[U-Boot] [PATCH] ARM: Samsung: Add Exynos5422-based Odroid HC2 support
Odroid HC2 board is based on Odroid XU4 board, like the Odroid HC1.
The linux kernel does not provide a hc2 DTB so the hc1 DTB is also used for the Odroid HC2.
Signed-off-by: Dirk Meul dirk.meul@rwth-aachen.de --- board/samsung/common/exynos5-dt-types.c | 16 +++++++++++++--- board/samsung/common/exynos5-dt.c | 4 ++-- configs/odroid-xu3_defconfig | 2 +- include/samsung/exynos5-dt-types.h | 2 ++ 4 files changed, 18 insertions(+), 6 deletions(-)
diff --git a/board/samsung/common/exynos5-dt-types.c b/board/samsung/common/exynos5-dt-types.c index 4473968db6..7a86e91877 100644 --- a/board/samsung/common/exynos5-dt-types.c +++ b/board/samsung/common/exynos5-dt-types.c @@ -24,14 +24,15 @@ static const struct udevice_id board_ids[] = { };
/** - * Odroix XU3/XU4/HC1 board revisions (from HC1_MAIN_REV0.1_20170630.pdf): + * Odroix XU3/XU4/HC1/HC2 board revisions (from HC1+_HC2_MAIN_REV0.1_20171017.pdf): * Rev ADCmax Board * 0.1 0 XU3 0.1 * 0.2 372 XU3 0.2 | XU3L - no DISPLAYPORT (probe I2C0:0x40 / INA231) * 0.3 1280 XU4 0.1 * 0.4 739 XU4 0.2 * 0.5 1016 XU4+Air0.1 (Passive cooling) - * 0.6 1308 XU4S 0.1 (HC1) + * 0.6 1309 XU4-HC1 0.1 + * 0.7 1470 XU4-HC1+ 0.1 (HC2) * Use +1% for ADC value tolerance in the array below, the code loops until * the measured ADC value is lower than then ADCmax from the array. */ @@ -39,7 +40,8 @@ struct odroid_rev_info odroid_info[] = { { EXYNOS5_BOARD_ODROID_XU3_REV01, 1, 10, "xu3" }, { EXYNOS5_BOARD_ODROID_XU3_REV02, 2, 375, "xu3" }, { EXYNOS5_BOARD_ODROID_XU4_REV01, 1, 1293, "xu4" }, - { EXYNOS5_BOARD_ODROID_HC1_REV01, 1, 1321, "hc1" }, + { EXYNOS5_BOARD_ODROID_HC1_REV01, 1, 1322, "hc1" }, + { EXYNOS5_BOARD_ODROID_HC2_REV01, 1, 1484, "hc1" }, { EXYNOS5_BOARD_ODROID_UNKNOWN, 0, 4095, "unknown" }, };
@@ -144,6 +146,14 @@ bool board_is_odroidhc1(void) return false; }
+bool board_is_odroidhc2(void) +{ + if (gd->board_type == EXYNOS5_BOARD_ODROID_HC2_REV01) + return true; + + return false; +} + bool board_is_generic(void) { if (gd->board_type == EXYNOS5_BOARD_GENERIC) diff --git a/board/samsung/common/exynos5-dt.c b/board/samsung/common/exynos5-dt.c index 8c3a9ea564..c183965b92 100644 --- a/board/samsung/common/exynos5-dt.c +++ b/board/samsung/common/exynos5-dt.c @@ -179,7 +179,7 @@ char *get_dfu_alt_system(char *interface, char *devstr) { char *info = "Not supported!";
- if (board_is_odroidxu4() || board_is_odroidhc1()) + if (board_is_odroidxu4() || board_is_odroidhc1() || board_is_odroidhc2()) return info;
return env_get("dfu_alt_system"); @@ -192,7 +192,7 @@ char *get_dfu_alt_boot(char *interface, char *devstr) char *alt_boot; int dev_num;
dev_num = simple_strtoul(devstr, NULL, 10); diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 258b9781cc..d5c7cc7129 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS5=y -CONFIG_IDENT_STRING=" for ODROID-XU3/XU4/HC1" +CONFIG_IDENT_STRING=" for ODROID-XU3/XU4/HC1/HC2" CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=8 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/include/samsung/exynos5-dt-types.h b/include/samsung/exynos5-dt-types.h index 8e11af30d1..8fe08fe211 100644 --- a/include/samsung/exynos5-dt-types.h +++ b/include/samsung/exynos5-dt-types.h @@ -9,6 +9,7 @@ enum { EXYNOS5_BOARD_ODROID_XU3_REV02, EXYNOS5_BOARD_ODROID_XU4_REV01, EXYNOS5_BOARD_ODROID_HC1_REV01, + EXYNOS5_BOARD_ODROID_HC2_REV01, EXYNOS5_BOARD_ODROID_UNKNOWN,
EXYNOS5_BOARD_COUNT, @@ -25,5 +26,6 @@ bool board_is_generic(void); bool board_is_odroidxu3(void); bool board_is_odroidxu4(void); bool board_is_odroidhc1(void); +bool board_is_odroidhc2(void);
#endif -- 2.17.1
Hi All,
I don't have access to HC2, but the code looks reasonable and does similar things I did while adding support for Odroid HC1.
Acked-by: Marek Szyprowski m.szyprowski@samsung.com
diff --git a/board/samsung/common/exynos5-dt-types.c b/board/samsung/common/exynos5-dt-types.c index 4473968db6..7a86e91877 100644 --- a/board/samsung/common/exynos5-dt-types.c +++ b/board/samsung/common/exynos5-dt-types.c @@ -24,14 +24,15 @@ static const struct udevice_id board_ids[] = { }; /**
- Odroix XU3/XU4/HC1 board revisions (from
- Odroix XU3/XU4/HC1/HC2 board revisions (from
- 0.6 1308 XU4S 0.1 (HC1)
- 0.6 1309 XU4-HC1 0.1
- 0.7 1470 XU4-HC1+ 0.1 (HC2)
* Use +1% for ADC value tolerance in the array below, the code loops until * the measured ADC value is lower than then ADCmax from the array. */ @@ -39,7 +40,8 @@ struct odroid_rev_info odroid_info[] = { { EXYNOS5_BOARD_ODROID_XU3_REV01, 1, 10, "xu3" }, { EXYNOS5_BOARD_ODROID_XU3_REV02, 2, 375, "xu3" }, { EXYNOS5_BOARD_ODROID_XU4_REV01, 1, 1293, "xu4" }, - { EXYNOS5_BOARD_ODROID_HC1_REV01, 1, 1321, "hc1" }, + { EXYNOS5_BOARD_ODROID_HC1_REV01, 1, 1322, "hc1" }, + { EXYNOS5_BOARD_ODROID_HC2_REV01, 1, 1484, "hc1" }, { EXYNOS5_BOARD_ODROID_UNKNOWN, 0, 4095, "unknown" }, }; @@ -144,6 +146,14 @@ bool board_is_odroidhc1(void) return false; } +bool board_is_odroidhc2(void) +{ + if (gd->board_type == EXYNOS5_BOARD_ODROID_HC2_REV01) + return true;
+ return false; +}
bool board_is_generic(void) { if (gd->board_type == EXYNOS5_BOARD_GENERIC) diff --git a/board/samsung/common/exynos5-dt.c b/board/samsung/common/exynos5-dt.c index 8c3a9ea564..c183965b92 100644 --- a/board/samsung/common/exynos5-dt.c +++ b/board/samsung/common/exynos5-dt.c @@ -179,7 +179,7 @@ char *get_dfu_alt_system(char *interface, char *devstr) { char *info = "Not supported!"; - if (board_is_odroidxu4() || board_is_odroidhc1()) + if (board_is_odroidxu4() || board_is_odroidhc1() || board_is_odroidhc2()) return info; return env_get("dfu_alt_system"); @@ -192,7 +192,7 @@ char *get_dfu_alt_boot(char *interface, char *devstr) char *alt_boot; int dev_num; - if (board_is_odroidxu4() || board_is_odroidhc1()) + if (board_is_odroidxu4() || board_is_odroidhc1() || board_is_odroidhc2()) return info; dev_num = simple_strtoul(devstr, NULL, 10); diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 258b9781cc..d5c7cc7129 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS5=y -CONFIG_IDENT_STRING=" for ODROID-XU3/XU4/HC1" +CONFIG_IDENT_STRING=" for ODROID-XU3/XU4/HC1/HC2" CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=8 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/include/samsung/exynos5-dt-types.h b/include/samsung/exynos5-dt-types.h index 8e11af30d1..8fe08fe211 100644 --- a/include/samsung/exynos5-dt-types.h +++ b/include/samsung/exynos5-dt-types.h @@ -9,6 +9,7 @@ enum { EXYNOS5_BOARD_ODROID_XU3_REV02, EXYNOS5_BOARD_ODROID_XU4_REV01, EXYNOS5_BOARD_ODROID_HC1_REV01, + EXYNOS5_BOARD_ODROID_HC2_REV01, EXYNOS5_BOARD_ODROID_UNKNOWN, EXYNOS5_BOARD_COUNT, @@ -25,5 +26,6 @@ bool board_is_generic(void); bool board_is_odroidxu3(void); bool board_is_odroidxu4(void); bool board_is_odroidhc1(void); +bool board_is_odroidhc2(void); #endif -- 2.17.1
Best regards
Hi Dirk,
- Rev ADCmax Board
- 0.1 0 XU3 0.1
- 0.2 372 XU3 0.2 | XU3L - no DISPLAYPORT (probe I2C0:0x40 /
INA231)
- 0.3 1280 XU4 0.1
- 0.4 739 XU4 0.2
- 0.5 1016 XU4+Air0.1 (Passive cooling)
- Use +1% for ADC value tolerance in the array below, the code
loops until
- the measured ADC value is lower than then ADCmax from the array.
- { EXYNOS5_BOARD_ODROID_HC1_REV01, 1, 1322, "hc1" },
- { EXYNOS5_BOARD_ODROID_HC2_REV01, 1, 1484, "hc1" }, { EXYNOS5_BOARD_ODROID_UNKNOWN, 0, 4095, "unknown" },
- if (gd->board_type == EXYNOS5_BOARD_ODROID_HC2_REV01)
return true;
- return false;
- if (board_is_odroidxu4() || board_is_odroidhc1() ||
#endif
2.17.1
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Dear Dirk Meul,
On 15/10/18 23:19, Lukasz Majewski wrote:
Hi Dirk,
I failed to apply your patch. Could you please check and resend?
checking file board/samsung/common/exynos5-dt-types.c Hunk #2 FAILED at 40. Hunk #3 succeeded at 145 with fuzz 1. 1 out of 3 hunks FAILED checking file board/samsung/common/exynos5-dt.c Hunk #1 FAILED at 179. Hunk #2 FAILED at 192. 2 out of 2 hunks FAILED checking file configs/odroid-xu3_defconfig checking file include/samsung/exynos5-dt-types.h Hunk #1 FAILED at 9. 1 out of 2 hunks FAILED
Thanks, Minkyu Kang.
#endif
Dear Dirk Meul,
Please send a v2 patch.
participants (5)
Dirk Meul
Lukasz Majewski
Marek Szyprowski
Meul, Dirk
Minkyu Kang
