[PATCH v4] rng: Add Turris Mox rTWM RNG driver
A RNG driver for Armada 3720 boards running the Turris Mox rWTM firmware from CZ.NIC in the secure processor.
Signed-off-by: Max Resch resch.max@gmail.com ---
Changes in v4: - wrongful/missing git rebase
Changes in v3: - More meaningful variable names in accordance with review
Changes in v2: - Removed ring buffer implementation
drivers/rng/Kconfig | 8 +++ drivers/rng/Makefile | 1 + drivers/rng/turris_rwtm_rng.c | 122 ++++++++++++++++++++++++++++++++++ 3 files changed, 131 insertions(+) create mode 100644 drivers/rng/turris_rwtm_rng.c
diff --git a/drivers/rng/Kconfig b/drivers/rng/Kconfig index a89c899568..cd72852a47 100644 --- a/drivers/rng/Kconfig +++ b/drivers/rng/Kconfig @@ -105,4 +105,12 @@ config RNG_JH7110 help Enable True Random Number Generator in StarFive JH7110 SoCs.
+config RNG_TURRIS_RWTM + bool "Turris Mox TRNG in Secure Processor" + depends on DM_RNG && ARMADA_3700 + help + Use TRNG in Turris Mox Secure Processor Firmware. Can be used + on other Armada-3700 devices (like EspressoBin) if Secure + Firmware from CZ.NIC is used. + endif diff --git a/drivers/rng/Makefile b/drivers/rng/Makefile index 7e64c4cdfc..ecae1a3da3 100644 --- a/drivers/rng/Makefile +++ b/drivers/rng/Makefile @@ -17,3 +17,4 @@ obj-$(CONFIG_RNG_SMCCC_TRNG) += smccc_trng.o obj-$(CONFIG_RNG_ARM_RNDR) += arm_rndr.o obj-$(CONFIG_TPM_RNG) += tpm_rng.o obj-$(CONFIG_RNG_JH7110) += jh7110_rng.o +obj-$(CONFIG_RNG_TURRIS_RWTM) += turris_rwtm_rng.o diff --git a/drivers/rng/turris_rwtm_rng.c b/drivers/rng/turris_rwtm_rng.c new file mode 100644 index 0000000000..ec2cb0bca3 --- /dev/null +++ b/drivers/rng/turris_rwtm_rng.c @@ -0,0 +1,122 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR BSD-3-Clause +/* + * Copyright (c) 2024, Max Resch + */ + +#include <dm.h> +#include <malloc.h> +#include <rng.h> +#include <asm/dma-mapping.h> +#include <asm/types.h> +#include <mach/mbox.h> + +/* size of entropy buffer */ +#define RNG_BUFFER_SIZE 128U + +struct turris_rwtm_rng_priv { + phys_addr_t buffer; +}; + +static int turris_rwtm_rng_fill_entropy(phys_addr_t entropy, size_t size) +{ + u32 args[3] = { 1, (u32)entropy, size }; + int ret; + + /* flush data cache */ + flush_dcache_range(entropy, entropy + size); + + /* + * get entropy + * args[0] = 1 copies BYTES array in args[1] of length args[2] + */ + ret = mbox_do_cmd(MBOX_CMD_GET_RANDOM, args, 3, NULL, 0); + if (ret < 0) + return ret; + + /* invalidate data cache */ + invalidate_dcache_range(entropy, entropy + size); + + return 0; +} + +static int turris_rwtm_rng_random_read(struct udevice *dev, void *data, size_t count) +{ + struct turris_rwtm_rng_priv *priv = dev_get_priv(dev); + phys_addr_t phys; + size_t size; + int ret; + + phys = priv->buffer; + + while (count) { + size = min_t(size_t, RNG_BUFFER_SIZE, count); + + ret = turris_rwtm_rng_fill_entropy(phys, size); + + memcpy(data, (void *)phys, size); + count -= size; + data = (u8 *)data + size; + } + + return 0; +} + +static int turris_rwtm_rng_probe(struct udevice *dev) +{ + struct turris_rwtm_rng_priv *priv = dev_get_priv(dev); + u32 args[] = { 0 }; + int ret; + + /* + * check if the random command is supported + * args[0] = 0 would copy 16 DWORDS entropy to out but we ignore them + */ + ret = mbox_do_cmd(MBOX_CMD_GET_RANDOM, args, ARRAY_SIZE(args), NULL, 0); + + if (ret < 0) + return ret; + + /* entropy buffer */ + priv->buffer = 0; + + /* buffer address need to be aligned */ + dma_alloc_coherent(RNG_BUFFER_SIZE, (unsigned long *)&priv->buffer); + if (!priv->buffer) + return -ENOMEM; + + return 0; +} + +static int turris_rwtm_rng_remove(struct udevice *dev) +{ + struct turris_rwtm_rng_priv *priv = dev_get_priv(dev); + phys_addr_t phys = priv->buffer; + + dma_free_coherent((void *)phys); + + return 0; +} + +static const struct dm_rng_ops turris_rwtm_rng_ops = { + .read = turris_rwtm_rng_random_read, +}; + +/* + * only Turris MOX firmware has the RNG but allow all probable devices to be + * probed the default firmware will just reject the probe + */ +static const struct udevice_id turris_rwtm_rng_match[] = { + { .compatible = "cznic,turris-mox-rwtm" }, + { .compatible = "marvell,armada-3700-rwtm-firmware" }, + {}, +}; + +U_BOOT_DRIVER(turris_rwtm_rng) = { + .name = "turris-rwtm-rng", + .id = UCLASS_RNG, + .of_match = turris_rwtm_rng_match, + .ops = &turris_rwtm_rng_ops, + .probe = turris_rwtm_rng_probe, + .remove = turris_rwtm_rng_remove, + .priv_auto = sizeof(struct turris_rwtm_rng_priv), +};
Hi Max,
mostly some nitpicking comments below.
Changes in v4:
Changes in v3:
Changes in v2:
- bool "Turris Mox TRNG in Secure Processor"
- depends on DM_RNG && ARMADA_3700
- help
- endif
- Copyright (c) 2024, Max Resch
- phys_addr_t buffer;
- u32 args[3] = { 1, (u32)entropy, size };
- int ret;
- /* flush data cache */
- flush_dcache_range(entropy, entropy + size);
* get entropy
- ret = mbox_do_cmd(MBOX_CMD_GET_RANDOM, args, 3, NULL, 0);
- if (ret < 0)
return ret;
- /* invalidate data cache */
- invalidate_dcache_range(entropy, entropy + size);
- struct turris_rwtm_rng_priv *priv = dev_get_priv(dev);
- phys_addr_t phys;
- size_t size;
- int ret;
- phys = priv->buffer;
- while (count) {
Return code check missing here.
count -= size;
- u32 args[] = { 0 };
- int ret;
- ret = mbox_do_cmd(MBOX_CMD_GET_RANDOM, args, ARRAY_SIZE(args), NULL, 0);
Please drop this empty line before the ret check.
- if (ret < 0)
return ret;
- /* entropy buffer */
- priv->buffer = 0;
- /* buffer address need to be aligned */
- dma_alloc_coherent(RNG_BUFFER_SIZE, (unsigned long *)&priv->buffer);
- if (!priv->buffer)
return -ENOMEM;
- phys_addr_t phys = priv->buffer;
- dma_free_coherent((void *)phys);
- .read = turris_rwtm_rng_random_read,
- only Turris MOX firmware has the RNG but allow all probable devices to be
- probed the default firmware will just reject the probe
- { .compatible = "cznic,turris-mox-rwtm" },
- { .compatible = "marvell,armada-3700-rwtm-firmware" },
- .name = "turris-rwtm-rng",
- .id = UCLASS_RNG,
- .of_match = turris_rwtm_rng_match,
- .ops = &turris_rwtm_rng_ops,
- .probe = turris_rwtm_rng_probe,
- .remove = turris_rwtm_rng_remove,
- .priv_auto = sizeof(struct turris_rwtm_rng_priv),
Thanks, Stefan
On 2/13/24 10:16, Stefan Roese wrote:
Hi Max,
diff --git a/drivers/rng/Kconfig b/drivers/rng/Kconfig index a89c899568..cd72852a47 100644 --- a/drivers/rng/Kconfig +++ b/drivers/rng/Kconfig @@ -105,4 +105,12 @@ config RNG_JH7110 help Enable True Random Number Generator in StarFive JH7110 SoCs. +config RNG_TURRIS_RWTM + bool "Turris Mox TRNG in Secure Processor" + depends on DM_RNG && ARMADA_3700 + help + Use TRNG in Turris Mox Secure Processor Firmware. Can be used + on other Armada-3700 devices (like EspressoBin) if Secure + Firmware from CZ.NIC is used.
On a device with memory above 4 GiB this (u32) conversion may point to a different location than rwtm_rng_priv.
Is the Armada 3700 family restricted to below 4 GiB?
Should we add a check in the probe function?
Best regards
Heinrich
+ int ret;
+ return 0; +}
+ return 0; +}
+ return 0; +}
+ return 0; +}
devices to be
Thanks, Stefan
On Tue, 13 Feb 2024 10:49:43 +0100 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Hi Max,
Indeed it is. Only virtual memory can be mapped to higher locations, all physical resources (DDR, registers, PCIe, DMA, rWTM) can only be confiured with 32 bits.
No need.
Marek Behún
Max Resch
Stefan Roese
