u32 ereg, u32 bit,
static int emif_clear(void) { - u32 i = DDR_MAX_TRIES; - u8 ret = 0; - writel(0, DDR_REG_CORE2SEQ);
- do { - ret = !wait_for_bit_le32((u32 *)DDR_REG_SEQ2CORE, - SEQ2CORE_MASK, 1, 50, 0); - } while (ret && (--i > 0)); - - return !i; + return wait_for_bit_le32((u32 *)DDR_REG_SEQ2CORE, + SEQ2CORE_MASK, 0, 1000, 0); }
static int emif_reset(void) { u32 c2s, s2c; + int ret;
c2s = readl(DDR_REG_CORE2SEQ); s2c = readl(DDR_REG_SEQ2CORE); @@ -159,9 +153,12 @@ static int emif_reset(void) readl(IO48_MMR_NIOS2_RESERVE2), readl(IO48_MMR_DRAMSTS));
- if ((s2c & SEQ2CORE_MASK) && emif_clear()) { - debug("failed emif_clear()\n"); - return -EPERM; + if (s2c & SEQ2CORE_MASK) { + ret = emif_clear(); + if (ret) { + debug("failed emif_clear()\n"); + return -EPERM; + } }
writel(CORE2SEQ_INT_REQ, DDR_REG_CORE2SEQ); @@ -173,7 +170,8 @@ static int emif_reset(void) debug("emif_reset interrupt acknowledged\n"); }
- if (emif_clear()) { + ret = emif_clear(); + if (ret) { debug("emif_clear() failed\n"); return -EPERM; }
