[U-Boot-Users] [PATCH] fdt_support: add crypto node handling for MPC8{3, 5}xxE processors
crypto node if not on an E-processor. If on 8360 or 834x family, check rev and up-rev crypto node (to SEC rev. 2.4) property values if on an 'EA' processor, e.g. MPC8349EA.
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- common/fdt_support.c | 87 +++++++++++++++++++++++++++++++++++++++++++ cpu/mpc83xx/fdt.c | 18 +++++++++ cpu/mpc85xx/fdt.c | 6 +++ include/asm-ppc/processor.h | 9 ++++ include/fdt_support.h | 6 +++ include/mpc83xx.h | 7 +++- 6 files changed, 132 insertions(+), 1 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 7507744..c5b4650 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -447,3 +447,90 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) prop, compat, fdt_strerror(err)); } #endif /* CONFIG_HAS_FSL_DR_USB */ + +#if defined(CONFIG_MPC83XX) || defined(CONFIG_MPC85xx) +/* + * update crypto node properties to a specified revision of the SEC + * called with sec_rev == 0 if not on an mpc8xxxE processor + */ +void fdt_fixup_crypto_node(void *blob, int sec_rev) +{ + const struct sec_rev_prop { + u32 sec_rev; + u32 num_channels; + u32 channel_fifo_len; + u32 exec_units_mask; + u32 descriptor_types_mask; + } sec_rev_prop_list [] = { + { 0x0200, 4, 24, 0x07e, 0x01010ebf }, /* SEC 2.0 */ + { 0x0201, 4, 24, 0x0fe, 0x012b0ebf }, /* SEC 2.1 */ + { 0x0202, 1, 24, 0x04c, 0x0122003f }, /* SEC 2.2 */ + { 0x0204, 4, 24, 0x07e, 0x012b0ebf }, /* SEC 2.4 */ + { 0x0300, 4, 24, 0x9fe, 0x03ab0ebf }, /* SEC 3.0 */ + { 0x0303, 4, 24, 0x97c, 0x03ab0abf }, /* SEC 3.3 */ + }; + char compat_strlist[ARRAY_SIZE(sec_rev_prop_list) * + sizeof("fsl,secX.Y")]; + int crypto_node, sec_idx, err; + char *p; + u32 val; + + /* locate crypto node based on lowest common compatible */ + crypto_node = fdt_node_offset_by_compatible(blob, -1, "fsl,sec2.0"); + if (crypto_node == -FDT_ERR_NOTFOUND) + return; + + /* delete it if not on an E-processor */ + if (crypto_node > 0 && !sec_rev) { + fdt_del_node(blob, crypto_node); + return; + } + + /* else we got called for possible uprev */ + for (sec_idx = 0; sec_idx < ARRAY_SIZE(sec_rev_prop_list); sec_idx++) + if (sec_rev_prop_list[sec_idx].sec_rev == sec_rev) + break; + + if (sec_idx == ARRAY_SIZE(sec_rev_prop_list)) { + puts("warning: unknown SEC revision number\n"); + return; + } + + val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].num_channels); + err = fdt_setprop(blob, crypto_node, "fsl,num-channels", &val, 4); + if (err < 0) + printf("WARNING: could not set crypto property: %s\n", + fdt_strerror(err)); + + val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].descriptor_types_mask); + err = fdt_setprop(blob, crypto_node, "fsl,descriptor-types-mask", &val, 4); + if (err < 0) + printf("WARNING: could not set crypto property: %s\n", + fdt_strerror(err)); + + val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].exec_units_mask); + err = fdt_setprop(blob, crypto_node, "fsl,exec-units-mask", &val, 4); + if (err < 0) + printf("WARNING: could not set crypto property: %s\n", + fdt_strerror(err)); + + val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].channel_fifo_len); + err = fdt_setprop(blob, crypto_node, "fsl,channel-fifo-len", &val, 4); + if (err < 0) + printf("WARNING: could not set crypto property: %s\n", + fdt_strerror(err)); + + val = 0; + while (sec_idx >= 0) { + p = compat_strlist + val; + val += sprintf(p, "fsl,sec%d.%d", + (sec_rev_prop_list[sec_idx].sec_rev & 0xff00) >> 8, + sec_rev_prop_list[sec_idx].sec_rev & 0x00ff); + sec_idx--; + } + err = fdt_setprop(blob, crypto_node, "compatible", &compat_strlist, val); + if (err < 0) + printf("WARNING: could not set crypto property: %s\n", + fdt_strerror(err)); +} +#endif /* defined(CONFIG_MPC83XX) || defined(CONFIG_MPC85xx) */ diff --git a/cpu/mpc83xx/fdt.c b/cpu/mpc83xx/fdt.c index 02c4d05..267ae6a 100644 --- a/cpu/mpc83xx/fdt.c +++ b/cpu/mpc83xx/fdt.c @@ -26,6 +26,7 @@ #include <common.h> #include <libfdt.h> #include <fdt_support.h> +#include <asm/processor.h>
extern void ft_qe_setup(void *blob);
@@ -33,6 +34,23 @@ DECLARE_GLOBAL_DATA_PTR;
void ft_cpu_setup(void *blob, bd_t *bd) { + immap_t *immr = (immap_t *)CFG_IMMR; + int spridr = immr->sysconf.spridr; + + /* + * delete crypto node if not on an E-processor + * initial revisions of the MPC834xE/6xE have the original SEC 2.0. + * EA revisions got the SEC uprevved to 2.4 but since the default device + * tree contains SEC 2.0 properties we uprev them here. + */ + if (!IS_E_PROCESSOR(spridr)) + fdt_fixup_crypto_node(blob, 0); + else if (IS_E_PROCESSOR(spridr) && + (SPR_FAMILY(spridr) == SPR_834X_FAMILY || + SPR_FAMILY(spridr) == SPR_836X_FAMILY) && + REVID_MAJOR(spridr) >= 2) + fdt_fixup_crypto_node(blob, 0x0204); + #if defined(CONFIG_HAS_ETH0) || defined(CONFIG_HAS_ETH1) ||\ defined(CONFIG_HAS_ETH2) || defined(CONFIG_HAS_ETH3) fdt_fixup_ethernet(blob, bd); diff --git a/cpu/mpc85xx/fdt.c b/cpu/mpc85xx/fdt.c index bb87740..aac74ac 100644 --- a/cpu/mpc85xx/fdt.c +++ b/cpu/mpc85xx/fdt.c @@ -26,8 +26,10 @@ #include <common.h> #include <libfdt.h> #include <fdt_support.h> +#include <asm/processor.h>
extern void ft_qe_setup(void *blob); + #ifdef CONFIG_MP #include "mp.h" DECLARE_GLOBAL_DATA_PTR; @@ -79,6 +81,10 @@ void ft_fixup_cpu(void *blob, u64 memory_limit)
void ft_cpu_setup(void *blob, bd_t *bd) { + /* delete crypto node if not on an E-processor */ + if (!IS_E_PROCESSOR(get_svr())) + fdt_fixup_crypto_node(blob, 0); + #if defined(CONFIG_HAS_ETH0) || defined(CONFIG_HAS_ETH1) ||\ defined(CONFIG_HAS_ETH2) || defined(CONFIG_HAS_ETH3) fdt_fixup_ethernet(blob, bd); diff --git a/include/asm-ppc/processor.h b/include/asm-ppc/processor.h index 8bdfb9d..14d3d70 100644 --- a/include/asm-ppc/processor.h +++ b/include/asm-ppc/processor.h @@ -883,6 +883,15 @@ /* Some parts define SVR[0:23] as the SOC version */ #define SVR_SOC_VER(svr) (((svr) >> 8) & 0xFFFFFF) /* SOC Version fields */
+/* whether MPC8xxxE (i.e. has SEC) */ +#if defined(CONFIG_MPC85xx) +#define IS_E_PROCESSOR(svr) (svr & 0x800) +#else +#if defined(CONFIG_MPC83XX) +#define IS_E_PROCESSOR(spridr) (!(spridr & 0x00010000)) +#endif +#endif + /* * SVR_SOC_VER() Version Values */ diff --git a/include/fdt_support.h b/include/fdt_support.h index 890993f..a7c6326 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -56,6 +56,12 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd); static inline void fdt_fixup_dr_usb(void *blob, bd_t *bd) {} #endif /* CONFIG_HAS_FSL_DR_USB */
+#if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC83XX) +void fdt_fixup_crypto_node(void *blob, int sec_rev); +#else +static inline void fdt_fixup_crypto_node(void *blob, int sec_rev) {} +#endif + #ifdef CONFIG_OF_BOARD_SETUP void ft_board_setup(void *blob, bd_t *bd); void ft_cpu_setup(void *blob, bd_t *bd); diff --git a/include/mpc83xx.h b/include/mpc83xx.h index d2e1e2b..1e8a641 100644 --- a/include/mpc83xx.h +++ b/include/mpc83xx.h @@ -60,21 +60,26 @@ #endif
#define PARTID_NO_E(spridr) ((spridr & 0xFFFE0000) >> 16) -#define IS_E_PROCESSOR(spridr) (!(spridr & 0x00010000)) /* has SEC */ +#define SPR_FAMILY(spridr) ((spridr & 0xFFF00000) >> 20)
+#define SPR_831X_FAMILY 0x80B #define SPR_8311 0x80B2 #define SPR_8313 0x80B0 #define SPR_8314 0x80B6 #define SPR_8315 0x80B4 +#define SPR_832X_FAMILY 0x806 #define SPR_8321 0x8066 #define SPR_8323 0x8062 +#define SPR_834X_FAMILY 0x803 #define SPR_8343 0x8036 #define SPR_8347_TBGA_ 0x8032 #define SPR_8347_PBGA_ 0x8034 #define SPR_8349 0x8030 +#define SPR_836X_FAMILY 0x804 #define SPR_8358_TBGA_ 0x804A #define SPR_8358_PBGA_ 0x804E #define SPR_8360 0x8048 +#define SPR_837X_FAMILY 0x80C #define SPR_8377 0x80C6 #define SPR_8378 0x80C4 #define SPR_8379 0x80C2
- /* delete crypto node if not on an E-processor */
- if (!IS_E_PROCESSOR(get_svr()))
This is wrong or you need to fix the IS_E_PROCESSOR() macro.
IS_E_PROCESSOR(svr) should be defined:
svr & 0x80000
or you want:
IS_E_PROCESSOR(SVR_SOC_VER(get_svr()))
- k
- SVR_SOC_VER() Version Values
Kim Phillips
Kumar Gala
