RE: [U-Boot-Users] board porting question
Again this is the screen print out looks like:
%s
U-Boot code: lFsa:hB%** *aWnrni g
-ab dRC,Cu isgnd feuatle vnrinoemtn
%s
sU-Boot code: BlFsa:hB** *aWnrni g
%s
sU-Boot code: BlFsa:hB%** *aWnrni
g -ab dRC,Cu isgnd feuatle vnrinoemtn
%s
Regards. Xuezhang.
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net] On Behalf Of Xuezhang Dong Sent: Thursday, January 12, 2006 2:31 PM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] board porting question
Thanks for the reply and my appology for the HTML format, I thought mail server will convert it. Never mind, it wonot happened again.
I was using the latest toolchain from snapgear: ARM/XSCALE - arm-linux-tools-20051123.tar.gz
And I supplied the compiler with -mbigarm parameter.
Any idea how I can verify/debug this problem?
Thanks. Xuezhang.
In message <54AD0F12E08D1541B826BE97C98F99F11C29B3@NT-SJCA-0751.brcm.ad.broadcom.co m> you wrote:
I have a board with arm926 big-endian, serial port, NOR/SRAM. I used omap 1610H2 as my code base since the cpu type is same. Problem is that the printf() function doesnot work, for example: printf("\n%s\n", uboot_version); instead of print the real string, it give me the "%s" as is. So I want to know it is a big-edian problem or ..., any clue will be appreciated.
I can only speculate here. Eventually this is a toolchain problem (printf() being a variable argument list function and thus sensible against problems with parameter passing).
Content-Type: text/html; charset=us-ascii Content-Transfer-Encoding: quoted-printable
And will you please stop posting HTML here???
I am *seriously* considering the option to move this list from SF and reject all messages that contain HTML (or even base64) encoded messages!!!
------------------------------------------------------- This SF.net email is sponsored by: Splunk Inc. Do you grep through log files for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://ads.osdn.com/?ad_idv37&alloc_id%16865&op=ick _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Xuezhang Dong
