[U-Boot] [PATCH 0/4 V3]EXYNOS: Convert Assembly code to c and make it common
Convert the assembly code in board/samsung to c and move the same to arch/arm. lds file made common across SMDKV310, Origen and SMDK5250. Add the power reset and exit wakeup api for exynos. Initialise GPIO for uart in Origen and SMDKV310 using pinmux.
Changes in V2: - Rebased on latest u-boot-samsung tree. - Incorporated review comments from Simon glass and Minkyu Kang. Changes in V3: - Optimised the mem_ctrl_init function for exynos4. - Removed magic numbers.
Rajeshwari Shinde (4): EXYNOS: Add API for power reset and exit wakeup EXYNOS: LDS file move to common EXYNOS4210: Configure GPIO for uart EXYNOS: Move files from board/samsung to arch/arm
arch/arm/cpu/armv7/exynos/Makefile | 17 +- .../arm/cpu/armv7/exynos}/clock_init.h | 0 arch/arm/cpu/armv7/exynos/clock_init_exynos4.c | 94 +++++ .../arm/cpu/armv7/exynos/clock_init_exynos5.c | 47 +-- arch/arm/cpu/armv7/exynos/common_setup.h | 43 ++ .../arm/cpu/armv7/exynos}/dmc_common.c | 7 +- .../arm/cpu/armv7/exynos}/dmc_init_ddr3.c | 19 +- arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c | 225 +++++++++++ .../arm/cpu/armv7/exynos/exynos4_setup.h | 386 +++++++++---------- .../arm/cpu/armv7/exynos/exynos5_setup.h | 28 +- arch/arm/cpu/armv7/exynos/lowlevel_init.c | 73 ++++ arch/arm/cpu/armv7/exynos/pinmux.c | 40 ++ arch/arm/cpu/armv7/exynos/power.c | 50 +++ .../arm/cpu/armv7/exynos}/spl_boot.c | 74 +++- arch/arm/include/asm/arch-exynos/cpu.h | 5 +- arch/arm/include/asm/arch-exynos/power.h | 12 + .../exynos-uboot-spl.lds} | 0 board/samsung/origen/Makefile | 11 +- board/samsung/origen/lowlevel_init.S | 357 ----------------- board/samsung/origen/mem_setup.S | 421 -------------------- board/samsung/origen/mmc_boot.c | 58 --- board/samsung/origen/origen.c | 46 +++ board/samsung/smdk5250/Makefile | 14 +- board/samsung/smdkv310/Makefile | 10 +- board/samsung/smdkv310/lowlevel_init.S | 414 ------------------- board/samsung/smdkv310/mem_setup.S | 365 ----------------- board/samsung/smdkv310/mmc_boot.c | 60 --- board/samsung/smdkv310/smdkv310.c | 46 +++ include/configs/exynos5250-dt.h | 10 +- include/configs/origen.h | 10 +- include/configs/smdkv310.h | 9 +- 31 files changed, 970 insertions(+), 1981 deletions(-) rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/clock_init.h (100%) create mode 100644 arch/arm/cpu/armv7/exynos/clock_init_exynos4.c rename board/samsung/smdk5250/clock_init.c => arch/arm/cpu/armv7/exynos/clock_init_exynos5.c (95%) create mode 100644 arch/arm/cpu/armv7/exynos/common_setup.h rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/dmc_common.c (97%) rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/dmc_init_ddr3.c (95%) create mode 100644 arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c rename board/samsung/origen/origen_setup.h => arch/arm/cpu/armv7/exynos/exynos4_setup.h (65%) rename board/samsung/smdk5250/setup.h => arch/arm/cpu/armv7/exynos/exynos5_setup.h (96%) create mode 100644 arch/arm/cpu/armv7/exynos/lowlevel_init.c rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/spl_boot.c (74%) rename board/samsung/{smdk5250/smdk5250-uboot-spl.lds => common/exynos-uboot-spl.lds} (100%) delete mode 100644 board/samsung/origen/lowlevel_init.S delete mode 100644 board/samsung/origen/mem_setup.S delete mode 100644 board/samsung/origen/mmc_boot.c delete mode 100644 board/samsung/smdkv310/lowlevel_init.S delete mode 100644 board/samsung/smdkv310/mem_setup.S delete mode 100644 board/samsung/smdkv310/mmc_boot.c
This patch adds APIs to get power reset status and exit the wakeup condition for both exynos5 and exynos4
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - Expanded the comments for get_reset_status function declaration. Changes in V3: - None arch/arm/cpu/armv7/exynos/power.c | 50 ++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/power.h | 12 +++++++ 2 files changed, 62 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/power.c b/arch/arm/cpu/armv7/exynos/power.c index 6375a81..5d3bda2 100644 --- a/arch/arm/cpu/armv7/exynos/power.c +++ b/arch/arm/cpu/armv7/exynos/power.c @@ -140,3 +140,53 @@ void set_hw_thermal_trip(void) setbits_le32(&power->ps_hold_control, POWER_ENABLE_HW_TRIP); } } + +static uint32_t exynos5_get_reset_status(void) +{ + struct exynos5_power *power = + (struct exynos5_power *)samsung_get_base_power(); + + return power->inform1; +} + +static uint32_t exynos4_get_reset_status(void) +{ + struct exynos4_power *power = + (struct exynos4_power *)samsung_get_base_power(); + + return power->inform1; +} + +uint32_t get_reset_status(void) +{ + if (cpu_is_exynos5()) + return exynos5_get_reset_status(); + else + return exynos4_get_reset_status(); +} + +static void exynos5_power_exit_wakeup(void) +{ + struct exynos5_power *power = + (struct exynos5_power *)samsung_get_base_power(); + typedef void (*resume_func)(void); + + ((resume_func)power->inform0)(); +} + +static void exynos4_power_exit_wakeup(void) +{ + struct exynos4_power *power = + (struct exynos4_power *)samsung_get_base_power(); + typedef void (*resume_func)(void); + + ((resume_func)power->inform0)(); +} + +void power_exit_wakeup(void) +{ + if (cpu_is_exynos5()) + exynos5_power_exit_wakeup(); + else + exynos4_power_exit_wakeup(); +} diff --git a/arch/arm/include/asm/arch-exynos/power.h b/arch/arm/include/asm/arch-exynos/power.h index 3549667..b8db663 100644 --- a/arch/arm/include/asm/arch-exynos/power.h +++ b/arch/arm/include/asm/arch-exynos/power.h @@ -888,4 +888,16 @@ void set_ps_hold_ctrl(void); * source as XXTI */ void set_xclkout(void); + +/* + * Read inform1 to get the reset status. + * @return: the value can be either S5P_CHECK_SLEEP or + * S5P_CHECK_DIDLE or S5P_CHECK_LPA as stored in inform1 + * if none of these then its normal booting. + */ +uint32_t get_reset_status(void); + + +/* Read the resume function and call it */ +void power_exit_wakeup(void); #endif
smdk5250-uboot-spl.lds is moved to common folder, so that it can be reused. It is renamed to exynos-uboot-spl.lds
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None .../exynos-uboot-spl.lds} | 0 include/configs/exynos5250-dt.h | 2 +- 2 files changed, 1 insertions(+), 1 deletions(-) rename board/samsung/{smdk5250/smdk5250-uboot-spl.lds => common/exynos-uboot-spl.lds} (100%)
diff --git a/board/samsung/smdk5250/smdk5250-uboot-spl.lds b/board/samsung/common/exynos-uboot-spl.lds similarity index 100% rename from board/samsung/smdk5250/smdk5250-uboot-spl.lds rename to board/samsung/common/exynos-uboot-spl.lds diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 1c9eca2..6c7a052 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -153,7 +153,7 @@ #define COPY_BL2_FNPTR_ADDR 0x02020030
/* specific .lds file */ -#define CONFIG_SPL_LDSCRIPT "board/samsung/smdk5250/smdk5250-uboot-spl.lds" +#define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds" #define CONFIG_SPL_TEXT_BASE 0x02023400 #define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024)
This patch configures the gpio values for UART on Origen and SMDKV310 using pinmux
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org --- Changes in V2: - None Changes in V3: - None arch/arm/cpu/armv7/exynos/pinmux.c | 40 +++++++++++++++++++++++++++++++ board/samsung/origen/origen.c | 46 ++++++++++++++++++++++++++++++++++++ board/samsung/smdkv310/smdkv310.c | 46 ++++++++++++++++++++++++++++++++++++ include/configs/origen.h | 1 + include/configs/smdkv310.h | 1 + 5 files changed, 134 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index bd499b4..2042062 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -408,9 +408,49 @@ static int exynos4_mmc_config(int peripheral, int flags) return 0; }
+static void exynos4_uart_config(int peripheral) +{ + struct exynos4_gpio_part1 *gpio1 = + (struct exynos4_gpio_part1 *)samsung_get_base_gpio_part1(); + struct s5p_gpio_bank *bank; + int i, start, count; + + switch (peripheral) { + case PERIPH_ID_UART0: + bank = &gpio1->a0; + start = 0; + count = 4; + break; + case PERIPH_ID_UART1: + bank = &gpio1->a0; + start = 4; + count = 4; + break; + case PERIPH_ID_UART2: + bank = &gpio1->a1; + start = 0; + count = 4; + break; + case PERIPH_ID_UART3: + bank = &gpio1->a1; + start = 4; + count = 2; + break; + } + for (i = start; i < start + count; i++) { + s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); + s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); + } +} static int exynos4_pinmux_config(int peripheral, int flags) { switch (peripheral) { + case PERIPH_ID_UART0: + case PERIPH_ID_UART1: + case PERIPH_ID_UART2: + case PERIPH_ID_UART3: + exynos4_uart_config(peripheral); + break; case PERIPH_ID_I2C0: case PERIPH_ID_I2C1: case PERIPH_ID_I2C2: diff --git a/board/samsung/origen/origen.c b/board/samsung/origen/origen.c index 638e7b1..b7dbb91 100644 --- a/board/samsung/origen/origen.c +++ b/board/samsung/origen/origen.c @@ -25,6 +25,8 @@ #include <asm/arch/cpu.h> #include <asm/arch/gpio.h> #include <asm/arch/mmc.h> +#include <asm/arch/periph.h> +#include <asm/arch/pinmux.h>
DECLARE_GLOBAL_DATA_PTR; struct exynos4_gpio_part1 *gpio1; @@ -39,6 +41,50 @@ int board_init(void) return 0; }
+static int board_uart_init(void) +{ + int err; + + err = exynos_pinmux_config(PERIPH_ID_UART0, PINMUX_FLAG_NONE); + if (err) { + debug("UART0 not configured\n"); + return err; + } + + err = exynos_pinmux_config(PERIPH_ID_UART1, PINMUX_FLAG_NONE); + if (err) { + debug("UART1 not configured\n"); + return err; + } + + err = exynos_pinmux_config(PERIPH_ID_UART2, PINMUX_FLAG_NONE); + if (err) { + debug("UART2 not configured\n"); + return err; + } + + err = exynos_pinmux_config(PERIPH_ID_UART3, PINMUX_FLAG_NONE); + if (err) { + debug("UART3 not configured\n"); + return err; + } + + return 0; +} + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ + int err; + err = board_uart_init(); + if (err) { + debug("UART init failed\n"); + return err; + } + return err; +} +#endif + int dram_init(void) { gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) diff --git a/board/samsung/smdkv310/smdkv310.c b/board/samsung/smdkv310/smdkv310.c index 81ac8f6..015b920 100644 --- a/board/samsung/smdkv310/smdkv310.c +++ b/board/samsung/smdkv310/smdkv310.c @@ -26,6 +26,8 @@ #include <asm/arch/cpu.h> #include <asm/arch/gpio.h> #include <asm/arch/mmc.h> +#include <asm/arch/periph.h> +#include <asm/arch/pinmux.h> #include <asm/arch/sromc.h>
DECLARE_GLOBAL_DATA_PTR; @@ -137,3 +139,47 @@ int board_mmc_init(bd_t *bis) return err; } #endif + +static int board_uart_init(void) +{ + int err; + + err = exynos_pinmux_config(PERIPH_ID_UART0, PINMUX_FLAG_NONE); + if (err) { + debug("UART0 not configured\n"); + return err; + } + + err = exynos_pinmux_config(PERIPH_ID_UART1, PINMUX_FLAG_NONE); + if (err) { + debug("UART1 not configured\n"); + return err; + } + + err = exynos_pinmux_config(PERIPH_ID_UART2, PINMUX_FLAG_NONE); + if (err) { + debug("UART2 not configured\n"); + return err; + } + + err = exynos_pinmux_config(PERIPH_ID_UART3, PINMUX_FLAG_NONE); + if (err) { + debug("UART3 not configured\n"); + return err; + } + + return 0; +} + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ + int err; + err = board_uart_init(); + if (err) { + debug("UART init failed\n"); + return err; + } + return err; +} +#endif diff --git a/include/configs/origen.h b/include/configs/origen.h index e179911..f71a463 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -36,6 +36,7 @@ #define CONFIG_ARCH_CPU_INIT #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_EARLY_INIT_F
/* Keep L2 Cache Disabled */ #define CONFIG_L2_OFF 1 diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 5e43066..db78127 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -36,6 +36,7 @@ #define CONFIG_ARCH_CPU_INIT #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_EARLY_INIT_F
/* Mach Type */ #define CONFIG_MACH_TYPE MACH_TYPE_SMDKV310
This patch performs the following:
1) Convert the assembly code for memory and clock initialization to C code. 2) Move the memory and clock init codes from board/samsung to arch/arm 3) Creat a common lowlevel_init file across Exynos4 and Exynos5. Converted the common lowlevel_init from assembly to C-code 4) Made spl_boot.c and tzpc_init.c common for both exynos4 and exynos5. 5) Enable CONFIG_SKIP_LOWLEVEL_INIT as stack pointer initialisation is already done in _main. 6) exynos-uboot-spl.lds made common across SMDKV310, Origen and SMDK5250.
TEST: Tested SD-MMC boot on SMDK5250 and Origen. Tested USB and SPI boot on SMDK5250 Compile tested for SMDKV310.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - Rebased on latest u-boot-samsung tree. - Incorporated review comments from Minkyu Kang. Changes in V3: - Optimised the mem_ctrl_init function for exynos4. - Removed magic numbers. arch/arm/cpu/armv7/exynos/Makefile | 17 +- .../arm/cpu/armv7/exynos}/clock_init.h | 0 arch/arm/cpu/armv7/exynos/clock_init_exynos4.c | 94 +++++ .../arm/cpu/armv7/exynos/clock_init_exynos5.c | 47 +-- arch/arm/cpu/armv7/exynos/common_setup.h | 43 ++ .../arm/cpu/armv7/exynos}/dmc_common.c | 7 +- .../arm/cpu/armv7/exynos}/dmc_init_ddr3.c | 19 +- arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c | 212 ++++++++++ .../arm/cpu/armv7/exynos/exynos4_setup.h | 397 +++++++++---------- .../arm/cpu/armv7/exynos/exynos5_setup.h | 28 +- arch/arm/cpu/armv7/exynos/lowlevel_init.c | 73 ++++ .../arm/cpu/armv7/exynos}/spl_boot.c | 74 +++- arch/arm/include/asm/arch-exynos/cpu.h | 5 +- board/samsung/origen/Makefile | 11 +- board/samsung/origen/lowlevel_init.S | 357 ----------------- board/samsung/origen/mem_setup.S | 421 -------------------- board/samsung/origen/mmc_boot.c | 58 --- board/samsung/smdk5250/Makefile | 14 +- board/samsung/smdkv310/Makefile | 10 +- board/samsung/smdkv310/lowlevel_init.S | 414 ------------------- board/samsung/smdkv310/mem_setup.S | 365 ----------------- board/samsung/smdkv310/mmc_boot.c | 60 --- include/configs/exynos5250-dt.h | 8 +- include/configs/origen.h | 8 +- include/configs/smdkv310.h | 7 +- 25 files changed, 770 insertions(+), 1979 deletions(-) rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/clock_init.h (100%) create mode 100644 arch/arm/cpu/armv7/exynos/clock_init_exynos4.c rename board/samsung/smdk5250/clock_init.c => arch/arm/cpu/armv7/exynos/clock_init_exynos5.c (95%) create mode 100644 arch/arm/cpu/armv7/exynos/common_setup.h rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/dmc_common.c (97%) rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/dmc_init_ddr3.c (95%) create mode 100644 arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c rename board/samsung/origen/origen_setup.h => arch/arm/cpu/armv7/exynos/exynos4_setup.h (65%) rename board/samsung/smdk5250/setup.h => arch/arm/cpu/armv7/exynos/exynos5_setup.h (96%) create mode 100644 arch/arm/cpu/armv7/exynos/lowlevel_init.c rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/spl_boot.c (74%) delete mode 100644 board/samsung/origen/lowlevel_init.S delete mode 100644 board/samsung/origen/mem_setup.S delete mode 100644 board/samsung/origen/mmc_boot.c delete mode 100644 board/samsung/smdkv310/lowlevel_init.S delete mode 100644 board/samsung/smdkv310/mem_setup.S delete mode 100644 board/samsung/smdkv310/mmc_boot.c
diff --git a/arch/arm/cpu/armv7/exynos/Makefile b/arch/arm/cpu/armv7/exynos/Makefile index b2f9152..4661155 100644 --- a/arch/arm/cpu/armv7/exynos/Makefile +++ b/arch/arm/cpu/armv7/exynos/Makefile @@ -22,10 +22,19 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(SOC).o
-COBJS += clock.o power.o soc.o system.o pinmux.o tzpc.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +COBJS-y += clock.o power.o soc.o system.o pinmux.o tzpc.o + +ifdef CONFIG_SPL_BUILD +COBJS-$(CONFIG_EXYNOS5) += clock_init_exynos5.o +COBJS-$(CONFIG_EXYNOS5) += dmc_common.o dmc_init_ddr3.o +COBJS-$(CONFIG_EXYNOS4210)+= dmc_init_exynos4.o clock_init_exynos4.o +COBJS-y += spl_boot.o +COBJS-y += lowlevel_init.o +endif + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS))
all: $(obj).depend $(LIB)
diff --git a/board/samsung/smdk5250/clock_init.h b/arch/arm/cpu/armv7/exynos/clock_init.h similarity index 100% rename from board/samsung/smdk5250/clock_init.h rename to arch/arm/cpu/armv7/exynos/clock_init.h diff --git a/arch/arm/cpu/armv7/exynos/clock_init_exynos4.c b/arch/arm/cpu/armv7/exynos/clock_init_exynos4.c new file mode 100644 index 0000000..bee0b5c --- /dev/null +++ b/arch/arm/cpu/armv7/exynos/clock_init_exynos4.c @@ -0,0 +1,94 @@ +/* + * Clock Initialization for board based on EXYNOS4210 + * + * Copyright (C) 2013 Samsung Electronics + * Rajeshwari Shinde rajeshwari.s@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <config.h> +#include <version.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/clock.h> +#include "common_setup.h" +#include "exynos4_setup.h" + +/* + * system_clock_init: Initialize core clock and bus clock. + * void system_clock_init(void) + */ +void system_clock_init(void) +{ + struct exynos4_clock *clk = (struct exynos4_clock *)EXYNOS4_CLOCK_BASE; + + writel(CLK_SRC_CPU_VAL, &clk->src_cpu); + + sdelay(0x10000); + + writel(CLK_SRC_TOP0_VAL, &clk->src_top0); + writel(CLK_SRC_TOP1_VAL, &clk->src_top1); + writel(CLK_SRC_DMC_VAL, &clk->src_dmc); + writel(CLK_SRC_LEFTBUS_VAL, &clk->src_leftbus); + writel(CLK_SRC_RIGHTBUS_VAL, &clk->src_rightbus); + writel(CLK_SRC_FSYS_VAL, &clk->src_fsys); + writel(CLK_SRC_PERIL0_VAL, &clk->src_peril0); + writel(CLK_SRC_CAM_VAL, &clk->src_cam); + writel(CLK_SRC_MFC_VAL, &clk->src_mfc); + writel(CLK_SRC_G3D_VAL, &clk->src_g3d); + writel(CLK_SRC_LCD0_VAL, &clk->src_lcd0); + + sdelay(0x10000); + + writel(CLK_DIV_CPU0_VAL, &clk->div_cpu0); + writel(CLK_DIV_CPU1_VAL, &clk->div_cpu1); + writel(CLK_DIV_DMC0_VAL, &clk->div_dmc0); + writel(CLK_DIV_DMC1_VAL, &clk->div_dmc1); + writel(CLK_DIV_LEFTBUS_VAL, &clk->div_leftbus); + writel(CLK_DIV_RIGHTBUS_VAL, &clk->div_rightbus); + writel(CLK_DIV_TOP_VAL, &clk->div_top); + writel(CLK_DIV_FSYS1_VAL, &clk->div_fsys1); + writel(CLK_DIV_FSYS2_VAL, &clk->div_fsys2); + writel(CLK_DIV_FSYS3_VAL, &clk->div_fsys3); + writel(CLK_DIV_PERIL0_VAL, &clk->div_peril0); + writel(CLK_DIV_CAM_VAL, &clk->div_cam); + writel(CLK_DIV_MFC_VAL, &clk->div_mfc); + writel(CLK_DIV_G3D_VAL, &clk->div_g3d); + writel(CLK_DIV_LCD0_VAL, &clk->div_lcd0); + + /* Set PLL locktime */ + writel(PLL_LOCKTIME, &clk->apll_lock); + writel(PLL_LOCKTIME, &clk->mpll_lock); + writel(PLL_LOCKTIME, &clk->epll_lock); + writel(PLL_LOCKTIME, &clk->vpll_lock); + + writel(APLL_CON1_VAL, &clk->apll_con1); + writel(APLL_CON0_VAL, &clk->apll_con0); + writel(MPLL_CON1_VAL, &clk->mpll_con1); + writel(MPLL_CON0_VAL, &clk->mpll_con0); + writel(EPLL_CON1_VAL, &clk->epll_con1); + writel(EPLL_CON0_VAL, &clk->epll_con0); + writel(VPLL_CON1_VAL, &clk->vpll_con1); + writel(VPLL_CON0_VAL, &clk->vpll_con0); + + sdelay(0x30000); +} diff --git a/board/samsung/smdk5250/clock_init.c b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c similarity index 95% rename from board/samsung/smdk5250/clock_init.c rename to arch/arm/cpu/armv7/exynos/clock_init_exynos5.c index b288e66..d1a0084 100644 --- a/board/samsung/smdk5250/clock_init.c +++ b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c @@ -31,7 +31,8 @@ #include <asm/arch/dwmmc.h>
#include "clock_init.h" -#include "setup.h" +#include "common_setup.h" +#include "exynos5_setup.h"
#define FSYS1_MMC0_DIV_MASK 0xff0f #define FSYS1_MMC0_DIV_VAL 0x0701 @@ -214,10 +215,10 @@ struct mem_timings mem_timings[] = { DMC_MEMCONTROL_BL_8 | DMC_MEMCONTROL_PZQ_DISABLE | DMC_MEMCONTROL_MRR_BYTE_7_0, - .memconfig = DMC_MEMCONFIGx_CHIP_MAP_INTERLEAVED | - DMC_MEMCONFIGx_CHIP_COL_10 | - DMC_MEMCONFIGx_CHIP_ROW_15 | - DMC_MEMCONFIGx_CHIP_BANK_8, + .memconfig = DMC_MEMCONFIGX_CHIP_MAP_INTERLEAVED | + DMC_MEMCONFIGX_CHIP_COL_10 | + DMC_MEMCONFIGX_CHIP_ROW_15 | + DMC_MEMCONFIGX_CHIP_BANK_8, .membaseconfig0 = DMC_MEMBASECONFIG_VAL(0x40), .membaseconfig1 = DMC_MEMBASECONFIG_VAL(0x80), .prechconfig_tp_cnt = 0xff, @@ -317,10 +318,10 @@ struct mem_timings mem_timings[] = { DMC_MEMCONTROL_BL_8 | DMC_MEMCONTROL_PZQ_DISABLE | DMC_MEMCONTROL_MRR_BYTE_7_0, - .memconfig = DMC_MEMCONFIGx_CHIP_MAP_INTERLEAVED | - DMC_MEMCONFIGx_CHIP_COL_10 | - DMC_MEMCONFIGx_CHIP_ROW_15 | - DMC_MEMCONFIGx_CHIP_BANK_8, + .memconfig = DMC_MEMCONFIGX_CHIP_MAP_INTERLEAVED | + DMC_MEMCONFIGX_CHIP_COL_10 | + DMC_MEMCONFIGX_CHIP_ROW_15 | + DMC_MEMCONFIGX_CHIP_BANK_8, .membaseconfig0 = DMC_MEMBASECONFIG_VAL(0x40), .membaseconfig1 = DMC_MEMBASECONFIG_VAL(0x80), .prechconfig_tp_cnt = 0xff, @@ -350,9 +351,8 @@ struct mem_timings mem_timings[] = { * @param frequency_mhz Returns memory speed in MHz * @param arm_freq Returns ARM clock speed in MHz * @param mem_manuf Return Memory Manufacturer name - * @return 0 if all ok */ -static int clock_get_mem_selection(enum ddr_mode *mem_type, +static void clock_get_mem_selection(enum ddr_mode *mem_type, unsigned *frequency_mhz, unsigned *arm_freq, enum mem_manuf *mem_manuf) { @@ -363,8 +363,6 @@ static int clock_get_mem_selection(enum ddr_mode *mem_type, *frequency_mhz = params->frequency_mhz; *arm_freq = params->arm_freq_mhz; *mem_manuf = params->mem_manuf; - - return 0; }
/* Get the ratios for setting ARM clock */ @@ -376,9 +374,9 @@ struct arm_clk_ratios *get_arm_ratios(void) unsigned frequency_mhz, arm_freq; int i;
- if (clock_get_mem_selection(&mem_type, &frequency_mhz, - &arm_freq, &mem_manuf)) - ; + clock_get_mem_selection(&mem_type, &frequency_mhz, + &arm_freq, &mem_manuf); + for (i = 0, arm_ratio = arm_clk_ratios; i < ARRAY_SIZE(arm_clk_ratios); i++, arm_ratio++) { if (arm_ratio->arm_freq_mhz == arm_freq) @@ -400,15 +398,14 @@ struct mem_timings *clock_get_mem_timings(void) unsigned frequency_mhz, arm_freq; int i;
- if (!clock_get_mem_selection(&mem_type, &frequency_mhz, - &arm_freq, &mem_manuf)) { - for (i = 0, mem = mem_timings; i < ARRAY_SIZE(mem_timings); - i++, mem++) { - if (mem->mem_type == mem_type && - mem->frequency_mhz == frequency_mhz && - mem->mem_manuf == mem_manuf) - return mem; - } + clock_get_mem_selection(&mem_type, &frequency_mhz, + &arm_freq, &mem_manuf); + for (i = 0, mem = mem_timings; i < ARRAY_SIZE(mem_timings); + i++, mem++) { + if (mem->mem_type == mem_type && + mem->frequency_mhz == frequency_mhz && + mem->mem_manuf == mem_manuf) + return mem; }
/* will hang if failed to find memory timings */ diff --git a/arch/arm/cpu/armv7/exynos/common_setup.h b/arch/arm/cpu/armv7/exynos/common_setup.h new file mode 100644 index 0000000..59ee192 --- /dev/null +++ b/arch/arm/cpu/armv7/exynos/common_setup.h @@ -0,0 +1,43 @@ +/* + * Common APIs for EXYNOS based board + * + * Copyright (C) 2013 Samsung Electronics + * Rajeshwari Shinde rajeshwari.s@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Memory initialization + * + * @param reset Reset PHY during initialization. + */ +void mem_ctrl_init(int reset); + + /* System Clock initialization */ +void system_clock_init(void); + +/* + * Init subsystems according to the reset status + * + * @return 0 for a normal boot, non-zero for a resume + */ +int do_lowlevel_init(void); + +void sdelay(unsigned long); diff --git a/board/samsung/smdk5250/dmc_common.c b/arch/arm/cpu/armv7/exynos/dmc_common.c similarity index 97% rename from board/samsung/smdk5250/dmc_common.c rename to arch/arm/cpu/armv7/exynos/dmc_common.c index 109602a..645f57e 100644 --- a/board/samsung/smdk5250/dmc_common.c +++ b/arch/arm/cpu/armv7/exynos/dmc_common.c @@ -26,7 +26,8 @@ #include <asm/arch/spl.h>
#define ZQ_INIT_TIMEOUT 10000
@@ -175,7 +176,7 @@ void dmc_config_memory(struct mem_timings *mem, struct exynos5_dmc *dmc) writel(DMC_MEMBASECONFIG1_VAL, &dmc->membaseconfig1); }
-void mem_ctrl_init() +void mem_ctrl_init(int reset) { struct spl_machine_param *param = spl_get_machine_params(); struct mem_timings *mem; @@ -185,7 +186,7 @@ void mem_ctrl_init()
/* If there are any other memory variant, add their init call below */ if (param->mem_type == DDR_MODE_DDR3) { - ret = ddr3_mem_ctrl_init(mem, param->mem_iv_size); + ret = ddr3_mem_ctrl_init(mem, param->mem_iv_size, reset); if (ret) { /* will hang if failed to init memory control */ while (1) diff --git a/board/samsung/smdk5250/dmc_init_ddr3.c b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c similarity index 95% rename from board/samsung/smdk5250/dmc_init_ddr3.c rename to arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c index e050790..de54af8 100644 --- a/board/samsung/smdk5250/dmc_init_ddr3.c +++ b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c @@ -27,7 +27,8 @@ #include <asm/arch/clock.h> #include <asm/arch/cpu.h> #include <asm/arch/dmc.h> -#include "setup.h" +#include "common_setup.h" +#include "exynos5_setup.h" #include "clock_init.h"
#define RDLVL_COMPLETE_TIMEOUT 10000 @@ -40,7 +41,8 @@ static void reset_phy_ctrl(void) writel(DDR3PHY_CTRL_PHY_RESET, &clk->lpddr3phy_ctrl); }
-int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size) +int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size, + int reset) { unsigned int val; struct exynos5_phy_control *phy0_ctrl, *phy1_ctrl; @@ -49,9 +51,10 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size)
phy0_ctrl = (struct exynos5_phy_control *)EXYNOS5_DMC_PHY0_BASE; phy1_ctrl = (struct exynos5_phy_control *)EXYNOS5_DMC_PHY1_BASE; - dmc = (struct exynos5_dmc *)EXYNOS5_DMC_CTRL_BASE; + dmc = (struct exynos5_dmc *)samsung_get_base_dmc0();
- reset_phy_ctrl(); + if (reset) + reset_phy_ctrl();
/* Set Impedance Output Driver */ val = (mem->impedance << CA_CK_DRVR_DS_OFFSET) | @@ -100,14 +103,14 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size)
/* Start DLL locking */ writel(val | (mem->ctrl_start << PHY_CON12_CTRL_START_SHIFT), - &phy0_ctrl->phy_con12); + &phy0_ctrl->phy_con12); writel(val | (mem->ctrl_start << PHY_CON12_CTRL_START_SHIFT), - &phy1_ctrl->phy_con12); + &phy1_ctrl->phy_con12);
update_reset_dll(dmc, DDR_MODE_DDR3);
writel(mem->concontrol | (mem->rd_fetch << CONCONTROL_RD_FETCH_SHIFT), - &dmc->concontrol); + &dmc->concontrol);
/* Memory Channel Inteleaving Size */ writel(mem->iv_size, &dmc->ivcontrol); @@ -119,7 +122,7 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size)
/* Precharge Configuration */ writel(mem->prechconfig_tp_cnt << PRECHCONFIG_TP_CNT_SHIFT, - &dmc->prechconfig); + &dmc->prechconfig);
/* Power Down mode Configuration */ writel(mem->dpwrdn_cyc << PWRDNCONFIG_DPWRDN_CYC_SHIFT | diff --git a/arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c b/arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c new file mode 100644 index 0000000..636d84c --- /dev/null +++ b/arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c @@ -0,0 +1,212 @@ +/* + * Memory setup for board based on EXYNOS4210 + * + * Copyright (C) 2013 Samsung Electronics + * Rajeshwari Shinde rajeshwari.s@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/dmc.h> +#include "common_setup.h" +#include "exynos4_setup.h" + +struct mem_timings mem = { + .direct_cmd_msr = { + DIRECT_CMD1, DIRECT_CMD2, DIRECT_CMD3, DIRECT_CMD4 + }, + .timingref = TIMINGREF_VAL, + .timingrow = TIMINGROW_VAL, + .timingdata = TIMINGDATA_VAL, + .timingpower = TIMINGPOWER_VAL, + .zqcontrol = ZQ_CONTROL_VAL, + .control0 = CONTROL0_VAL, + .control1 = CONTROL1_VAL, + .control2 = CONTROL2_VAL, + .concontrol = CONCONTROL_VAL, + .prechconfig = PRECHCONFIG, + .memcontrol = MEMCONTROL_VAL, + .memconfig0 = MEMCONFIG0_VAL, + .memconfig1 = MEMCONFIG1_VAL, + .dll_resync = FORCE_DLL_RESYNC, + .dll_on = DLL_CONTROL_ON, +}; +static void phy_control_reset(int ctrl_no, struct exynos4_dmc *dmc) +{ + if (ctrl_no) { + writel((mem.control1 | (1 << mem.dll_resync)), + &dmc->phycontrol1); + writel((mem.control1 | (0 << mem.dll_resync)), + &dmc->phycontrol1); + } else { + writel((mem.control0 | (0 << mem.dll_on)), + &dmc->phycontrol0); + writel((mem.control0 | (1 << mem.dll_on)), + &dmc->phycontrol0); + } +} + +static void dmc_config_mrs(struct exynos4_dmc *dmc, int chip) +{ + int i; + unsigned long mask = 0; + + if (chip) + mask = DIRECT_CMD_CHIP1_SHIFT; + + for (i = 0; i < MEM_TIMINGS_MSR_COUNT; i++) { + writel(mem.direct_cmd_msr[i] | mask, + &dmc->directcmd); + } +} + +static void dmc_init(struct exynos4_dmc *dmc) +{ + /* + * DLL Parameter Setting: + * Termination: Enable R/W + * Phase Delay for DQS Cleaning: 180' Shift + */ + writel(mem.control1, &dmc->phycontrol1); + + /* + * ZQ Calibration + * Termination: Disable + * Auto Calibration Start: Enable + */ + writel(mem.zqcontrol, &dmc->phyzqcontrol); + sdelay(0x100000); + + /* + * Update DLL Information: + * Force DLL Resyncronization + */ + phy_control_reset(1, dmc); + phy_control_reset(0, dmc); + + /* Set DLL Parameters */ + writel(mem.control1, &dmc->phycontrol1); + + /* DLL Start */ + writel((mem.control0 | CTRL_START | CTRL_DLL_ON), &dmc->phycontrol0); + + writel(mem.control2, &dmc->phycontrol2); + + /* Set Clock Ratio of Bus clock to Memory Clock */ + writel(mem.concontrol, &dmc->concontrol); + + /* + * Memor Burst length: 8 + * Number of chips: 2 + * Memory Bus width: 32 bit + * Memory Type: DDR3 + * Additional Latancy for PLL: 1 Cycle + */ + writel(mem.memcontrol, &dmc->memcontrol); + + writel(mem.memconfig0, &dmc->memconfig0); + writel(mem.memconfig1, &dmc->memconfig1); + + /* Config Precharge Policy */ + writel(mem.prechconfig, &dmc->prechconfig); + /* + * TimingAref, TimingRow, TimingData, TimingPower Setting: + * Values as per Memory AC Parameters + */ + writel(mem.timingref, &dmc->timingref); + writel(mem.timingrow, &dmc->timingrow); + writel(mem.timingdata, &dmc->timingdata); + writel(mem.timingpower, &dmc->timingpower); + + /* Chip0: NOP Command: Assert and Hold CKE to high level */ + writel(DIRECT_CMD_NOP, &dmc->directcmd); + sdelay(0x100000); + + /* Chip0: EMRS2, EMRS3, EMRS, MRS Commands Using Direct Command */ + dmc_config_mrs(dmc, 0); + sdelay(0x100000); + + /* Chip0: ZQINIT */ + writel(DIRECT_CMD_ZQ, &dmc->directcmd); + sdelay(0x100000); + + writel((DIRECT_CMD_NOP | DIRECT_CMD_CHIP1_SHIFT), &dmc->directcmd); + sdelay(0x100000); + + /* Chip1: EMRS2, EMRS3, EMRS, MRS Commands Using Direct Command */ + dmc_config_mrs(dmc, 1); + sdelay(0x100000); + + /* Chip1: ZQINIT */ + writel((DIRECT_CMD_ZQ | DIRECT_CMD_CHIP1_SHIFT), &dmc->directcmd); + sdelay(0x100000); + + phy_control_reset(1, dmc); + sdelay(0x100000); + + /* turn on DREX0, DREX1 */ + writel((mem.concontrol | AREF_EN), &dmc->concontrol); +} + +void mem_ctrl_init(int reset) +{ + struct exynos4_dmc *dmc; + + /* + * Async bridge configuration at CPU_core: + * 1: half_sync + * 0: full_sync + */ + writel(1, ASYNC_CONFIG); +#ifdef CONFIG_ORIGEN + /* Interleave: 2Bit, Interleave_bit1: 0x15, Interleave_bit0: 0x7 */ + writel(APB_SFR_INTERLEAVE_CONF_VAL, EXYNOS4_MIU_BASE + + APB_SFR_INTERLEAVE_CONF_OFFSET); + /* Update MIU Configuration */ + writel(APB_SFR_ARBRITATION_CONF_VAL, EXYNOS4_MIU_BASE + + APB_SFR_ARBRITATION_CONF_OFFSET); +#else + writel(APB_SFR_INTERLEAVE_CONF_VAL, EXYNOS4_MIU_BASE + + APB_SFR_INTERLEAVE_CONF_OFFSET); + writel(INTERLEAVE_ADDR_MAP_START_ADDR, EXYNOS4_MIU_BASE + + ABP_SFR_INTERLEAVE_ADDRMAP_START_OFFSET); + writel(INTERLEAVE_ADDR_MAP_END_ADDR, EXYNOS4_MIU_BASE + + ABP_SFR_INTERLEAVE_ADDRMAP_END_OFFSET); + writel(INTERLEAVE_ADDR_MAP_EN, EXYNOS4_MIU_BASE + + ABP_SFR_SLV_ADDRMAP_CONF_OFFSET); +#ifdef CONFIG_MIU_LINEAR + writel(SLAVE0_SINGLE_ADDR_MAP_START_ADDR, EXYNOS4_MIU_BASE + + ABP_SFR_SLV0_SINGLE_ADDRMAP_START_OFFSET); + writel(SLAVE0_SINGLE_ADDR_MAP_END_ADDR, EXYNOS4_MIU_BASE + + ABP_SFR_SLV0_SINGLE_ADDRMAP_END_OFFSET); + writel(SLAVE1_SINGLE_ADDR_MAP_START_ADDR, EXYNOS4_MIU_BASE + + ABP_SFR_SLV1_SINGLE_ADDRMAP_START_OFFSET); + writel(SLAVE1_SINGLE_ADDR_MAP_END_ADDR, EXYNOS4_MIU_BASE + + ABP_SFR_SLV1_SINGLE_ADDRMAP_END_OFFSET); + writel(APB_SFR_SLV_ADDR_MAP_CONF_VAL, EXYNOS4_MIU_BASE + + ABP_SFR_SLV_ADDRMAP_CONF_OFFSET); +#endif +#endif + /* DREX0 */ + dmc = (struct exynos4_dmc *)samsung_get_base_dmc0(); + dmc_init(dmc); + dmc = (struct exynos4_dmc *)samsung_get_base_dmc1(); + dmc_init(dmc); +} diff --git a/board/samsung/origen/origen_setup.h b/arch/arm/cpu/armv7/exynos/exynos4_setup.h similarity index 65% rename from board/samsung/origen/origen_setup.h rename to arch/arm/cpu/armv7/exynos/exynos4_setup.h index 926a4cc..6d25058 100644 --- a/board/samsung/origen/origen_setup.h +++ b/arch/arm/cpu/armv7/exynos/exynos4_setup.h @@ -1,5 +1,5 @@ /* - * Machine Specific Values for ORIGEN board based on S5PV310 + * Machine Specific Values for EXYNOS4012 based board * * Copyright (C) 2011 Samsung Electronics * @@ -29,98 +29,22 @@ #include <version.h> #include <asm/arch/cpu.h>
-/* Offsets of clock registers (sources and dividers) */ -#define CLK_SRC_CPU_OFFSET 0x14200 -#define CLK_DIV_CPU0_OFFSET 0x14500 -#define CLK_DIV_CPU1_OFFSET 0x14504 - -#define CLK_SRC_DMC_OFFSET 0x10200 -#define CLK_DIV_DMC0_OFFSET 0x10500 -#define CLK_DIV_DMC1_OFFSET 0x10504 - -#define CLK_SRC_TOP0_OFFSET 0xC210 -#define CLK_SRC_TOP1_OFFSET 0xC214 -#define CLK_DIV_TOP_OFFSET 0xC510 - -#define CLK_SRC_LEFTBUS_OFFSET 0x4200 -#define CLK_DIV_LEFTBUS_OFFSET 0x4500 - -#define CLK_SRC_RIGHTBUS_OFFSET 0x8200 -#define CLK_DIV_RIGHTBUS_OFFSET 0x8500 - -#define CLK_SRC_FSYS_OFFSET 0xC240 -#define CLK_DIV_FSYS1_OFFSET 0xC544 -#define CLK_DIV_FSYS2_OFFSET 0xC548 -#define CLK_DIV_FSYS3_OFFSET 0xC54C - -#define CLK_SRC_CAM_OFFSET 0xC220 -#define CLK_SRC_TV_OFFSET 0xC224 -#define CLK_SRC_MFC_OFFSET 0xC228 -#define CLK_SRC_G3D_OFFSET 0xC22C -#define CLK_SRC_LCD0_OFFSET 0xC234 -#define CLK_SRC_PERIL0_OFFSET 0xC250 - -#define CLK_DIV_CAM_OFFSET 0xC520 -#define CLK_DIV_TV_OFFSET 0xC524 -#define CLK_DIV_MFC_OFFSET 0xC528 -#define CLK_DIV_G3D_OFFSET 0xC52C -#define CLK_DIV_LCD0_OFFSET 0xC534 -#define CLK_DIV_PERIL0_OFFSET 0xC550 - -#define CLK_SRC_LCD0_OFFSET 0xC234 - -#define APLL_LOCK_OFFSET 0x14000 -#define MPLL_LOCK_OFFSET 0x14008 -#define APLL_CON0_OFFSET 0x14100 -#define APLL_CON1_OFFSET 0x14104 -#define MPLL_CON0_OFFSET 0x14108 -#define MPLL_CON1_OFFSET 0x1410C - -#define EPLL_LOCK_OFFSET 0xC010 -#define VPLL_LOCK_OFFSET 0xC020 -#define EPLL_CON0_OFFSET 0xC110 -#define EPLL_CON1_OFFSET 0xC114 -#define VPLL_CON0_OFFSET 0xC120 -#define VPLL_CON1_OFFSET 0xC124 - -/* DMC: DRAM Controllor Register offsets */ -#define DMC_CONCONTROL 0x00 -#define DMC_MEMCONTROL 0x04 -#define DMC_MEMCONFIG0 0x08 -#define DMC_MEMCONFIG1 0x0C -#define DMC_DIRECTCMD 0x10 -#define DMC_PRECHCONFIG 0x14 -#define DMC_PHYCONTROL0 0x18 -#define DMC_PHYCONTROL1 0x1C -#define DMC_PHYCONTROL2 0x20 -#define DMC_TIMINGAREF 0x30 -#define DMC_TIMINGROW 0x34 -#define DMC_TIMINGDATA 0x38 -#define DMC_TIMINGPOWER 0x3C -#define DMC_PHYZQCONTROL 0x44 +#ifdef CONFIG_CLK_800_330_165 +#define DRAM_CLK_330 +#endif +#ifdef CONFIG_CLK_1000_200_200 +#define DRAM_CLK_200 +#endif +#ifdef CONFIG_CLK_1000_330_165 +#define DRAM_CLK_330 +#endif +#ifdef CONFIG_CLK_1000_400_200 +#define DRAM_CLK_400 +#endif
/* Bus Configuration Register Address */ #define ASYNC_CONFIG 0x10010350
-/* MIU Config Register Offsets*/ -#define APB_SFR_INTERLEAVE_CONF_OFFSET 0x400 -#define APB_SFR_ARBRITATION_CONF_OFFSET 0xC00 - -/* Offset for inform registers */ -#define INFORM0_OFFSET 0x800 -#define INFORM1_OFFSET 0x804 - -/* GPIO Offsets for UART: GPIO Contol Register */ -#define EXYNOS4_GPIO_A0_CON_OFFSET 0x00 -#define EXYNOS4_GPIO_A1_CON_OFFSET 0x20 - -/* UART Register offsets */ -#define ULCON_OFFSET 0x00 -#define UCON_OFFSET 0x04 -#define UFCON_OFFSET 0x08 -#define UBRDIV_OFFSET 0x28 -#define UFRACVAL_OFFSET 0x2C - /* CLK_SRC_CPU */ #define MUX_HPM_SEL_MOUTAPLL 0x0 #define MUX_HPM_SEL_SCLKMPLL 0x1 @@ -485,123 +409,186 @@ | (VPLL_MRR << 24) \ | (VPLL_MFR << 16) \ | (VPLL_K << 0)) -/* - * UART GPIO_A0/GPIO_A1 Control Register Value - * 0x2: UART Function - */ -#define EXYNOS4_GPIO_A0_CON_VAL 0x22222222 -#define EXYNOS4_GPIO_A1_CON_VAL 0x222222 - -/* ULCON: UART Line Control Value 8N1 */ -#define WORD_LEN_5_BIT 0x00 -#define WORD_LEN_6_BIT 0x01 -#define WORD_LEN_7_BIT 0x02 -#define WORD_LEN_8_BIT 0x03 - -#define STOP_BIT_1 0x00 -#define STOP_BIT_2 0x01 - -#define NO_PARITY 0x00 -#define ODD_PARITY 0x4 -#define EVEN_PARITY 0x5 -#define FORCED_PARITY_CHECK_AS_1 0x6 -#define FORCED_PARITY_CHECK_AS_0 0x7 - -#define INFRAMODE_NORMAL 0x00 -#define INFRAMODE_INFRARED 0x01 - -#define ULCON_VAL ((INFRAMODE_NORMAL << 6) \ - | (NO_PARITY << 3) \ - | (STOP_BIT_1 << 2) \ - | (WORD_LEN_8_BIT << 0))
-/* - * UCON: UART Control Value - * Tx_interrupt Type: Level - * Rx_interrupt Type: Level - * Rx Timeout Enabled: Yes - * Rx-Error Atatus_Int Enable: Yes - * Loop_Back: No - * Break Signal: No - * Transmit mode : Interrupt request/polling - * Receive mode : Interrupt request/polling - */ -#define TX_PULSE_INTERRUPT 0 -#define TX_LEVEL_INTERRUPT 1 -#define RX_PULSE_INTERRUPT 0 -#define RX_LEVEL_INTERRUPT 1 - -#define RX_TIME_OUT ENABLE -#define RX_ERROR_STATE_INT_ENB ENABLE -#define LOOP_BACK DISABLE -#define BREAK_SIGNAL DISABLE - -#define TX_MODE_DISABLED 0X00 -#define TX_MODE_IRQ_OR_POLL 0X01 -#define TX_MODE_DMA 0X02 - -#define RX_MODE_DISABLED 0X00 -#define RX_MODE_IRQ_OR_POLL 0X01 -#define RX_MODE_DMA 0X02 - -#define UCON_VAL ((TX_LEVEL_INTERRUPT << 9) \ - | (RX_LEVEL_INTERRUPT << 8) \ - | (RX_TIME_OUT << 7) \ - | (RX_ERROR_STATE_INT_ENB << 6) \ - | (LOOP_BACK << 5) \ - | (BREAK_SIGNAL << 4) \ - | (TX_MODE_IRQ_OR_POLL << 2) \ - | (RX_MODE_IRQ_OR_POLL << 0)) +/* DMC */ +#define DIRECT_CMD_NOP 0x07000000 +#define DIRECT_CMD_ZQ 0x0a000000 +#define DIRECT_CMD_CHIP1_SHIFT (1 << 20) +#define MEM_TIMINGS_MSR_COUNT 4 +#define CTRL_START (1 << 0) +#define CTRL_DLL_ON (1 << 1) +#define AREF_EN (1 << 5) +#define DRV_TYPE (1 << 6) + +struct mem_timings { + unsigned direct_cmd_msr[MEM_TIMINGS_MSR_COUNT]; + unsigned timingref; + unsigned timingrow; + unsigned timingdata; + unsigned timingpower; + unsigned zqcontrol; + unsigned control0; + unsigned control1; + unsigned control2; + unsigned concontrol; + unsigned prechconfig; + unsigned memcontrol; + unsigned memconfig0; + unsigned memconfig1; + unsigned dll_resync; + unsigned dll_on; +}; + +/* MIU */ +/* MIU Config Register Offsets*/ +#define APB_SFR_INTERLEAVE_CONF_OFFSET 0x400 +#define APB_SFR_ARBRITATION_CONF_OFFSET 0xC00 +#define ABP_SFR_SLV_ADDRMAP_CONF_OFFSET 0x800 +#define ABP_SFR_INTERLEAVE_ADDRMAP_START_OFFSET 0x808 +#define ABP_SFR_INTERLEAVE_ADDRMAP_END_OFFSET 0x810 +#define ABP_SFR_SLV0_SINGLE_ADDRMAP_START_OFFSET 0x818 +#define ABP_SFR_SLV0_SINGLE_ADDRMAP_END_OFFSET 0x820 +#define ABP_SFR_SLV1_SINGLE_ADDRMAP_START_OFFSET 0x828 +#define ABP_SFR_SLV1_SINGLE_ADDRMAP_END_OFFSET 0x830 + +#ifdef CONFIG_ORIGEN +/* Interleave: 2Bit, Interleave_bit1: 0x15, Interleave_bit0: 0x7 */ +#define APB_SFR_INTERLEAVE_CONF_VAL 0x20001507 +#define APB_SFR_ARBRITATION_CONF_VAL 0x00000001 +#endif
-/* - * UFCON: UART FIFO Control Value - * Tx FIFO Trigger LEVEL: 2 Bytes (001) - * Rx FIFO Trigger LEVEL: 2 Bytes (001) - * Tx Fifo Reset: No - * Rx Fifo Reset: No - * FIFO Enable: Yes - */ -#define TX_FIFO_TRIGGER_LEVEL_0_BYTES 0x00 -#define TX_FIFO_TRIGGER_LEVEL_2_BYTES 0x1 -#define TX_FIFO_TRIGGER_LEVEL_4_BYTES 0x2 -#define TX_FIFO_TRIGGER_LEVEL_6_BYTES 0x3 -#define TX_FIFO_TRIGGER_LEVEL_8_BYTES 0x4 -#define TX_FIFO_TRIGGER_LEVEL_10_BYTES 0x5 -#define TX_FIFO_TRIGGER_LEVEL_12_BYTES 0x6 -#define TX_FIFO_TRIGGER_LEVEL_14_BYTES 0x7 - -#define RX_FIFO_TRIGGER_LEVEL_2_BYTES 0x0 -#define RX_FIFO_TRIGGER_LEVEL_4_BYTES 0x1 -#define RX_FIFO_TRIGGER_LEVEL_6_BYTES 0x2 -#define RX_FIFO_TRIGGER_LEVEL_8_BYTES 0x3 -#define RX_FIFO_TRIGGER_LEVEL_10_BYTES 0x4 -#define RX_FIFO_TRIGGER_LEVEL_12_BYTES 0x5 -#define RX_FIFO_TRIGGER_LEVEL_14_BYTES 0x6 -#define RX_FIFO_TRIGGER_LEVEL_16_BYTES 0x7 - -#define TX_FIFO_TRIGGER_LEVEL TX_FIFO_TRIGGER_LEVEL_2_BYTES -#define RX_FIFO_TRIGGER_LEVEL RX_FIFO_TRIGGER_LEVEL_4_BYTES -#define TX_FIFO_RESET DISABLE -#define RX_FIFO_RESET DISABLE -#define FIFO_ENABLE ENABLE -#define UFCON_VAL ((TX_FIFO_TRIGGER_LEVEL << 8) \ - | (RX_FIFO_TRIGGER_LEVEL << 4) \ - | (TX_FIFO_RESET << 2) \ - | (RX_FIFO_RESET << 1) \ - | (FIFO_ENABLE << 0)) -/* - * Baud Rate Division Value - * 115200 BAUD: - * UBRDIV_VAL = SCLK_UART/((115200 * 16) - 1) - * UBRDIV_VAL = (800 MHz)/((115200 * 16) - 1) - */ -#define UBRDIV_VAL 0x35 +#define INTERLEAVE_ADDR_MAP_START_ADDR 0x40000000 +#define INTERLEAVE_ADDR_MAP_END_ADDR 0xbfffffff +#define INTERLEAVE_ADDR_MAP_EN 0x00000001
-/* - * Fractional Part of Baud Rate Divisor: - * 115200 BAUD: - * UBRFRACVAL = ((((SCLK_UART*10/(115200*16) -10))%10)*16/10) - * UBRFRACVAL = ((((800MHz*10/(115200*16) -10))%10)*16/10) - */ -#define UFRACVAL_VAL 0x4 +#ifdef CONFIG_MIU_1BIT_INTERLEAVED +/* Interleave_bit0: 0xC*/ +#define APB_SFR_INTERLEAVE_CONF_VAL 0x0000000c +#endif +#ifdef CONFIG_MIU_2BIT_INTERLEAVED +/* Interleave: 2Bit, Interleave_bit1: 0x15, Interleave_bit0: 0xc */ +#define APB_SFR_INTERLEAVE_CONF_VAL 0x2000150c +#endif +#define SLAVE0_SINGLE_ADDR_MAP_START_ADDR 0x40000000 +#define SLAVE0_SINGLE_ADDR_MAP_END_ADDR 0x7fffffff +#define SLAVE1_SINGLE_ADDR_MAP_START_ADDR 0x80000000 +#define SLAVE1_SINGLE_ADDR_MAP_END_ADDR 0xbfffffff +/* Enable SME0 and SME1*/ +#define APB_SFR_SLV_ADDR_MAP_CONF_VAL 0x00000006 + +#define FORCE_DLL_RESYNC 3 +#define DLL_CONTROL_ON 1 + +#define DIRECT_CMD1 0x00020000 +#define DIRECT_CMD2 0x00030000 +#define DIRECT_CMD3 0x00010002 +#define DIRECT_CMD4 0x00000328 + +#define CTRL_ZQ_MODE_NOTERM (0x1 << 0) +#define CTRL_ZQ_START (0x1 << 1) +#define CTRL_ZQ_DIV (0 << 4) +#define CTRL_ZQ_MODE_DDS (0x7 << 8) +#define CTRL_ZQ_MODE_TERM (0x2 << 11) +#define CTRL_ZQ_FORCE_IMPN (0x5 << 14) +#define CTRL_ZQ_FORCE_IMPP (0x6 << 17) +#define CTRL_DCC (0xE38 << 20) +#define ZQ_CONTROL_VAL (CTRL_ZQ_MODE_NOTERM | CTRL_ZQ_START\ + | CTRL_ZQ_DIV | CTRL_ZQ_MODE_DDS\ + | CTRL_ZQ_MODE_TERM | CTRL_ZQ_FORCE_IMPN\ + | CTRL_ZQ_FORCE_IMPP | CTRL_DCC) + +#define ASYNC (0 << 0) +#define CLK_RATIO (1 << 1) +#define DIV_PIPE (1 << 3) +#define AWR_ON (1 << 4) +#define AREF_DISABLE (0 << 5) +#define DRV_TYPE_DISABLE (0 << 6) +#define CHIP0_NOT_EMPTY (0 << 8) +#define CHIP1_NOT_EMPTY (0 << 9) +#define DQ_SWAP_DISABLE (0 << 10) +#define QOS_FAST_DISABLE (0 << 11) +#define RD_FETCH (0x3 << 12) +#define TIMEOUT_LEVEL0 (0xFFF << 16) +#define CONCONTROL_VAL (ASYNC | CLK_RATIO | DIV_PIPE | AWR_ON\ + | AREF_DISABLE | DRV_TYPE_DISABLE\ + | CHIP0_NOT_EMPTY | CHIP1_NOT_EMPTY\ + | DQ_SWAP_DISABLE | QOS_FAST_DISABLE\ + | RD_FETCH | TIMEOUT_LEVEL0) + +#define CLK_STOP_DISABLE (0 << 1) +#define DPWRDN_DISABLE (0 << 2) +#define DPWRDN_TYPE (0 << 3) +#define TP_DISABLE (0 << 4) +#define DSREF_DIABLE (0 << 5) +#define ADD_LAT_PALL (1 << 6) +#define MEM_TYPE_DDR3 (0x6 << 8) +#define MEM_WIDTH_32 (0x2 << 12) +#define NUM_CHIP_2 (1 << 16) +#define BL_8 (0x3 << 20) +#define MEMCONTROL_VAL (CLK_STOP_DISABLE | DPWRDN_DISABLE\ + | DPWRDN_TYPE | TP_DISABLE | DSREF_DIABLE\ + | ADD_LAT_PALL | MEM_TYPE_DDR3 | MEM_WIDTH_32\ + | NUM_CHIP_2 | BL_8) + + +#define CHIP_BANK_8 (0x3 << 0) +#define CHIP_ROW_14 (0x2 << 4) +#define CHIP_COL_10 (0x3 << 8) +#define CHIP_MAP_INTERLEAVED (1 << 12) +#define CHIP_MASK (0xe0 << 16) +#ifdef CONFIG_MIU_LINEAR +#define CHIP0_BASE (0x40 << 24) +#define CHIP1_BASE (0x60 << 24) +#else +#define CHIP0_BASE (0x20 << 24) +#define CHIP1_BASE (0x40 << 24) +#endif +#define MEMCONFIG0_VAL (CHIP_BANK_8 | CHIP_ROW_14 | CHIP_COL_10\ + | CHIP_MAP_INTERLEAVED | CHIP_MASK | CHIP0_BASE) +#define MEMCONFIG1_VAL (CHIP_BANK_8 | CHIP_ROW_14 | CHIP_COL_10\ + | CHIP_MAP_INTERLEAVED | CHIP_MASK | CHIP1_BASE) + +#define TP_CNT (0xff << 24) +#define PRECHCONFIG TP_CNT + +#define CTRL_OFF (0 << 0) +#define CTRL_DLL_OFF (0 << 1) +#define CTRL_HALF (0 << 2) +#define CTRL_DFDQS (1 << 3) +#define DQS_DELAY (0 << 4) +#define CTRL_START_POINT (0x10 << 8) +#define CTRL_INC (0x10 << 16) +#define CTRL_FORCE (0x71 << 24) +#define CONTROL0_VAL (CTRL_OFF | CTRL_DLL_OFF | CTRL_HALF\ + | CTRL_DFDQS | DQS_DELAY | CTRL_START_POINT\ + | CTRL_INC | CTRL_FORCE) + +#define CTRL_SHIFTC (0x6 << 0) +#define CTRL_REF (8 << 4) +#define CTRL_SHGATE (1 << 29) +#define TERM_READ_EN (1 << 30) +#define TERM_WRITE_EN (1 << 31) +#define CONTROL1_VAL (CTRL_SHIFTC | CTRL_REF | CTRL_SHGATE\ + | TERM_READ_EN | TERM_WRITE_EN) + +#define CONTROL2_VAL 0x00000000 + +#ifdef CONFIG_ORIGEN +#define TIMINGREF_VAL 0x000000BB +#define TIMINGROW_VAL 0x4046654f +#define TIMINGDATA_VAL 0x46400506 +#define TIMINGPOWER_VAL 0x52000A3C +#else +#define TIMINGREF_VAL 0x000000BC +#ifdef DRAM_CLK_330 +#define TIMINGROW_VAL 0x3545548d +#define TIMINGDATA_VAL 0x45430506 +#define TIMINGPOWER_VAL 0x4439033c +#endif +#ifdef DRAM_CLK_400 +#define TIMINGROW_VAL 0x45430506 +#define TIMINGDATA_VAL 0x56500506 +#define TIMINGPOWER_VAL 0x5444033d +#endif +#endif #endif diff --git a/board/samsung/smdk5250/setup.h b/arch/arm/cpu/armv7/exynos/exynos5_setup.h similarity index 96% rename from board/samsung/smdk5250/setup.h rename to arch/arm/cpu/armv7/exynos/exynos5_setup.h index eb91d13..8f36c16 100644 --- a/board/samsung/smdk5250/setup.h +++ b/arch/arm/cpu/armv7/exynos/exynos5_setup.h @@ -93,17 +93,17 @@ #define DMC_MEMCONTROL_MRR_BYTE_31_24 (3 << 25)
/* MEMCONFIG0 register bit fields */ -#define DMC_MEMCONFIGx_CHIP_MAP_INTERLEAVED (1 << 12) -#define DMC_MEMCONFIGx_CHIP_COL_10 (3 << 8) -#define DMC_MEMCONFIGx_CHIP_ROW_14 (2 << 4) -#define DMC_MEMCONFIGx_CHIP_ROW_15 (3 << 4) -#define DMC_MEMCONFIGx_CHIP_BANK_8 (3 << 0) - -#define DMC_MEMBASECONFIGx_CHIP_BASE(x) (x << 16) -#define DMC_MEMBASECONFIGx_CHIP_MASK(x) (x << 0) +#define DMC_MEMCONFIGX_CHIP_MAP_INTERLEAVED (1 << 12) +#define DMC_MEMCONFIGX_CHIP_COL_10 (3 << 8) +#define DMC_MEMCONFIGX_CHIP_ROW_14 (2 << 4) +#define DMC_MEMCONFIGX_CHIP_ROW_15 (3 << 4) +#define DMC_MEMCONFIGX_CHIP_BANK_8 (3 << 0) + +#define DMC_MEMBASECONFIGX_CHIP_BASE(x) (x << 16) +#define DMC_MEMBASECONFIGX_CHIP_MASK(x) (x << 0) #define DMC_MEMBASECONFIG_VAL(x) ( \ - DMC_MEMBASECONFIGx_CHIP_BASE(x) | \ - DMC_MEMBASECONFIGx_CHIP_MASK(0x780) \ + DMC_MEMBASECONFIGX_CHIP_BASE(x) | \ + DMC_MEMBASECONFIGX_CHIP_MASK(0x780) \ )
#define DMC_MEMBASECONFIG0_VAL DMC_MEMBASECONFIG_VAL(0x40) @@ -513,9 +513,11 @@ enum { * which the DMC uses to decide how to split a memory * chunk into smaller chunks to support concurrent * accesses; may vary across boards. + * @param reset Reset DDR PHY during initialization. * @return 0 if ok, SETUP_ERR_... if there is a problem */ -int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size); +int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size, + int reset);
/* * Configure ZQ I/O interface @@ -562,8 +564,4 @@ void dmc_config_memory(struct mem_timings *mem, struct exynos5_dmc *dmc); * @param ddr_mode Type of DDR memory */ void update_reset_dll(struct exynos5_dmc *, enum ddr_mode); - -void sdelay(unsigned long); -void mem_ctrl_init(void); -void system_clock_init(void); #endif diff --git a/arch/arm/cpu/armv7/exynos/lowlevel_init.c b/arch/arm/cpu/armv7/exynos/lowlevel_init.c new file mode 100644 index 0000000..11fe5b8 --- /dev/null +++ b/arch/arm/cpu/armv7/exynos/lowlevel_init.c @@ -0,0 +1,73 @@ +/* + * Lowlevel setup for EXYNOS5 based board + * + * Copyright (C) 2013 Samsung Electronics + * Rajeshwari Shinde rajeshwari.s@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <config.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dmc.h> +#include <asm/arch/power.h> +#include <asm/arch/tzpc.h> +#include <asm/arch/periph.h> +#include <asm/arch/pinmux.h> +#include "common_setup.h" + +/* These are the things we can do during low-level init */ +enum { + DO_WAKEUP = 1 << 0, + DO_CLOCKS = 1 << 1, + DO_MEM_RESET = 1 << 2, + DO_UART = 1 << 3, +}; + +int do_lowlevel_init(void) +{ + uint32_t reset_status; + int actions = 0; + + arch_cpu_init(); + + reset_status = get_reset_status(); + + switch (reset_status) { + case S5P_CHECK_SLEEP: + actions = DO_CLOCKS | DO_WAKEUP; + break; + case S5P_CHECK_DIDLE: + case S5P_CHECK_LPA: + actions = DO_WAKEUP; + break; + default: + /* This is a normal boot (not a wake from sleep) */ + actions = DO_CLOCKS | DO_MEM_RESET; + } + + if (actions & DO_CLOCKS) { + system_clock_init(); + mem_ctrl_init(actions & DO_MEM_RESET); + tzpc_init(); + } + + return actions & DO_WAKEUP; +} diff --git a/board/samsung/smdk5250/spl_boot.c b/arch/arm/cpu/armv7/exynos/spl_boot.c similarity index 74% rename from board/samsung/smdk5250/spl_boot.c rename to arch/arm/cpu/armv7/exynos/spl_boot.c index 83275f1..6e8dd3b 100644 --- a/board/samsung/smdk5250/spl_boot.c +++ b/arch/arm/cpu/armv7/exynos/spl_boot.c @@ -23,13 +23,18 @@ #include<common.h> #include<config.h>
-#include <asm/arch-exynos/dmc.h> #include <asm/arch/clock.h> #include <asm/arch/clk.h> +#include <asm/arch/dmc.h> +#include <asm/arch/power.h> #include <asm/arch/spl.h>
+#include "common_setup.h" #include "clock_init.h"
+DECLARE_GLOBAL_DATA_PTR; +#define OM_STAT (0x1f << 1) + /* Index into irom ptr table */ enum index { MMC_INDEX, @@ -54,6 +59,7 @@ void *get_irom_func(int index) return (void *)*(u32 *)irom_ptr_table[index]; }
+#ifdef CONFIG_USB_BOOTING /* * Set/clear program flow prediction and return the previous state. */ @@ -67,6 +73,7 @@ static int config_branch_prediction(int set_cr_z)
return cr & CR_Z; } +#endif
/* * Copy U-boot from mmc to RAM: @@ -75,35 +82,42 @@ static int config_branch_prediction(int set_cr_z) */ void copy_uboot_to_ram(void) { - int is_cr_z_set; - unsigned int sec_boot_check; enum boot_mode bootmode = BOOT_MODE_OM;
- u32 (*spi_copy)(u32 offset, u32 nblock, u32 dst); - u32 (*copy_bl2)(u32 offset, u32 nblock, u32 dst); + u32 (*copy_bl2)(u32 offset, u32 nblock, u32 dst) = NULL; + u32 offset = 0, size = 0; +#ifdef CONFIG_SUPPORT_EMMC_BOOT u32 (*copy_bl2_from_emmc)(u32 nblock, u32 dst); void (*end_bootop_from_emmc)(void); +#endif +#ifdef CONFIG_USB_BOOTING u32 (*usb_copy)(void); + int is_cr_z_set; + unsigned int sec_boot_check;
/* Read iRAM location to check for secondary USB boot mode */ sec_boot_check = readl(EXYNOS_IRAM_SECONDARY_BASE); if (sec_boot_check == EXYNOS_USB_SECONDARY_BOOT) bootmode = BOOT_MODE_USB; +#endif
if (bootmode == BOOT_MODE_OM) - bootmode = readl(EXYNOS5_POWER_BASE) & OM_STAT; + bootmode = readl(samsung_get_base_power()) & OM_STAT;
switch (bootmode) { +#ifdef CONFIG_SPI_BOOTING case BOOT_MODE_SERIAL: - spi_copy = get_irom_func(SPI_INDEX); - spi_copy(SPI_FLASH_UBOOT_POS, CONFIG_BL2_SIZE, - CONFIG_SYS_TEXT_BASE); + offset = SPI_FLASH_UBOOT_POS; + size = CONFIG_BL2_SIZE; + copy_bl2 = get_irom_func(SPI_INDEX); break; +#endif case BOOT_MODE_MMC: + offset = BL2_START_OFFSET; + size = BL2_SIZE_BLOC_COUNT; copy_bl2 = get_irom_func(MMC_INDEX); - copy_bl2(BL2_START_OFFSET, BL2_SIZE_BLOC_COUNT, - CONFIG_SYS_TEXT_BASE); break; +#ifdef CONFIG_SUPPORT_EMMC_BOOT case BOOT_MODE_EMMC: /* Set the FSYS1 clock divisor value for EMMC boot */ emmc_boot_clk_div_set(); @@ -114,6 +128,8 @@ void copy_uboot_to_ram(void) copy_bl2_from_emmc(BL2_SIZE_BLOC_COUNT, CONFIG_SYS_TEXT_BASE); end_bootop_from_emmc(); break; +#endif +#ifdef CONFIG_USB_BOOTING case BOOT_MODE_USB: /* * iROM needs program flow prediction to be disabled @@ -124,14 +140,50 @@ void copy_uboot_to_ram(void) usb_copy(); config_branch_prediction(is_cr_z_set); break; +#endif default: break; } + + if (copy_bl2) + copy_bl2(offset, size, CONFIG_SYS_TEXT_BASE); +} + +void memzero(void *s, size_t n) +{ + char *ptr = s; + size_t i; + + for (i = 0; i < n; i++) + *ptr++ = '\0'; +} + +/** + * Set up the U-Boot global_data pointer + * + * This sets the address of the global data, and sets up basic values. + * + * @param gdp Value to give to gd + */ +static void setup_global_data(gd_t *gdp) +{ + gd = gdp; + memzero((void *)gd, sizeof(gd_t)); + gd->flags |= GD_FLG_RELOC; + gd->baudrate = CONFIG_BAUDRATE; + gd->have_console = 1; }
void board_init_f(unsigned long bootflag) { + __aligned(8) gd_t local_gd; __attribute__((noreturn)) void (*uboot)(void); + + setup_global_data(&local_gd); + + if (do_lowlevel_init()) + power_exit_wakeup(); + copy_uboot_to_ram();
/* Jump to U-Boot image */ diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index 36b98c8..75dbe26 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -115,7 +115,7 @@ #define EXYNOS5_DMC_PHY0_BASE 0x10C00000 #define EXYNOS5_DMC_PHY1_BASE 0x10C10000 #define EXYNOS5_GPIO_PART3_BASE 0x10D10000 -#define EXYNOS5_DMC_CTRL_BASE 0x10DD0000 +#define EXYNOS5_DMC0_BASE 0x10DD0000 #define EXYNOS5_GPIO_PART1_BASE 0x11400000 #define EXYNOS5_MIPI_DSIM_BASE 0x11D00000 #define EXYNOS5_USB_HOST_EHCI_BASE 0x12110000 @@ -135,6 +135,7 @@
#define EXYNOS5_ADC_BASE DEVICE_NOT_AVAILABLE #define EXYNOS5_MODEM_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS5_DMC1_BASE DEVICE_NOT_AVAILABLE
#ifndef __ASSEMBLY__ #include <asm/io.h> @@ -237,6 +238,8 @@ SAMSUNG_BASE(power, POWER_BASE) SAMSUNG_BASE(spi, SPI_BASE) SAMSUNG_BASE(spi_isp, SPI_ISP_BASE) SAMSUNG_BASE(tzpc, TZPC_BASE) +SAMSUNG_BASE(dmc0, DMC0_BASE) +SAMSUNG_BASE(dmc1, DMC1_BASE) #endif
#endif /* _EXYNOS4_CPU_H */ diff --git a/board/samsung/origen/Makefile b/board/samsung/origen/Makefile index 3a885a5..63c8b46 100644 --- a/board/samsung/origen/Makefile +++ b/board/samsung/origen/Makefile @@ -24,19 +24,12 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
-SOBJS := mem_setup.o -SOBJS += lowlevel_init.o - ifndef CONFIG_SPL_BUILD COBJS += origen.o endif
-ifdef CONFIG_SPL_BUILD -COBJS += mmc_boot.o -endif - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS))
ALL +=$(obj).depend $(LIB)
diff --git a/board/samsung/origen/lowlevel_init.S b/board/samsung/origen/lowlevel_init.S deleted file mode 100644 index be9d418..0000000 --- a/board/samsung/origen/lowlevel_init.S +++ /dev/null @@ -1,357 +0,0 @@ -/* - * Lowlevel setup for ORIGEN board based on EXYNOS4210 - * - * Copyright (C) 2011 Samsung Electronics - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <version.h> -#include <asm/arch/cpu.h> -#include "origen_setup.h" -/* - * Register usages: - * - * r5 has zero always - * r7 has GPIO part1 base 0x11400000 - * r6 has GPIO part2 base 0x11000000 - */ - -_TEXT_BASE: - .word CONFIG_SYS_TEXT_BASE - - .globl lowlevel_init -lowlevel_init: - push {lr} - - /* r5 has always zero */ - mov r5, #0 - ldr r7, =EXYNOS4_GPIO_PART1_BASE - ldr r6, =EXYNOS4_GPIO_PART2_BASE - - /* check reset status */ - ldr r0, =(EXYNOS4_POWER_BASE + INFORM1_OFFSET) - ldr r1, [r0] - - /* AFTR wakeup reset */ - ldr r2, =S5P_CHECK_DIDLE - cmp r1, r2 - beq exit_wakeup - - /* LPA wakeup reset */ - ldr r2, =S5P_CHECK_LPA - cmp r1, r2 - beq exit_wakeup - - /* Sleep wakeup reset */ - ldr r2, =S5P_CHECK_SLEEP - cmp r1, r2 - beq wakeup_reset - - /* - * If U-boot is already running in ram, no need to relocate U-Boot. - * Memory controller must be configured before relocating U-Boot - * in ram. - */ - ldr r0, =0x0ffffff /* r0 <- Mask Bits*/ - bic r1, pc, r0 /* pc <- current addr of code */ - /* r1 <- unmasked bits of pc */ - ldr r2, _TEXT_BASE /* r2 <- original base addr in ram */ - bic r2, r2, r0 /* r2 <- unmasked bits of r2*/ - cmp r1, r2 /* compare r1, r2 */ - beq 1f /* r0 == r1 then skip sdram init */ - - /* init system clock */ - bl system_clock_init - - /* Memory initialize */ - bl mem_ctrl_asm_init - -1: - /* for UART */ - bl uart_asm_init - bl arch_cpu_init - bl tzpc_init - pop {pc} - -wakeup_reset: - bl system_clock_init - bl mem_ctrl_asm_init - bl arch_cpu_init - bl tzpc_init - -exit_wakeup: - /* Load return address and jump to kernel */ - ldr r0, =(EXYNOS4_POWER_BASE + INFORM0_OFFSET) - - /* r1 = physical address of exynos4210_cpu_resume function */ - ldr r1, [r0] - - /* Jump to kernel*/ - mov pc, r1 - nop - nop - -/* - * system_clock_init: Initialize core clock and bus clock. - * void system_clock_init(void) - */ -system_clock_init: - push {lr} - ldr r0, =EXYNOS4_CLOCK_BASE - - /* APLL(1), MPLL(1), CORE(0), HPM(0) */ - ldr r1, =CLK_SRC_CPU_VAL - ldr r2, =CLK_SRC_CPU_OFFSET - str r1, [r0, r2] - - /* wait ?us */ - mov r1, #0x10000 -2: subs r1, r1, #1 - bne 2b - - ldr r1, =CLK_SRC_TOP0_VAL - ldr r2, =CLK_SRC_TOP0_OFFSET - str r1, [r0, r2] - - ldr r1, =CLK_SRC_TOP1_VAL - ldr r2, =CLK_SRC_TOP1_OFFSET - str r1, [r0, r2] - - /* DMC */ - ldr r1, =CLK_SRC_DMC_VAL - ldr r2, =CLK_SRC_DMC_OFFSET - str r1, [r0, r2] - - /*CLK_SRC_LEFTBUS */ - ldr r1, =CLK_SRC_LEFTBUS_VAL - ldr r2, =CLK_SRC_LEFTBUS_OFFSET - str r1, [r0, r2] - - /*CLK_SRC_RIGHTBUS */ - ldr r1, =CLK_SRC_RIGHTBUS_VAL - ldr r2, =CLK_SRC_RIGHTBUS_OFFSET - str r1, [r0, r2] - - /* SATA: SCLKMPLL(0), MMC[0:4]: SCLKMPLL(6) */ - ldr r1, =CLK_SRC_FSYS_VAL - ldr r2, =CLK_SRC_FSYS_OFFSET - str r1, [r0, r2] - - /* UART[0:4] */ - ldr r1, =CLK_SRC_PERIL0_VAL - ldr r2, =CLK_SRC_PERIL0_OFFSET - str r1, [r0, r2] - - /* CAM , FIMC 0-3 */ - ldr r1, =CLK_SRC_CAM_VAL - ldr r2, =CLK_SRC_CAM_OFFSET - str r1, [r0, r2] - - /* MFC */ - ldr r1, =CLK_SRC_MFC_VAL - ldr r2, =CLK_SRC_MFC_OFFSET - str r1, [r0, r2] - - /* G3D */ - ldr r1, =CLK_SRC_G3D_VAL - ldr r2, =CLK_SRC_G3D_OFFSET - str r1, [r0, r2] - - /* LCD0 */ - ldr r1, =CLK_SRC_LCD0_VAL - ldr r2, =CLK_SRC_LCD0_OFFSET - str r1, [r0, r2] - - /* wait ?us */ - mov r1, #0x10000 -3: subs r1, r1, #1 - bne 3b - - /* CLK_DIV_CPU0 */ - ldr r1, =CLK_DIV_CPU0_VAL - ldr r2, =CLK_DIV_CPU0_OFFSET - str r1, [r0, r2] - - /* CLK_DIV_CPU1 */ - ldr r1, =CLK_DIV_CPU1_VAL - ldr r2, =CLK_DIV_CPU1_OFFSET - str r1, [r0, r2] - - /* CLK_DIV_DMC0 */ - ldr r1, =CLK_DIV_DMC0_VAL - ldr r2, =CLK_DIV_DMC0_OFFSET - str r1, [r0, r2] - - /*CLK_DIV_DMC1 */ - ldr r1, =CLK_DIV_DMC1_VAL - ldr r2, =CLK_DIV_DMC1_OFFSET - str r1, [r0, r2] - - /* CLK_DIV_LEFTBUS */ - ldr r1, =CLK_DIV_LEFTBUS_VAL - ldr r2, =CLK_DIV_LEFTBUS_OFFSET - str r1, [r0, r2] - - /* CLK_DIV_RIGHTBUS */ - ldr r1, =CLK_DIV_RIGHTBUS_VAL - ldr r2, =CLK_DIV_RIGHTBUS_OFFSET - str r1, [r0, r2] - - /* CLK_DIV_TOP */ - ldr r1, =CLK_DIV_TOP_VAL - ldr r2, =CLK_DIV_TOP_OFFSET - str r1, [r0, r2] - - /* MMC[0:1] */ - ldr r1, =CLK_DIV_FSYS1_VAL /* 800(MPLL) / (15 + 1) */ - ldr r2, =CLK_DIV_FSYS1_OFFSET - str r1, [r0, r2] - - /* MMC[2:3] */ - ldr r1, =CLK_DIV_FSYS2_VAL /* 800(MPLL) / (15 + 1) */ - ldr r2, =CLK_DIV_FSYS2_OFFSET - str r1, [r0, r2] - - /* MMC4 */ - ldr r1, =CLK_DIV_FSYS3_VAL /* 800(MPLL) / (15 + 1) */ - ldr r2, =CLK_DIV_FSYS3_OFFSET - str r1, [r0, r2] - - /* CLK_DIV_PERIL0: UART Clock Divisors */ - ldr r1, =CLK_DIV_PERIL0_VAL - ldr r2, =CLK_DIV_PERIL0_OFFSET - str r1, [r0, r2] - - /* CAM, FIMC 0-3: CAM Clock Divisors */ - ldr r1, =CLK_DIV_CAM_VAL - ldr r2, =CLK_DIV_CAM_OFFSET - str r1, [r0, r2] - - /* CLK_DIV_MFC: MFC Clock Divisors */ - ldr r1, =CLK_DIV_MFC_VAL - ldr r2, =CLK_DIV_MFC_OFFSET - str r1, [r0, r2] - - /* CLK_DIV_G3D: G3D Clock Divisors */ - ldr r1, =CLK_DIV_G3D_VAL - ldr r2, =CLK_DIV_G3D_OFFSET - str r1, [r0, r2] - - /* CLK_DIV_LCD0: LCD0 Clock Divisors */ - ldr r1, =CLK_DIV_LCD0_VAL - ldr r2, =CLK_DIV_LCD0_OFFSET - str r1, [r0, r2] - - /* Set PLL locktime */ - ldr r1, =PLL_LOCKTIME - ldr r2, =APLL_LOCK_OFFSET - str r1, [r0, r2] - - ldr r1, =PLL_LOCKTIME - ldr r2, =MPLL_LOCK_OFFSET - str r1, [r0, r2] - - ldr r1, =PLL_LOCKTIME - ldr r2, =EPLL_LOCK_OFFSET - str r1, [r0, r2] - - ldr r1, =PLL_LOCKTIME - ldr r2, =VPLL_LOCK_OFFSET - str r1, [r0, r2] - - /* APLL_CON1 */ - ldr r1, =APLL_CON1_VAL - ldr r2, =APLL_CON1_OFFSET - str r1, [r0, r2] - - /* APLL_CON0 */ - ldr r1, =APLL_CON0_VAL - ldr r2, =APLL_CON0_OFFSET - str r1, [r0, r2] - - /* MPLL_CON1 */ - ldr r1, =MPLL_CON1_VAL - ldr r2, =MPLL_CON1_OFFSET - str r1, [r0, r2] - - /* MPLL_CON0 */ - ldr r1, =MPLL_CON0_VAL - ldr r2, =MPLL_CON0_OFFSET - str r1, [r0, r2] - - /* EPLL */ - ldr r1, =EPLL_CON1_VAL - ldr r2, =EPLL_CON1_OFFSET - str r1, [r0, r2] - - /* EPLL_CON0 */ - ldr r1, =EPLL_CON0_VAL - ldr r2, =EPLL_CON0_OFFSET - str r1, [r0, r2] - - /* VPLL_CON1 */ - ldr r1, =VPLL_CON1_VAL - ldr r2, =VPLL_CON1_OFFSET - str r1, [r0, r2] - - /* VPLL_CON0 */ - ldr r1, =VPLL_CON0_VAL - ldr r2, =VPLL_CON0_OFFSET - str r1, [r0, r2] - - /* wait ?us */ - mov r1, #0x30000 -4: subs r1, r1, #1 - bne 4b - - pop {pc} -/* - * uart_asm_init: Initialize UART in asm mode, 115200bps fixed. - * void uart_asm_init(void) - */ - .globl uart_asm_init -uart_asm_init: - - /* setup UART0-UART3 GPIOs (part1) */ - mov r0, r7 - ldr r1, =EXYNOS4_GPIO_A0_CON_VAL - str r1, [r0, #EXYNOS4_GPIO_A0_CON_OFFSET] - ldr r1, =EXYNOS4_GPIO_A1_CON_VAL - str r1, [r0, #EXYNOS4_GPIO_A1_CON_OFFSET] - - ldr r0, =EXYNOS4_UART_BASE - add r0, r0, #EXYNOS4_DEFAULT_UART_OFFSET - - ldr r1, =ULCON_VAL - str r1, [r0, #ULCON_OFFSET] - ldr r1, =UCON_VAL - str r1, [r0, #UCON_OFFSET] - ldr r1, =UFCON_VAL - str r1, [r0, #UFCON_OFFSET] - ldr r1, =UBRDIV_VAL - str r1, [r0, #UBRDIV_OFFSET] - ldr r1, =UFRACVAL_VAL - str r1, [r0, #UFRACVAL_OFFSET] - mov pc, lr - nop - nop - nop - diff --git a/board/samsung/origen/mem_setup.S b/board/samsung/origen/mem_setup.S deleted file mode 100644 index b49b193..0000000 --- a/board/samsung/origen/mem_setup.S +++ /dev/null @@ -1,421 +0,0 @@ -/* - * Memory setup for ORIGEN board based on EXYNOS4210 - * - * Copyright (C) 2011 Samsung Electronics - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include "origen_setup.h" -#define SET_MIU - - .globl mem_ctrl_asm_init -mem_ctrl_asm_init: - /* - * Async bridge configuration at CPU_core: - * 1: half_sync - * 0: full_sync - */ - ldr r0, =ASYNC_CONFIG - mov r1, #1 - str r1, [r0] - -#ifdef SET_MIU - ldr r0, =EXYNOS4_MIU_BASE - /* Interleave: 2Bit, Interleave_bit1: 0x21, Interleave_bit2: 0x7 */ - ldr r1, =0x20001507 - str r1, [r0, #APB_SFR_INTERLEAVE_CONF_OFFSET] - - /* Update MIU Configuration */ - ldr r1, =0x00000001 - str r1, [r0, #APB_SFR_ARBRITATION_CONF_OFFSET] -#endif - /* DREX0 */ - ldr r0, =EXYNOS4_DMC0_BASE - - /* - * DLL Parameter Setting: - * Termination: Enable R/W - * Phase Delay for DQS Cleaning: 180' Shift - */ - ldr r1, =0xe0000086 - str r1, [r0, #DMC_PHYCONTROL1] - - /* - * ZQ Calibration - * Termination: Disable - * Auto Calibration Start: Enable - */ - ldr r1, =0xE3855703 - str r1, [r0, #DMC_PHYZQCONTROL] - - /* Wait ?us*/ - mov r2, #0x100000 -1: subs r2, r2, #1 - bne 1b - - /* - * Update DLL Information: - * Force DLL Resyncronization - */ - ldr r1, =0xe000008e - str r1, [r0, #DMC_PHYCONTROL1] - - /* Reset Force DLL Resyncronization */ - ldr r1, =0xe0000086 - str r1, [r0, #DMC_PHYCONTROL1] - - /* Enable Differential DQS, DLL Off*/ - ldr r1, =0x71101008 - str r1, [r0, #DMC_PHYCONTROL0] - - /* Activate PHY DLL: DLL On */ - ldr r1, =0x7110100A - str r1, [r0, #DMC_PHYCONTROL0] - - /* Set DLL Parameters */ - ldr r1, =0xe0000086 - str r1, [r0, #DMC_PHYCONTROL1] - - /* DLL Start */ - ldr r1, =0x7110100B - str r1, [r0, #DMC_PHYCONTROL0] - - ldr r1, =0x00000000 - str r1, [r0, #DMC_PHYCONTROL2] - - /* Set Clock Ratio of Bus clock to Memory Clock */ - ldr r1, =0x0FFF301a - str r1, [r0, #DMC_CONCONTROL] - - /* - * Memor Burst length: 8 - * Number of chips: 2 - * Memory Bus width: 32 bit - * Memory Type: DDR3 - * Additional Latancy for PLL: 1 Cycle - */ - ldr r1, =0x00312640 - str r1, [r0, #DMC_MEMCONTROL] - - /* - * Memory Configuration Chip 0 - * Address Mapping: Interleaved - * Number of Column address Bits: 10 bits - * Number of Rows Address Bits: 14 - * Number of Banks: 8 - */ - ldr r1, =0x20e01323 - str r1, [r0, #DMC_MEMCONFIG0] - - /* - * Memory Configuration Chip 1 - * Address Mapping: Interleaved - * Number of Column address Bits: 10 bits - * Number of Rows Address Bits: 14 - * Number of Banks: 8 - */ - ldr r1, =0x40e01323 - str r1, [r0, #DMC_MEMCONFIG1] - - /* Config Precharge Policy */ - ldr r1, =0xff000000 - str r1, [r0, #DMC_PRECHCONFIG] - - /* - * TimingAref, TimingRow, TimingData, TimingPower Setting: - * Values as per Memory AC Parameters - */ - ldr r1, =0x000000BB - str r1, [r0, #DMC_TIMINGAREF] - ldr r1, =0x4046654f - str r1, [r0, #DMC_TIMINGROW] - ldr r1, =0x46400506 - str r1, [r0, #DMC_TIMINGDATA] - ldr r1, =0x52000A3C - str r1, [r0, #DMC_TIMINGPOWER] - - /* Chip0: NOP Command: Assert and Hold CKE to high level */ - ldr r1, =0x07000000 - str r1, [r0, #DMC_DIRECTCMD] - - /* Wait ?us*/ - mov r2, #0x100000 -2: subs r2, r2, #1 - bne 2b - - /* Chip0: EMRS2, EMRS3, EMRS, MRS Commands Using Direct Command */ - ldr r1, =0x00020000 - str r1, [r0, #DMC_DIRECTCMD] - ldr r1, =0x00030000 - str r1, [r0, #DMC_DIRECTCMD] - ldr r1, =0x00010002 - str r1, [r0, #DMC_DIRECTCMD] - ldr r1, =0x00000328 - str r1, [r0, #DMC_DIRECTCMD] - - /* Wait ?us*/ - mov r2, #0x100000 -3: subs r2, r2, #1 - bne 3b - - /* Chip0: ZQINIT */ - ldr r1, =0x0a000000 - str r1, [r0, #DMC_DIRECTCMD] - - /* Wait ?us*/ - mov r2, #0x100000 -4: subs r2, r2, #1 - bne 4b - - /* Chip1: NOP Command: Assert and Hold CKE to high level */ - ldr r1, =0x07100000 - str r1, [r0, #DMC_DIRECTCMD] - - /* Wait ?us*/ - mov r2, #0x100000 -5: subs r2, r2, #1 - bne 5b - - /* Chip1: EMRS2, EMRS3, EMRS, MRS Commands Using Direct Command */ - ldr r1, =0x00120000 - str r1, [r0, #DMC_DIRECTCMD] - ldr r1, =0x00130000 - str r1, [r0, #DMC_DIRECTCMD] - ldr r1, =0x00110002 - str r1, [r0, #DMC_DIRECTCMD] - ldr r1, =0x00100328 - str r1, [r0, #DMC_DIRECTCMD] - - /* Wait ?us*/ - mov r2, #0x100000 -6: subs r2, r2, #1 - bne 6b - - /* Chip1: ZQINIT */ - ldr r1, =0x0a100000 - str r1, [r0, #DMC_DIRECTCMD] - - /* Wait ?us*/ - mov r2, #0x100000 -7: subs r2, r2, #1 - bne 7b - - ldr r1, =0xe000008e - str r1, [r0, #DMC_PHYCONTROL1] - ldr r1, =0xe0000086 - str r1, [r0, #DMC_PHYCONTROL1] - - /* Wait ?us*/ - mov r2, #0x100000 -8: subs r2, r2, #1 - bne 8b - - /* DREX1 */ - ldr r0, =EXYNOS4_DMC1_BASE @0x10410000 - - /* - * DLL Parameter Setting: - * Termination: Enable R/W - * Phase Delay for DQS Cleaning: 180' Shift - */ - ldr r1, =0xe0000086 - str r1, [r0, #DMC_PHYCONTROL1] - - /* - * ZQ Calibration: - * Termination: Disable - * Auto Calibration Start: Enable - */ - ldr r1, =0xE3855703 - str r1, [r0, #DMC_PHYZQCONTROL] - - /* Wait ?us*/ - mov r2, #0x100000 -1: subs r2, r2, #1 - bne 1b - - /* - * Update DLL Information: - * Force DLL Resyncronization - */ - ldr r1, =0xe000008e - str r1, [r0, #DMC_PHYCONTROL1] - - /* Reset Force DLL Resyncronization */ - ldr r1, =0xe0000086 - str r1, [r0, #DMC_PHYCONTROL1] - - /* Enable Differential DQS, DLL Off*/ - ldr r1, =0x71101008 - str r1, [r0, #DMC_PHYCONTROL0] - - /* Activate PHY DLL: DLL On */ - ldr r1, =0x7110100A - str r1, [r0, #DMC_PHYCONTROL0] - - /* Set DLL Parameters */ - ldr r1, =0xe0000086 - str r1, [r0, #DMC_PHYCONTROL1] - - /* DLL Start */ - ldr r1, =0x7110100B - str r1, [r0, #DMC_PHYCONTROL0] - - ldr r1, =0x00000000 - str r1, [r0, #DMC_PHYCONTROL2] - - /* Set Clock Ratio of Bus clock to Memory Clock */ - ldr r1, =0x0FFF301a - str r1, [r0, #DMC_CONCONTROL] - - /* - * Memor Burst length: 8 - * Number of chips: 2 - * Memory Bus width: 32 bit - * Memory Type: DDR3 - * Additional Latancy for PLL: 1 Cycle - */ - ldr r1, =0x00312640 - str r1, [r0, #DMC_MEMCONTROL] - - /* - * Memory Configuration Chip 0 - * Address Mapping: Interleaved - * Number of Column address Bits: 10 bits - * Number of Rows Address Bits: 14 - * Number of Banks: 8 - */ - ldr r1, =0x20e01323 - str r1, [r0, #DMC_MEMCONFIG0] - - /* - * Memory Configuration Chip 1 - * Address Mapping: Interleaved - * Number of Column address Bits: 10 bits - * Number of Rows Address Bits: 14 - * Number of Banks: 8 - */ - ldr r1, =0x40e01323 - str r1, [r0, #DMC_MEMCONFIG1] - - /* Config Precharge Policy */ - ldr r1, =0xff000000 - str r1, [r0, #DMC_PRECHCONFIG] - - /* - * TimingAref, TimingRow, TimingData, TimingPower Setting: - * Values as per Memory AC Parameters - */ - ldr r1, =0x000000BB - str r1, [r0, #DMC_TIMINGAREF] - ldr r1, =0x4046654f - str r1, [r0, #DMC_TIMINGROW] - ldr r1, =0x46400506 - str r1, [r0, #DMC_TIMINGDATA] - ldr r1, =0x52000A3C - str r1, [r0, #DMC_TIMINGPOWER] - - /* Chip0: NOP Command: Assert and Hold CKE to high level */ - ldr r1, =0x07000000 - str r1, [r0, #DMC_DIRECTCMD] - - /* Wait ?us*/ - mov r2, #0x100000 -2: subs r2, r2, #1 - bne 2b - - /* Chip0: EMRS2, EMRS3, EMRS, MRS Commands Using Direct Command */ - ldr r1, =0x00020000 - str r1, [r0, #DMC_DIRECTCMD] - ldr r1, =0x00030000 - str r1, [r0, #DMC_DIRECTCMD] - ldr r1, =0x00010002 - str r1, [r0, #DMC_DIRECTCMD] - ldr r1, =0x00000328 - str r1, [r0, #DMC_DIRECTCMD] - - /* Wait ?us*/ - mov r2, #0x100000 -3: subs r2, r2, #1 - bne 3b - - /* Chip 0: ZQINIT */ - ldr r1, =0x0a000000 - str r1, [r0, #DMC_DIRECTCMD] - - /* Wait ?us*/ - mov r2, #0x100000 -4: subs r2, r2, #1 - bne 4b - - /* Chip1: NOP Command: Assert and Hold CKE to high level */ - ldr r1, =0x07100000 - str r1, [r0, #DMC_DIRECTCMD] - - /* Wait ?us*/ - mov r2, #0x100000 -5: subs r2, r2, #1 - bne 5b - - /* Chip1: EMRS2, EMRS3, EMRS, MRS Commands Using Direct Command */ - ldr r1, =0x00120000 - str r1, [r0, #DMC_DIRECTCMD] - ldr r1, =0x00130000 - str r1, [r0, #DMC_DIRECTCMD] - ldr r1, =0x00110002 - str r1, [r0, #DMC_DIRECTCMD] - ldr r1, =0x00100328 - str r1, [r0, #DMC_DIRECTCMD] - - /* Wait ?us*/ - mov r2, #0x100000 -6: subs r2, r2, #1 - bne 6b - - /* Chip1: ZQINIT */ - ldr r1, =0x0a100000 - str r1, [r0, #DMC_DIRECTCMD] - - /* Wait ?us*/ - mov r2, #0x100000 -7: subs r2, r2, #1 - bne 7b - - ldr r1, =0xe000008e - str r1, [r0, #DMC_PHYCONTROL1] - ldr r1, =0xe0000086 - str r1, [r0, #DMC_PHYCONTROL1] - - /* Wait ?us*/ - mov r2, #0x100000 -8: subs r2, r2, #1 - bne 8b - - /* turn on DREX0, DREX1 */ - ldr r0, =EXYNOS4_DMC0_BASE - ldr r1, =0x0FFF303a - str r1, [r0, #DMC_CONCONTROL] - - ldr r0, =EXYNOS4_DMC1_BASE - ldr r1, =0x0FFF303a - str r1, [r0, #DMC_CONCONTROL] - - mov pc, lr diff --git a/board/samsung/origen/mmc_boot.c b/board/samsung/origen/mmc_boot.c deleted file mode 100644 index 072f161..0000000 --- a/board/samsung/origen/mmc_boot.c +++ /dev/null @@ -1,58 +0,0 @@ -/* - * Copyright (C) 2011 Samsung Electronics - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include<common.h> -#include<config.h> - -/* -* Copy U-boot from mmc to RAM: -* COPY_BL2_FNPTR_ADDR: Address in iRAM, which Contains -* Pointer to API (Data transfer from mmc to ram) -*/ -void copy_uboot_to_ram(void) -{ - u32 (*copy_bl2)(u32, u32, u32) = (void *) *(u32 *)COPY_BL2_FNPTR_ADDR; - - copy_bl2(BL2_START_OFFSET, BL2_SIZE_BLOC_COUNT, CONFIG_SYS_TEXT_BASE); -} - -void board_init_f(unsigned long bootflag) -{ - __attribute__((noreturn)) void (*uboot)(void); - copy_uboot_to_ram(); - - /* Jump to U-Boot image */ - uboot = (void *)CONFIG_SYS_TEXT_BASE; - (*uboot)(); - /* Never returns Here */ -} - -/* Place Holders */ -void board_init_r(gd_t *id, ulong dest_addr) -{ - /* Function attribute is no-return */ - /* This Function never executes */ - while (1) - ; -} - -void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) {} diff --git a/board/samsung/smdk5250/Makefile b/board/samsung/smdk5250/Makefile index f2c32ee..9412e37 100644 --- a/board/samsung/smdk5250/Makefile +++ b/board/samsung/smdk5250/Makefile @@ -24,10 +24,6 @@ include $(TOPDIR)/config.mk
-SOBJS := lowlevel_init.o - -COBJS := clock_init.o -COBJS += dmc_common.o dmc_init_ddr3.o COBJS += smdk5250_spl.o
ifndef CONFIG_SPL_BUILD @@ -38,14 +34,10 @@ COBJS += smdk5250.o endif endif
-ifdef CONFIG_SPL_BUILD -COBJS += spl_boot.o -endif - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS))
-ALL := $(obj).depend $(LIB) +ALL := $(obj).depend $(LIB)
all: $(ALL)
diff --git a/board/samsung/smdkv310/Makefile b/board/samsung/smdkv310/Makefile index 56e0c16..c4cd0a3 100644 --- a/board/samsung/smdkv310/Makefile +++ b/board/samsung/smdkv310/Makefile @@ -24,18 +24,12 @@ include $(TOPDIR)/config.mk
-SOBJS := mem_setup.o -SOBJS += lowlevel_init.o ifndef CONFIG_SPL_BUILD COBJS += smdkv310.o endif
diff --git a/board/samsung/smdkv310/lowlevel_init.S b/board/samsung/smdkv310/lowlevel_init.S deleted file mode 100644 index 31e0e2e..0000000 --- a/board/samsung/smdkv310/lowlevel_init.S +++ /dev/null @@ -1,414 +0,0 @@ -/* - * Lowlevel setup for SMDKV310 board based on EXYNOS4210 - * - * Copyright (C) 2011 Samsung Electronics - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <version.h> -#include <asm/arch/cpu.h> - -/* - * Register usages: - * - * r5 has zero always - * r7 has GPIO part1 base 0x11400000 - * r6 has GPIO part2 base 0x11000000 - */ - -#define MEM_DLLl_ON - -_TEXT_BASE: - .word CONFIG_SYS_TEXT_BASE - - .globl lowlevel_init -lowlevel_init: - push {lr} - - /* r5 has always zero */ - mov r5, #0 - ldr r7, =EXYNOS4_GPIO_PART1_BASE - ldr r6, =EXYNOS4_GPIO_PART2_BASE - - /* check reset status */ - ldr r0, =(EXYNOS4_POWER_BASE + 0x81C) @ INFORM7 - ldr r1, [r0] - - /* AFTR wakeup reset */ - ldr r2, =S5P_CHECK_DIDLE - cmp r1, r2 - beq exit_wakeup - - /* Sleep wakeup reset */ - ldr r2, =S5P_CHECK_SLEEP - cmp r1, r2 - beq wakeup_reset - - /* - * If U-boot is already running in ram, no need to relocate U-Boot. - * Memory controller must be configured before relocating U-Boot - * in ram. - */ - ldr r0, =0x00ffffff /* r0 <- Mask Bits*/ - bic r1, pc, r0 /* pc <- current addr of code */ - /* r1 <- unmasked bits of pc */ - - ldr r2, _TEXT_BASE /* r2 <- original base addr in ram */ - bic r2, r2, r0 /* r2 <- unmasked bits of r2*/ - cmp r1, r2 /* compare r1, r2 */ - beq 1f /* r0 == r1 then skip sdram init */ - - /* init system clock */ - bl system_clock_init - - /* Memory initialize */ - bl mem_ctrl_asm_init - -1: - /* for UART */ - bl uart_asm_init - bl arch_cpu_init - bl tzpc_init - pop {pc} - -wakeup_reset: - bl system_clock_init - bl mem_ctrl_asm_init - bl arch_cpu_init - bl tzpc_init - -exit_wakeup: - /* Load return address and jump to kernel */ - ldr r0, =(EXYNOS4_POWER_BASE + 0x800) @ INFORM0 - - /* r1 = physical address of exynos4210_cpu_resume function */ - ldr r1, [r0] - - /* Jump to kernel*/ - mov pc, r1 - nop - nop - -/* - * system_clock_init: Initialize core clock and bus clock. - * void system_clock_init(void) - */ -system_clock_init: - push {lr} - ldr r0, =EXYNOS4_CLOCK_BASE - - /* APLL(1), MPLL(1), CORE(0), HPM(0) */ - ldr r1, =0x0101 - ldr r2, =0x14200 @CLK_SRC_CPU - str r1, [r0, r2] - - /* wait ?us */ - mov r1, #0x10000 -2: subs r1, r1, #1 - bne 2b - - ldr r1, =0x00 - ldr r2, =0x0C210 @CLK_SRC_TOP0 - str r1, [r0, r2] - - ldr r1, =0x00 - ldr r2, =0x0C214 @CLK_SRC_TOP1_OFFSET - str r1, [r0, r2] - - /* DMC */ - ldr r1, =0x00 - ldr r2, =0x10200 @CLK_SRC_DMC_OFFSET - str r1, [r0, r2] - - /*CLK_SRC_LEFTBUS */ - ldr r1, =0x00 - ldr r2, =0x04200 @CLK_SRC_LEFTBUS_OFFSET - str r1, [r0, r2] - - /*CLK_SRC_RIGHTBUS */ - ldr r1, =0x00 - ldr r2, =0x08200 @CLK_SRC_RIGHTBUS_OFFSET - str r1, [r0, r2] - - /* SATA: SCLKMPLL(0), MMC[0:4]: SCLKMPLL(6) */ - ldr r1, =0x066666 - ldr r2, =0x0C240 @ CLK_SRC_FSYS - str r1, [r0, r2] - - /* UART[0:4], PWM: SCLKMPLL(6) */ - ldr r1, =0x06666666 - ldr r2, =0x0C250 @CLK_SRC_PERIL0_OFFSET - str r1, [r0, r2] - - /* wait ?us */ - mov r1, #0x10000 -3: subs r1, r1, #1 - bne 3b - - /* - * CLK_DIV_CPU0: - * - * PCLK_DBG_RATIO[20] 0x1 - * ATB_RATIO[16] 0x3 - * PERIPH_RATIO[12] 0x3 - * COREM1_RATIO[8] 0x7 - * COREM0_RATIO[4] 0x3 - */ - ldr r1, =0x0133730 - ldr r2, =0x14500 @CLK_DIV_CPU0_OFFSET - str r1, [r0, r2] - - /* CLK_DIV_CPU1: COPY_RATIO [0] 0x3 */ - ldr r1, =0x03 - ldr r2, =0x14504 @CLK_DIV_CPU1_OFFSET - str r1, [r0, r2] - - /* - * CLK_DIV_DMC0: - * - * CORE_TIMERS_RATIO[28] 0x1 - * COPY2_RATIO[24] 0x3 - * DMCP_RATIO[20] 0x1 - * DMCD_RATIO[16] 0x1 - * DMC_RATIO[12] 0x1 - * DPHY_RATIO[8] 0x1 - * ACP_PCLK_RATIO[4] 0x1 - * ACP_RATIO[0] 0x3 - */ - ldr r1, =0x13111113 - ldr r2, =0x010500 @CLK_DIV_DMC0_OFFSET - str r1, [r0, r2] - - /* - * CLK_DIV_DMC1: - * - * DPM_RATIO[24] 0x1 - * DVSEM_RATIO[16] 0x1 - * PWI_RATIO[8] 0x1 - */ - ldr r1, =0x01010100 - ldr r2, =0x010504 @CLK_DIV_DMC1_OFFSET - str r1, [r0, r2] - - /* - * CLK_DIV_LEFRBUS: - * - * GPL_RATIO[4] 0x1 - * GDL_RATIO[0] 0x3 - */ - ldr r1, =0x013 - ldr r2, =0x04500 @CLK_DIV_LEFTBUS_OFFSET - str r1, [r0, r2] - - /* - * CLK_DIV_RIGHTBUS: - * - * GPR_RATIO[4] 0x1 - * GDR_RATIO[0] 0x3 - */ - ldr r1, =0x013 - ldr r2, =0x08500 @CLK_DIV_RIGHTBUS_OFFSET - str r1, [r0, r2] - - /* - * CLK_DIV_TOP: - * - * ONENAND_RATIO[16] 0x0 - * ACLK_133_RATIO[12] 0x5 - * ACLK_160_RATIO[8] 0x4 - * ACLK_100_RATIO[4] 0x7 - * ACLK_200_RATIO[0] 0x3 - */ - ldr r1, =0x05473 - ldr r2, =0x0C510 @CLK_DIV_TOP_OFFSET - str r1, [r0, r2] - - /* MMC[0:1] */ - ldr r1, =0x000f000f /* 800(MPLL) / (15 + 1) */ - ldr r2, =0x0C544 @ CLK_DIV_FSYS1 - str r1, [r0, r2] - - /* MMC[2:3] */ - ldr r1, =0x000f000f /* 800(MPLL) / (15 + 1) */ - ldr r2, =0x0C548 @ CLK_DIV_FSYS2 - str r1, [r0, r2] - - /* MMC4 */ - ldr r1, =0x000f /* 800(MPLL) / (15 + 1) */ - ldr r2, =0x0C54C @ CLK_DIV_FSYS3 - str r1, [r0, r2] - - /* wait ?us */ - mov r1, #0x10000 -4: subs r1, r1, #1 - bne 4b - - /* - * CLK_DIV_PERIL0: - * - * UART5_RATIO[20] 8 - * UART4_RATIO[16] 8 - * UART3_RATIO[12] 8 - * UART2_RATIO[8] 8 - * UART1_RATIO[4] 8 - * UART0_RATIO[0] 8 - */ - ldr r1, =0x774777 - ldr r2, =0x0C550 @CLK_DIV_PERIL0_OFFSET - str r1, [r0, r2] - - /* SLIMBUS: ???, PWM */ - ldr r1, =0x8 - ldr r2, =0x0C55C @ CLK_DIV_PERIL3 - str r1, [r0, r2] - - /* Set PLL locktime */ - ldr r1, =0x01C20 - ldr r2, =0x014000 @APLL_LOCK_OFFSET - str r1, [r0, r2] - ldr r1, =0x01C20 - ldr r2, =0x014008 @MPLL_LOCK_OFFSET - str r1, [r0, r2] - ldr r1, =0x01C20 - ldr r2, =0x0C010 @EPLL_LOCK_OFFSET - str r1, [r0, r2] - ldr r1, =0x01C20 - ldr r2, =0x0C020 @VPLL_LOCK_OFFSET - str r1, [r0, r2] - - /* - * APLL_CON1: - * - * APLL_AFC_ENB[31] 0x1 - * APLL_AFC[0] 0xC - */ - ldr r1, =0x8000000C - ldr r2, =0x014104 @APLL_CON1_OFFSET - str r1, [r0, r2] - - /* - * APLL_CON0: - * - * APLL_MDIV[16] 0xFA - * APLL_PDIV[8] 0x6 - * APLL_SDIV[0] 0x1 - */ - ldr r1, =0x80FA0601 - ldr r2, =0x014100 @APLL_CON0_OFFSET - str r1, [r0, r2] - - /* - * MPLL_CON1: - * - * MPLL_AFC_ENB[31] 0x1 - * MPLL_AFC[0] 0x1C - */ - ldr r1, =0x0000001C - ldr r2, =0x01410C @MPLL_CON1_OFFSET - str r1, [r0, r2] - - /* - * MPLL_CON0: - * - * MPLL_MDIV[16] 0xC8 - * MPLL_PDIV[8] 0x6 - * MPLL_SDIV[0] 0x1 - */ - ldr r1, =0x80C80601 - ldr r2, =0x014108 @MPLL_CON0_OFFSET - str r1, [r0, r2] - - /* EPLL */ - ldr r1, =0x0 - ldr r2, =0x0C114 @EPLL_CON1_OFFSET - str r1, [r0, r2] - - /* - * EPLL_CON0: - * - * EPLL_MDIV[16] 0x30 - * EPLL_PDIV[8] 0x3 - * EPLL_SDIV[0] 0x2 - */ - ldr r1, =0x80300302 - ldr r2, =0x0C110 @EPLL_CON0_OFFSET - str r1, [r0, r2] - - /* - * VPLL_CON1: - * - * VPLL_MRR[24] 0x11 - * VPLL_MFR[16] 0x0 - * VPLL_K[0] 0x400 - */ - ldr r1, =0x11000400 - ldr r2, =0x0C124 @VPLL_CON1_OFFSET - str r1, [r0, r2] - - /* - * VPLL_CON0: - * - * VPLL_MDIV[16] 0x35 - * VPLL_PDIV[8] 0x3 - * VPLL_SDIV[0] 0x2 - */ - ldr r1, =0x80350302 - ldr r2, =0x0C120 @VPLL_CON0_OFFSET - str r1, [r0, r2] - - /* wait ?us */ - mov r1, #0x30000 -3: subs r1, r1, #1 - bne 3b - - pop {pc} -/* - * uart_asm_init: Initialize UART in asm mode, 115200bps fixed. - * void uart_asm_init(void) - */ - .globl uart_asm_init -uart_asm_init: - - /* setup UART0-UART3 GPIOs (part1) */ - mov r0, r7 - ldr r1, =0x22222222 - str r1, [r0, #0x00] @ EXYNOS4_GPIO_A0_OFFSET - ldr r1, =0x00222222 - str r1, [r0, #0x20] @ EXYNOS4_GPIO_A1_OFFSET - - ldr r0, =EXYNOS4_UART_BASE - add r0, r0, #EXYNOS4_DEFAULT_UART_OFFSET - - ldr r1, =0x3C5 - str r1, [r0, #0x4] - ldr r1, =0x111 - str r1, [r0, #0x8] - ldr r1, =0x3 - str r1, [r0, #0x0] - ldr r1, =0x35 - str r1, [r0, #0x28] - ldr r1, =0x4 - str r1, [r0, #0x2c] - - mov pc, lr - nop - nop - nop diff --git a/board/samsung/smdkv310/mem_setup.S b/board/samsung/smdkv310/mem_setup.S deleted file mode 100644 index d3b6265..0000000 --- a/board/samsung/smdkv310/mem_setup.S +++ /dev/null @@ -1,365 +0,0 @@ -/* - * Memory setup for SMDKV310 board based on EXYNOS4210 - * - * Copyright (C) 2011 Samsung Electronics - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> - -#define SET_MIU - -#define MEM_DLL - -#ifdef CONFIG_CLK_800_330_165 -#define DRAM_CLK_330 -#endif -#ifdef CONFIG_CLK_1000_200_200 -#define DRAM_CLK_200 -#endif -#ifdef CONFIG_CLK_1000_330_165 -#define DRAM_CLK_330 -#endif -#ifdef CONFIG_CLK_1000_400_200 -#define DRAM_CLK_400 -#endif - - .globl mem_ctrl_asm_init -mem_ctrl_asm_init: - - /* - * Async bridge configuration at CPU_core: - * 1: half_sync - * 0: full_sync - */ - ldr r0, =0x10010350 - mov r1, #1 - str r1, [r0] - -#ifdef SET_MIU - ldr r0, =EXYNOS4_MIU_BASE @0x10600000 -#ifdef CONFIG_MIU_1BIT_INTERLEAVED - ldr r1, =0x0000000c - str r1, [r0, #0x400] @MIU_INTLV_CONFIG - ldr r1, =0x40000000 - str r1, [r0, #0x808] @MIU_INTLV_START_ADDR - ldr r1, =0xbfffffff - str r1, [r0, #0x810] @MIU_INTLV_END_ADDR - ldr r1, =0x00000001 - str r1, [r0, #0x800] @MIU_MAPPING_UPDATE -#endif -#ifdef CONFIG_MIU_2BIT_INTERLEAVED - ldr r1, =0x2000150c - str r1, [r0, #0x400] @MIU_INTLV_CONFIG - ldr r1, =0x40000000 - str r1, [r0, #0x808] @MIU_INTLV_START_ADDR - ldr r1, =0xbfffffff - str r1, [r0, #0x810] @MIU_INTLV_END_ADDR - ldr r1, =0x00000001 - str r1, [r0, #0x800] @MIU_MAPPING_UPDATE -#endif -#ifdef CONFIG_MIU_LINEAR - ldr r1, =0x40000000 - str r1, [r0, #0x818] @MIU_SINGLE_MAPPING0_START_ADDR - ldr r1, =0x7fffffff - str r1, [r0, #0x820] @MIU_SINGLE_MAPPING0_END_ADDR - ldr r1, =0x80000000 - str r1, [r0, #0x828] @MIU_SINGLE_MAPPING1_START_ADDR - ldr r1, =0xbfffffff - str r1, [r0, #0x830] @MIU_SINGLE_MAPPING1_END_ADDR] - ldr r1, =0x00000006 - str r1, [r0, #0x800] @MIU_MAPPING_UPDATE -#endif -#endif - /* DREX0 */ - ldr r0, =EXYNOS4_DMC0_BASE @0x10400000 - - ldr r1, =0xe0000086 - str r1, [r0, #0x1C] @DMC_PHYCONTROL1 - - ldr r1, =0xE3855703 - str r1, [r0, #0x44] @DMC_PHYZQCONTROL - - mov r2, #0x100000 -1: subs r2, r2, #1 - bne 1b - - ldr r1, =0xe000008e - str r1, [r0, #0x1C] @DMC_PHYCONTROL1 - ldr r1, =0xe0000086 - str r1, [r0, #0x1C] @DMC_PHYCONTROL1 - - ldr r1, =0x71101008 - str r1, [r0, #0x18] @DMC_PHYCONTROL0 - ldr r1, =0x7110100A - str r1, [r0, #0x18] @DMC_PHYCONTROL0 - ldr r1, =0xe0000086 - str r1, [r0, #0x1C] @DMC_PHYCONTROL1 - ldr r1, =0x7110100B - str r1, [r0, #0x18] @DMC_PHYCONTROL0 - - ldr r1, =0x00000000 - str r1, [r0, #0x20] @DMC_PHYCONTROL2 - - ldr r1, =0x0FFF301a - str r1, [r0, #0x00] @DMC_CONCONTROL - ldr r1, =0x00312640 - str r1, [r0, #0x04] @DMC_MEMCONTROL] - -#ifdef CONFIG_MIU_LINEAR - ldr r1, =0x40e01323 - str r1, [r0, #0x08] @DMC_MEMCONFIG0 - ldr r1, =0x60e01323 - str r1, [r0, #0x0C] @DMC_MEMCONFIG1 -#else /* @MIU_1BIT_INTERLEAVED | MIU_2BIT_INTERLEAVED */ - ldr r1, =0x20e01323 - str r1, [r0, #0x08] @DMC_MEMCONFIG0 - ldr r1, =0x40e01323 - str r1, [r0, #0x0C] @DMC_MEMCONFIG1 -#endif - - ldr r1, =0xff000000 - str r1, [r0, #0x14] @DMC_PRECHCONFIG - - ldr r1, =0x000000BC - str r1, [r0, #0x30] @DMC_TIMINGAREF - -#ifdef DRAM_CLK_330 - ldr r1, =0x3545548d - str r1, [r0, #0x34] @DMC_TIMINGROW - ldr r1, =0x45430506 - str r1, [r0, #0x38] @DMC_TIMINGDATA - ldr r1, =0x4439033c - str r1, [r0, #0x3C] @DMC_TIMINGPOWER -#endif -#ifdef DRAM_CLK_400 - ldr r1, =0x4046654f - str r1, [r0, #0x34] @DMC_TIMINGROW - ldr r1, =0x56500506 - str r1, [r0, #0x38] @DMC_TIMINGDATA - ldr r1, =0x5444033d - str r1, [r0, #0x3C] @DMC_TIMINGPOWER -#endif - ldr r1, =0x07000000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - - mov r2, #0x100000 -2: subs r2, r2, #1 - bne 2b - - ldr r1, =0x00020000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - ldr r1, =0x00030000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - ldr r1, =0x00010002 - str r1, [r0, #0x10] @DMC_DIRECTCMD - ldr r1, =0x00000328 - str r1, [r0, #0x10] @DMC_DIRECTCMD - - mov r2, #0x100000 -3: subs r2, r2, #1 - bne 3b - - ldr r1, =0x0a000000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - - mov r2, #0x100000 -4: subs r2, r2, #1 - bne 4b - - ldr r1, =0x07100000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - - mov r2, #0x100000 -5: subs r2, r2, #1 - bne 5b - - ldr r1, =0x00120000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - ldr r1, =0x00130000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - ldr r1, =0x00110002 - str r1, [r0, #0x10] @DMC_DIRECTCMD - ldr r1, =0x00100328 - str r1, [r0, #0x10] @DMC_DIRECTCMD - - mov r2, #0x100000 -6: subs r2, r2, #1 - bne 6b - - ldr r1, =0x0a100000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - - mov r2, #0x100000 -7: subs r2, r2, #1 - bne 7b - - ldr r1, =0xe000008e - str r1, [r0, #0x1C] @DMC_PHYCONTROL1 - ldr r1, =0xe0000086 - str r1, [r0, #0x1C] @DMC_PHYCONTROL1 - - mov r2, #0x100000 -8: subs r2, r2, #1 - bne 8b - - /* DREX1 */ - ldr r0, =EXYNOS4_DMC1_BASE @0x10410000 - - ldr r1, =0xe0000086 - str r1, [r0, #0x1C] @DMC_PHYCONTROL1 - - ldr r1, =0xE3855703 - str r1, [r0, #0x44] @DMC_PHYZQCONTROL - - mov r2, #0x100000 -1: subs r2, r2, #1 - bne 1b - - ldr r1, =0xe000008e - str r1, [r0, #0x1C] @DMC_PHYCONTROL1 - ldr r1, =0xe0000086 - str r1, [r0, #0x1C] @DMC_PHYCONTROL1 - - ldr r1, =0x71101008 - str r1, [r0, #0x18] @DMC_PHYCONTROL0 - ldr r1, =0x7110100A - str r1, [r0, #0x18] @DMC_PHYCONTROL0 - ldr r1, =0xe0000086 - str r1, [r0, #0x1C] @DMC_PHYCONTROL1 - ldr r1, =0x7110100B - str r1, [r0, #0x18] @DMC_PHYCONTROL0 - - ldr r1, =0x00000000 - str r1, [r0, #0x20] @DMC_PHYCONTROL2 - - ldr r1, =0x0FFF301a - str r1, [r0, #0x00] @DMC_CONCONTROL - ldr r1, =0x00312640 - str r1, [r0, #0x04] @DMC_MEMCONTROL] - -#ifdef CONFIG_MIU_LINEAR - ldr r1, =0x40e01323 - str r1, [r0, #0x08] @DMC_MEMCONFIG0 - ldr r1, =0x60e01323 - str r1, [r0, #0x0C] @DMC_MEMCONFIG1 -#else /* @MIU_1BIT_INTERLEAVED | MIU_2BIT_INTERLEAVED */ - ldr r1, =0x20e01323 - str r1, [r0, #0x08] @DMC_MEMCONFIG0 - ldr r1, =0x40e01323 - str r1, [r0, #0x0C] @DMC_MEMCONFIG1 -#endif - - ldr r1, =0xff000000 - str r1, [r0, #0x14] @DMC_PRECHCONFIG - - ldr r1, =0x000000BC - str r1, [r0, #0x30] @DMC_TIMINGAREF - -#ifdef DRAM_CLK_330 - ldr r1, =0x3545548d - str r1, [r0, #0x34] @DMC_TIMINGROW - ldr r1, =0x45430506 - str r1, [r0, #0x38] @DMC_TIMINGDATA - ldr r1, =0x4439033c - str r1, [r0, #0x3C] @DMC_TIMINGPOWER -#endif -#ifdef DRAM_CLK_400 - ldr r1, =0x4046654f - str r1, [r0, #0x34] @DMC_TIMINGROW - ldr r1, =0x56500506 - str r1, [r0, #0x38] @DMC_TIMINGDATA - ldr r1, =0x5444033d - str r1, [r0, #0x3C] @DMC_TIMINGPOWER -#endif - - ldr r1, =0x07000000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - - mov r2, #0x100000 -2: subs r2, r2, #1 - bne 2b - - ldr r1, =0x00020000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - ldr r1, =0x00030000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - ldr r1, =0x00010002 - str r1, [r0, #0x10] @DMC_DIRECTCMD - ldr r1, =0x00000328 - str r1, [r0, #0x10] @DMC_DIRECTCMD - - mov r2, #0x100000 -3: subs r2, r2, #1 - bne 3b - - ldr r1, =0x0a000000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - - mov r2, #0x100000 -4: subs r2, r2, #1 - bne 4b - - ldr r1, =0x07100000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - - mov r2, #0x100000 -5: subs r2, r2, #1 - bne 5b - - ldr r1, =0x00120000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - ldr r1, =0x00130000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - ldr r1, =0x00110002 - str r1, [r0, #0x10] @DMC_DIRECTCMD - ldr r1, =0x00100328 - str r1, [r0, #0x10] @DMC_DIRECTCMD - - mov r2, #0x100000 -6: subs r2, r2, #1 - bne 6b - - ldr r1, =0x0a100000 - str r1, [r0, #0x10] @DMC_DIRECTCMD - - mov r2, #0x100000 -7: subs r2, r2, #1 - bne 7b - - ldr r1, =0xe000008e - str r1, [r0, #0x1C] @DMC_PHYCONTROL1 - ldr r1, =0xe0000086 - str r1, [r0, #0x1C] @DMC_PHYCONTROL1 - - mov r2, #0x100000 -8: subs r2, r2, #1 - bne 8b - - /* turn on DREX0, DREX1 */ - ldr r0, =0x10400000 @APB_DMC_0_BASE - ldr r1, =0x0FFF303a - str r1, [r0, #0x00] @DMC_CONCONTROL - - ldr r0, =0x10410000 @APB_DMC_1_BASE - ldr r1, =0x0FFF303a - str r1, [r0, #0x00] @DMC_CONCONTROL - - mov pc, lr diff --git a/board/samsung/smdkv310/mmc_boot.c b/board/samsung/smdkv310/mmc_boot.c deleted file mode 100644 index d3fc18d..0000000 --- a/board/samsung/smdkv310/mmc_boot.c +++ /dev/null @@ -1,60 +0,0 @@ -/* - * Copyright (C) 2011 Samsung Electronics - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include<common.h> -#include<config.h> - -/* -* Copy U-boot from mmc to RAM: -* COPY_BL2_FNPTR_ADDR: Address in iRAM, which Contains -* API (Data transfer from mmc to ram) -*/ -void copy_uboot_to_ram(void) -{ - u32 (*copy_bl2)(u32, u32, u32) = (void *)COPY_BL2_FNPTR_ADDR; - - copy_bl2(BL2_START_OFFSET, BL2_SIZE_BLOC_COUNT, CONFIG_SYS_TEXT_BASE); -} - -void board_init_f(unsigned long bootflag) -{ - __attribute__((noreturn)) void (*uboot)(void); - copy_uboot_to_ram(); - - /* Jump to U-Boot image */ - uboot = (void *)CONFIG_SYS_TEXT_BASE; - (*uboot)(); - /* Never returns Here */ -} - -/* Place Holders */ -void board_init_r(gd_t *id, ulong dest_addr) -{ - /*Function attribute is no-return*/ - /*This Function never executes*/ - while (1) - ; -} - -void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) -{ -} diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 6c7a052..b32d1bd 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -104,6 +104,7 @@
#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_SKIP_LOWLEVEL_INIT
/* PWM */ #define CONFIG_PWM @@ -137,6 +138,7 @@ #define CONFIG_USB_STORAGE
/* USB boot mode */ +#define CONFIG_USB_BOOTING #define EXYNOS_COPY_USB_FNPTR_ADDR 0x02020070 #define EXYNOS_USB_SECONDARY_BOOT 0xfeed0002 #define EXYNOS_IRAM_SECONDARY_BASE 0x02020018 @@ -152,6 +154,8 @@ #define CONFIG_SPL #define COPY_BL2_FNPTR_ADDR 0x02020030
+#define CONFIG_SPL_LIBCOMMON_SUPPORT + /* specific .lds file */ #define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds" #define CONFIG_SPL_TEXT_BASE 0x02023400 @@ -229,7 +233,7 @@ #define BL2_START_OFFSET (CONFIG_BL2_OFFSET/512) #define BL2_SIZE_BLOC_COUNT (CONFIG_BL2_SIZE/512)
-#define OM_STAT (0x1f << 1) +#define CONFIG_SPI_BOOTING #define EXYNOS_COPY_SPI_FNPTR_ADDR 0x02020058 #define SPI_FLASH_UBOOT_POS (CONFIG_SEC_FW_SIZE + CONFIG_BL1_SIZE)
@@ -241,7 +245,7 @@
#define CONFIG_IRAM_STACK 0x02050000
-#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000) +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_IRAM_STACK
/* I2C */ #define CONFIG_SYS_I2C_INIT_BOARD diff --git a/include/configs/origen.h b/include/configs/origen.h index f71a463..fd7d667 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -68,6 +68,8 @@ #define CONFIG_BAUDRATE 115200 #define EXYNOS4_DEFAULT_UART_OFFSET 0x020000
+#define CONFIG_SKIP_LOWLEVEL_INIT + /* SD/MMC configuration */ #define CONFIG_GENERIC_MMC #define CONFIG_MMC @@ -148,7 +150,10 @@ #define CONFIG_ENV_OFFSET (RESERVE_BLOCK_SIZE + BL1_SIZE) #define CONFIG_DOS_PARTITION 1
-#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds" +#define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024) + +#define CONFIG_SYS_INIT_SP_ADDR 0x02040000
/* U-boot copy size from boot Media to DRAM.*/ #define COPY_BL2_SIZE 0x80000 @@ -157,4 +162,5 @@
/* Enable devicetree support */ #define CONFIG_OF_LIBFDT + #endif /* __CONFIG_H */ diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index db78127..38ba292 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -58,6 +58,7 @@ /* Handling Sleep Mode*/ #define S5P_CHECK_SLEEP 0x00000BAD #define S5P_CHECK_DIDLE 0xBAD00000 +#define S5P_CHECK_LPA 0xABAD0000
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) @@ -94,6 +95,7 @@
/* MMC SPL */ #define CONFIG_SPL +#define CONFIG_SKIP_LOWLEVEL_INIT #define COPY_BL2_FNPTR_ADDR 0x00002488
#define CONFIG_SPL_TEXT_BASE 0x02021410 @@ -147,7 +149,10 @@ #define CONFIG_ENV_OFFSET (RESERVE_BLOCK_SIZE + BL1_SIZE) #define CONFIG_DOS_PARTITION 1
On 02/07/13 22:12, Rajeshwari Shinde wrote:
This patch performs the following:
- Convert the assembly code for memory and clock initialization to C code.
- Move the memory and clock init codes from board/samsung to arch/arm
- Creat a common lowlevel_init file across Exynos4 and Exynos5. Converted the common lowlevel_init from assembly to C-code
- Made spl_boot.c and tzpc_init.c common for both exynos4 and exynos5.
- Enable CONFIG_SKIP_LOWLEVEL_INIT as stack pointer initialisation is already done in _main.
- exynos-uboot-spl.lds made common across SMDKV310, Origen and SMDK5250.
TEST: Tested SD-MMC boot on SMDK5250 and Origen. Tested USB and SPI boot on SMDK5250 Compile tested for SMDKV310.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com
Changes in V2: - Rebased on latest u-boot-samsung tree. - Incorporated review comments from Minkyu Kang. Changes in V3:
- Optimised the mem_ctrl_init function for exynos4.
- Removed magic numbers.
arch/arm/cpu/armv7/exynos/Makefile | 17 +- .../arm/cpu/armv7/exynos}/clock_init.h | 0 arch/arm/cpu/armv7/exynos/clock_init_exynos4.c | 94 +++++ .../arm/cpu/armv7/exynos/clock_init_exynos5.c | 47 +-- arch/arm/cpu/armv7/exynos/common_setup.h | 43 ++ .../arm/cpu/armv7/exynos}/dmc_common.c | 7 +- .../arm/cpu/armv7/exynos}/dmc_init_ddr3.c | 19 +- arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c | 212 ++++++++++ .../arm/cpu/armv7/exynos/exynos4_setup.h | 397 +++++++++---------- .../arm/cpu/armv7/exynos/exynos5_setup.h | 28 +- arch/arm/cpu/armv7/exynos/lowlevel_init.c | 73 ++++ .../arm/cpu/armv7/exynos}/spl_boot.c | 74 +++- arch/arm/include/asm/arch-exynos/cpu.h | 5 +- board/samsung/origen/Makefile | 11 +- board/samsung/origen/lowlevel_init.S | 357 ----------------- board/samsung/origen/mem_setup.S | 421 -------------------- board/samsung/origen/mmc_boot.c | 58 --- board/samsung/smdk5250/Makefile | 14 +- board/samsung/smdkv310/Makefile | 10 +- board/samsung/smdkv310/lowlevel_init.S | 414 ------------------- board/samsung/smdkv310/mem_setup.S | 365 ----------------- board/samsung/smdkv310/mmc_boot.c | 60 --- include/configs/exynos5250-dt.h | 8 +- include/configs/origen.h | 8 +- include/configs/smdkv310.h | 7 +- 25 files changed, 770 insertions(+), 1979 deletions(-) rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/clock_init.h (100%) create mode 100644 arch/arm/cpu/armv7/exynos/clock_init_exynos4.c rename board/samsung/smdk5250/clock_init.c => arch/arm/cpu/armv7/exynos/clock_init_exynos5.c (95%) create mode 100644 arch/arm/cpu/armv7/exynos/common_setup.h rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/dmc_common.c (97%) rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/dmc_init_ddr3.c (95%) create mode 100644 arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c rename board/samsung/origen/origen_setup.h => arch/arm/cpu/armv7/exynos/exynos4_setup.h (65%) rename board/samsung/smdk5250/setup.h => arch/arm/cpu/armv7/exynos/exynos5_setup.h (96%) create mode 100644 arch/arm/cpu/armv7/exynos/lowlevel_init.c rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/spl_boot.c (74%) delete mode 100644 board/samsung/origen/lowlevel_init.S delete mode 100644 board/samsung/origen/mem_setup.S delete mode 100644 board/samsung/origen/mmc_boot.c delete mode 100644 board/samsung/smdkv310/lowlevel_init.S delete mode 100644 board/samsung/smdkv310/mem_setup.S delete mode 100644 board/samsung/smdkv310/mmc_boot.c
diff --git a/arch/arm/cpu/armv7/exynos/Makefile b/arch/arm/cpu/armv7/exynos/Makefile index b2f9152..4661155 100644 --- a/arch/arm/cpu/armv7/exynos/Makefile +++ b/arch/arm/cpu/armv7/exynos/Makefile @@ -22,10 +22,19 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(SOC).o
-COBJS += clock.o power.o soc.o system.o pinmux.o tzpc.o
-SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +COBJS-y += clock.o power.o soc.o system.o pinmux.o tzpc.o
+ifdef CONFIG_SPL_BUILD +COBJS-$(CONFIG_EXYNOS5) += clock_init_exynos5.o +COBJS-$(CONFIG_EXYNOS5) += dmc_common.o dmc_init_ddr3.o +COBJS-$(CONFIG_EXYNOS4210)+= dmc_init_exynos4.o clock_init_exynos4.o +COBJS-y += spl_boot.o +COBJS-y += lowlevel_init.o +endif
+COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS))
all: $(obj).depend $(LIB)
diff --git a/board/samsung/smdk5250/clock_init.h b/arch/arm/cpu/armv7/exynos/clock_init.h similarity index 100% rename from board/samsung/smdk5250/clock_init.h rename to arch/arm/cpu/armv7/exynos/clock_init.h diff --git a/arch/arm/cpu/armv7/exynos/clock_init_exynos4.c b/arch/arm/cpu/armv7/exynos/clock_init_exynos4.c new file mode 100644 index 0000000..bee0b5c --- /dev/null +++ b/arch/arm/cpu/armv7/exynos/clock_init_exynos4.c @@ -0,0 +1,94 @@ +/*
- Clock Initialization for board based on EXYNOS4210
- Copyright (C) 2013 Samsung Electronics
- Rajeshwari Shinde rajeshwari.s@samsung.com
- project.
- MA 02111-1307 USA
+#include <common.h> +#include <config.h> +#include <version.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/clock.h> +#include "common_setup.h" +#include "exynos4_setup.h"
- system_clock_init: Initialize core clock and bus clock.
- void system_clock_init(void)
+void system_clock_init(void) +{
- struct exynos4_clock *clk = (struct exynos4_clock *)EXYNOS4_CLOCK_BASE;
NAK.
- writel(CLK_SRC_CPU_VAL, &clk->src_cpu);
- sdelay(0x10000);
- writel(CLK_SRC_TOP0_VAL, &clk->src_top0);
- writel(CLK_SRC_TOP1_VAL, &clk->src_top1);
- writel(CLK_SRC_DMC_VAL, &clk->src_dmc);
- writel(CLK_SRC_LEFTBUS_VAL, &clk->src_leftbus);
- writel(CLK_SRC_RIGHTBUS_VAL, &clk->src_rightbus);
- writel(CLK_SRC_FSYS_VAL, &clk->src_fsys);
- writel(CLK_SRC_PERIL0_VAL, &clk->src_peril0);
- writel(CLK_SRC_CAM_VAL, &clk->src_cam);
- writel(CLK_SRC_MFC_VAL, &clk->src_mfc);
- writel(CLK_SRC_G3D_VAL, &clk->src_g3d);
- writel(CLK_SRC_LCD0_VAL, &clk->src_lcd0);
- sdelay(0x10000);
- writel(CLK_DIV_CPU0_VAL, &clk->div_cpu0);
- writel(CLK_DIV_CPU1_VAL, &clk->div_cpu1);
- writel(CLK_DIV_DMC0_VAL, &clk->div_dmc0);
- writel(CLK_DIV_DMC1_VAL, &clk->div_dmc1);
- writel(CLK_DIV_LEFTBUS_VAL, &clk->div_leftbus);
- writel(CLK_DIV_RIGHTBUS_VAL, &clk->div_rightbus);
- writel(CLK_DIV_TOP_VAL, &clk->div_top);
- writel(CLK_DIV_FSYS1_VAL, &clk->div_fsys1);
- writel(CLK_DIV_FSYS2_VAL, &clk->div_fsys2);
- writel(CLK_DIV_FSYS3_VAL, &clk->div_fsys3);
- writel(CLK_DIV_PERIL0_VAL, &clk->div_peril0);
- writel(CLK_DIV_CAM_VAL, &clk->div_cam);
- writel(CLK_DIV_MFC_VAL, &clk->div_mfc);
- writel(CLK_DIV_G3D_VAL, &clk->div_g3d);
- writel(CLK_DIV_LCD0_VAL, &clk->div_lcd0);
- writel(PLL_LOCKTIME, &clk->apll_lock);
- writel(PLL_LOCKTIME, &clk->mpll_lock);
- writel(PLL_LOCKTIME, &clk->epll_lock);
- writel(PLL_LOCKTIME, &clk->vpll_lock);
- writel(APLL_CON1_VAL, &clk->apll_con1);
- writel(APLL_CON0_VAL, &clk->apll_con0);
- writel(MPLL_CON1_VAL, &clk->mpll_con1);
- writel(MPLL_CON0_VAL, &clk->mpll_con0);
- writel(EPLL_CON1_VAL, &clk->epll_con1);
- writel(EPLL_CON0_VAL, &clk->epll_con0);
- writel(VPLL_CON1_VAL, &clk->vpll_con1);
- writel(VPLL_CON0_VAL, &clk->vpll_con0);
- sdelay(0x30000);
diff --git a/board/samsung/smdk5250/dmc_init_ddr3.c b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c similarity index 95% rename from board/samsung/smdk5250/dmc_init_ddr3.c rename to arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c index e050790..de54af8 100644 --- a/board/samsung/smdk5250/dmc_init_ddr3.c +++ b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c @@ -27,7 +27,8 @@ #include <asm/arch/clock.h> #include <asm/arch/cpu.h> #include <asm/arch/dmc.h> -#include "setup.h" +#include "common_setup.h" +#include "exynos5_setup.h" #include "clock_init.h"
#define RDLVL_COMPLETE_TIMEOUT 10000 @@ -40,7 +41,8 @@ static void reset_phy_ctrl(void) writel(DDR3PHY_CTRL_PHY_RESET, &clk->lpddr3phy_ctrl); }
-int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size) +int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size,
int reset)
{ unsigned int val; struct exynos5_phy_control *phy0_ctrl, *phy1_ctrl; @@ -49,9 +51,10 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size)
phy0_ctrl = (struct exynos5_phy_control *)EXYNOS5_DMC_PHY0_BASE; phy1_ctrl = (struct exynos5_phy_control *)EXYNOS5_DMC_PHY1_BASE;
NAK. Please use function instead.
- dmc = (struct exynos5_dmc *)EXYNOS5_DMC_CTRL_BASE;
- dmc = (struct exynos5_dmc *)samsung_get_base_dmc0();
- reset_phy_ctrl();
if (reset)
reset_phy_ctrl();
/* Set Impedance Output Driver */ val = (mem->impedance << CA_CK_DRVR_DS_OFFSET) |
@@ -100,14 +103,14 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size)
/* Start DLL locking */ writel(val | (mem->ctrl_start << PHY_CON12_CTRL_START_SHIFT),
&phy0_ctrl->phy_con12);
writel(val | (mem->ctrl_start << PHY_CON12_CTRL_START_SHIFT),&phy0_ctrl->phy_con12);
&phy1_ctrl->phy_con12);
update_reset_dll(dmc, DDR_MODE_DDR3);
writel(mem->concontrol | (mem->rd_fetch << CONCONTROL_RD_FETCH_SHIFT),
&dmc->concontrol);
&dmc->concontrol);
/* Memory Channel Inteleaving Size */ writel(mem->iv_size, &dmc->ivcontrol);
@@ -119,7 +122,7 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size)
/* Precharge Configuration */ writel(mem->prechconfig_tp_cnt << PRECHCONFIG_TP_CNT_SHIFT,
&dmc->prechconfig);
&dmc->prechconfig);
/* Power Down mode Configuration */ writel(mem->dpwrdn_cyc << PWRDNCONFIG_DPWRDN_CYC_SHIFT |
diff --git a/arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c b/arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c new file mode 100644 index 0000000..636d84c --- /dev/null +++ b/arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c @@ -0,0 +1,212 @@ +/*
- Memory setup for board based on EXYNOS4210
- project.
- MA 02111-1307 USA
+#include <config.h> +#include <asm/arch/dmc.h> +#include "common_setup.h" +#include "exynos4_setup.h"
+struct mem_timings mem = {
- .direct_cmd_msr = {
DIRECT_CMD1, DIRECT_CMD2, DIRECT_CMD3, DIRECT_CMD4
- .timingref = TIMINGREF_VAL,
- .timingrow = TIMINGROW_VAL,
- .timingdata = TIMINGDATA_VAL,
- .timingpower = TIMINGPOWER_VAL,
- .zqcontrol = ZQ_CONTROL_VAL,
- .control0 = CONTROL0_VAL,
- .control1 = CONTROL1_VAL,
- .control2 = CONTROL2_VAL,
- .concontrol = CONCONTROL_VAL,
- .prechconfig = PRECHCONFIG,
- .memcontrol = MEMCONTROL_VAL,
- .memconfig0 = MEMCONFIG0_VAL,
- .memconfig1 = MEMCONFIG1_VAL,
- .dll_resync = FORCE_DLL_RESYNC,
- .dll_on = DLL_CONTROL_ON,
+}; +static void phy_control_reset(int ctrl_no, struct exynos4_dmc *dmc) +{
- if (ctrl_no) {
writel((mem.control1 | (1 << mem.dll_resync)),
&dmc->phycontrol1);
writel((mem.control1 | (0 << mem.dll_resync)),
&dmc->phycontrol1);
- } else {
writel((mem.control0 | (0 << mem.dll_on)),
&dmc->phycontrol0);
writel((mem.control0 | (1 << mem.dll_on)),
&dmc->phycontrol0);
+static void dmc_config_mrs(struct exynos4_dmc *dmc, int chip) +{
- int i;
- unsigned long mask = 0;
- if (chip)
mask = DIRECT_CMD_CHIP1_SHIFT;
- for (i = 0; i < MEM_TIMINGS_MSR_COUNT; i++) {
writel(mem.direct_cmd_msr[i] | mask,
&dmc->directcmd);
+static void dmc_init(struct exynos4_dmc *dmc) +{
- writel(mem.control1, &dmc->phycontrol1);
* ZQ Calibration
- writel(mem.zqcontrol, &dmc->phyzqcontrol);
- sdelay(0x100000);
- phy_control_reset(1, dmc);
- phy_control_reset(0, dmc);
- /* DLL Start */
- writel((mem.control0 | CTRL_START | CTRL_DLL_ON), &dmc->phycontrol0);
- writel(mem.control2, &dmc->phycontrol2);
- writel(mem.concontrol, &dmc->concontrol);
* Memory Type: DDR3
- writel(mem.memcontrol, &dmc->memcontrol);
- writel(mem.memconfig0, &dmc->memconfig0);
- writel(mem.memconfig1, &dmc->memconfig1);
- writel(mem.prechconfig, &dmc->prechconfig);
- writel(mem.timingref, &dmc->timingref);
- writel(mem.timingrow, &dmc->timingrow);
- writel(mem.timingdata, &dmc->timingdata);
- writel(mem.timingpower, &dmc->timingpower);
- writel(DIRECT_CMD_NOP, &dmc->directcmd);
- sdelay(0x100000);
- dmc_config_mrs(dmc, 0);
- sdelay(0x100000);
- writel(DIRECT_CMD_ZQ, &dmc->directcmd);
- sdelay(0x100000);
- writel((DIRECT_CMD_NOP | DIRECT_CMD_CHIP1_SHIFT), &dmc->directcmd);
- sdelay(0x100000);
- dmc_config_mrs(dmc, 1);
- sdelay(0x100000);
- writel((DIRECT_CMD_ZQ | DIRECT_CMD_CHIP1_SHIFT), &dmc->directcmd);
- sdelay(0x100000);
- sdelay(0x100000);
- writel((mem.concontrol | AREF_EN), &dmc->concontrol);
+void mem_ctrl_init(int reset) +{
- struct exynos4_dmc *dmc;
* 1: half_sync
* 0: full_sync
- writel(1, ASYNC_CONFIG);
+#ifdef CONFIG_ORIGEN
- /* Interleave: 2Bit, Interleave_bit1: 0x15, Interleave_bit0: 0x7 */
- writel(APB_SFR_INTERLEAVE_CONF_VAL, EXYNOS4_MIU_BASE +
APB_SFR_INTERLEAVE_CONF_OFFSET);
- writel(APB_SFR_ARBRITATION_CONF_VAL, EXYNOS4_MIU_BASE +
APB_SFR_ARBRITATION_CONF_OFFSET);
+#else
- writel(INTERLEAVE_ADDR_MAP_START_ADDR, EXYNOS4_MIU_BASE +
ABP_SFR_INTERLEAVE_ADDRMAP_START_OFFSET);
- writel(INTERLEAVE_ADDR_MAP_END_ADDR, EXYNOS4_MIU_BASE +
ABP_SFR_INTERLEAVE_ADDRMAP_END_OFFSET);
- writel(INTERLEAVE_ADDR_MAP_EN, EXYNOS4_MIU_BASE +
ABP_SFR_SLV_ADDRMAP_CONF_OFFSET);
+#ifdef CONFIG_MIU_LINEAR
- writel(SLAVE0_SINGLE_ADDR_MAP_START_ADDR, EXYNOS4_MIU_BASE +
ABP_SFR_SLV0_SINGLE_ADDRMAP_START_OFFSET);
- writel(SLAVE0_SINGLE_ADDR_MAP_END_ADDR, EXYNOS4_MIU_BASE +
ABP_SFR_SLV0_SINGLE_ADDRMAP_END_OFFSET);
- writel(SLAVE1_SINGLE_ADDR_MAP_START_ADDR, EXYNOS4_MIU_BASE +
ABP_SFR_SLV1_SINGLE_ADDRMAP_START_OFFSET);
- writel(SLAVE1_SINGLE_ADDR_MAP_END_ADDR, EXYNOS4_MIU_BASE +
ABP_SFR_SLV1_SINGLE_ADDRMAP_END_OFFSET);
- writel(APB_SFR_SLV_ADDR_MAP_CONF_VAL, EXYNOS4_MIU_BASE +
+#endif +#endif
- /* DREX0 */
- dmc = (struct exynos4_dmc *)samsung_get_base_dmc0();
- dmc_init(dmc);
- dmc = (struct exynos4_dmc *)samsung_get_base_dmc1();
- dmc_init(dmc);
+} diff --git a/board/samsung/origen/origen_setup.h b/arch/arm/cpu/armv7/exynos/exynos4_setup.h similarity index 65% rename from board/samsung/origen/origen_setup.h rename to arch/arm/cpu/armv7/exynos/exynos4_setup.h index 926a4cc..6d25058 100644 --- a/board/samsung/origen/origen_setup.h +++ b/arch/arm/cpu/armv7/exynos/exynos4_setup.h @@ -1,5 +1,5 @@ /*
- Machine Specific Values for ORIGEN board based on S5PV310
- Machine Specific Values for EXYNOS4012 based board
- Copyright (C) 2011 Samsung Electronics
@@ -29,98 +29,22 @@ #include <version.h> #include <asm/arch/cpu.h>
-/* Offsets of clock registers (sources and dividers) */ -#define CLK_SRC_CPU_OFFSET 0x14200 -#define CLK_DIV_CPU0_OFFSET 0x14500 -#define CLK_DIV_CPU1_OFFSET 0x14504
-#define CLK_SRC_DMC_OFFSET 0x10200 -#define CLK_DIV_DMC0_OFFSET 0x10500 -#define CLK_DIV_DMC1_OFFSET 0x10504
-#define CLK_SRC_TOP0_OFFSET 0xC210 -#define CLK_SRC_TOP1_OFFSET 0xC214 -#define CLK_DIV_TOP_OFFSET 0xC510
-#define CLK_SRC_LEFTBUS_OFFSET 0x4200 -#define CLK_DIV_LEFTBUS_OFFSET 0x4500
-#define CLK_SRC_RIGHTBUS_OFFSET 0x8200 -#define CLK_DIV_RIGHTBUS_OFFSET 0x8500
-#define CLK_SRC_FSYS_OFFSET 0xC240 -#define CLK_DIV_FSYS1_OFFSET 0xC544 -#define CLK_DIV_FSYS2_OFFSET 0xC548 -#define CLK_DIV_FSYS3_OFFSET 0xC54C
-#define CLK_SRC_CAM_OFFSET 0xC220 -#define CLK_SRC_TV_OFFSET 0xC224 -#define CLK_SRC_MFC_OFFSET 0xC228 -#define CLK_SRC_G3D_OFFSET 0xC22C -#define CLK_SRC_LCD0_OFFSET 0xC234 -#define CLK_SRC_PERIL0_OFFSET 0xC250
-#define CLK_DIV_CAM_OFFSET 0xC520 -#define CLK_DIV_TV_OFFSET 0xC524 -#define CLK_DIV_MFC_OFFSET 0xC528 -#define CLK_DIV_G3D_OFFSET 0xC52C -#define CLK_DIV_LCD0_OFFSET 0xC534 -#define CLK_DIV_PERIL0_OFFSET 0xC550
-#define APLL_LOCK_OFFSET 0x14000 -#define MPLL_LOCK_OFFSET 0x14008 -#define APLL_CON0_OFFSET 0x14100 -#define APLL_CON1_OFFSET 0x14104 -#define MPLL_CON0_OFFSET 0x14108 -#define MPLL_CON1_OFFSET 0x1410C
-#define EPLL_LOCK_OFFSET 0xC010 -#define VPLL_LOCK_OFFSET 0xC020 -#define EPLL_CON0_OFFSET 0xC110 -#define EPLL_CON1_OFFSET 0xC114 -#define VPLL_CON0_OFFSET 0xC120 -#define VPLL_CON1_OFFSET 0xC124
-/* DMC: DRAM Controllor Register offsets */ -#define DMC_CONCONTROL 0x00 -#define DMC_MEMCONTROL 0x04 -#define DMC_MEMCONFIG0 0x08 -#define DMC_MEMCONFIG1 0x0C -#define DMC_DIRECTCMD 0x10 -#define DMC_PRECHCONFIG 0x14 -#define DMC_PHYCONTROL0 0x18 -#define DMC_PHYCONTROL1 0x1C -#define DMC_PHYCONTROL2 0x20 -#define DMC_TIMINGAREF 0x30 -#define DMC_TIMINGROW 0x34 -#define DMC_TIMINGDATA 0x38 -#define DMC_TIMINGPOWER 0x3C -#define DMC_PHYZQCONTROL 0x44 +#ifdef CONFIG_CLK_800_330_165 +#define DRAM_CLK_330 +#endif +#ifdef CONFIG_CLK_1000_200_200 +#define DRAM_CLK_200 +#endif +#ifdef CONFIG_CLK_1000_330_165 +#define DRAM_CLK_330 +#endif +#ifdef CONFIG_CLK_1000_400_200 +#define DRAM_CLK_400 +#endif
/* Bus Configuration Register Address */ #define ASYNC_CONFIG 0x10010350
-/* MIU Config Register Offsets*/ -#define APB_SFR_INTERLEAVE_CONF_OFFSET 0x400 -#define APB_SFR_ARBRITATION_CONF_OFFSET 0xC00
-/* Offset for inform registers */ -#define INFORM0_OFFSET 0x800 -#define INFORM1_OFFSET 0x804
-/* GPIO Offsets for UART: GPIO Contol Register */ -#define EXYNOS4_GPIO_A0_CON_OFFSET 0x00 -#define EXYNOS4_GPIO_A1_CON_OFFSET 0x20
-/* UART Register offsets */ -#define ULCON_OFFSET 0x00 -#define UCON_OFFSET 0x04 -#define UFCON_OFFSET 0x08 -#define UBRDIV_OFFSET 0x28 -#define UFRACVAL_OFFSET 0x2C
/* CLK_SRC_CPU */ #define MUX_HPM_SEL_MOUTAPLL 0x0 #define MUX_HPM_SEL_SCLKMPLL 0x1 @@ -485,123 +409,186 @@ | (VPLL_MRR << 24) \ | (VPLL_MFR << 16) \ | (VPLL_K << 0)) -/*
- UART GPIO_A0/GPIO_A1 Control Register Value
- 0x2: UART Function
-#define EXYNOS4_GPIO_A0_CON_VAL 0x22222222 -#define EXYNOS4_GPIO_A1_CON_VAL 0x222222
-/* ULCON: UART Line Control Value 8N1 */ -#define WORD_LEN_5_BIT 0x00 -#define WORD_LEN_6_BIT 0x01 -#define WORD_LEN_7_BIT 0x02 -#define WORD_LEN_8_BIT 0x03
-#define STOP_BIT_1 0x00 -#define STOP_BIT_2 0x01
-#define NO_PARITY 0x00 -#define ODD_PARITY 0x4 -#define EVEN_PARITY 0x5 -#define FORCED_PARITY_CHECK_AS_1 0x6 -#define FORCED_PARITY_CHECK_AS_0 0x7
-#define INFRAMODE_NORMAL 0x00 -#define INFRAMODE_INFRARED 0x01
-#define ULCON_VAL ((INFRAMODE_NORMAL << 6) \
| (NO_PARITY << 3) \
| (STOP_BIT_1 << 2) \
| (WORD_LEN_8_BIT << 0))
- UCON: UART Control Value
- Tx_interrupt Type: Level
- Rx_interrupt Type: Level
- Rx Timeout Enabled: Yes
- Rx-Error Atatus_Int Enable: Yes
- Loop_Back: No
- Break Signal: No
- Transmit mode : Interrupt request/polling
- Receive mode : Interrupt request/polling
-#define TX_PULSE_INTERRUPT 0 -#define TX_LEVEL_INTERRUPT 1 -#define RX_PULSE_INTERRUPT 0 -#define RX_LEVEL_INTERRUPT 1
-#define RX_TIME_OUT ENABLE -#define RX_ERROR_STATE_INT_ENB ENABLE -#define LOOP_BACK DISABLE -#define BREAK_SIGNAL DISABLE
-#define TX_MODE_DISABLED 0X00 -#define TX_MODE_IRQ_OR_POLL 0X01 -#define TX_MODE_DMA 0X02
-#define RX_MODE_DISABLED 0X00 -#define RX_MODE_IRQ_OR_POLL 0X01 -#define RX_MODE_DMA 0X02
-#define UCON_VAL ((TX_LEVEL_INTERRUPT << 9) \
| (RX_LEVEL_INTERRUPT << 8) \
| (RX_TIME_OUT << 7) \
| (RX_ERROR_STATE_INT_ENB << 6) \
| (LOOP_BACK << 5) \
| (BREAK_SIGNAL << 4) \
| (TX_MODE_IRQ_OR_POLL << 2) \
| (RX_MODE_IRQ_OR_POLL << 0))
+/* DMC */ +#define DIRECT_CMD_NOP 0x07000000 +#define DIRECT_CMD_ZQ 0x0a000000 +#define DIRECT_CMD_CHIP1_SHIFT (1 << 20) +#define MEM_TIMINGS_MSR_COUNT 4 +#define CTRL_START (1 << 0) +#define CTRL_DLL_ON (1 << 1) +#define AREF_EN (1 << 5) +#define DRV_TYPE (1 << 6)
+struct mem_timings {
- unsigned direct_cmd_msr[MEM_TIMINGS_MSR_COUNT];
- unsigned timingref;
- unsigned timingrow;
- unsigned timingdata;
- unsigned timingpower;
- unsigned zqcontrol;
- unsigned control0;
- unsigned control1;
- unsigned control2;
- unsigned concontrol;
- unsigned prechconfig;
- unsigned memcontrol;
- unsigned memconfig0;
- unsigned memconfig1;
- unsigned dll_resync;
- unsigned dll_on;
+/* MIU */ +/* MIU Config Register Offsets*/ +#define APB_SFR_INTERLEAVE_CONF_OFFSET 0x400 +#define APB_SFR_ARBRITATION_CONF_OFFSET 0xC00 +#define ABP_SFR_SLV_ADDRMAP_CONF_OFFSET 0x800 +#define ABP_SFR_INTERLEAVE_ADDRMAP_START_OFFSET 0x808 +#define ABP_SFR_INTERLEAVE_ADDRMAP_END_OFFSET 0x810 +#define ABP_SFR_SLV0_SINGLE_ADDRMAP_START_OFFSET 0x818 +#define ABP_SFR_SLV0_SINGLE_ADDRMAP_END_OFFSET 0x820 +#define ABP_SFR_SLV1_SINGLE_ADDRMAP_START_OFFSET 0x828 +#define ABP_SFR_SLV1_SINGLE_ADDRMAP_END_OFFSET 0x830
+#ifdef CONFIG_ORIGEN +/* Interleave: 2Bit, Interleave_bit1: 0x15, Interleave_bit0: 0x7 */ +#define APB_SFR_INTERLEAVE_CONF_VAL 0x20001507 +#define APB_SFR_ARBRITATION_CONF_VAL 0x00000001 +#endif
- UFCON: UART FIFO Control Value
- Tx FIFO Trigger LEVEL: 2 Bytes (001)
- Rx FIFO Trigger LEVEL: 2 Bytes (001)
- Tx Fifo Reset: No
- Rx Fifo Reset: No
- FIFO Enable: Yes
-#define TX_FIFO_TRIGGER_LEVEL_0_BYTES 0x00 -#define TX_FIFO_TRIGGER_LEVEL_2_BYTES 0x1 -#define TX_FIFO_TRIGGER_LEVEL_4_BYTES 0x2 -#define TX_FIFO_TRIGGER_LEVEL_6_BYTES 0x3 -#define TX_FIFO_TRIGGER_LEVEL_8_BYTES 0x4 -#define TX_FIFO_TRIGGER_LEVEL_10_BYTES 0x5 -#define TX_FIFO_TRIGGER_LEVEL_12_BYTES 0x6 -#define TX_FIFO_TRIGGER_LEVEL_14_BYTES 0x7
-#define RX_FIFO_TRIGGER_LEVEL_2_BYTES 0x0 -#define RX_FIFO_TRIGGER_LEVEL_4_BYTES 0x1 -#define RX_FIFO_TRIGGER_LEVEL_6_BYTES 0x2 -#define RX_FIFO_TRIGGER_LEVEL_8_BYTES 0x3 -#define RX_FIFO_TRIGGER_LEVEL_10_BYTES 0x4 -#define RX_FIFO_TRIGGER_LEVEL_12_BYTES 0x5 -#define RX_FIFO_TRIGGER_LEVEL_14_BYTES 0x6 -#define RX_FIFO_TRIGGER_LEVEL_16_BYTES 0x7
-#define TX_FIFO_TRIGGER_LEVEL TX_FIFO_TRIGGER_LEVEL_2_BYTES -#define RX_FIFO_TRIGGER_LEVEL RX_FIFO_TRIGGER_LEVEL_4_BYTES -#define TX_FIFO_RESET DISABLE -#define RX_FIFO_RESET DISABLE -#define FIFO_ENABLE ENABLE -#define UFCON_VAL ((TX_FIFO_TRIGGER_LEVEL << 8) \
| (RX_FIFO_TRIGGER_LEVEL << 4) \
| (TX_FIFO_RESET << 2) \
| (RX_FIFO_RESET << 1) \
| (FIFO_ENABLE << 0))
- Baud Rate Division Value
- 115200 BAUD:
- UBRDIV_VAL = SCLK_UART/((115200 * 16) - 1)
- UBRDIV_VAL = (800 MHz)/((115200 * 16) - 1)
-#define UBRDIV_VAL 0x35 +#define INTERLEAVE_ADDR_MAP_START_ADDR 0x40000000 +#define INTERLEAVE_ADDR_MAP_END_ADDR 0xbfffffff +#define INTERLEAVE_ADDR_MAP_EN 0x00000001
- Fractional Part of Baud Rate Divisor:
- 115200 BAUD:
- UBRFRACVAL = ((((SCLK_UART*10/(115200*16) -10))%10)*16/10)
- UBRFRACVAL = ((((800MHz*10/(115200*16) -10))%10)*16/10)
-#define UFRACVAL_VAL 0x4 +#ifdef CONFIG_MIU_1BIT_INTERLEAVED +/* Interleave_bit0: 0xC*/ +#define APB_SFR_INTERLEAVE_CONF_VAL 0x0000000c +#endif +#ifdef CONFIG_MIU_2BIT_INTERLEAVED +/* Interleave: 2Bit, Interleave_bit1: 0x15, Interleave_bit0: 0xc */ +#define APB_SFR_INTERLEAVE_CONF_VAL 0x2000150c +#endif +#define SLAVE0_SINGLE_ADDR_MAP_START_ADDR 0x40000000 +#define SLAVE0_SINGLE_ADDR_MAP_END_ADDR 0x7fffffff +#define SLAVE1_SINGLE_ADDR_MAP_START_ADDR 0x80000000 +#define SLAVE1_SINGLE_ADDR_MAP_END_ADDR 0xbfffffff +/* Enable SME0 and SME1*/ +#define APB_SFR_SLV_ADDR_MAP_CONF_VAL 0x00000006
+#define FORCE_DLL_RESYNC 3 +#define DLL_CONTROL_ON 1
+#define DIRECT_CMD1 0x00020000 +#define DIRECT_CMD2 0x00030000 +#define DIRECT_CMD3 0x00010002 +#define DIRECT_CMD4 0x00000328
+#define CTRL_ZQ_MODE_NOTERM (0x1 << 0) +#define CTRL_ZQ_START (0x1 << 1) +#define CTRL_ZQ_DIV (0 << 4) +#define CTRL_ZQ_MODE_DDS (0x7 << 8) +#define CTRL_ZQ_MODE_TERM (0x2 << 11) +#define CTRL_ZQ_FORCE_IMPN (0x5 << 14) +#define CTRL_ZQ_FORCE_IMPP (0x6 << 17) +#define CTRL_DCC (0xE38 << 20) +#define ZQ_CONTROL_VAL (CTRL_ZQ_MODE_NOTERM | CTRL_ZQ_START\
| CTRL_ZQ_DIV | CTRL_ZQ_MODE_DDS\
| CTRL_ZQ_MODE_TERM | CTRL_ZQ_FORCE_IMPN\
| CTRL_ZQ_FORCE_IMPP | CTRL_DCC)
+#define ASYNC (0 << 0) +#define CLK_RATIO (1 << 1) +#define DIV_PIPE (1 << 3) +#define AWR_ON (1 << 4) +#define AREF_DISABLE (0 << 5) +#define DRV_TYPE_DISABLE (0 << 6) +#define CHIP0_NOT_EMPTY (0 << 8) +#define CHIP1_NOT_EMPTY (0 << 9) +#define DQ_SWAP_DISABLE (0 << 10) +#define QOS_FAST_DISABLE (0 << 11) +#define RD_FETCH (0x3 << 12) +#define TIMEOUT_LEVEL0 (0xFFF << 16) +#define CONCONTROL_VAL (ASYNC | CLK_RATIO | DIV_PIPE | AWR_ON\
| AREF_DISABLE | DRV_TYPE_DISABLE\
| CHIP0_NOT_EMPTY | CHIP1_NOT_EMPTY\
| DQ_SWAP_DISABLE | QOS_FAST_DISABLE\
| RD_FETCH | TIMEOUT_LEVEL0)
+#define CLK_STOP_DISABLE (0 << 1) +#define DPWRDN_DISABLE (0 << 2) +#define DPWRDN_TYPE (0 << 3) +#define TP_DISABLE (0 << 4) +#define DSREF_DIABLE (0 << 5) +#define ADD_LAT_PALL (1 << 6) +#define MEM_TYPE_DDR3 (0x6 << 8) +#define MEM_WIDTH_32 (0x2 << 12) +#define NUM_CHIP_2 (1 << 16) +#define BL_8 (0x3 << 20) +#define MEMCONTROL_VAL (CLK_STOP_DISABLE | DPWRDN_DISABLE\
| DPWRDN_TYPE | TP_DISABLE | DSREF_DIABLE\
| ADD_LAT_PALL | MEM_TYPE_DDR3 | MEM_WIDTH_32\
| NUM_CHIP_2 | BL_8)
+#define CHIP_BANK_8 (0x3 << 0) +#define CHIP_ROW_14 (0x2 << 4) +#define CHIP_COL_10 (0x3 << 8) +#define CHIP_MAP_INTERLEAVED (1 << 12) +#define CHIP_MASK (0xe0 << 16) +#ifdef CONFIG_MIU_LINEAR +#define CHIP0_BASE (0x40 << 24) +#define CHIP1_BASE (0x60 << 24) +#else +#define CHIP0_BASE (0x20 << 24) +#define CHIP1_BASE (0x40 << 24) +#endif +#define MEMCONFIG0_VAL (CHIP_BANK_8 | CHIP_ROW_14 | CHIP_COL_10\
| CHIP_MAP_INTERLEAVED | CHIP_MASK | CHIP0_BASE)
+#define MEMCONFIG1_VAL (CHIP_BANK_8 | CHIP_ROW_14 | CHIP_COL_10\
| CHIP_MAP_INTERLEAVED | CHIP_MASK | CHIP1_BASE)
+#define TP_CNT (0xff << 24) +#define PRECHCONFIG TP_CNT
+#define CTRL_OFF (0 << 0) +#define CTRL_DLL_OFF (0 << 1) +#define CTRL_HALF (0 << 2) +#define CTRL_DFDQS (1 << 3) +#define DQS_DELAY (0 << 4) +#define CTRL_START_POINT (0x10 << 8) +#define CTRL_INC (0x10 << 16) +#define CTRL_FORCE (0x71 << 24) +#define CONTROL0_VAL (CTRL_OFF | CTRL_DLL_OFF | CTRL_HALF\
| CTRL_DFDQS | DQS_DELAY | CTRL_START_POINT\
| CTRL_INC | CTRL_FORCE)
+#define CTRL_SHIFTC (0x6 << 0) +#define CTRL_REF (8 << 4) +#define CTRL_SHGATE (1 << 29) +#define TERM_READ_EN (1 << 30) +#define TERM_WRITE_EN (1 << 31) +#define CONTROL1_VAL (CTRL_SHIFTC | CTRL_REF | CTRL_SHGATE\
| TERM_READ_EN | TERM_WRITE_EN)
+#define CONTROL2_VAL 0x00000000
+#ifdef CONFIG_ORIGEN +#define TIMINGREF_VAL 0x000000BB +#define TIMINGROW_VAL 0x4046654f +#define TIMINGDATA_VAL 0x46400506 +#define TIMINGPOWER_VAL 0x52000A3C +#else +#define TIMINGREF_VAL 0x000000BC +#ifdef DRAM_CLK_330 +#define TIMINGROW_VAL 0x3545548d +#define TIMINGDATA_VAL 0x45430506 +#define TIMINGPOWER_VAL 0x4439033c +#endif +#ifdef DRAM_CLK_400 +#define TIMINGROW_VAL 0x45430506 +#define TIMINGDATA_VAL 0x56500506 +#define TIMINGPOWER_VAL 0x5444033d +#endif +#endif #endif diff --git a/board/samsung/smdk5250/setup.h b/arch/arm/cpu/armv7/exynos/exynos5_setup.h similarity index 96% rename from board/samsung/smdk5250/setup.h rename to arch/arm/cpu/armv7/exynos/exynos5_setup.h index eb91d13..8f36c16 100644 --- a/board/samsung/smdk5250/setup.h +++ b/arch/arm/cpu/armv7/exynos/exynos5_setup.h @@ -93,17 +93,17 @@ #define DMC_MEMCONTROL_MRR_BYTE_31_24 (3 << 25)
/* MEMCONFIG0 register bit fields */ -#define DMC_MEMCONFIGx_CHIP_MAP_INTERLEAVED (1 << 12) -#define DMC_MEMCONFIGx_CHIP_COL_10 (3 << 8) -#define DMC_MEMCONFIGx_CHIP_ROW_14 (2 << 4) -#define DMC_MEMCONFIGx_CHIP_ROW_15 (3 << 4) -#define DMC_MEMCONFIGx_CHIP_BANK_8 (3 << 0)
-#define DMC_MEMBASECONFIGx_CHIP_BASE(x) (x << 16) -#define DMC_MEMBASECONFIGx_CHIP_MASK(x) (x << 0) +#define DMC_MEMCONFIGX_CHIP_MAP_INTERLEAVED (1 << 12) +#define DMC_MEMCONFIGX_CHIP_COL_10 (3 << 8) +#define DMC_MEMCONFIGX_CHIP_ROW_14 (2 << 4) +#define DMC_MEMCONFIGX_CHIP_ROW_15 (3 << 4) +#define DMC_MEMCONFIGX_CHIP_BANK_8 (3 << 0)
+#define DMC_MEMBASECONFIGX_CHIP_BASE(x) (x << 16) +#define DMC_MEMBASECONFIGX_CHIP_MASK(x) (x << 0) #define DMC_MEMBASECONFIG_VAL(x) ( \
- DMC_MEMBASECONFIGx_CHIP_BASE(x) | \
- DMC_MEMBASECONFIGx_CHIP_MASK(0x780) \
- DMC_MEMBASECONFIGX_CHIP_BASE(x) | \
- DMC_MEMBASECONFIGX_CHIP_MASK(0x780) \
#define DMC_MEMBASECONFIG0_VAL DMC_MEMBASECONFIG_VAL(0x40) @@ -513,9 +513,11 @@ enum {
which the DMC uses to decide how to split a memory
chunk into smaller chunks to support concurrent
accesses; may vary across boards.
- @param reset Reset DDR PHY during initialization.
- @return 0 if ok, SETUP_ERR_... if there is a problem
-int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size); +int ddr3_mem_ctrl_init(struct mem_timings *mem, unsigned long mem_iv_size,
int reset);
- Configure ZQ I/O interface
@@ -562,8 +564,4 @@ void dmc_config_memory(struct mem_timings *mem, struct exynos5_dmc *dmc);
- @param ddr_mode Type of DDR memory
*/ void update_reset_dll(struct exynos5_dmc *, enum ddr_mode);
-void sdelay(unsigned long); -void mem_ctrl_init(void); -void system_clock_init(void); #endif diff --git a/arch/arm/cpu/armv7/exynos/lowlevel_init.c b/arch/arm/cpu/armv7/exynos/lowlevel_init.c new file mode 100644 index 0000000..11fe5b8 --- /dev/null +++ b/arch/arm/cpu/armv7/exynos/lowlevel_init.c @@ -0,0 +1,73 @@ +/*
- Lowlevel setup for EXYNOS5 based board
- project.
- MA 02111-1307 USA
+#include <common.h> +#include <config.h> +#include <asm/arch/cpu.h> +#include <asm/arch/dmc.h> +#include <asm/arch/power.h> +#include <asm/arch/tzpc.h> +#include <asm/arch/periph.h> +#include <asm/arch/pinmux.h> +#include "common_setup.h"
+/* These are the things we can do during low-level init */ +enum {
- DO_WAKEUP = 1 << 0,
- DO_CLOCKS = 1 << 1,
- DO_MEM_RESET = 1 << 2,
- DO_UART = 1 << 3,
+int do_lowlevel_init(void) +{
- uint32_t reset_status;
- int actions = 0;
- arch_cpu_init();
- reset_status = get_reset_status();
- switch (reset_status) {
- case S5P_CHECK_SLEEP:
actions = DO_CLOCKS | DO_WAKEUP;
break;
- case S5P_CHECK_DIDLE:
- case S5P_CHECK_LPA:
actions = DO_WAKEUP;
break;
- default:
/* This is a normal boot (not a wake from sleep) */
actions = DO_CLOCKS | DO_MEM_RESET;
- if (actions & DO_CLOCKS) {
system_clock_init();
mem_ctrl_init(actions & DO_MEM_RESET);
tzpc_init();
- return actions & DO_WAKEUP;
+} diff --git a/board/samsung/smdk5250/spl_boot.c b/arch/arm/cpu/armv7/exynos/spl_boot.c similarity index 74% rename from board/samsung/smdk5250/spl_boot.c rename to arch/arm/cpu/armv7/exynos/spl_boot.c index 83275f1..6e8dd3b 100644 --- a/board/samsung/smdk5250/spl_boot.c +++ b/arch/arm/cpu/armv7/exynos/spl_boot.c @@ -23,13 +23,18 @@ #include<common.h> #include<config.h>
-#include <asm/arch-exynos/dmc.h> #include <asm/arch/clock.h> #include <asm/arch/clk.h> +#include <asm/arch/dmc.h> +#include <asm/arch/power.h> #include <asm/arch/spl.h>
+#include "common_setup.h" #include "clock_init.h"
+DECLARE_GLOBAL_DATA_PTR; +#define OM_STAT (0x1f << 1)
/* Index into irom ptr table */ enum index { MMC_INDEX, @@ -54,6 +59,7 @@ void *get_irom_func(int index) return (void *)*(u32 *)irom_ptr_table[index]; }
+#ifdef CONFIG_USB_BOOTING /*
- Set/clear program flow prediction and return the previous state.
*/ @@ -67,6 +73,7 @@ static int config_branch_prediction(int set_cr_z)
return cr & CR_Z; } +#endif
- Copy U-boot from mmc to RAM:
@@ -75,35 +82,42 @@ static int config_branch_prediction(int set_cr_z) */ void copy_uboot_to_ram(void) {
int is_cr_z_set;
unsigned int sec_boot_check; enum boot_mode bootmode = BOOT_MODE_OM;
u32 (*spi_copy)(u32 offset, u32 nblock, u32 dst);
u32 (*copy_bl2)(u32 offset, u32 nblock, u32 dst);
- u32 (*copy_bl2)(u32 offset, u32 nblock, u32 dst) = NULL;
- u32 offset = 0, size = 0;
+#ifdef CONFIG_SUPPORT_EMMC_BOOT u32 (*copy_bl2_from_emmc)(u32 nblock, u32 dst); void (*end_bootop_from_emmc)(void); +#endif +#ifdef CONFIG_USB_BOOTING u32 (*usb_copy)(void);
int is_cr_z_set;
/* Read iRAM location to check for secondary USB boot mode */ sec_boot_check = readl(EXYNOS_IRAM_SECONDARY_BASE); if (sec_boot_check == EXYNOS_USB_SECONDARY_BOOT) bootmode = BOOT_MODE_USB;
if (bootmode == BOOT_MODE_OM)
bootmode = readl(EXYNOS5_POWER_BASE) & OM_STAT;
bootmode = readl(samsung_get_base_power()) & OM_STAT;
switch (bootmode) {
+#ifdef CONFIG_SPI_BOOTING case BOOT_MODE_SERIAL:
spi_copy = get_irom_func(SPI_INDEX);
spi_copy(SPI_FLASH_UBOOT_POS, CONFIG_BL2_SIZE,
offset = SPI_FLASH_UBOOT_POS;
size = CONFIG_BL2_SIZE;
break;copy_bl2 = get_irom_func(SPI_INDEX);
+#endif case BOOT_MODE_MMC:
offset = BL2_START_OFFSET;
copy_bl2 = get_irom_func(MMC_INDEX);size = BL2_SIZE_BLOC_COUNT;
break;CONFIG_SYS_TEXT_BASE);
+#ifdef CONFIG_SUPPORT_EMMC_BOOT case BOOT_MODE_EMMC: /* Set the FSYS1 clock divisor value for EMMC boot */ emmc_boot_clk_div_set(); @@ -114,6 +128,8 @@ void copy_uboot_to_ram(void) copy_bl2_from_emmc(BL2_SIZE_BLOC_COUNT, CONFIG_SYS_TEXT_BASE); end_bootop_from_emmc(); break; +#endif +#ifdef CONFIG_USB_BOOTING case BOOT_MODE_USB: /* * iROM needs program flow prediction to be disabled @@ -124,14 +140,50 @@ void copy_uboot_to_ram(void) usb_copy(); config_branch_prediction(is_cr_z_set); break; +#endif default: break; }
- if (copy_bl2)
copy_bl2(offset, size, CONFIG_SYS_TEXT_BASE);
+void memzero(void *s, size_t n) +{
- char *ptr = s;
- size_t i;
- for (i = 0; i < n; i++)
*ptr++ = '\0';
- Set up the U-Boot global_data pointer
- This sets the address of the global data, and sets up basic values.
- @param gdp Value to give to gd
+static void setup_global_data(gd_t *gdp) +{
- gd = gdp;
- memzero((void *)gd, sizeof(gd_t));
- gd->flags |= GD_FLG_RELOC;
- gd->baudrate = CONFIG_BAUDRATE;
- gd->have_console = 1;
void board_init_f(unsigned long bootflag) {
__aligned(8) gd_t local_gd; __attribute__((noreturn)) void (*uboot)(void);
setup_global_data(&local_gd);
if (do_lowlevel_init())
power_exit_wakeup();
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index 36b98c8..75dbe26 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -115,7 +115,7 @@ #define EXYNOS5_DMC_PHY0_BASE 0x10C00000 #define EXYNOS5_DMC_PHY1_BASE 0x10C10000
maybe it can be dmc0 and dmc1 If you want to keep the interface with exynos4.
#define EXYNOS5_GPIO_PART3_BASE 0x10D10000 -#define EXYNOS5_DMC_CTRL_BASE 0x10DD0000 +#define EXYNOS5_DMC0_BASE 0x10DD0000
why?
#define EXYNOS5_GPIO_PART1_BASE 0x11400000 #define EXYNOS5_MIPI_DSIM_BASE 0x11D00000 #define EXYNOS5_USB_HOST_EHCI_BASE 0x12110000 @@ -135,6 +135,7 @@
#define EXYNOS5_ADC_BASE DEVICE_NOT_AVAILABLE #define EXYNOS5_MODEM_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS5_DMC1_BASE DEVICE_NOT_AVAILABLE
It looks weird.
#ifndef __ASSEMBLY__ #include <asm/io.h> @@ -237,6 +238,8 @@ SAMSUNG_BASE(power, POWER_BASE) SAMSUNG_BASE(spi, SPI_BASE) SAMSUNG_BASE(spi_isp, SPI_ISP_BASE) SAMSUNG_BASE(tzpc, TZPC_BASE) +SAMSUNG_BASE(dmc0, DMC0_BASE) +SAMSUNG_BASE(dmc1, DMC1_BASE) #endif
#endif /* _EXYNOS4_CPU_H */
@@ -241,7 +245,7 @@
Thanks, Minkyu Kang.
Hi Minkyu Kang,
Thank you for comments. Please find the clarificatio below.
Changes in V2: - Rebased on latest u-boot-samsung tree. - Incorporated review comments from Minkyu Kang. Changes in V3: - Optimised the mem_ctrl_init function for exynos4. - Removed magic numbers. arch/arm/cpu/armv7/exynos/Makefile | 17 +- .../arm/cpu/armv7/exynos}/clock_init.h | 0 arch/arm/cpu/armv7/exynos/clock_init_exynos4.c | 94 +++++ .../arm/cpu/armv7/exynos/clock_init_exynos5.c | 47 +-- arch/arm/cpu/armv7/exynos/common_setup.h | 43 ++ .../arm/cpu/armv7/exynos}/dmc_common.c | 7 +- .../arm/cpu/armv7/exynos}/dmc_init_ddr3.c | 19 +- arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c | 212 ++++++++++ .../arm/cpu/armv7/exynos/exynos4_setup.h | 397 +++++++++---------- .../arm/cpu/armv7/exynos/exynos5_setup.h | 28 +- arch/arm/cpu/armv7/exynos/lowlevel_init.c | 73 ++++ .../arm/cpu/armv7/exynos}/spl_boot.c | 74 +++- arch/arm/include/asm/arch-exynos/cpu.h | 5 +- board/samsung/origen/Makefile | 11 +- board/samsung/origen/lowlevel_init.S | 357 ----------------- board/samsung/origen/mem_setup.S | 421 -------------------- board/samsung/origen/mmc_boot.c | 58 --- board/samsung/smdk5250/Makefile | 14 +- board/samsung/smdkv310/Makefile | 10 +- board/samsung/smdkv310/lowlevel_init.S | 414 ------------------- board/samsung/smdkv310/mem_setup.S | 365 ----------------- board/samsung/smdkv310/mmc_boot.c | 60 --- include/configs/exynos5250-dt.h | 8 +- include/configs/origen.h | 8 +- include/configs/smdkv310.h | 7 +- 25 files changed, 770 insertions(+), 1979 deletions(-) rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/clock_init.h (100%) create mode 100644 arch/arm/cpu/armv7/exynos/clock_init_exynos4.c rename board/samsung/smdk5250/clock_init.c => arch/arm/cpu/armv7/exynos/clock_init_exynos5.c (95%) create mode 100644 arch/arm/cpu/armv7/exynos/common_setup.h rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/dmc_common.c (97%) rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/dmc_init_ddr3.c (95%) create mode 100644 arch/arm/cpu/armv7/exynos/dmc_init_exynos4.c rename board/samsung/origen/origen_setup.h => arch/arm/cpu/armv7/exynos/exynos4_setup.h (65%) rename board/samsung/smdk5250/setup.h => arch/arm/cpu/armv7/exynos/exynos5_setup.h (96%) create mode 100644 arch/arm/cpu/armv7/exynos/lowlevel_init.c rename {board/samsung/smdk5250 => arch/arm/cpu/armv7/exynos}/spl_boot.c (74%) delete mode 100644 board/samsung/origen/lowlevel_init.S delete mode 100644 board/samsung/origen/mem_setup.S delete mode 100644 board/samsung/origen/mmc_boot.c delete mode 100644 board/samsung/smdkv310/lowlevel_init.S delete mode 100644 board/samsung/smdkv310/mem_setup.S delete mode 100644 board/samsung/smdkv310/mmc_boot.c
- project.
- MA 02111-1307 USA
NAK.
Will correct this
sdelay(0x10000);
sdelay(0x10000);
sdelay(0x30000);
int reset)
Will correct this.
reset_phy_ctrl();
if (reset)
reset_phy_ctrl(); /* Set Impedance Output Driver */ val = (mem->impedance << CA_CK_DRVR_DS_OFFSET) |
&phy0_ctrl->phy_con12); writel(val | (mem->ctrl_start << PHY_CON12_CTRL_START_SHIFT),
&phy1_ctrl->phy_con12); update_reset_dll(dmc, DDR_MODE_DDR3); writel(mem->concontrol | (mem->rd_fetch << CONCONTROL_RD_FETCH_SHIFT),
&dmc->concontrol);
&dmc->concontrol); /* Memory Channel Inteleaving Size */ writel(mem->iv_size, &dmc->ivcontrol);
&dmc->prechconfig);
&dmc->prechconfig); /* Power Down mode Configuration */ writel(mem->dpwrdn_cyc << PWRDNCONFIG_DPWRDN_CYC_SHIFT |
- project.
- MA 02111-1307 USA
.direct_cmd_msr = {
if (ctrl_no) {
&dmc->phycontrol1);
&dmc->phycontrol1);
} else {
&dmc->phycontrol0);
&dmc->phycontrol0);
int i;
if (chip)
&dmc->directcmd);
* DLL Parameter Setting:
* Termination: Enable R/W
* Phase Delay for DQS Cleaning: 180' Shift
* ZQ Calibration
* Termination: Disable
* Auto Calibration Start: Enable
sdelay(0x100000);
* Update DLL Information:
* Force DLL Resyncronization
/* Set DLL Parameters */
/* DLL Start */
/* Set Clock Ratio of Bus clock to Memory Clock */
* Memor Burst length: 8
* Number of chips: 2
* Memory Bus width: 32 bit
* Memory Type: DDR3
* Additional Latancy for PLL: 1 Cycle
/* Config Precharge Policy */
* TimingAref, TimingRow, TimingData, TimingPower Setting:
* Values as per Memory AC Parameters
/* Chip0: NOP Command: Assert and Hold CKE to high level */
sdelay(0x100000);
/* Chip0: EMRS2, EMRS3, EMRS, MRS Commands Using Direct Command */
sdelay(0x100000);
/* Chip0: ZQINIT */
sdelay(0x100000);
sdelay(0x100000);
/* Chip1: EMRS2, EMRS3, EMRS, MRS Commands Using Direct Command */
sdelay(0x100000);
/* Chip1: ZQINIT */
sdelay(0x100000);
sdelay(0x100000);
* 1: half_sync
* 0: full_sync
/* Update MIU Configuration */
+#else
+#endif +#endif
/* DREX0 */
dmc_init(dmc);
dmc_init(dmc);
| (NO_PARITY << 3) \
| (STOP_BIT_1 << 2) \
- Loop_Back: No
- Break Signal: No
| (LOOP_BACK << 5) \
unsigned timingref;
unsigned timingrow;
unsigned zqcontrol;
unsigned control0;
unsigned control1;
unsigned control2;
unsigned dll_on;
- Tx Fifo Reset: No
- Rx Fifo Reset: No
- FIFO Enable: Yes
| (FIFO_ENABLE << 0))
- 115200 BAUD:
- 115200 BAUD:
| NUM_CHIP_2 | BL_8)
int reset);
- project.
- MA 02111-1307 USA
DO_WAKEUP = 1 << 0,
DO_CLOCKS = 1 << 1,
DO_UART = 1 << 3,
int actions = 0;
arch_cpu_init();
break;
case S5P_CHECK_LPA:
break;
default:
tzpc_init();
return cr & CR_Z;
} +#endif
int is_cr_z_set;
int is_cr_z_set;
unsigned int sec_boot_check; /* Read iRAM location to check for secondary USB boot mode */ sec_boot_check = readl(EXYNOS_IRAM_SECONDARY_BASE); if (sec_boot_check == EXYNOS_USB_SECONDARY_BOOT) bootmode = BOOT_MODE_USB;
bootmode = readl(samsung_get_base_power()) & OM_STAT; switch (bootmode) {
copy_bl2 = get_irom_func(SPI_INDEX); break;
size = BL2_SIZE_BLOC_COUNT; copy_bl2 = get_irom_func(MMC_INDEX);
CONFIG_SYS_TEXT_BASE); break;
if (copy_bl2)
char *ptr = s;
size_t i;
*ptr++ = '\0';
gd = gdp;
copy_uboot_to_ram(); /* Jump to U-Boot image */
EXYNOS4 donot have seperate Phy controller it is a part of DMC controller. then I need to add following for EXYNOS4 EXYNOS4_DMC_PHY1_BASE DEVICE_NOT_AVAILABLE EXYNOS4_DMC_PHY_BASE DEVICE_NOT_AVAILABLE
why?
if we want to make funstion to get the DMC base address it is needed to be added for EXYNOS5 as well hence made this change.
It looks weird.
Since EXYNOS4 has 2 DMC controllers and EXYNOS5 has only 1 DMC controller I had to add this to avoid compilation error. Please do let me know if you are fine with these changes.
@@ -241,7 +245,7 @@
Thanks, Minkyu Kang. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
why?
It looks weird.
I suggest following.
EXYNOS4_DMC_BASE 0x- EXYNOS4_DMC_PHY_BASE DEVICE_NOT_AVAILABLE
EXYNOS4X12_DMC_BASE 0x- EXYNOS4X12_DMC_PHY_BASE DEVICE_NOT_AVAILABLE
EXYNOS5_DMC_PHY_BASE 0x- EXYNOS5_DMC_BASE 0x-
then we need to add 2 SAMSUNG_BASE.
SAMSUNG_BASE(dmc, DMC_BASE) SAMSUNG_BASE(dmc_phy, DMC_PHY_BASE)
and we can access dmc1 and dmc phy1 by offset.
What do you think about it?
Hi Minkyu Kang,
why?
It looks weird.
Needed a clarification:
But we have 2 DMC controller DMC0 and DMC1 so it will be EXYNOS4_DMC0_BASE and EXYNOS4_DMC1_BASE EXYNOS4_DMC1_BASE not available in EXYNOS5
It has 2 phy controllers so it would be EXYNOS5_DMC_PHY0_BASE and EXYNOS5_DMC_PHY1_BASE and it would be DEVICE_NOT_AVAILABLE in other 2 SOC
On 04/07/13 14:27, Rajeshwari Birje wrote:
Hi Minkyu Kang,
why?
It looks weird.
no. It means.. DO NOT define dmc0 and dmc1 separately. We need dmc base and we can access dmc1. For example, uart have 4 devices but we defined uart0 address as UART's base. and access by offset.
u32 offset = dev_index * sizeof(struct s5p_uart); return (struct s5p_uart *)(samsung_get_base_uart() + offset);
no.
Hi Minkyu Kang,
Hi Minkyu Kang,
why?
It looks weird.
Thank you for clarification. Will make this change and send a new patch set.
no.
Minkyu Kang
Rajeshwari Birje
Rajeshwari Shinde
