Re: FW: U-Boot: spl: partition error (stm32mp157)
it seems that the GPT partitionning is not regonized in SPL in part.c;
see the trace:
## Unknown partition table type 0
But you have correclty activate the GPT support in SPL
CONFIG_SPL_EFI_PARTITION=y
So I uspect read error in sdmmc driver
and no HW isue as ROM code load the SPL, but only 1 wire is used i this case
you can check the SPL device tree / try to reduce the SD card support to 1 wire and 25MHz.
And activated trace in SDMMC driver / dump the data readen (for the GPT header)
regard
Patrick
-----Original Message----- From: Patrice CHOTARD - foss patrice.chotard@foss.st.com Sent: mardi 8 décembre 2020 08:37 To: Jagan Teki jagan@amarulasolutions.com; Patrick DELAUNAY patrick.delaunay@st.com Cc: U-Boot-Denx u-boot@lists.denx.de Subject: Re: U-Boot: spl: partition error (stm32mp157)
Hi Jagan
On 12/7/20 6:46 PM, Jagan Teki wrote:
Hi Patrick,
Not sure, it's an issue with the current tree, or I may miss something.
Any suggestions?
U-Boot SPL 2021.01-rc2-00143-g345dd00160-dirty (Dec 07 2020 - 01:48:44 +0530) Model: Engicam i.Core STM32MP1 EDIMM2.2 Starter Kit RAM: DDR3-DDR3L 32bits 528000Khz WDT: Start## Unknown partition table type 0ed with servicing (60s timeout) ## Unknown partition table type 0 spl: partition error SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
Disk /dev/sda: 29.83 GiB, 32010928128 bytes, 62521344 sectors Disk model: Storage Device Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 6524CDDB-929F-4A12-96B2-C04F07403931
Device Start End Sectors Size Type /dev/sda1 34 545 512 256K Linux filesystem /dev/sda2 546 1057 512 256K Linux filesystem /dev/sda3 1058 5153 4096 2M Linux filesystem /dev/sda4 5154 62521310 62516157 29.8G Linux filesystem
I am not sure that the 3 first partition are using the correct filesystem type.
Do you follow indications in ./doc/board/st/stm32mp1.rst and more precisely the "Prepare an SD card" chapter ?
Thanks
$ sudo dd if=u-boot-spl.stm32 of=/dev/sda1 $ sudo dd if=u-boot-spl.stm32 of=/dev/sda2 $ sudo dd if=u-boot.img of=/dev/sda3
.config:
# # Automatically generated file; DO NOT EDIT. # U-Boot 2021.01-rc2 Configuration #
# # Compiler: arm-buildroot-linux-gnueabihf-gcc.br_real (Buildroot 2020.08-849-gdcd4b75069-dirty) 9.3.0 # CONFIG_CREATE_ARCH_SYMLINK=y # CONFIG_ARC is not set CONFIG_ARM=y # CONFIG_M68K is not set # CONFIG_MICROBLAZE is not set # CONFIG_MIPS is not set # CONFIG_NDS32 is not set # CONFIG_NIOS2 is not set # CONFIG_PPC is not set # CONFIG_RISCV is not set # CONFIG_SANDBOX is not set # CONFIG_SH is not set # CONFIG_X86 is not set # CONFIG_XTENSA is not set CONFIG_SYS_ARCH="arm" CONFIG_SYS_CPU="armv7" CONFIG_SYS_SOC="stm32mp" CONFIG_SYS_VENDOR="engicam" CONFIG_SYS_BOARD="stm32mp1" CONFIG_SYS_CONFIG_NAME="stm32mp1" # CONFIG_SYS_ICACHE_OFF is not set # CONFIG_SPL_SYS_ICACHE_OFF is not set # CONFIG_SYS_DCACHE_OFF is not set # CONFIG_SPL_SYS_DCACHE_OFF is not set
# # ARM architecture # # CONFIG_GIC_V3_ITS is not set CONFIG_HAS_VBAR=y CONFIG_HAS_THUMB2=y CONFIG_ARM_ASM_UNIFIED=y CONFIG_SYS_ARM_CACHE_CP15=y CONFIG_SYS_ARM_MMU=y # CONFIG_SYS_ARM_MPU is not set CONFIG_CPU_V7A=y CONFIG_SYS_ARM_ARCH=7 CONFIG_SYS_CACHE_SHIFT_6=y CONFIG_SYS_CACHELINE_SIZE=64 CONFIG_SYS_ARM_CACHE_WRITEBACK=y # CONFIG_SYS_ARM_CACHE_WRITETHROUGH is not set # CONFIG_SYS_ARM_CACHE_WRITEALLOC is not set # CONFIG_ARCH_CPU_INIT is not set CONFIG_SYS_ARCH_TIMER=y # CONFIG_ARM_SMCCC is not set # CONFIG_SEMIHOSTING is not set CONFIG_SYS_THUMB_BUILD=y CONFIG_SPL_SYS_THUMB_BUILD=y # CONFIG_SYS_L2CACHE_OFF is not set # CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK is not set CONFIG_USE_ARCH_MEMCPY=y CONFIG_SPL_USE_ARCH_MEMCPY=y CONFIG_USE_ARCH_MEMSET=y CONFIG_SPL_USE_ARCH_MEMSET=y # CONFIG_ARCH_AT91 is not set # CONFIG_TARGET_EDB93XX is not set # CONFIG_TARGET_ASPENITE is not set # CONFIG_TARGET_GPLUGD is not set # CONFIG_ARCH_DAVINCI is not set # CONFIG_ARCH_KIRKWOOD is not set # CONFIG_ARCH_MVEBU is not set # CONFIG_TARGET_APF27 is not set # CONFIG_ARCH_ORION5X is not set # CONFIG_TARGET_SPEAR300 is not set # CONFIG_TARGET_SPEAR310 is not set # CONFIG_TARGET_SPEAR320 is not set # CONFIG_TARGET_SPEAR600 is not set # CONFIG_TARGET_STV0991 is not set # CONFIG_TARGET_X600 is not set # CONFIG_TARGET_FLEA3 is not set # CONFIG_TARGET_MX35PDK is not set # CONFIG_ARCH_BCM283X is not set # CONFIG_ARCH_BCM63158 is not set # CONFIG_ARCH_BCM68360 is not set # CONFIG_ARCH_BCM6858 is not set # CONFIG_TARGET_VEXPRESS_CA15_TC2 is not set # CONFIG_ARCH_BCMSTB is not set # CONFIG_TARGET_VEXPRESS_CA5X2 is not set # CONFIG_TARGET_VEXPRESS_CA9X4 is not set # CONFIG_TARGET_BCM23550_W1D is not set # CONFIG_TARGET_BCM28155_AP is not set # CONFIG_TARGET_BCMCYGNUS is not set # CONFIG_TARGET_BCMNSP is not set # CONFIG_TARGET_BCMNS2 is not set # CONFIG_TARGET_BCMNS3 is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_S5PC1XX is not set # CONFIG_ARCH_HIGHBANK is not set # CONFIG_ARCH_INTEGRATOR is not set # CONFIG_ARCH_IPQ40XX is not set # CONFIG_ARCH_KEYSTONE is not set # CONFIG_ARCH_K3 is not set # CONFIG_ARCH_OMAP2PLUS is not set # CONFIG_ARCH_MESON is not set # CONFIG_ARCH_MEDIATEK is not set # CONFIG_ARCH_LPC32XX is not set # CONFIG_ARCH_IMX8 is not set # CONFIG_ARCH_IMX8M is not set # CONFIG_ARCH_IMXRT is not set # CONFIG_ARCH_MX23 is not set # CONFIG_ARCH_MX25 is not set # CONFIG_ARCH_MX28 is not set # CONFIG_ARCH_MX31 is not set # CONFIG_ARCH_MX7ULP is not set # CONFIG_ARCH_MX7 is not set # CONFIG_ARCH_MX6 is not set CONFIG_SPL_LDSCRIPT="arch/$(ARCH)/cpu/u-boot-spl.lds" # CONFIG_ARCH_MX5 is not set # CONFIG_ARCH_NEXELL is not set # CONFIG_ARCH_OWL is not set # CONFIG_ARCH_QEMU is not set # CONFIG_ARCH_RMOBILE is not set # CONFIG_TARGET_S32V234EVB is not set # CONFIG_ARCH_SNAPDRAGON is not set # CONFIG_ARCH_SOCFPGA is not set # CONFIG_ARCH_SUNXI is not set # CONFIG_ARCH_U8500 is not set # CONFIG_ARCH_VERSAL is not set # CONFIG_ARCH_VF610 is not set # CONFIG_ARCH_ZYNQ is not set # CONFIG_ARCH_ZYNQMP_R5 is not set # CONFIG_ARCH_ZYNQMP is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_TARGET_VEXPRESS64_AEMV8A is not set # CONFIG_TARGET_VEXPRESS64_BASE_FVP is not set # CONFIG_TARGET_VEXPRESS64_JUNO is not set # CONFIG_TARGET_TOTAL_COMPUTE is not set # CONFIG_TARGET_LS2080A_EMU is not set # CONFIG_TARGET_LS2080A_SIMU is not set # CONFIG_TARGET_LS1088AQDS is not set # CONFIG_TARGET_LS2080AQDS is not set # CONFIG_TARGET_LS2080ARDB is not set # CONFIG_TARGET_LS2081ARDB is not set # CONFIG_TARGET_LX2160ARDB is not set # CONFIG_TARGET_LX2160AQDS is not set # CONFIG_TARGET_HIKEY is not set # CONFIG_TARGET_HIKEY960 is not set # CONFIG_TARGET_POPLAR is not set # CONFIG_TARGET_LS1012AQDS is not set # CONFIG_TARGET_LS1012ARDB is not set # CONFIG_TARGET_LS1012A2G5RDB is not set # CONFIG_TARGET_LS1012AFRWY is not set # CONFIG_TARGET_LS1012AFRDM is not set # CONFIG_TARGET_LS1028AQDS is not set # CONFIG_TARGET_LS1028ARDB is not set # CONFIG_TARGET_LS1088ARDB is not set # CONFIG_TARGET_LS1021AQDS is not set # CONFIG_TARGET_LS1021ATWR is not set # CONFIG_TARGET_LS1021ATSN is not set # CONFIG_TARGET_LS1021AIOT is not set # CONFIG_TARGET_LS1043AQDS is not set # CONFIG_TARGET_LS1043ARDB is not set # CONFIG_TARGET_LS1046AQDS is not set # CONFIG_TARGET_LS1046ARDB is not set # CONFIG_TARGET_LS1046AFRWY is not set # CONFIG_TARGET_SL28 is not set # CONFIG_TARGET_COLIBRI_PXA270 is not set # CONFIG_ARCH_UNIPHIER is not set # CONFIG_ARCH_STM32 is not set # CONFIG_ARCH_STI is not set CONFIG_ARCH_STM32MP=y # CONFIG_ARCH_ROCKCHIP is not set # CONFIG_ARCH_OCTEONTX is not set # CONFIG_ARCH_OCTEONTX2 is not set # CONFIG_TARGET_THUNDERX_88XX is not set # CONFIG_ARCH_ASPEED is not set # CONFIG_TARGET_DURIAN is not set # CONFIG_TARGET_PRESIDIO_ASIC is not set # CONFIG_TARGET_XENGUEST_ARM64 is not set CONFIG_ARCH_SUPPORT_TFABOOT=y # CONFIG_TFABOOT is not set CONFIG_SYS_TEXT_BASE=0xC0100000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_MEMTEST_START=0xc0000000 CONFIG_SYS_MEMTEST_END=0xc4000000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x280000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y CONFIG_SPL_TEXT_BASE=0x2FFC2500 CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_BOOTCOUNT_BOOTLIMIT=0 CONFIG_SYS_BOOTCOUNT_ADDR=0x5C00A154 CONFIG_SPL_SYS_MALLOC_F_LEN=0x3000 CONFIG_ERR_PTR_OFFSET=0x0 CONFIG_SPL_SIZE_LIMIT=0x0 CONFIG_SPL=y CONFIG_STM32MP15x=y # CONFIG_TARGET_ST_STM32MP15x is not set CONFIG_TARGET_ICORE_STM32MP1=y # CONFIG_TARGET_DH_STM32MP1_PDK2 is not set CONFIG_DDR_CACHEABLE_SIZE=0x40000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_MMC2=1 CONFIG_STM32_ETZPC=y CONFIG_CMD_STM32PROG=y CONFIG_CMD_STM32KEY=y CONFIG_PRE_CON_BUF_ADDR=0xC02FF000 CONFIG_PRE_CON_BUF_SZ=4096 CONFIG_BOOTSTAGE_STASH_ADDR=0xC3000000 CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y # CONFIG_CMD_STBOARD is not set CONFIG_DFU_ALT_RAM0="uImage ram 0xc2000000 0x2000000;devicetree.dtb ram 0xc4000000 0x100000;uramdisk.image.gz ram 0xc4400000 0x10000000" CONFIG_TYPEC_STUSB160X=y CONFIG_ENV_OFFSET_REDUND=0x2C0000 CONFIG_IDENT_STRING="" # CONFIG_SPL_FS_FAT is not set CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_CPU_V7_HAS_NONSEC=y CONFIG_CPU_V7_HAS_VIRT=y CONFIG_ARCH_SUPPORT_PSCI=y CONFIG_ARMV7_NONSEC=y # CONFIG_ARMV7_BOOT_SEC_DEFAULT is not set # CONFIG_ARMV7_VIRT is not set CONFIG_ARMV7_PSCI=y CONFIG_ARMV7_PSCI_1_0=y # CONFIG_ARMV7_PSCI_0_2 is not set # CONFIG_ARMV7_PSCI_0_1 is not set CONFIG_ARMV7_PSCI_NR_CPUS=4 # CONFIG_ARMV7_LPAE is not set # CONFIG_CMD_DEKBLOB is not set # CONFIG_CMD_HDMIDETECT is not set CONFIG_IMX_DCD_ADDR=0x00910000
# # ARM debug # # CONFIG_DEBUG_LL is not set CONFIG_SPL_PAYLOAD="u-boot.bin" CONFIG_BUILD_TARGET="" CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-icore-stm32mp1" # CONFIG_DEBUG_UART is not set # CONFIG_AHCI is not set # CONFIG_OF_BOARD_FIXUP is not set
# # General setup # CONFIG_LOCALVERSION="" CONFIG_LOCALVERSION_AUTO=y CONFIG_CC_OPTIMIZE_FOR_SIZE=y # CONFIG_OPTIMIZE_INLINING is not set # CONFIG_SPL_OPTIMIZE_INLINING is not set CONFIG_CC_HAS_ASM_INLINE=y # CONFIG_XEN is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_ENV_VARS_UBOOT_CONFIG=y # CONFIG_SYS_BOOT_GET_CMDLINE is not set # CONFIG_SYS_BOOT_GET_KBD is not set CONFIG_SYS_MALLOC_F=y CONFIG_EXPERT=y CONFIG_SYS_MALLOC_CLEAR_ON_INIT=y # CONFIG_SYS_MALLOC_DEFAULT_TO_INIT is not set # CONFIG_TOOLS_DEBUG is not set # CONFIG_PHYS_64BIT is not set CONFIG_SPL_IMAGE="spl/u-boot-spl.bin" # CONFIG_SYS_CUSTOM_LDSCRIPT is not set CONFIG_PLATFORM_ELFENTRY="_start" CONFIG_STACK_SIZE=0x1000000 CONFIG_SYS_SRAM_BASE=0x0 CONFIG_SYS_SRAM_SIZE=0x0 # CONFIG_EXAMPLES is not set
# # API # # CONFIG_API is not set
# # Boot options #
# # Boot images # CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x0 CONFIG_FIT_ENABLE_SHA256_SUPPORT=y # CONFIG_FIT_ENABLE_SHA384_SUPPORT is not set # CONFIG_FIT_ENABLE_SHA512_SUPPORT is not set # CONFIG_FIT_SIGNATURE is not set # CONFIG_FIT_CIPHER is not set # CONFIG_FIT_VERBOSE is not set # CONFIG_FIT_BEST_MATCH is not set # CONFIG_SPL_FIT is not set # CONFIG_SPL_FIT_SIGNATURE is not set # CONFIG_SPL_LOAD_FIT is not set # CONFIG_SPL_LOAD_FIT_FULL is not set # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y # CONFIG_OF_STDOUT_VIA_ALIAS is not set CONFIG_SYS_EXTRA_OPTIONS="" CONFIG_HAVE_SYS_TEXT_BASE=y CONFIG_ARCH_FIXUP_FDT_MEMORY=y # CONFIG_CHROMEOS is not set # CONFIG_CHROMEOS_VBOOT is not set
# # Boot timing # CONFIG_BOOTSTAGE=y CONFIG_SPL_BOOTSTAGE=y # CONFIG_TPL_BOOTSTAGE is not set # CONFIG_BOOTSTAGE_REPORT is not set CONFIG_BOOTSTAGE_RECORD_COUNT=30 CONFIG_SPL_BOOTSTAGE_RECORD_COUNT=5 CONFIG_TPL_BOOTSTAGE_RECORD_COUNT=5 # CONFIG_BOOTSTAGE_FDT is not set CONFIG_BOOTSTAGE_STASH=y CONFIG_BOOTSTAGE_STASH_SIZE=0x1000 # CONFIG_SHOW_BOOT_PROGRESS is not set
# # Boot media # # CONFIG_NAND_BOOT is not set # CONFIG_ONENAND_BOOT is not set # CONFIG_QSPI_BOOT is not set # CONFIG_SATA_BOOT is not set # CONFIG_SD_BOOT is not set # CONFIG_SPI_BOOT is not set
# # Autoboot options # CONFIG_AUTOBOOT=y CONFIG_BOOTDELAY=2 # CONFIG_AUTOBOOT_KEYED is not set # CONFIG_AUTOBOOT_USE_MENUKEY is not set # CONFIG_USE_BOOTARGS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="" CONFIG_DEFAULT_FDT_FILE=""
# # Console # CONFIG_MENU=y # CONFIG_CONSOLE_RECORD is not set CONFIG_DISABLE_CONSOLE=y CONFIG_LOGLEVEL=4 CONFIG_SPL_LOGLEVEL=4 CONFIG_TPL_LOGLEVEL=4 CONFIG_SILENT_CONSOLE=y # CONFIG_SILENT_U_BOOT_ONLY is not set CONFIG_SILENT_CONSOLE_UPDATE_ON_SET=y # CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC is not set CONFIG_PRE_CONSOLE_BUFFER=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE is not set # CONFIG_SYS_CONSOLE_ENV_OVERWRITE is not set # CONFIG_SYS_CONSOLE_INFO_QUIET is not set # CONFIG_SYS_STDIO_DEREGISTER is not set # CONFIG_SPL_SYS_STDIO_DEREGISTER is not set # CONFIG_SYS_DEVICE_NULLDEV is not set
# # Logging # # CONFIG_LOG is not set
# # Init options # # CONFIG_BOARD_TYPES is not set CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_DISPLAY_BOARDINFO_LATE is not set
# # Start-up hooks # # CONFIG_ARCH_EARLY_INIT_R is not set CONFIG_ARCH_MISC_INIT=y CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_BOARD_EARLY_INIT_R is not set CONFIG_BOARD_LATE_INIT=y # CONFIG_LAST_STAGE_INIT is not set # CONFIG_MISC_INIT_R is not set
# # Security support # CONFIG_HASH=y
# # Update support # # CONFIG_UPDATE_TFTP is not set # CONFIG_UPDATE_FIT is not set # CONFIG_ANDROID_AB is not set
# # Blob list # # CONFIG_BLOBLIST is not set
# # SPL / TPL # CONFIG_SUPPORT_SPL=y CONFIG_SPL_FRAMEWORK=y # CONFIG_SPL_FRAMEWORK_BOARD_INIT_F is not set CONFIG_SPL_SYS_STACK_F_CHECK_BYTE=0xaa # CONFIG_SPL_SYS_REPORT_STACK_F_USAGE is not set
# # PowerPC and LayerScape SPL Boot options # CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_BOOTROM_SUPPORT is not set # CONFIG_SPL_BOOTCOUNT_LIMIT is not set CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_LEGACY_IMAGE_SUPPORT=y # CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK is not set # CONFIG_SPL_SYS_MALLOC_SIMPLE is not set # CONFIG_SPL_STACK_R is not set # CONFIG_SPL_SEPARATE_BSS is not set CONFIG_SPL_BANNER_PRINT=y # CONFIG_SPL_EARLY_BSS is not set CONFIG_SPL_DISPLAY_PRINT=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE is not set # CONFIG_SUPPORT_EMMC_BOOT_OVERRIDE_PART_CONFIG is not set CONFIG_SPL_CRC32_SUPPORT=y # CONFIG_SPL_CACHE_SUPPORT is not set # CONFIG_SPL_CPU_SUPPORT is not set # CONFIG_SPL_CRYPTO_SUPPORT is not set # CONFIG_SPL_HASH_SUPPORT is not set # CONFIG_SPL_DMA is not set CONFIG_SPL_ENV_SUPPORT=y # CONFIG_SPL_SAVEENV is not set # CONFIG_SPL_ETH_SUPPORT is not set # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_FS_SQUASHFS is not set # CONFIG_SPL_FAT_WRITE is not set # CONFIG_SPL_FPGA is not set CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DM_MAILBOX is not set CONFIG_SYS_MMCSD_FS_BOOT_PARTITION=1 # CONFIG_SPL_MMC_TINY is not set # CONFIG_SPL_MMC_WRITE is not set # CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT is not set # CONFIG_SPL_MTD_SUPPORT is not set # CONFIG_SPL_MUSB_NEW_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set # CONFIG_SPL_NAND_DRIVERS is not set # CONFIG_SPL_NAND_ECC is not set # CONFIG_SPL_NAND_SIMPLE is not set # CONFIG_SPL_UBI is not set CONFIG_SPL_DM_SPI_FLASH=y # CONFIG_SPL_NET_SUPPORT is not set # CONFIG_SPL_NO_CPU_SUPPORT is not set # CONFIG_SPL_NOR_SUPPORT is not set # CONFIG_SPL_XIP_SUPPORT is not set # CONFIG_SPL_ONENAND_SUPPORT is not set # CONFIG_SPL_OS_BOOT is not set # CONFIG_SPL_PCI is not set # CONFIG_SPL_PCH_SUPPORT is not set # CONFIG_SPL_POST_MEM_SUPPORT is not set CONFIG_SPL_DM_RESET=y CONFIG_SPL_POWER_SUPPORT=y # CONFIG_SPL_POWER_DOMAIN is not set # CONFIG_SPL_RAM_SUPPORT is not set # CONFIG_SPL_REMOTEPROC is not set # CONFIG_SPL_RTC_SUPPORT is not set # CONFIG_SPL_SATA_SUPPORT is not set CONFIG_SPL_SPI_FLASH_TINY=y # CONFIG_SPL_SPI_FLASH_MTD is not set # CONFIG_SPL_SPI_LOAD is not set # CONFIG_SPL_THERMAL is not set # CONFIG_SPL_USB_HOST_SUPPORT is not set # CONFIG_SPL_USB_GADGET is not set CONFIG_SPL_WATCHDOG_SUPPORT=y # CONFIG_SPL_YMODEM_SUPPORT is not set # CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC is not set # CONFIG_SPL_OPTEE is not set
# # Command line interface # CONFIG_CMDLINE=y CONFIG_HUSH_PARSER=y CONFIG_CMDLINE_EDITING=y CONFIG_AUTO_COMPLETE=y CONFIG_SYS_LONGHELP=y CONFIG_SYS_PROMPT="STM32MP> " CONFIG_SYS_XTRACE="y"
# # Commands #
# # Info commands # # CONFIG_CMD_ACPI is not set CONFIG_CMD_BDI=y # CONFIG_CMD_CONFIG is not set CONFIG_CMD_CONSOLE=y # CONFIG_CMD_CPU is not set # CONFIG_CMD_LICENSE is not set # CONFIG_CMD_PMC is not set
# # Boot commands # CONFIG_CMD_BOOTD=y CONFIG_CMD_BOOTM=y CONFIG_BOOTM_EFI=y CONFIG_CMD_BOOTZ=y CONFIG_BOOTM_LINUX=y CONFIG_BOOTM_NETBSD=y # CONFIG_BOOTM_OPENRTOS is not set # CONFIG_BOOTM_OSE is not set CONFIG_BOOTM_PLAN9=y CONFIG_BOOTM_RTEMS=y CONFIG_BOOTM_VXWORKS=y CONFIG_CMD_BOOTEFI=y CONFIG_CMD_BOOTEFI_HELLO_COMPILE=y # CONFIG_CMD_BOOTEFI_HELLO is not set # CONFIG_CMD_BOOTEFI_SELFTEST is not set # CONFIG_CMD_BOOTMENU is not set CONFIG_CMD_ADTIMG=y # CONFIG_CMD_ABOOTIMG is not set CONFIG_CMD_ELF=y CONFIG_CMD_FDT=y CONFIG_CMD_GO=y CONFIG_CMD_RUN=y CONFIG_CMD_IMI=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_XIMG=y # CONFIG_CMD_SPL is not set # CONFIG_CMD_THOR_DOWNLOAD is not set # CONFIG_CMD_ZBOOT is not set
# # Environment commands # # CONFIG_CMD_ASKENV is not set CONFIG_CMD_EXPORTENV=y CONFIG_CMD_IMPORTENV=y CONFIG_CMD_EDITENV=y # CONFIG_CMD_GREPENV is not set CONFIG_CMD_SAVEENV=y CONFIG_CMD_ERASEENV=y CONFIG_CMD_ENV_EXISTS=y # CONFIG_CMD_ENV_CALLBACK is not set # CONFIG_CMD_ENV_FLAGS is not set # CONFIG_CMD_NVEDIT_EFI is not set CONFIG_CMD_NVEDIT_INFO=y # CONFIG_CMD_NVEDIT_LOAD is not set # CONFIG_CMD_NVEDIT_SELECT is not set
# # Memory commands # # CONFIG_CMD_BINOP is not set # CONFIG_CMD_BLOBLIST is not set CONFIG_CMD_CRC32=y # CONFIG_CRC32_VERIFY is not set # CONFIG_CMD_EEPROM is not set # CONFIG_LOOPW is not set # CONFIG_CMD_MD5SUM is not set CONFIG_CMD_MEMINFO=y CONFIG_CMD_MEMORY=y # CONFIG_CMD_MEM_SEARCH is not set # CONFIG_CMD_MX_CYCLIC is not set CONFIG_CMD_RANDOM=y CONFIG_CMD_MEMTEST=y # CONFIG_SYS_ALT_MEMTEST is not set # CONFIG_CMD_SHA1SUM is not set # CONFIG_CMD_STRINGS is not set
# # Compression commands # # CONFIG_CMD_LZMADEC is not set # CONFIG_CMD_UNLZ4 is not set # CONFIG_CMD_UNZIP is not set # CONFIG_CMD_ZIP is not set
# # Device access commands # # CONFIG_CMD_ARMFLASH is not set CONFIG_CMD_ADC=y # CONFIG_CMD_BCB is not set # CONFIG_CMD_BIND is not set CONFIG_CMD_CLK=y # CONFIG_CMD_DEMO is not set # CONFIG_CMD_DFU is not set CONFIG_CMD_DM=y CONFIG_CMD_FASTBOOT=y # CONFIG_CMD_FPGAD is not set CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_RANDOM_UUID=y # CONFIG_CMD_GPT_RENAME is not set # CONFIG_CMD_IDE is not set # CONFIG_CMD_IO is not set # CONFIG_CMD_IOTRACE is not set CONFIG_CMD_I2C=y CONFIG_CMD_LOADB=y CONFIG_CMD_LOADS=y # CONFIG_CMD_LSBLK is not set # CONFIG_CMD_MISC is not set CONFIG_CMD_MMC=y # CONFIG_CMD_BKOPS_ENABLE is not set # CONFIG_CMD_MMC_SWRITE is not set # CONFIG_CMD_CLONE is not set # CONFIG_CMD_OSD is not set CONFIG_CMD_PART=y # CONFIG_CMD_PCI is not set CONFIG_CMD_PINMUX=y CONFIG_CMD_POWEROFF=y # CONFIG_CMD_READ is not set CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SATA is not set # CONFIG_CMD_SAVES is not set # CONFIG_CMD_SCSI is not set # CONFIG_CMD_SDRAM is not set CONFIG_CMD_SF=y # CONFIG_CMD_SF_TEST is not set CONFIG_CMD_SPI=y CONFIG_DEFAULT_SPI_BUS=0 CONFIG_DEFAULT_SPI_MODE=0 # CONFIG_CMD_TSI148 is not set # CONFIG_CMD_UNIVERSE is not set CONFIG_CMD_USB=y # CONFIG_CMD_USB_SDP is not set CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_WDT is not set
# # Shell scripting commands # CONFIG_CMD_ECHO=y CONFIG_CMD_ITEST=y CONFIG_CMD_SOURCE=y CONFIG_CMD_SETEXPR=y
# # Android support commands # CONFIG_CMD_NET=y CONFIG_CMD_BOOTP=y CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTPATH=y CONFIG_BOOTP_DNS=y # CONFIG_BOOTP_DNS2 is not set CONFIG_BOOTP_GATEWAY=y CONFIG_BOOTP_HOSTNAME=y # CONFIG_BOOTP_PREFER_SERVERIP is not set CONFIG_BOOTP_SUBNETMASK=y # CONFIG_BOOTP_NTPSERVER is not set # CONFIG_CMD_PCAP is not set CONFIG_BOOTP_PXE=y CONFIG_BOOTP_PXE_CLIENTARCH=0x15 CONFIG_BOOTP_VCI_STRING="U-Boot.armv7" CONFIG_CMD_TFTPBOOT=y # CONFIG_CMD_TFTPPUT is not set # CONFIG_CMD_TFTPSRV is not set CONFIG_NET_TFTP_VARS=y # CONFIG_CMD_RARP is not set CONFIG_CMD_NFS=y CONFIG_CMD_MII=y CONFIG_CMD_MDIO=y CONFIG_CMD_PING=y # CONFIG_CMD_CDP is not set # CONFIG_CMD_SNTP is not set # CONFIG_CMD_DNS is not set # CONFIG_CMD_LINK_LOCAL is not set # CONFIG_CMD_ETHSW is not set CONFIG_CMD_PXE=y # CONFIG_CMD_WOL is not set
# # Misc commands # CONFIG_CMD_BMP=y CONFIG_CMD_BOOTCOUNT=y # CONFIG_CMD_BSP is not set CONFIG_CMD_BLOCK_CACHE=y CONFIG_CMD_CACHE=y # CONFIG_CMD_CONITRACE is not set CONFIG_CMD_CLS=y # CONFIG_CMD_EFIDEBUG is not set # CONFIG_CMD_EXCEPTION is not set CONFIG_CMD_LED=y CONFIG_CMD_DATE=y # CONFIG_CMD_RTC is not set CONFIG_CMD_TIME=y # CONFIG_CMD_GETTIME is not set # CONFIG_CMD_RNG is not set CONFIG_CMD_SLEEP=y # CONFIG_MP is not set CONFIG_CMD_TIMER=y CONFIG_CMD_SYSBOOT=y # CONFIG_CMD_QFW is not set # CONFIG_CMD_PSTORE is not set # CONFIG_CMD_TERMINAL is not set # CONFIG_CMD_UUID is not set
# # TI specific command line interface # # CONFIG_CMD_DDR3 is not set CONFIG_CMD_BOOTSTAGE=y
# # Power commands # CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y
# # Security commands # # CONFIG_CMD_AES is not set # CONFIG_CMD_BLOB is not set # CONFIG_CMD_HASH is not set
# # Firmware commands #
# # Filesystem commands # # CONFIG_CMD_BTRFS is not set CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y # CONFIG_CMD_SQUASHFS is not set CONFIG_CMD_FS_GENERIC=y # CONFIG_CMD_FS_UUID is not set # CONFIG_CMD_JFFS2 is not set CONFIG_MTDIDS_DEFAULT="" CONFIG_MTDPARTS_DEFAULT="" # CONFIG_CMD_REISER is not set # CONFIG_CMD_ZFS is not set
# # Debug commands # # CONFIG_CMD_BEDBUG is not set # CONFIG_CMD_DIAG is not set # CONFIG_CMD_LOG is not set # CONFIG_CMD_TRACE is not set # CONFIG_CMD_UBI is not set
# # Partition Types # CONFIG_PARTITIONS=y # CONFIG_MAC_PARTITION is not set # CONFIG_SPL_MAC_PARTITION is not set CONFIG_DOS_PARTITION=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_AMIGA_PARTITION is not set # CONFIG_SPL_AMIGA_PARTITION is not set CONFIG_EFI_PARTITION=y CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=128 CONFIG_EFI_PARTITION_ENTRIES_OFF=0 CONFIG_SPL_EFI_PARTITION=y CONFIG_PARTITION_UUIDS=y CONFIG_SPL_PARTITION_UUIDS=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_SUPPORT_OF_CONTROL=y CONFIG_DTC=y
# # Device Tree Control # CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y # CONFIG_OF_LIVE is not set CONFIG_OF_SEPARATE=y # CONFIG_OF_EMBED is not set # CONFIG_OF_BOARD is not set # CONFIG_OF_PRIOR_STAGE is not set # CONFIG_MULTI_DTB_FIT is not set CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-names interrupts-extended interrupt-controller \#interrupt-cells interrupt-parent dmas dma-names assigned-clocks assigned-clock-rates assigned-clock-parents hwlocks" # CONFIG_OF_DTB_PROPS_REMOVE is not set # CONFIG_SPL_OF_PLATDATA is not set
# # Environment # CONFIG_ENV_SUPPORT=y CONFIG_SAVEENV=y # CONFIG_ENV_OVERWRITE is not set CONFIG_ENV_IS_NOWHERE=y # CONFIG_ENV_IS_IN_EEPROM is not set # CONFIG_ENV_IS_IN_FAT is not set # CONFIG_ENV_IS_IN_EXT4 is not set # CONFIG_ENV_IS_IN_FLASH is not set CONFIG_ENV_IS_IN_MMC=y # CONFIG_ENV_IS_IN_NAND is not set # CONFIG_ENV_IS_IN_NVRAM is not set # CONFIG_ENV_IS_IN_ONENAND is not set # CONFIG_ENV_IS_IN_REMOTE is not set CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_USE_ENV_SPI_BUS is not set # CONFIG_USE_ENV_SPI_CS is not set # CONFIG_USE_ENV_SPI_MAX_HZ is not set # CONFIG_USE_ENV_SPI_MODE is not set # CONFIG_ENV_SPI_EARLY is not set CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_ADDR=0x0 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=0 CONFIG_SYS_MMC_ENV_PART=0 # CONFIG_USE_DEFAULT_ENV_FILE is not set CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y # CONFIG_ENV_APPEND is not set # CONFIG_ENV_WRITEABLE_LIST is not set # CONFIG_ENV_ACCESS_IGNORE_FORCE is not set # CONFIG_SPL_ENV_IS_NOWHERE is not set CONFIG_SPL_ENV_IS_IN_MMC=y # CONFIG_SPL_ENV_IS_IN_SPI_FLASH is not set # CONFIG_VERSION_VARIABLE is not set CONFIG_NET=y # CONFIG_PROT_UDP is not set # CONFIG_BOOTP_SEND_HOSTNAME is not set # CONFIG_NET_RANDOM_ETHADDR is not set # CONFIG_NETCONSOLE is not set # CONFIG_IP_DEFRAG is not set CONFIG_TFTP_BLOCKSIZE=1468 CONFIG_TFTP_WINDOWSIZE=1
# # Device Drivers #
# # Generic Driver Options # CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DM_WARN=y # CONFIG_SPL_DM_WARN is not set # CONFIG_DM_DEBUG is not set CONFIG_DM_DEVICE_REMOVE=y # CONFIG_SPL_DM_DEVICE_REMOVE is not set CONFIG_DM_STDIO=y CONFIG_DM_SEQ_ALIAS=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y # CONFIG_DEVRES is not set CONFIG_SIMPLE_BUS=y CONFIG_SPL_SIMPLE_BUS=y CONFIG_OF_TRANSLATE=y CONFIG_SPL_OF_TRANSLATE=y # CONFIG_TRANSLATION_OFFSET is not set CONFIG_DM_DEV_READ_INLINE=y # CONFIG_ACPIGEN is not set # CONFIG_BOUNCE_BUFFER is not set CONFIG_ADC=y # CONFIG_ADC_EXYNOS is not set # CONFIG_ADC_SANDBOX is not set # CONFIG_SARADC_MESON is not set # CONFIG_SARADC_ROCKCHIP is not set CONFIG_STM32_ADC=y # CONFIG_SATA is not set # CONFIG_SCSI_AHCI is not set
# # SATA/SCSI device support # # CONFIG_DWC_AHSATA is not set # CONFIG_FSL_SATA is not set # CONFIG_MVSATA_IDE is not set # CONFIG_SATA_MV is not set # CONFIG_SATA_SIL is not set # CONFIG_SATA_SIL3114 is not set # CONFIG_AXI is not set
# # Bus devices # CONFIG_BLK=y CONFIG_HAVE_BLOCK_DEVICE=y CONFIG_SPL_BLK=y CONFIG_BLOCK_CACHE=y # CONFIG_SPL_BLOCK_CACHE is not set # CONFIG_IDE is not set CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_GENERIC=y # CONFIG_BOOTCOUNT_EXT is not set # CONFIG_BOOTCOUNT_ENV is not set # CONFIG_BOOTCOUNT_RAM is not set # CONFIG_BOOTCOUNT_I2C is not set # CONFIG_DM_BOOTCOUNT is not set CONFIG_SYS_BOOTCOUNT_MAGIC=0xB001C041
# # Button Support # # CONFIG_BUTTON is not set
# # Cache Controller drivers # # CONFIG_CACHE is not set # CONFIG_L2X0_CACHE is not set # CONFIG_NCORE_CACHE is not set
# # Clock # CONFIG_CLK=y CONFIG_SPL_CLK=y # CONFIG_SPL_CLK_CCF is not set # CONFIG_CLK_CCF is not set CONFIG_CLK_STM32MP1=y # CONFIG_CLK_CDCE9XX is not set # CONFIG_CLK_AT91 is not set # CONFIG_CLK_SIFIVE is not set # CONFIG_ICS8N3QV01 is not set # CONFIG_CLK_MPC83XX is not set # CONFIG_CPU is not set
# # Hardware crypto devices # # CONFIG_FSL_CAAM is not set # CONFIG_SYS_FSL_SEC_BE is not set # CONFIG_SYS_FSL_SEC_LE is not set
# # Demo for driver model # # CONFIG_DM_DEMO is not set
# # DFU support # CONFIG_DFU=y CONFIG_DFU_OVER_USB=y # CONFIG_DFU_TFTP is not set # CONFIG_DFU_TIMEOUT is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y # CONFIG_DFU_SF is not set CONFIG_DFU_VIRT=y CONFIG_SET_DFU_ALT_INFO=y
# # DMA Support # # CONFIG_DMA is not set # CONFIG_TI_EDMA3 is not set
# # Fastboot support # CONFIG_FASTBOOT=y CONFIG_USB_FUNCTION_FASTBOOT=y # CONFIG_UDP_FUNCTION_FASTBOOT is not set CONFIG_FASTBOOT_BUF_ADDR=0xC0000000 CONFIG_FASTBOOT_BUF_SIZE=0x02000000 CONFIG_FASTBOOT_USB_DEV=1 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_FASTBOOT_GPT_NAME="gpt" CONFIG_FASTBOOT_MBR_NAME="mbr" # CONFIG_FASTBOOT_CMD_OEM_FORMAT is not set # CONFIG_FIRMWARE is not set # CONFIG_ZYNQMP_FIRMWARE is not set # CONFIG_SCMI_FIRMWARE is not set
# # FPGA support # # CONFIG_FPGA_ALTERA is not set # CONFIG_FPGA_SOCFPGA is not set # CONFIG_FPGA_XILINX is not set
# # GPIO Support # CONFIG_SPL_DM_GPIO=y CONFIG_GPIO_HOG=y # CONFIG_DM_GPIO_LOOKUP_LABEL is not set # CONFIG_SPL_DM_GPIO_LOOKUP_LABEL is not set # CONFIG_ALTERA_PIO is not set # CONFIG_DWAPB_GPIO is not set # CONFIG_AT91_GPIO is not set # CONFIG_ATMEL_PIO4 is not set # CONFIG_DA8XX_GPIO is not set # CONFIG_INTEL_BROADWELL_GPIO is not set # CONFIG_INTEL_GPIO is not set # CONFIG_INTEL_ICH6_GPIO is not set # CONFIG_IMX_RGPIO2P is not set # CONFIG_IPROC_GPIO is not set # CONFIG_HSDK_CREG_GPIO is not set # CONFIG_LPC32XX_GPIO is not set # CONFIG_MSM_GPIO is not set # CONFIG_MXC_GPIO is not set # CONFIG_MXS_GPIO is not set # CONFIG_CMD_PCA953X is not set # CONFIG_PCF8575_GPIO is not set # CONFIG_ROCKCHIP_GPIO is not set # CONFIG_XILINX_GPIO is not set # CONFIG_CMD_TCA642X is not set # CONFIG_TEGRA_GPIO is not set # CONFIG_TEGRA186_GPIO is not set # CONFIG_VYBRID_GPIO is not set CONFIG_STM32_GPIO=y # CONFIG_SIFIVE_GPIO is not set # CONFIG_ZYNQ_GPIO is not set # CONFIG_DM_74X164 is not set # CONFIG_DM_PCA953X is not set # CONFIG_SPL_DM_PCA953X is not set # CONFIG_MPC8XXX_GPIO is not set # CONFIG_NX_GPIO is not set
# # Hardware Spinlock Support # CONFIG_DM_HWSPINLOCK=y CONFIG_HWSPINLOCK_STM32=y
# # I2C support # CONFIG_DM_I2C=y # CONFIG_I2C_SET_DEFAULT_BUS_NUM is not set # CONFIG_DM_I2C_GPIO is not set # CONFIG_SYS_I2C_IPROC is not set # CONFIG_SYS_I2C_FSL is not set # CONFIG_SYS_I2C_CADENCE is not set # CONFIG_SYS_I2C_DW is not set # CONFIG_SYS_I2C_INTEL is not set # CONFIG_SYS_I2C_IMX_LPI2C is not set # CONFIG_SYS_I2C_MXC is not set # CONFIG_SYS_I2C_NEXELL is not set # CONFIG_SYS_I2C_ROCKCHIP is not set CONFIG_SYS_I2C_STM32F7=y # CONFIG_SYS_I2C_MVTWSI is not set # CONFIG_SYS_I2C_XILINX_XIIC is not set # CONFIG_SYS_I2C_IHS is not set # CONFIG_I2C_MUX is not set CONFIG_INPUT=y # CONFIG_SPL_INPUT is not set # CONFIG_DM_KEYBOARD is not set # CONFIG_SPL_DM_KEYBOARD is not set # CONFIG_CROS_EC_KEYB is not set # CONFIG_TEGRA_KEYBOARD is not set # CONFIG_TWL4030_INPUT is not set
# # LED Support # CONFIG_LED=y # CONFIG_LED_BLINK is not set # CONFIG_SPL_LED is not set CONFIG_LED_GPIO=y # CONFIG_LED_STATUS is not set
# # Mailbox Controller Support # CONFIG_DM_MAILBOX=y CONFIG_STM32_IPCC=y
# # Memory Controller drivers # CONFIG_STM32_FMC2_EBI=y
# # Multifunction device drivers # CONFIG_MISC=y # CONFIG_SPL_MISC is not set # CONFIG_ALTERA_SYSID is not set # CONFIG_ATSHA204A is not set # CONFIG_ROCKCHIP_EFUSE is not set # CONFIG_ROCKCHIP_OTP is not set # CONFIG_SIFIVE_OTP is not set # CONFIG_VEXPRESS_CONFIG is not set # CONFIG_CROS_EC is not set # CONFIG_SPL_CROS_EC is not set # CONFIG_DS4510 is not set # CONFIG_FSL_SEC_MON is not set # CONFIG_NUVOTON_NCT6102D is not set # CONFIG_PWRSEQ is not set # CONFIG_PCA9551_LED is not set CONFIG_STM32MP_FUSE=y CONFIG_STM32_RCC=y # CONFIG_TWL4030_LED is not set # CONFIG_WINBOND_W83627 is not set # CONFIG_I2C_EEPROM is not set # CONFIG_SPL_I2C_EEPROM is not set # CONFIG_GDSYS_RXAUI_CTRL is not set # CONFIG_GDSYS_IOEP is not set # CONFIG_MPC83XX_SERDES is not set # CONFIG_FS_LOADER is not set # CONFIG_GDSYS_SOC is not set # CONFIG_IHS_FPGA is not set # CONFIG_MICROCHIP_FLEXCOM is not set # CONFIG_ESM_PMIC is not set
# # MMC Host controller Support # CONFIG_MMC=y CONFIG_MMC_WRITE=y # CONFIG_MMC_BROKEN_CD is not set CONFIG_DM_MMC=y CONFIG_SPL_DM_MMC=y # CONFIG_MMC_SPI is not set # CONFIG_ARM_PL180_MMCI is not set CONFIG_MMC_QUIRKS=y CONFIG_MMC_HW_PARTITIONING=y # CONFIG_SUPPORT_EMMC_RPMB is not set CONFIG_SUPPORT_EMMC_BOOT=y # CONFIG_MMC_IO_VOLTAGE is not set # CONFIG_SPL_MMC_IO_VOLTAGE is not set # CONFIG_MMC_HS400_ES_SUPPORT is not set # CONFIG_SPL_MMC_HS400_ES_SUPPORT is not set # CONFIG_MMC_HS400_SUPPORT is not set # CONFIG_SPL_MMC_HS400_SUPPORT is not set # CONFIG_MMC_HS200_SUPPORT is not set # CONFIG_SPL_MMC_HS200_SUPPORT is not set CONFIG_MMC_VERBOSE=y # CONFIG_MMC_TRACE is not set # CONFIG_MMC_DW is not set # CONFIG_MMC_MXC is not set # CONFIG_MMC_PCI is not set # CONFIG_PXA_MMC_GENERIC is not set # CONFIG_MMC_OMAP_HS is not set # CONFIG_MMC_SDHCI is not set CONFIG_STM32_SDMMC2=y # CONFIG_FTSDC010 is not set # CONFIG_FSL_ESDHC is not set # CONFIG_FSL_ESDHC_IMX is not set
# # MTD Support # CONFIG_MTD_PARTITIONS=y # CONFIG_MTD is not set # CONFIG_DM_MTD is not set # CONFIG_MTD_NOR_FLASH is not set # CONFIG_FLASH_CFI_DRIVER is not set # CONFIG_HBMC_AM654 is not set # CONFIG_MTD_RAW_NAND is not set
# # SPI Flash Support # CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=0 CONFIG_SF_DEFAULT_CS=0 CONFIG_SF_DEFAULT_MODE=3 CONFIG_SF_DEFAULT_SPEED=1000000 # CONFIG_SPI_FLASH_SFDP_SUPPORT is not set # CONFIG_SPI_FLASH_BAR is not set # CONFIG_SF_DUAL_FLASH is not set # CONFIG_SPI_FLASH_ATMEL is not set # CONFIG_SPI_FLASH_EON is not set # CONFIG_SPI_FLASH_GIGADEVICE is not set # CONFIG_SPI_FLASH_ISSI is not set CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_SST is not set CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_XMC is not set # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set # CONFIG_SPI_FLASH_DATAFLASH is not set
# # UBI support # CONFIG_UBI_SILENCE_MSG=y CONFIG_MTD_UBI=y CONFIG_MTD_UBI_WL_THRESHOLD=4096 CONFIG_MTD_UBI_BEB_LIMIT=20 # CONFIG_MTD_UBI_FASTMAP is not set
# # Multiplexer drivers # # CONFIG_MULTIPLEXER is not set # CONFIG_BITBANGMII is not set # CONFIG_MV88E6352_SWITCH is not set CONFIG_PHYLIB=y # CONFIG_PHY_ADDR_ENABLE is not set # CONFIG_B53_SWITCH is not set # CONFIG_MV88E61XX_SWITCH is not set # CONFIG_PHYLIB_10G is not set # CONFIG_PHY_AQUANTIA is not set # CONFIG_PHY_ATHEROS is not set # CONFIG_PHY_BROADCOM is not set # CONFIG_PHY_CORTINA is not set # CONFIG_PHY_DAVICOM is not set # CONFIG_PHY_ET1011C is not set # CONFIG_PHY_LXT is not set # CONFIG_PHY_MARVELL is not set # CONFIG_PHY_MESON_GXL is not set # CONFIG_PHY_MICREL is not set # CONFIG_PHY_MSCC is not set # CONFIG_PHY_NATSEMI is not set CONFIG_PHY_REALTEK=y # CONFIG_RTL8211E_PINE64_GIGABIT_FIX is not set # CONFIG_RTL8211X_PHY_FORCE_MASTER is not set # CONFIG_RTL8211F_PHY_FORCE_EEE_RXC_ON is not set # CONFIG_RTL8201F_PHY_S700_RMII_TIMINGS is not set # CONFIG_PHY_SMSC is not set # CONFIG_PHY_TERANETICS is not set # CONFIG_PHY_TI is not set # CONFIG_PHY_TI_DP83867 is not set # CONFIG_PHY_TI_GENERIC is not set # CONFIG_PHY_VITESSE is not set # CONFIG_PHY_XILINX is not set # CONFIG_PHY_XILINX_GMII2RGMII is not set # CONFIG_PHY_FIXED is not set # CONFIG_PHY_NCSI is not set # CONFIG_FSL_PFE is not set CONFIG_DM_ETH=y # CONFIG_DM_MDIO is not set # CONFIG_DM_ETH_PHY is not set CONFIG_NETDEVICES=y # CONFIG_PHY_GIGE is not set # CONFIG_ALTERA_TSE is not set # CONFIG_BCM_SF2_ETH is not set # CONFIG_BCMGENET is not set CONFIG_DWC_ETH_QOS=y # CONFIG_DWC_ETH_QOS_IMX is not set CONFIG_DWC_ETH_QOS_STM32=y # CONFIG_DWC_ETH_QOS_TEGRA186 is not set # CONFIG_EEPRO100 is not set # CONFIG_ETH_DESIGNWARE is not set # CONFIG_ETHOC is not set # CONFIG_FMAN_ENET is not set # CONFIG_FTMAC100 is not set # CONFIG_FTGMAC100 is not set # CONFIG_MCFFEC is not set # CONFIG_FSLDMAFEC is not set # CONFIG_KS8851_MLL is not set # CONFIG_MACB is not set # CONFIG_RGMII is not set # CONFIG_MII is not set # CONFIG_PCNET is not set # CONFIG_QE_UEC is not set # CONFIG_RTL8139 is not set # CONFIG_RTL8169 is not set # CONFIG_SMC911X is not set # CONFIG_SUN7I_GMAC is not set # CONFIG_SUN4I_EMAC is not set # CONFIG_SUN8I_EMAC is not set # CONFIG_SH_ETHER is not set # CONFIG_DRIVER_TI_CPSW is not set # CONFIG_DRIVER_TI_EMAC is not set # CONFIG_DRIVER_TI_KEYSTONE_NET is not set # CONFIG_XILINX_AXIEMAC is not set # CONFIG_XILINX_EMACLITE is not set # CONFIG_ZYNQ_GEM is not set # CONFIG_SYS_DPAA_QBMAN is not set # CONFIG_TSEC_ENET is not set # CONFIG_MEDIATEK_ETH is not set # CONFIG_HIGMACV300_ETH is not set # CONFIG_PCI is not set
# # PCI Endpoint # # CONFIG_PCI_ENDPOINT is not set # CONFIG_X86_PCH7 is not set # CONFIG_X86_PCH9 is not set
# # PHY Subsystem # CONFIG_PHY=y # CONFIG_SPL_PHY is not set # CONFIG_NOP_PHY is not set # CONFIG_BCM_SR_PCIE_PHY is not set CONFIG_PHY_STM32_USBPHYC=y # CONFIG_MSM8916_USB_PHY is not set # CONFIG_OMAP_USB2_PHY is not set
# # Rockchip PHY driver # # CONFIG_MVEBU_COMPHY_SUPPORT is not set
# # Pin controllers # CONFIG_PINCTRL=y CONFIG_PINCTRL_FULL=y CONFIG_PINCTRL_GENERIC=y CONFIG_PINMUX=y CONFIG_PINCONF=y # CONFIG_PINCONF_RECURSIVE is not set CONFIG_SPL_PINCTRL=y # CONFIG_SPL_PINCTRL_FULL is not set # CONFIG_PINCTRL_AT91 is not set # CONFIG_PINCTRL_AT91PIO4 is not set # CONFIG_PINCTRL_INTEL is not set # CONFIG_PINCTRL_QE is not set # CONFIG_PINCTRL_ROCKCHIP_RV1108 is not set # CONFIG_PINCTRL_SINGLE is not set CONFIG_PINCTRL_STM32=y CONFIG_PINCTRL_STMFX=y # CONFIG_PINCTRL_K210 is not set
# # Power # # CONFIG_ACPI_PMC is not set # CONFIG_SPL_ACPI_PMC is not set # CONFIG_TPL_ACPI_PMC is not set
# # Power Domain Support # # CONFIG_POWER_DOMAIN is not set CONFIG_DM_PMIC=y CONFIG_PMIC_CHILDREN=y # CONFIG_SPL_PMIC_CHILDREN is not set # CONFIG_PMIC_ACT8846 is not set # CONFIG_DM_PMIC_DA9063 is not set # CONFIG_SPL_DM_PMIC_DA9063 is not set # CONFIG_PMIC_AS3722 is not set # CONFIG_DM_PMIC_BD71837 is not set # CONFIG_SPL_DM_PMIC_BD71837 is not set # CONFIG_DM_PMIC_FAN53555 is not set # CONFIG_DM_PMIC_PCA9450 is not set # CONFIG_DM_PMIC_PFUZE100 is not set # CONFIG_SPL_DM_PMIC_PFUZE100 is not set # CONFIG_DM_PMIC_MAX77686 is not set # CONFIG_DM_PMIC_MAX8998 is not set # CONFIG_DM_PMIC_MC34708 is not set # CONFIG_PMIC_MAX8997 is not set # CONFIG_PMIC_PM8916 is not set # CONFIG_PMIC_RK8XX is not set # CONFIG_PMIC_S2MPS11 is not set # CONFIG_DM_PMIC_SANDBOX is not set # CONFIG_PMIC_S5M8767 is not set # CONFIG_PMIC_RN5T567 is not set # CONFIG_PMIC_TPS65090 is not set # CONFIG_PMIC_PALMAS is not set # CONFIG_PMIC_LP873X is not set # CONFIG_PMIC_LP87565 is not set # CONFIG_POWER_MC34VR500 is not set # CONFIG_DM_PMIC_TPS65910 is not set CONFIG_PMIC_STPMIC1=y # CONFIG_SPL_PMIC_PALMAS is not set # CONFIG_SPL_PMIC_LP873X is not set # CONFIG_SPL_PMIC_LP87565 is not set # CONFIG_PMIC_TPS65941 is not set CONFIG_DM_REGULATOR=y # CONFIG_SPL_DM_REGULATOR is not set # CONFIG_REGULATOR_PWM is not set CONFIG_DM_REGULATOR_COMMON=y CONFIG_DM_REGULATOR_FIXED=y # CONFIG_SPL_DM_REGULATOR_FIXED is not set CONFIG_DM_REGULATOR_GPIO=y # CONFIG_SPL_DM_REGULATOR_GPIO is not set # CONFIG_DM_REGULATOR_PBIAS is not set CONFIG_DM_REGULATOR_STM32_VREFBUF=y # CONFIG_DM_REGULATOR_TPS62360 is not set CONFIG_DM_REGULATOR_STPMIC1=y # CONFIG_POWER_MT6323 is not set # CONFIG_DM_PWM is not set # CONFIG_PWM_IMX is not set # CONFIG_PWM_SANDBOX is not set # CONFIG_U_QE is not set CONFIG_RAM=y CONFIG_SPL_RAM=y # CONFIG_TPL_RAM is not set # CONFIG_STM32_SDRAM is not set # CONFIG_MPC83XX_SDRAM is not set # CONFIG_K3_J721E_DDRSS is not set # CONFIG_IMXRT_SDRAM is not set # CONFIG_ROCKCHIP_SDRAM_COMMON is not set CONFIG_STM32MP1_DDR=y # CONFIG_STM32MP1_DDR_INTERACTIVE is not set
# # Remote Processor drivers # CONFIG_REMOTEPROC=y CONFIG_REMOTEPROC_STM32_COPRO=y
# # Reset Controller Support # CONFIG_DM_RESET=y CONFIG_STM32_RESET=y # CONFIG_RESET_AST2500 is not set # CONFIG_RESET_HISILICON is not set # CONFIG_RESET_SYSCON is not set # CONFIG_RESET_SCMI is not set CONFIG_DM_RNG=y # CONFIG_RNG_MSM is not set CONFIG_RNG_STM32MP1=y
# # Real Time Clock # CONFIG_DM_RTC=y # CONFIG_SPL_DM_RTC is not set # CONFIG_RTC_ENABLE_32KHZ_OUTPUT is not set # CONFIG_RTC_PCF2127 is not set # CONFIG_RTC_DS1307 is not set # CONFIG_RTC_DS3232 is not set # CONFIG_RTC_EMULATION is not set # CONFIG_RTC_ISL1208 is not set # CONFIG_RTC_PCF8563 is not set # CONFIG_RTC_RV3029 is not set # CONFIG_RTC_RV8803 is not set # CONFIG_RTC_RX8010SJ is not set # CONFIG_RTC_RX8025 is not set # CONFIG_RTC_PL031 is not set # CONFIG_RTC_MV is not set # CONFIG_RTC_S35392A is not set # CONFIG_RTC_MC146818 is not set # CONFIG_RTC_M41T62 is not set CONFIG_RTC_STM32=y # CONFIG_SCSI is not set # CONFIG_DM_SCSI is not set
# # Serial drivers # CONFIG_BAUDRATE=115200 CONFIG_REQUIRE_SERIAL_CONSOLE=y # CONFIG_SPECIFY_CONSOLE_INDEX is not set CONFIG_SERIAL_PRESENT=y CONFIG_SPL_SERIAL_PRESENT=y CONFIG_DM_SERIAL=y CONFIG_SERIAL_RX_BUFFER=y CONFIG_SERIAL_RX_BUFFER_SIZE=256 # CONFIG_SERIAL_SEARCH_ALL is not set CONFIG_SPL_DM_SERIAL=y # CONFIG_ALTERA_JTAG_UART is not set # CONFIG_ALTERA_UART is not set # CONFIG_ARC_SERIAL is not set # CONFIG_ARM_DCC is not set # CONFIG_ATMEL_USART is not set # CONFIG_BCM6345_SERIAL is not set # CONFIG_COREBOOT_SERIAL is not set # CONFIG_CORTINA_UART is not set # CONFIG_FSL_LINFLEXUART is not set # CONFIG_FSL_LPUART is not set # CONFIG_MVEBU_A3700_UART is not set # CONFIG_MCFUART is not set # CONFIG_NULLDEV_SERIAL is not set # CONFIG_SYS_NS16550 is not set # CONFIG_NS16550_DYNAMIC is not set # CONFIG_PL01X_SERIAL is not set # CONFIG_XILINX_UARTLITE is not set # CONFIG_MSM_SERIAL is not set # CONFIG_OMAP_SERIAL is not set # CONFIG_PXA_SERIAL is not set # CONFIG_SIFIVE_SERIAL is not set CONFIG_STM32_SERIAL=y # CONFIG_ZYNQ_SERIAL is not set # CONFIG_MTK_SERIAL is not set # CONFIG_SMEM is not set
# # Sound support # # CONFIG_SOUND is not set
# # SOC (System On Chip) specific Drivers # # CONFIG_SOC_DEVICE is not set # CONFIG_SOC_TI is not set CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_SPI_MEM=y # CONFIG_ALTERA_SPI is not set # CONFIG_ATCSPI200_SPI is not set # CONFIG_ATMEL_SPI is not set # CONFIG_BCMSTB_SPI is not set # CONFIG_CADENCE_QSPI is not set # CONFIG_CF_SPI is not set # CONFIG_DESIGNWARE_SPI is not set # CONFIG_EXYNOS_SPI is not set # CONFIG_FSL_DSPI is not set # CONFIG_FSL_QSPI is not set # CONFIG_ICH_SPI is not set # CONFIG_KIRKWOOD_SPI is not set # CONFIG_MPC8XXX_SPI is not set # CONFIG_MTK_SNFI_SPI is not set # CONFIG_MVEBU_A3700_SPI is not set # CONFIG_MXS_SPI is not set # CONFIG_NXP_FSPI is not set # CONFIG_OMAP3_SPI is not set # CONFIG_PL022_SPI is not set # CONFIG_ROCKCHIP_SPI is not set # CONFIG_SPI_SIFIVE is not set # CONFIG_SOFT_SPI is not set # CONFIG_SPI_SUNXI is not set CONFIG_STM32_QSPI=y CONFIG_STM32_SPI=y # CONFIG_TEGRA114_SPI is not set # CONFIG_TEGRA20_SFLASH is not set # CONFIG_TEGRA20_SLINK is not set # CONFIG_TEGRA210_QSPI is not set # CONFIG_TI_QSPI is not set # CONFIG_XILINX_SPI is not set # CONFIG_ZYNQ_SPI is not set # CONFIG_ZYNQ_QSPI is not set # CONFIG_ZYNQMP_GQSPI is not set # CONFIG_FSL_ESPI is not set # CONFIG_SH_QSPI is not set # CONFIG_MXC_SPI is not set
# # SPMI support # # CONFIG_SPMI is not set # CONFIG_SYSINFO is not set
# # System reset device drivers # CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_CMD_POWEROFF=y # CONFIG_POWEROFF_GPIO is not set # CONFIG_SYSRESET_GPIO is not set CONFIG_SYSRESET_SYSCON=y # CONFIG_SYSRESET_WATCHDOG is not set # CONFIG_SYSRESET_RESETCTL is not set # CONFIG_SYSRESET_MPC83XX is not set # CONFIG_TEE is not set # CONFIG_OPTEE is not set # CONFIG_DM_THERMAL is not set
# # Timer Support # # CONFIG_TIMER is not set
# # TPM support # CONFIG_USB=y CONFIG_DM_USB=y CONFIG_SPL_DM_USB=y CONFIG_DM_USB_GADGET=y # CONFIG_SPL_DM_USB_GADGET is not set
# # USB Host Controller Drivers # CONFIG_USB_HOST=y # CONFIG_USB_XHCI_HCD is not set CONFIG_USB_EHCI_HCD=y # CONFIG_USB_EHCI_MSM is not set # CONFIG_USB_EHCI_PCI is not set # CONFIG_USB_EHCI_ZYNQ is not set CONFIG_USB_EHCI_GENERIC=y # CONFIG_USB_EHCI_FSL is not set # CONFIG_USB_OHCI_HCD is not set # CONFIG_USB_OHCI_PCI is not set # CONFIG_USB_UHCI_HCD is not set # CONFIG_USB_DWC2 is not set # CONFIG_USB_R8A66597_HCD is not set # CONFIG_USB_CDNS3 is not set # CONFIG_USB_DWC3 is not set
# # Legacy MUSB Support # # CONFIG_USB_MUSB_HCD is not set # CONFIG_USB_MUSB_UDC is not set
# # MUSB Controller Driver # # CONFIG_USB_MUSB_HOST is not set # CONFIG_USB_MUSB_GADGET is not set # CONFIG_USB_MUSB_DA8XX is not set # CONFIG_USB_MUSB_TI is not set # CONFIG_USB_MUSB_AM35X is not set # CONFIG_USB_MUSB_DSPS is not set # CONFIG_USB_MUSB_PIO_ONLY is not set
# # USB Phy # # CONFIG_TWL4030_USB is not set # CONFIG_OMAP_USB_PHY is not set # CONFIG_ROCKCHIP_USB2_PHY is not set
# # ULPI drivers #
# # USB peripherals # CONFIG_USB_STORAGE=y # CONFIG_USB_KEYBOARD is not set CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="STMicroelectronics" CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 # CONFIG_USB_GADGET_ATMEL_USBA is not set # CONFIG_USB_GADGET_BCM_UDC_OTG_PHY is not set CONFIG_USB_GADGET_DWC2_OTG=y # CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8 is not set # CONFIG_CI_UDC is not set # CONFIG_USB_GADGET_MAX3420 is not set CONFIG_USB_GADGET_VBUS_DRAW=2 CONFIG_SDP_LOADADDR=0 CONFIG_USB_GADGET_DUALSPEED=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_FUNCTION_MASS_STORAGE=y # CONFIG_USB_FUNCTION_ROCKUSB is not set # CONFIG_USB_FUNCTION_SDP is not set # CONFIG_USB_FUNCTION_THOR is not set # CONFIG_USB_ETHER is not set # CONFIG_USB_HOST_ETHER is not set
# # UFS Host Controller Support # # CONFIG_TI_J721E_UFS is not set
# # Graphics support # CONFIG_DM_VIDEO=y CONFIG_BACKLIGHT=y CONFIG_VIDEO_PCI_DEFAULT_FB_SIZE=0 # CONFIG_VIDEO_COPY is not set CONFIG_BACKLIGHT_GPIO=y CONFIG_CMD_VIDCONSOLE=y CONFIG_VIDEO_BPP8=y CONFIG_VIDEO_BPP16=y CONFIG_VIDEO_BPP32=y CONFIG_VIDEO_ANSI=y CONFIG_VIDEO_MIPI_DSI=y CONFIG_CONSOLE_NORMAL=y # CONFIG_CONSOLE_ROTATION is not set # CONFIG_CONSOLE_TRUETYPE is not set # CONFIG_SYS_WHITE_ON_BLACK is not set # CONFIG_NO_FB_CLEAR is not set CONFIG_PANEL=y CONFIG_SIMPLE_PANEL=y
# # TrueType Fonts # # CONFIG_VIDCONSOLE_AS_LCD is not set # CONFIG_VIDEO_VESA is not set # CONFIG_VIDEO_LCD_ANX9804 is not set CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y CONFIG_VIDEO_LCD_RAYDIUM_RM68200=y # CONFIG_VIDEO_LCD_SSD2828 is not set # CONFIG_VIDEO_MESON is not set # CONFIG_VIDEO_MVEBU is not set # CONFIG_I2C_EDID is not set # CONFIG_DISPLAY is not set # CONFIG_ATMEL_HLCD is not set # CONFIG_AM335X_LCD is not set # CONFIG_VIDEO_FSL_DCU_FB is not set # CONFIG_VIDEO_ROCKCHIP is not set # CONFIG_VIDEO_ARM_MALIDP is not set CONFIG_VIDEO_STM32=y CONFIG_VIDEO_STM32_DSI=y CONFIG_VIDEO_STM32_MAX_XRES=1280 CONFIG_VIDEO_STM32_MAX_YRES=800 CONFIG_VIDEO_STM32_MAX_BPP=16 # CONFIG_VIDEO_TEGRA20 is not set # CONFIG_VIDEO_TEGRA124 is not set CONFIG_VIDEO_BRIDGE=y # CONFIG_VIDEO_BRIDGE_PARADE_PS862X is not set # CONFIG_VIDEO_BRIDGE_NXP_PTN3460 is not set # CONFIG_VIDEO_BRIDGE_ANALOGIX_ANX6345 is not set CONFIG_CONSOLE_SCROLL_LINES=1 # CONFIG_LCD is not set CONFIG_VIDEO_DW_MIPI_DSI=y # CONFIG_VIDEO_SIMPLE is not set # CONFIG_VIDEO_DT_SIMPLEFB is not set # CONFIG_OSD is not set # CONFIG_SPLASH_SCREEN is not set # CONFIG_SPLASH_SCREEN_ALIGN is not set # CONFIG_VIDEO_BMP_GZIP is not set CONFIG_VIDEO_BMP_RLE8=y CONFIG_BMP_16BPP=y CONFIG_BMP_24BPP=y CONFIG_BMP_32BPP=y # CONFIG_VIDEO_VCXK is not set
# # VirtIO Drivers # # CONFIG_VIRTIO_MMIO is not set
# # 1-Wire support # # CONFIG_W1 is not set
# # 1-wire EEPROM support # # CONFIG_W1_EEPROM is not set
# # Watchdog Timer Support # CONFIG_WATCHDOG=y CONFIG_WATCHDOG_TIMEOUT_MSECS=60000 # CONFIG_IMX_WATCHDOG is not set # CONFIG_ULP_WATCHDOG is not set # CONFIG_DESIGNWARE_WATCHDOG is not set CONFIG_WDT=y # CONFIG_WDT_ASPEED is not set # CONFIG_WDT_AT91 is not set # CONFIG_WDT_CDNS is not set # CONFIG_WDT_CORTINA is not set # CONFIG_WDT_ORION is not set # CONFIG_WDT_SBSA is not set # CONFIG_WDT_SP805 is not set CONFIG_WDT_STM32MP=y # CONFIG_XILINX_TB_WATCHDOG is not set CONFIG_SPL_WDT=y # CONFIG_PVBLOCK is not set # CONFIG_PHYS_TO_BUS is not set
# # File systems # # CONFIG_FS_BTRFS is not set # CONFIG_FS_CBFS is not set # CONFIG_SPL_FS_CBFS is not set CONFIG_FS_EXT4=y CONFIG_EXT4_WRITE=y CONFIG_FS_FAT=y CONFIG_FAT_WRITE=y CONFIG_FS_FAT_MAX_CLUSTSIZE=65536 # CONFIG_FS_JFFS2 is not set CONFIG_UBIFS_SILENCE_MSG=y # CONFIG_FS_CRAMFS is not set # CONFIG_YAFFS2 is not set # CONFIG_FS_SQUASHFS is not set
# # Library routines # # CONFIG_ADDR_MAP is not set # CONFIG_BCH is not set # CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED is not set # CONFIG_DYNAMIC_CRC_TABLE is not set CONFIG_HAVE_PRIVATE_LIBGCC=y CONFIG_LIB_UUID=y CONFIG_PRINTF=y CONFIG_SPL_PRINTF=y CONFIG_SPRINTF=y CONFIG_SPL_SPRINTF=y CONFIG_STRTO=y CONFIG_SPL_STRTO=y CONFIG_IMAGE_SPARSE=y CONFIG_IMAGE_SPARSE_FILLBUF_SIZE=0x80000 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_SYS_HZ=1000 CONFIG_SPL_USE_TINY_PRINTF=y # CONFIG_PANIC_HANG is not set CONFIG_REGEX=y CONFIG_LIB_RAND=y # CONFIG_LIB_HW_RAND is not set # CONFIG_SPL_TINY_MEMSET is not set # CONFIG_TPL_TINY_MEMSET is not set CONFIG_RBTREE=y # CONFIG_BITREVERSE is not set # CONFIG_TRACE is not set # CONFIG_CMD_DHRYSTONE is not set
# # Security support # # CONFIG_AES is not set # CONFIG_RSA is not set # CONFIG_ASYMMETRIC_KEY_TYPE is not set # CONFIG_TPM is not set # CONFIG_SPL_TPM is not set
# # Android Verified Boot # # CONFIG_LIBAVB is not set
# # Hashing Support # CONFIG_SHA1=y CONFIG_SHA256=y # CONFIG_SHA512_ALGO is not set # CONFIG_SHA_HW_ACCEL is not set CONFIG_MD5=y # CONFIG_SPL_MD5 is not set
# # Compression Support # # CONFIG_LZ4 is not set # CONFIG_LZMA is not set CONFIG_LZO=y CONFIG_GZIP=y # CONFIG_ZLIB_UNCOMPRESS is not set # CONFIG_BZIP2 is not set CONFIG_ZLIB=y # CONFIG_ZSTD is not set # CONFIG_SPL_LZ4 is not set # CONFIG_SPL_LZMA is not set # CONFIG_SPL_LZO is not set # CONFIG_SPL_GZIP is not set # CONFIG_SPL_ZSTD is not set CONFIG_ERRNO_STR=y # CONFIG_HEXDUMP is not set # CONFIG_GETOPT is not set CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_ASSUME_MASK=0 CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_SPL_OF_LIBFDT=y CONFIG_SPL_OF_LIBFDT_ASSUME_MASK=0xff # CONFIG_TPL_OF_LIBFDT is not set CONFIG_TPL_OF_LIBFDT_ASSUME_MASK=0xff
# # System tables # CONFIG_GENERATE_SMBIOS_TABLE=y # CONFIG_SMBIOS_PARSER is not set CONFIG_EFI_LOADER=y CONFIG_EFI_VARIABLE_FILE_STORE=y # CONFIG_EFI_VARIABLES_PRESEED is not set CONFIG_EFI_GET_TIME=y # CONFIG_EFI_SET_TIME is not set CONFIG_EFI_DEVICE_PATH_TO_TEXT=y CONFIG_EFI_LOADER_HII=y CONFIG_EFI_UNICODE_COLLATION_PROTOCOL2=y CONFIG_EFI_UNICODE_CAPITALIZATION=y # CONFIG_EFI_UNICODE_COLLATION_PROTOCOL is not set CONFIG_EFI_PLATFORM_LANG_CODES="en-US" CONFIG_EFI_GRUB_ARM32_WORKAROUND=y CONFIG_EFI_RNG_PROTOCOL=y # CONFIG_EFI_LOAD_FILE2_INITRD is not set # CONFIG_EFI_SECURE_BOOT is not set # CONFIG_TEST_FDTDEC is not set CONFIG_LIB_DATE=y CONFIG_LIB_ELF=y # CONFIG_UNIT_TEST is not set # CONFIG_SPL_UNIT_TEST is not set
# # Tools options # CONFIG_MKIMAGE_DTC_PATH="dtc"
-- Jagan Teki, Amarula Solutions India Pvt. Ltd. Co-Founder & Embedded Linux Architect 405/E-Block, Sri Lakshmi Shubham Arcade, Chandanagar, Hyderabad - 500050, India M. (+91) 910 009 0959 [`as] http://www.amarulasolutions.com
On Tue, Dec 8, 2020 at 2:42 PM Patrick DELAUNAY patrick.delaunay@foss.st.com wrote:
see the trace:
Yeah, I missed the u-boot,dm-pre-reloc in one of the pins in sdmmc1_b4_pins_a. Able to boot now.
Thanks for the response.
Jagan.
Jagan Teki
Patrick DELAUNAY
