[U-Boot] [PATCH v6.2] cmd: env: add "-e" option for handling UEFI variables
# This is a replacement of my patch#1[1] with minor updates to fix # travis build errors. The other patches are the exact same as in v6. # [1] https://lists.denx.de/pipermail/u-boot/2019-January/356035.html
"env [print|set] -e" allows for handling uefi variables without knowing details about mapping to corresponding u-boot variables.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- MAINTAINERS | 1 + cmd/Kconfig | 6 + cmd/Makefile | 1 + cmd/nvedit.c | 28 +++- cmd/nvedit_efi.c | 340 ++++++++++++++++++++++++++++++++++++++++++++++ include/command.h | 4 + 6 files changed, 379 insertions(+), 1 deletion(-) create mode 100644 cmd/nvedit_efi.c
diff --git a/MAINTAINERS b/MAINTAINERS index ae825014bda9..22ac686ab2d6 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -438,6 +438,7 @@ F: lib/efi*/ F: test/py/tests/test_efi* F: test/unicode_ut.c F: cmd/bootefi.c +F: cmd/nvedit_efi.c F: tools/file2include.c
FPGA diff --git a/cmd/Kconfig b/cmd/Kconfig index ea1a325eb301..c66333598d31 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -53,6 +53,12 @@ config SYS_PROMPT This string is displayed in the command line to the left of the cursor.
+config CMD_NVEDIT_EFI + bool + depends on EFI_LOADER + default y + imply HEXDUMP + menu "Autoboot options"
config AUTOBOOT diff --git a/cmd/Makefile b/cmd/Makefile index 15ae4d250f50..142e0ee222ca 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -98,6 +98,7 @@ obj-$(CONFIG_CMD_MTD) += mtd.o obj-$(CONFIG_CMD_MTDPARTS) += mtdparts.o obj-$(CONFIG_CMD_NAND) += nand.o obj-$(CONFIG_CMD_NET) += net.o +obj-$(CONFIG_CMD_NVEDIT_EFI) += nvedit_efi.o obj-$(CONFIG_CMD_ONENAND) += onenand.o obj-$(CONFIG_CMD_OSD) += osd.o obj-$(CONFIG_CMD_PART) += part.o diff --git a/cmd/nvedit.c b/cmd/nvedit.c index ce746bbf1b3e..07285b877f40 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -119,6 +119,11 @@ static int do_env_print(cmd_tbl_t *cmdtp, int flag, int argc, int rcode = 0; int env_flag = H_HIDE_DOT;
+#if defined(CONFIG_CMD_NVEDIT_EFI) + if (argc > 1 && argv[1][0] == '-' && argv[1][1] == 'e') + return do_env_print_efi(cmdtp, flag, --argc, ++argv); +#endif + if (argc > 1 && argv[1][0] == '-' && argv[1][1] == 'a') { argc--; argv++; @@ -216,6 +221,12 @@ static int _do_env_set(int flag, int argc, char * const argv[], int env_flag) ENTRY e, *ep;
debug("Initial value for argc=%d\n", argc); + +#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_CMD_NVEDIT_EFI) + if (argc > 1 && argv[1][0] == '-' && argv[1][1] == 'e') + return do_env_set_efi(NULL, flag, --argc, ++argv); +#endif + while (argc > 1 && **(argv + 1) == '-') { char *arg = *++argv;
@@ -1263,14 +1274,21 @@ static char env_help_text[] = "env import [-d] [-t [-r] | -b | -c] addr [size] [var ...] - import environment\n" #endif "env print [-a | name ...] - print environment\n" +#if defined(CONFIG_CMD_NVEDIT_EFI) + "env print -e [name ...] - print UEFI environment\n" +#endif #if defined(CONFIG_CMD_RUN) "env run var [...] - run commands in an environment variable\n" #endif #if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) "env save - save environment\n" #endif +#if defined(CONFIG_CMD_NVEDIT_EFI) + "env set [-e | -f] name [arg ...]\n"; +#else "env set [-f] name [arg ...]\n"; #endif +#endif
U_BOOT_CMD( env, CONFIG_SYS_MAXARGS, 1, do_env, @@ -1295,6 +1313,10 @@ U_BOOT_CMD_COMPLETE( printenv, CONFIG_SYS_MAXARGS, 1, do_env_print, "print environment variables", "[-a]\n - print [all] values of all environment variables\n" +#if defined(CONFIG_CMD_NVEDIT_EFI) + "printenv -e [<name> ...]\n" + " - print UEFI variable 'name' or all the variables\n" +#endif "printenv name ...\n" " - print value of environment variable 'name'", var_complete @@ -1322,7 +1344,11 @@ U_BOOT_CMD_COMPLETE( U_BOOT_CMD_COMPLETE( setenv, CONFIG_SYS_MAXARGS, 0, do_env_set, "set environment variables", - "[-f] name value ...\n" +#if defined(CONFIG_CMD_NVEDIT_EFI) + "-e <name> [<value> ...]\n" + " - set UEFI variable 'name' to 'value' ...'\n" +#endif + "setenv [-f] name value ...\n" " - [forcibly] set environment variable 'name' to 'value ...'\n" "setenv [-f] name\n" " - [forcibly] delete environment variable 'name'", diff --git a/cmd/nvedit_efi.c b/cmd/nvedit_efi.c new file mode 100644 index 000000000000..08a7889139e6 --- /dev/null +++ b/cmd/nvedit_efi.c @@ -0,0 +1,340 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Integrate UEFI variables to u-boot env interface + * + * Copyright (c) 2018 AKASHI Takahiro, Linaro Limited + */ + +#include <charset.h> +#include <common.h> +#include <command.h> +#include <efi_loader.h> +#include <exports.h> +#include <hexdump.h> +#include <malloc.h> +#include <linux/kernel.h> + +/* + * From efi_variable.c, + * + * Mapping between UEFI variables and u-boot variables: + * + * efi_$guid_$varname = {attributes}(type)value + */ + +static const struct { + u32 mask; + char *text; +} efi_var_attrs[] = { + {EFI_VARIABLE_NON_VOLATILE, "NV"}, + {EFI_VARIABLE_BOOTSERVICE_ACCESS, "BS"}, + {EFI_VARIABLE_RUNTIME_ACCESS, "RT"}, + {EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS, "AW"}, + {EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS, "AT"}, +}; + +/* show information of named variable */ +static void print_variable_info(u16 *name, efi_guid_t *guid) +{ + u32 attributes; + u8 *data; + efi_uintn_t size; + int count, i; + efi_status_t ret; + + data = NULL; + size = 0; + ret = efi_get_variable(name, guid, &attributes, &size, data); + if (ret == EFI_BUFFER_TOO_SMALL) { + data = malloc(size); + if (!data) + goto out; + + ret = efi_get_variable(name, guid, &attributes, &size, data); + } + if (ret == EFI_NOT_FOUND) { + printf("Error: "%ls" not defined\n", name); + goto out; + } + if (ret != EFI_SUCCESS) + goto out; + + printf("%ls:", name); + for (count = 0, i = 0; i < ARRAY_SIZE(efi_var_attrs); i++) + if (attributes & efi_var_attrs[i].mask) { + if (count) + putc('|'); + else + putc(' '); + count++; + puts(efi_var_attrs[i].text); + } + printf(", DataSize = 0x%zx\n", size); + print_hex_dump(" ", DUMP_PREFIX_OFFSET, 16, 1, data, size, true); + + return; +out: + free(data); +} + +static int efi_dump_var_ones(int argc, char * const argv[]) +{ + u16 *var_name16, *p; + efi_uintn_t buf_size, size; + + buf_size = 128; + var_name16 = malloc(buf_size); + if (!var_name16) + return CMD_RET_FAILURE; + + for (; argc > 0; argc--, argv++) { + size = (utf8_utf16_strlen(argv[0]) + 1) * sizeof(u16); + if (buf_size < size) { + buf_size = size; + p = realloc(var_name16, buf_size); + if (!p) { + free(var_name16); + return CMD_RET_FAILURE; + } + var_name16 = p; + } + + p = var_name16; + utf8_utf16_strcpy(&p, argv[0]); + + print_variable_info(var_name16, + (efi_guid_t *)&efi_global_variable_guid); + } + + free(var_name16); + + return CMD_RET_SUCCESS; +} + +static int efi_dump_var_all(void) +{ + u16 *var_name16, *p; + efi_uintn_t buf_size, size; + efi_guid_t guid; + efi_status_t ret; + + buf_size = 128; + var_name16 = malloc(buf_size); + if (!var_name16) + return CMD_RET_FAILURE; + + var_name16[0] = 0; + for (;;) { + size = buf_size; + ret = efi_get_next_variable_name(&size, var_name16, &guid); + if (ret == EFI_NOT_FOUND) + break; + if (ret == EFI_BUFFER_TOO_SMALL) { + buf_size = size; + p = realloc(var_name16, buf_size); + if (!p) { + free(var_name16); + return CMD_RET_FAILURE; + } + var_name16 = p; + ret = efi_get_next_variable_name(&size, var_name16, + &guid); + } + if (ret != EFI_SUCCESS) { + free(var_name16); + return CMD_RET_FAILURE; + } + + print_variable_info(var_name16, &guid); + } + + free(var_name16); + + return CMD_RET_SUCCESS; +} + +static int efi_dump_var(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + if (argc > 1) + /* show specified UEFI variables */ + return efi_dump_var_ones(--argc, ++argv); + + /* enumerate and show all UEFI variables */ + return efi_dump_var_all(); +} + +int do_env_print_efi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + efi_status_t r; + + /* Initialize EFI drivers */ + r = efi_init_obj_list(); + if (r != EFI_SUCCESS) { + printf("Error: Cannot initialize UEFI sub-system, r = %lu\n", + r & ~EFI_ERROR_MASK); + return CMD_RET_FAILURE; + } + + return efi_dump_var(cmdtp, flag, argc, argv); +} + +/* + * Interpret a given data string and append it to buffer. + * Buffer will be realloc'ed if necessary. + */ +static int append_value(char **bufp, size_t *sizep, char *data) +{ + char *tmp_buf = NULL, *new_buf = NULL, *value; + unsigned long len = 0; + + if (!strncmp(data, "=0x", 2)) { /* hexadecimal number */ + union { + u8 u8; + u16 u16; + u32 u32; + u64 u64; + } tmp_data; + unsigned long hex_value; + void *hex_ptr; + + data += 3; + len = strlen(data); + if ((len & 0x1)) /* not multiple of two */ + return -1; + + len /= 2; + if (len > 8) + return -1; + else if (len > 4) + len = 8; + else if (len > 2) + len = 4; + + /* convert hex hexadecimal number */ + if (strict_strtoul(data, 16, &hex_value) < 0) + return -1; + + tmp_buf = malloc(len); + if (!tmp_buf) + return -1; + + if (len == 1) { + tmp_data.u8 = hex_value; + hex_ptr = &tmp_data.u8; + } else if (len == 2) { + tmp_data.u16 = hex_value; + hex_ptr = &tmp_data.u16; + } else if (len == 4) { + tmp_data.u32 = hex_value; + hex_ptr = &tmp_data.u32; + } else { + tmp_data.u64 = hex_value; + hex_ptr = &tmp_data.u64; + } + memcpy(tmp_buf, hex_ptr, len); + value = tmp_buf; + + } else if (!strncmp(data, "=H", 2)) { /* hexadecimal-byte array */ + data += 2; + len = strlen(data); + if (len & 0x1) /* not multiple of two */ + return -1; + + len /= 2; + tmp_buf = malloc(len); + if (!tmp_buf) + return -1; + + if (hex2bin((u8 *)tmp_buf, data, len) < 0) + return -1; + + value = tmp_buf; + } else { /* string */ + if (!strncmp(data, "="", 2) || !strncmp(data, "=S"", 3)) { + if (data[1] == '"') + data += 2; + else + data += 3; + value = data; + len = strlen(data) - 1; + if (data[len] != '"') + return -1; + } else { + value = data; + len = strlen(data); + } + } + + new_buf = realloc(*bufp, *sizep + len); + if (!new_buf) + goto out; + + memcpy(new_buf + *sizep, value, len); + *bufp = new_buf; + *sizep += len; + +out: + free(tmp_buf); + + return 0; +} + +static int efi_set_var(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + char *var_name, *value = NULL; + efi_uintn_t size = 0; + u16 *var_name16 = NULL, *p; + efi_guid_t guid; + efi_status_t ret; + + if (argc == 1) + return CMD_RET_SUCCESS; + + var_name = argv[1]; + if (argc == 2) { + /* remove */ + value = NULL; + size = 0; + } else { /* set */ + argc -= 2; + argv += 2; + + for ( ; argc > 0; argc--, argv++) + if (append_value(&value, &size, argv[0]) < 0) { + ret = CMD_RET_FAILURE; + goto out; + } + } + + var_name16 = malloc((strlen(var_name) + 1) * 2); + p = var_name16; + utf8_utf16_strncpy(&p, var_name, strlen(var_name) + 1); + + guid = efi_global_variable_guid; + ret = efi_set_variable(var_name16, &guid, + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, size, value); + ret = (ret == EFI_SUCCESS ? CMD_RET_SUCCESS : CMD_RET_FAILURE); +out: + free(value); + free(var_name16); + + return ret; +} + +int do_env_set_efi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + efi_status_t r; + + /* Initialize EFI drivers */ + r = efi_init_obj_list(); + if (r != EFI_SUCCESS) { + printf("Error: Cannot initialize UEFI sub-system, r = %lu\n", + r & ~EFI_ERROR_MASK); + return CMD_RET_FAILURE; + } + + return efi_set_var(cmdtp, flag, argc, argv); +} diff --git a/include/command.h b/include/command.h index feddef300ccc..efc4dfc457c1 100644 --- a/include/command.h +++ b/include/command.h @@ -51,6 +51,10 @@ extern int do_run(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); #if defined(CONFIG_CMD_BOOTEFI) extern int do_bootefi_run(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); #endif +#if defined(CONFIG_CMD_NVEDIT_EFI) +int do_env_print_efi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); +int do_env_set_efi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); +#endif
/* common/command.c */ int _do_help (cmd_tbl_t *cmd_start, int cmd_items, cmd_tbl_t * cmdtp, int
Thanks for the patch. As long as we use U-Boot variables as backend for EFI variables this additional functionality is very helpful.
How about adding a Python test (in a separate patch)?
When resending, please, send the complete series marked as v7 or whatever is next.
Please, provide a change log separated via --- from the commit message (so that it is not copied into the repository).
- bool
- depends on EFI_LOADER
- default y
- imply HEXDUMP
Please, add a descriptive text so that this configuration item become editable with 'make menuconfig'.
- if (argc > 1 && argv[1][0] == '-' && argv[1][1] == 'e')
- if (argc > 1 && argv[1][0] == '-' && argv[1][1] == 'a') { argc--; argv++;
- while (argc > 1 && **(argv + 1) == '-') { char *arg = *++argv;
- "env print -e [name ...] - print UEFI environment\n"
There is a duplicate space before '-e'.
- "env set [-e | -f] name [arg ...]\n";
=> help env set env - environment handling commands
Usage: <snip> env set [-e | -f] name [arg ...]
This leaves the user without a clue what env set actually does and what -e is meant for.
Please, add a bit more text.
Wouldn't separate lines for 'set' with and without '-e' be more consistent with what you did for 'env print'?
Here too.
#endif +#endif
- "printenv -e [<name> ...]\n"
- " - print UEFI variable 'name' or all the variables\n"
- "-e <name> [<value> ...]\n"
- " - set UEFI variable 'name' to 'value' ...'\n"
- "setenv [-f] name value ...\n" " - [forcibly] set environment variable 'name' to 'value ...'\n" "setenv [-f] name\n" " - [forcibly] delete environment variable 'name'",
- Integrate UEFI variables to u-boot env interface
- Copyright (c) 2018 AKASHI Takahiro, Linaro Limited
- From efi_variable.c,
- Mapping between UEFI variables and u-boot variables:
- efi_$guid_$varname = {attributes}(type)value
- u32 mask;
- char *text;
- {EFI_VARIABLE_NON_VOLATILE, "NV"},
- {EFI_VARIABLE_BOOTSERVICE_ACCESS, "BS"},
- {EFI_VARIABLE_RUNTIME_ACCESS, "RT"},
- {EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS, "AW"},
- {EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS, "AT"},
The comments for a function should look like shown below. This allows to use Sphinx to generate a html documentation page. I prefer to add descriptions to all functions.
/** * print_variable_info() - show information about a variable * * @name: name of the variable * @guid: vendor GUID */
- u32 attributes;
- u8 *data;
- efi_uintn_t size;
- int count, i;
- efi_status_t ret;
- data = NULL;
- size = 0;
- ret = efi_get_variable(name, guid, &attributes, &size, data);
- if (ret == EFI_BUFFER_TOO_SMALL) {
if (!data)
goto out;
- if (ret == EFI_NOT_FOUND) {
printf("Error: \"%ls\" not defined\n", name);
goto out;
- if (ret != EFI_SUCCESS)
goto out;
- printf("%ls:", name);
- for (count = 0, i = 0; i < ARRAY_SIZE(efi_var_attrs); i++)
if (count)
putc('|');
else
putc(' ');
count++;
- printf(", DataSize = 0x%zx\n", size);
- print_hex_dump(" ", DUMP_PREFIX_OFFSET, 16, 1, data, size, true);
- return;
+out:
- free(data);
The naming of this function sounds strange. How about efi_dump_single_var() or just efi_dump_var()?
- u16 *var_name16, *p;
- efi_uintn_t buf_size, size;
- buf_size = 128;
- var_name16 = malloc(buf_size);
- if (!var_name16)
- for (; argc > 0; argc--, argv++) {
buf_size = size;
if (!p) {
free(var_name16);
var_name16 = p;
p = var_name16;
- free(var_name16);
- return CMD_RET_SUCCESS;
- efi_guid_t guid;
- efi_status_t ret;
- buf_size = 128;
- if (!var_name16)
- var_name16[0] = 0;
- for (;;) {
size = buf_size;
break;
buf_size = size;
if (!p) {
free(var_name16);
var_name16 = p;
&guid);
free(var_name16);
- free(var_name16);
- if (argc > 1)
- /* enumerate and show all UEFI variables */
- return efi_dump_var_all();
- efi_status_t r;
- /* Initialize EFI drivers */
- r = efi_init_obj_list();
- if (r != EFI_SUCCESS) {
- return efi_dump_var(cmdtp, flag, argc, argv);
- Interpret a given data string and append it to buffer.
- Buffer will be realloc'ed if necessary.
Please, use Sphinx style comment:
/** * append_value() - append data string to buffer * * Interpret a given data string and append it to buffer. * Buffer will be realloc'ed if necessary. * * @bufp: pointer to pointer to buffer * @sizep: pointer to size of buffer * (updated if buffer is reallocated) * @data: data to be interpreted and appended * Return: 0 on success */
- char *tmp_buf = NULL, *new_buf = NULL, *value;
- unsigned long len = 0;
- if (!strncmp(data, "=0x", 2)) { /* hexadecimal number */
union {
u8 u8;
u16 u16;
u32 u32;
u64 u64;
} tmp_data;
void *hex_ptr;
data += 3;
len = strlen(data);
return -1;
len /= 2;
if (len > 8)
return -1;
else if (len > 4)
len = 8;
else if (len > 2)
len = 4;
return -1;
if (!tmp_buf)
return -1;
if (len == 1) {
} else {
value = tmp_buf;
- } else if (!strncmp(data, "=H", 2)) { /* hexadecimal-byte array */
data += 2;
len = strlen(data);
return -1;
len /= 2;
if (!tmp_buf)
return -1;
return -1;
value = tmp_buf;
- } else { /* string */
if (!strncmp(data, "=\"", 2) || !strncmp(data, "=S\"", 3)) {
if (data[1] == '"')
data += 2;
else
data += 3;
value = data;
return -1;
} else {
value = data;
len = strlen(data);
- new_buf = realloc(*bufp, *sizep + len);
- if (!new_buf)
goto out;
- memcpy(new_buf + *sizep, value, len);
- *bufp = new_buf;
- *sizep += len;
+out:
- free(tmp_buf);
- char *var_name, *value = NULL;
- efi_uintn_t size = 0;
- u16 *var_name16 = NULL, *p;
- efi_guid_t guid;
- efi_status_t ret;
- if (argc == 1)
- var_name = argv[1];
- if (argc == 2) {
/* remove */
value = NULL;
size = 0;
- } else { /* set */
argc -= 2;
argv += 2;
goto out;
- var_name16 = malloc((strlen(var_name) + 1) * 2);
Please, always check the return value of malloc().
strlen() is the wrong function here. Use utf8_utf16_strlen() to match the copy function below.
- p = var_name16;
- utf8_utf16_strncpy(&p, var_name, strlen(var_name) + 1);
Don't you trust your malloc() call? Wouldn't you use utf8_utf16_strcpy()?
Best regards
Heinrich
- guid = efi_global_variable_guid;
- ret = efi_set_variable(var_name16, &guid,
- ret = (ret == EFI_SUCCESS ? CMD_RET_SUCCESS : CMD_RET_FAILURE);
+out:
- free(value);
- free(var_name16);
- return ret;
- efi_status_t r;
- return efi_set_var(cmdtp, flag, argc, argv);
Yes, I will when I have time.
The reason why I didn't do so is that I haven't had any reviews on the rest of the patches. In addition, patch#1 can be applied on its own since v6.
Normally if I want to add a change log, I will create a cover letter even there is only one patch file.
- bool
- default y
- imply HEXDUMP
I don't really think it is necessary, but I will do so.
Fill fix.
Usage:
Well, it is also the case for [-f].
So I will add a separate help line for clarification: "env set -e name [arg ...] - set UEFI variable\n"
Here too.
#endif +#endif
- u32 mask;
- char *text;
Okay, but really "all?"
- print_variable_info() - show information about a variable
- @name: name of the variable
- @guid: vendor GUID
I'm really confused with the format of description. There are several different styles of syntax seen across the tree. See my comment below.
- u32 attributes;
- u8 *data;
- efi_uintn_t size;
- int count, i;
- efi_status_t ret;
- data = NULL;
- size = 0;
if (!data)
goto out;
goto out;
goto out;
if (count)
putc('|');
else
putc(' ');
count++;
- return;
+out:
- free(data);
Okay.
- buf_size = 128;
- if (!var_name16)
buf_size = size;
if (!p) {
free(var_name16);
var_name16 = p;
p = var_name16;
- free(var_name16);
- efi_guid_t guid;
- efi_status_t ret;
- buf_size = 128;
- if (!var_name16)
- for (;;) {
size = buf_size;
break;
buf_size = size;
if (!p) {
free(var_name16);
var_name16 = p;
&guid);
free(var_name16);
- free(var_name16);
- if (argc > 1)
- efi_status_t r;
- append_value() - append data string to buffer
For example, the function description should be placed between "@data" and "Return:"?
- @bufp: pointer to pointer to buffer
- @sizep: pointer to size of buffer
- @data: data to be interpreted and appended
- Return: 0 on success
Some people writes "@return(:)". Some people have nothing about return value.
union {
u8 u8;
u16 u16;
u32 u32;
u64 u64;
} tmp_data;
void *hex_ptr;
data += 3;
len = strlen(data);
return -1;
len /= 2;
if (len > 8)
return -1;
else if (len > 4)
len = 8;
else if (len > 2)
len = 4;
return -1;
if (!tmp_buf)
return -1;
if (len == 1) {
} else {
value = tmp_buf;
data += 2;
len = strlen(data);
return -1;
len /= 2;
if (!tmp_buf)
return -1;
return -1;
value = tmp_buf;
if (data[1] == '"')
data += 2;
else
data += 3;
value = data;
return -1;
} else {
value = data;
len = strlen(data);
- if (!new_buf)
goto out;
- *bufp = new_buf;
- *sizep += len;
+out:
- free(tmp_buf);
- efi_guid_t guid;
- efi_status_t ret;
- if (argc == 1)
- if (argc == 2) {
/* remove */
value = NULL;
size = 0;
argc -= 2;
argv += 2;
goto out;
Okay.
Okay.
- p = var_name16;
utf8_utf16_strcpy() doesn't exist now. utf8_utf16_strncpy() does.
Thanks, -Takahiro Akashi
Best regards
Heinrich
+out:
- free(value);
- free(var_name16);
- return ret;
- efi_status_t r;
AKASHI Takahiro
