[U-Boot] [PATCH v3 2/7] zynq-common: Define CONFIG_NAND_ZYNQ
From: Jagannadha Sutradharudu Teki jaganna@xilinx.com
Defined CONFIG_NAND_ZYNQ for enabling zynq nand controller with onfi detection support.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- Changes for v3: -Separated out the nand patch series as per Michal comment. Changes for v2: -None --- include/configs/zynq-common.h | 10 ++++++++++ 1 files changed, 10 insertions(+), 0 deletions(-)
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index e7a8e9f..08adaa2 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -91,6 +91,16 @@ # define CONFIG_SYS_FLASH_USE_BUFFER_WRITE #endif
+/* NAND */ +#ifdef CONFIG_NAND_ZYNQ +# define CONFIG_CMD_NAND +# define CONFIG_CMD_NAND_LOCK_UNLOCK +# define CONFIG_SYS_MAX_NAND_DEVICE 1 +# define CONFIG_SYS_NAND_SELF_INIT +# define CONFIG_SYS_NAND_ONFI_DETECTION +# define CONFIG_MTD_DEVICE +#endif + /* MMC */ #if defined(CONFIG_ZYNQ_SDHCI0) || defined(CONFIG_ZYNQ_SDHCI1) # define CONFIG_MMC
