[U-Boot] [PATCH v2] configs: imx: Make CONFIG_SYS_PROMPT uniform across FSL boards
There is no real benefit in adding the board name into U-boot's prompt, so remove the custom CONFIG_SYS_PROMPT definitions so that the standard "=> " prompt is used across FSL boards.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Remove CONFIG_SYS_PROMPT completely, instead of replacing with '=>'
include/configs/mx25pdk.h | 1 - include/configs/mx28evk.h | 1 - include/configs/mx31pdk.h | 1 - include/configs/mx35pdk.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx53smd.h | 1 - include/configs/mx6qarm2.h | 1 - include/configs/mx6sabre_common.h | 1 - 10 files changed, 10 deletions(-)
diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index 543c415..79b36c2 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -65,7 +65,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 0
/* U-Boot general configuration */ -#define CONFIG_SYS_PROMPT "MX25PDK U-Boot > " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print buffer sz */ diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 07f88ca..22fdb3a 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -14,7 +14,6 @@ /* System configurations */ #define CONFIG_MX28 /* i.MX28 SoC */ #define CONFIG_MACH_TYPE MACH_TYPE_MX28EVK -#define CONFIG_SYS_PROMPT "MX28EVK U-Boot > "
/* U-Boot Commands */ #define CONFIG_SYS_NO_FLASH diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index d41f2cd..591ab54 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -120,7 +120,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "MX31PDK U-Boot > " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 2f59104..d72b312 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -136,7 +136,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "MX35 U-Boot > " #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */
diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 04f518a..4edbc4c 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -219,7 +219,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "MX51EVK U-Boot > " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index fe5cf3c..99c40d8 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -136,7 +136,6 @@ /* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "MX53EVK U-Boot > " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index bd2fa43..e000839 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -178,7 +178,6 @@ /* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "MX53LOCO U-Boot > " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */
diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index 12b2c0d..a1d5b70 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -121,7 +121,6 @@ /* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "MX53SMD U-Boot > " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */
diff --git a/include/configs/mx6qarm2.h b/include/configs/mx6qarm2.h index ef3058c..d759de7 100644 --- a/include/configs/mx6qarm2.h +++ b/include/configs/mx6qarm2.h @@ -114,7 +114,6 @@ /* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP #define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "MX6QARM2 U-Boot > " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256
diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index bf6113b..0fb8e0b 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -171,7 +171,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#define CONFIG_SYS_PROMPT "U-Boot > " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256
Hi Stefano,
On Fri, Nov 1, 2013 at 8:12 AM, Fabio Estevam fabio.estevam@freescale.com wrote:
Changes since v1:
Forgot to mention that this patch depends on Rob's: http://patchwork.ozlabs.org/patch/279334/
,otherwise we get build errors.
Regards,
Fabio Estevam
Hi Fabio,
On 04/11/2013 00:50, Fabio Estevam wrote:
Hi Stefano,
Changes since v1:
Right, I am tracking Rob's patch before including yours.
Best regards, Stefano Babic
Applied to u-boot-imx, thanks.
Fabio Estevam
Fabio Estevam
Stefano Babic
