[U-Boot] use of global static variables?
With the relocation changes are global statics variables ok if we know code is called after relocation?
- k
Hi Kumar,
Yes, they should work as expected after relocation.
Prior to relocation you should be able to read the values of the global statics if they are initialized to a non-zero value, but not modify them.
Best, Peter
Dear Peter Tyser,
Correct. And in some places we enable these even for zero valued variables by using the old trick of writing
int foo __attribute__ ((section(".data"))) = 0;
Dear Kumar Gala,
In message BF924A4F-6A8D-43C0-9B7B-58D1C6D3B850@kernel.crashing.org you wrote:
They have always been ok (as far as global variables can be ok) if you were aware of their restrictions before relocation.
Kumar Gala
Peter Tyser
