[PATCH 0/2] tpm: Add support for TPMv2.x I2C chips
Add a tpm driver that should support any TPMv2 compliant I2C chips, such as the NPCT75X chip. In my testing I also noticed that the timeouts weren't set before requesting the locality so I have included a fix.
Eddie James (2): tpm: core: Set timeouts before requesting locality tpm: add support for TPMv2.x I2C chips
drivers/tpm/Kconfig | 9 ++ drivers/tpm/Makefile | 1 + drivers/tpm/tpm2_tis_core.c | 7 +- drivers/tpm/tpm2_tis_i2c.c | 171 ++++++++++++++++++++++++++++++++++++ 4 files changed, 185 insertions(+), 3 deletions(-) create mode 100644 drivers/tpm/tpm2_tis_i2c.c
Requesting the locality uses the timeout values, so they need to be set beforehand.
Signed-off-by: Eddie James eajames@linux.ibm.com --- drivers/tpm/tpm2_tis_core.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/tpm/tpm2_tis_core.c b/drivers/tpm/tpm2_tis_core.c index 51392c4584..985a816219 100644 --- a/drivers/tpm/tpm2_tis_core.c +++ b/drivers/tpm/tpm2_tis_core.c @@ -433,15 +433,16 @@ int tpm_tis_init(struct udevice *dev) log_err("Driver bug. No bus ops defined\n"); return -1; } - ret = tpm_tis_request_locality(dev, 0); - if (ret) - return ret;
chip->timeout_a = TIS_SHORT_TIMEOUT_MS; chip->timeout_b = TIS_LONG_TIMEOUT_MS; chip->timeout_c = TIS_SHORT_TIMEOUT_MS; chip->timeout_d = TIS_SHORT_TIMEOUT_MS;
+ ret = tpm_tis_request_locality(dev, 0); + if (ret) + return ret; + /* Disable interrupts */ phy_ops->read32(dev, TPM_INT_ENABLE(chip->locality), &tmp); tmp |= TPM_INTF_CMD_READY_INT | TPM_INTF_LOCALITY_CHANGE_INT |
Hi Eddie,
Thanks for the patches. I am currently traveling so apologies for the slow replies. This one looks good, I'll have a look at the rest once I get back
if (ret)
return ret; chip->timeout_a = TIS_SHORT_TIMEOUT_MS; chip->timeout_b = TIS_LONG_TIMEOUT_MS; chip->timeout_c = TIS_SHORT_TIMEOUT_MS; chip->timeout_d = TIS_SHORT_TIMEOUT_MS;
if (ret)
return ret;
-- 2.27.0
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Reviewed-by: Joel Stanley joel@jms.id.au
if (ret)
if (ret)
return ret;
-- 2.27.0
Add the tpm2_tis_i2c driver that should support any TPMv2 compliant I2C chips, such as the NPCT75X chip.
Signed-off-by: Eddie James eajames@linux.ibm.com --- drivers/tpm/Kconfig | 9 ++ drivers/tpm/Makefile | 1 + drivers/tpm/tpm2_tis_i2c.c | 171 +++++++++++++++++++++++++++++++++++++ 3 files changed, 181 insertions(+) create mode 100644 drivers/tpm/tpm2_tis_i2c.c
diff --git a/drivers/tpm/Kconfig b/drivers/tpm/Kconfig index eceff27d5f..d59102d9a6 100644 --- a/drivers/tpm/Kconfig +++ b/drivers/tpm/Kconfig @@ -185,6 +185,15 @@ config TPM2_TIS_SPI to the device using the standard TPM Interface Specification (TIS) protocol.
+config TPM2_TIS_I2C + bool "Enable support for TPMv2.x I2C chips" + depends on TPM_V2 && DM_I2C + help + This driver supports TPMv2.x devices connected on the I2C bus. + The usual TPM operations and the 'tpm' command can be used to talk + to the device using the standard TPM Interface Specification (TIS) + protocol. + config TPM2_FTPM_TEE bool "TEE based fTPM Interface" depends on TEE && OPTEE && TPM_V2 diff --git a/drivers/tpm/Makefile b/drivers/tpm/Makefile index 51725230c7..9540fd7fe7 100644 --- a/drivers/tpm/Makefile +++ b/drivers/tpm/Makefile @@ -13,5 +13,6 @@ obj-$(CONFIG_TPM_ST33ZP24_SPI) += tpm_tis_st33zp24_spi.o obj-$(CONFIG_$(SPL_TPL_)TPM2_CR50_I2C) += cr50_i2c.o obj-$(CONFIG_TPM2_TIS_SANDBOX) += tpm2_tis_sandbox.o sandbox_common.o obj-$(CONFIG_TPM2_TIS_SPI) += tpm2_tis_core.o tpm2_tis_spi.o +obj-$(CONFIG_TPM2_TIS_I2C) += tpm2_tis_core.o tpm2_tis_i2c.o obj-$(CONFIG_TPM2_FTPM_TEE) += tpm2_ftpm_tee.o obj-$(CONFIG_TPM2_MMIO) += tpm2_tis_core.o tpm2_tis_mmio.o diff --git a/drivers/tpm/tpm2_tis_i2c.c b/drivers/tpm/tpm2_tis_i2c.c new file mode 100644 index 0000000000..33cd5bb84b --- /dev/null +++ b/drivers/tpm/tpm2_tis_i2c.c @@ -0,0 +1,171 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2022 IBM Corp. + */ + +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <i2c.h> +#include <log.h> +#include <tpm-v2.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/errno.h> +#include <linux/compiler.h> +#include <linux/types.h> +#include <linux/unaligned/be_byteshift.h> +#include <asm-generic/gpio.h> + +#include "tpm_tis.h" +#include "tpm_internal.h" + +struct tpm_tis_chip_data { + unsigned int pcr_count; + unsigned int pcr_select_min; +}; + +static uint tpm_tis_i2c_address_to_register(u32 addr) +{ + addr &= 0xFFF; + + /* + * Adapt register addresses that have changed compared to older TIS + * version. + */ + switch (addr) { + case TPM_ACCESS(0): + return 0x04; + case TPM_DID_VID(0): + return 0x48; + case TPM_RID(0): + return 0x4C; + default: + return addr; + } +} + +static int tpm_tis_i2c_read(struct udevice *dev, u32 addr, u16 len, u8 *in) +{ + int rc; + int count = 0; + uint reg = tpm_tis_i2c_address_to_register(addr); + + do { + rc = dm_i2c_read(dev, reg, in, len); + udelay(SLEEP_DURATION_US); + } while (rc && count++ < MAX_COUNT); + + return rc; +} + +static int tpm_tis_i2c_write(struct udevice *dev, u32 addr, u16 len, + const u8 *out) +{ + int rc; + int count = 0; + uint reg = tpm_tis_i2c_address_to_register(addr); + + do { + rc = dm_i2c_write(dev, reg, out, len); + udelay(SLEEP_DURATION_US); + } while (rc && count++ < MAX_COUNT); + + return rc; +} + +static int tpm_tis_i2c_read32(struct udevice *dev, u32 addr, u32 *result) +{ + __le32 result_le; + int rc; + + rc = tpm_tis_i2c_read(dev, addr, sizeof(u32), (u8 *)&result_le); + if (!rc) + *result = le32_to_cpu(result_le); + + return rc; +} + +static int tpm_tis_i2c_write32(struct udevice *dev, u32 addr, u32 value) +{ + __le32 value_le = cpu_to_le32(value); + + return tpm_tis_i2c_write(dev, addr, sizeof(value), (u8 *)&value_le); +} + +static struct tpm_tis_phy_ops phy_ops = { + .read_bytes = tpm_tis_i2c_read, + .write_bytes = tpm_tis_i2c_write, + .read32 = tpm_tis_i2c_read32, + .write32 = tpm_tis_i2c_write32, +}; + +static int tpm_tis_i2c_probe(struct udevice *udev) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(udev); + struct tpm_chip_priv *priv = dev_get_uclass_priv(udev); + int rc; + u8 loc = 0; + + tpm_tis_ops_register(udev, &phy_ops); + + /* + * Force locality 0. The core driver doesn't actually write the + * locality register and instead just reads/writes various access + * bits of the selected locality. + */ + rc = dm_i2c_write(udev, 0, &loc, 1); + if (rc) + return rc; + + rc = tpm_tis_init(udev); + if (rc) + return rc; + + priv->pcr_count = drv_data->pcr_count; + priv->pcr_select_min = drv_data->pcr_select_min; + priv->version = TPM_V2; + + return 0; +} + +static int tpm_tis_i2c_remove(struct udevice *udev) +{ + return tpm_tis_cleanup(udev); +} + +static const struct tpm_ops tpm_tis_i2c_ops = { + .open = tpm_tis_open, + .close = tpm_tis_close, + .get_desc = tpm_tis_get_desc, + .send = tpm_tis_send, + .recv = tpm_tis_recv, + .cleanup = tpm_tis_cleanup, +}; + +static const struct tpm_tis_chip_data tpm_tis_std_chip_data = { + .pcr_count = 24, + .pcr_select_min = 3, +}; + +static const struct udevice_id tpm_tis_i2c_ids[] = { + { + .compatible = "nuvoton,npct75x", + .data = (ulong)&tpm_tis_std_chip_data, + }, + { + .compatible = "tcg,tpm-tis-i2c", + .data = (ulong)&tpm_tis_std_chip_data, + }, + { } +}; + +U_BOOT_DRIVER(tpm_tis_i2c) = { + .name = "tpm_tis_i2c", + .id = UCLASS_TPM, + .of_match = tpm_tis_i2c_ids, + .ops = &tpm_tis_i2c_ops, + .probe = tpm_tis_i2c_probe, + .remove = tpm_tis_i2c_remove, + .priv_auto_alloc_size = sizeof(struct tpm_chip), +};
help
protocol.
- Copyright 2022 IBM Corp.
addr &= 0xFFF;
* version.
switch (addr) {
case TPM_ACCESS(0):
return 0x04;
return 0x48;
case TPM_RID(0):
return 0x4C;
default:
return addr;
int rc;
int count = 0;
do {
return rc;
const u8 *out)
int rc;
int count = 0;
do {
return rc;
__le32 result_le;
int rc;
if (!rc)
return rc;
int rc;
u8 loc = 0;
if (rc)
return rc;
if (rc)
return rc;
.pcr_count = 24,
The .data pointers are the same, so could we do away with it all together and just have
#define TPM_TIS_I2C_PCR_COUNT 24 #define TPM_TIS_I2C_PCR_SELECT_MIN 3
Aside from that small cleanup:
.id = UCLASS_TPM,
2.27.0
Hi Eddie,
Thanks for the patch.
- .pcr_count = 24,
- .pcr_select_min = 3,
- .name = "tpm_tis_i2c",
- .id = UCLASS_TPM,
- .of_match = tpm_tis_i2c_ids,
- .ops = &tpm_tis_i2c_ops,
- .probe = tpm_tis_i2c_probe,
- .remove = tpm_tis_i2c_remove,
- .priv_auto_alloc_size = sizeof(struct tpm_chip),
Shouldn't this be .priv_auto only? IIRC we got rid of the .priv_auto_alloc_size a while back? If so I can fix this while merging
Regards /Ilias
2.27.0
On 5/23/22 01:12, Ilias Apalodimas wrote:
Hi Eddie,
- .pcr_count = 24,
- .id = UCLASS_TPM,
Yes, I think so. I tested with an older u-boot (openbmc uses a modified v2019.04) with all the TPM core patches, and I think I missed this bit in rebasing.
Thanks,
Eddie
Regards /Ilias
2.27.0
Hi Eddie,
- .pcr_count = 24,
- .id = UCLASS_TPM,
No worries, I can fix this while merging, there's no need for a v2. I don't see anything obviously wrong with the patchset, unfortunately I don't have an i2c tpm to test. Anyway
P.S: Was the new TIS API useful?
Thanks /Ilias
Thanks,
Eddie
Regards /Ilias
2.27.0
On Mon, 23 May 2022 at 13:25, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
I'll reply on behalf of Eddie; he said it made it much easier to implement! Thanks!
We've backported the patches to our v2019.04 branch and are using them there.
Cheers,
Joel
Cheers,
Great thanks! Patches are in -master now
Cheers /Ilias
Joel
Eddie James
Ilias Apalodimas
Joel Stanley
