RE: [U-Boot-Users] S29GLxxxM Flash write buffer programming
Sebastian,
I have used u-boot-1.1.2 for the IceCube board(MPC5200) to bring Linux on this board. It's working well. This board has a flash AMD: AM29LV0652D in X8 mode.
Tien Nghiem
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net]On Behalf Of Sebastian Schau Sent: Friday, April 08, 2005 6:43 AM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] S29GLxxxM Flash write buffer programming
Hi all,
I am using Spansion S29GL128M / AMD Am29LV128M flash in 8-Bit mode on our Board. Older Versions of this Flash supported a "Byte Program" mode to write a single byte into flash. Newer versions don't support this command. According to Datasheet you should use "Write Buffer Programming" in X8 (8-Bit) mode. My question is, if anyone has experience in using this Flash in X8 mode with U-Boot and/or Linux?
Thanks Sebastian
------------------------------------------------------- SF email is sponsored by - The IT Product Guide Read honest & candid reviews on hundreds of IT Products from real users. Discover which products truly live up to the hype. Start reading now. http://ads.osdn.com/?ad_id=6595&alloc_id=14396&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Nghiem, Tien
