[PATCH v2 1/1] riscv: restore global data pointer in trap handler
The gp register is used to store U-Boot's global data pointer. We should not assume that an UEFI application leaves the gp register unchanged as the UEFI specifications does not define who is the owner of the gp and tp registers.
So the following sequence should be followed in the trap handler:
* save the caller's gp register * restore the global data pointer * serve interrupts or print crash dump and reset * restore the caller's gp register
Cc: Abner Chang abner.chang@hpe.com Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: Saving and restoring the caller's x3 is already handled in mtrap.S. efi_loader.h provides an empty fallback efi_restore_gd() function if CONFIG_EFI_LOADER=n. --- arch/riscv/lib/interrupts.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/riscv/lib/interrupts.c b/arch/riscv/lib/interrupts.c index cd47e64487..8ff40f0f36 100644 --- a/arch/riscv/lib/interrupts.c +++ b/arch/riscv/lib/interrupts.c @@ -111,6 +111,9 @@ ulong handle_trap(ulong cause, ulong epc, ulong tval, struct pt_regs *regs) { ulong is_irq, irq;
+ /* An UEFI application may have changed gd. Restore U-Boot's gd. */ + efi_restore_gd(); + is_irq = (cause & MCAUSE_INT); irq = (cause & ~MCAUSE_INT);
-- 2.28.0
On Sun, Sep 27, 2020 at 4:24 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
- save the caller's gp register
- restore the global data pointer
- serve interrupts or print crash dump and reset
- restore the caller's gp register
efi_restore_gd();
Reviewed-by: Bin Meng bin.meng@windriver.com
Does other arch suffer the same issue?
efi_restore_gd();
Hello Bin,
x86 does not use a register of gd. arm has this statement already. No further architectures support UEFI.
Best regards
Heinrich
Hi Heinrich,
On Sun, Sep 27, 2020 at 4:46 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
efi_restore_gd();
Hello Bin,
x86 uses fs segment register to point to gd. Does UEFI not use fs?
Regards, Bin
On 9/27/20 10:51 AM, Bin Meng wrote:
Hi Heinrich,
efi_restore_gd();
Hello Bin,
The UEFI 2.8B specification is available at https://uefi.org/sites/default/files/resources/UEFI%20Spec%202.8B%20May%2020....
Chapter 2.3.2 "IA-32 Platform" and chapter 2.3.4 x64 "PlatformsAll" both have this sentence: "Other general purpose flag registers are undefined."
I could find no provision that segment registers remain unchanged.
Chapter 2.3.4.3 "Enabling Paging or Alternate Translations" and 2.3.4.3 "Enabling Paging or Alternate Translations in an Application" both allow UEFI payloads to have their own GDT and IDT. But it seems these have to be restored by the payload before entering an API call: "An application with translations enabled can restore firmware required mapping before each UEFI call."
This implies we have to change multiple places in U-Boot. For ARM and RISC-V we have routines
* efi_save_gd() * efi_restore_gd() * efi_set_gd() * trace_save_gd(); * trace_swap_gd();
So what we need to do is:
* Save our value of fs in efi_save_gd() and trace_save_gd(). * On API entry from the caller save the value of the callers fs and restore our value. * Before returning restore the callers fs.
Best regards
Heinrich
Regards, Bin
Bin Meng
