[U-Boot] [PATCH 1/2] mx6: Factor out common HDMI setup code
Instead of duplicating HDMI setup code for every mx6 board, factor out the common code
Signed-off-by: Pardeep Kumar Singla b45784@freescale.com --- arch/arm/cpu/armv7/mx6/soc.c | 51 ++++++++++++++ arch/arm/include/asm/arch-mx6/mxc_hdmi.h | 6 ++ arch/arm/include/asm/arch-mx6/sys_proto.h | 13 ++++ board/boundary/nitrogen6x/nitrogen6x.c | 57 +--------------- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 60 ++-------------- board/wandboard/wandboard.c | 91 ++++++------------------- include/configs/mx6qsabrelite.h | 8 ++- include/configs/nitrogen6x.h | 2 +- include/configs/wandboard.h | 1 + 9 files changed, 106 insertions(+), 183 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index fc436fb..6e79310 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -32,6 +32,8 @@ #include <asm/imx-common/boot_mode.h> #include <asm/imx-common/dma.h> #include <stdbool.h> +#include <asm/arch/mxc_hdmi.h> +#include <asm/arch/crm_regs.h>
struct scu_regs { u32 ctrl; @@ -228,3 +230,52 @@ const struct boot_mode soc_boot_modes[] = { void s_init(void) { } + +#ifdef CONFIG_IMX_HDMI +void imx_enable_hdmi_phy(struct display_info_t const *dev) +{ + struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; + u8 reg; + reg = readb(&hdmi->phy_conf0); + reg |= HDMI_PHY_CONF0_PDZ_MASK; + writeb(reg, &hdmi->phy_conf0); + udelay(3000); + reg |= HDMI_PHY_CONF0_ENTMDS_MASK; + writeb(reg, &hdmi->phy_conf0); + udelay(3000); + reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK; + writeb(reg, &hdmi->phy_conf0); + writeb(HDMI_MC_PHYRSTZ_ASSERT, &hdmi->mc_phyrstz); +} + +void imx_setup_hdmi(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; + int reg; + + /* Turn on IPU clock */ + reg = readl(&mxc_ccm->CCGR3); + reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET; + writel(reg, &mxc_ccm->CCGR3); + + /* Turn on HDMI PHY clock */ + reg = readl(&mxc_ccm->CCGR2); + reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK| + MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK; + writel(reg, &mxc_ccm->CCGR2); + /* clear HDMI PHY reset */ + writeb(HDMI_MC_PHYRSTZ_DEASSERT, &hdmi->mc_phyrstz); + reg = readl(&mxc_ccm->chsccdr); + reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK| + MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK| + MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); + reg |= (CHSCCDR_CLK_SEL_LDB_DI0 + << MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET)| + (CHSCCDR_PODF_DIVIDE_BY_3 + << MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) + |(CHSCCDR_IPU_PRE_CLK_540M_PFD + << MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->chsccdr); +} +#endif diff --git a/arch/arm/include/asm/arch-mx6/mxc_hdmi.h b/arch/arm/include/asm/arch-mx6/mxc_hdmi.h index 9dccb3f..9e2074b 100644 --- a/arch/arm/include/asm/arch-mx6/mxc_hdmi.h +++ b/arch/arm/include/asm/arch-mx6/mxc_hdmi.h @@ -21,6 +21,12 @@ #ifndef __MXC_HDMI_H__ #define __MXC_HDMI_H__
+#ifdef CONFIG_IMX_HDMI +#include<asm/arch/sys_proto.h> +void imx_enable_hdmi_phy(struct display_info_t const *dev); +void imx_setup_hdmi(void); +#endif + /* * Hdmi controller registers */ diff --git a/arch/arm/include/asm/arch-mx6/sys_proto.h b/arch/arm/include/asm/arch-mx6/sys_proto.h index 38e4e51..9fb539b 100644 --- a/arch/arm/include/asm/arch-mx6/sys_proto.h +++ b/arch/arm/include/asm/arch-mx6/sys_proto.h @@ -25,6 +25,9 @@ #define _SYS_PROTO_H_
#include <asm/imx-common/regs-common.h> +#include<linux/list.h> +#include <linux/fb.h> +#include <i2c.h>
#define MXC_CPU_MX51 0x51 #define MXC_CPU_MX53 0x53 @@ -34,6 +37,16 @@ #define MXC_CPU_MX6Q 0x63
#define is_soc_rev(rev) ((get_cpu_rev() & 0xFF) - rev) + +struct display_info_t { + int bus; + int addr; + int pixfmt; + int (*detect)(struct display_info_t const *dev); + void (*enable)(struct display_info_t const *dev); + struct fb_videomode mode; +}; + u32 get_cpu_rev(void); const char *get_imx_type(u32 imxtype); unsigned imx_ddr_size(void); diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 8f0f9b8..d97d47a 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -464,40 +464,12 @@ static iomux_v3_cfg_t const rgb_pads[] = { MX6_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23, };
-struct display_info_t { - int bus; - int addr; - int pixfmt; - int (*detect)(struct display_info_t const *dev); - void (*enable)(struct display_info_t const *dev); - struct fb_videomode mode; -}; - - static int detect_hdmi(struct display_info_t const *dev) { struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; return readb(&hdmi->phy_stat0) & HDMI_PHY_HPD; }
-static void enable_hdmi(struct display_info_t const *dev) -{ - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - u8 reg; - printf("%s: setup HDMI monitor\n", __func__); - reg = readb(&hdmi->phy_conf0); - reg |= HDMI_PHY_CONF0_PDZ_MASK; - writeb(reg, &hdmi->phy_conf0); - - udelay(3000); - reg |= HDMI_PHY_CONF0_ENTMDS_MASK; - writeb(reg, &hdmi->phy_conf0); - udelay(3000); - reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK; - writeb(reg, &hdmi->phy_conf0); - writeb(HDMI_MC_PHYRSTZ_ASSERT, &hdmi->mc_phyrstz); -} - static int detect_i2c(struct display_info_t const *dev) { return ((0 == i2c_set_bus_num(dev->bus)) @@ -528,7 +500,7 @@ static struct display_info_t const displays[] = {{ .addr = 0, .pixfmt = IPU_PIX_FMT_RGB24, .detect = detect_hdmi, - .enable = enable_hdmi, + .enable = imx_enable_hdmi_phy, .mode = { .name = "HDMI", .refresh = 60, @@ -653,25 +625,14 @@ static void setup_display(void) struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - int reg;
+ imx_setup_hdmi(); /* Turn on LDB0,IPU,IPU DI0 clocks */ reg = __raw_readl(&mxc_ccm->CCGR3); - reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET - |MXC_CCM_CCGR3_LDB_DI0_MASK; + reg |= MXC_CCM_CCGR3_LDB_DI0_MASK; writel(reg, &mxc_ccm->CCGR3);
- /* Turn on HDMI PHY clock */ - reg = __raw_readl(&mxc_ccm->CCGR2); - reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK - |MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK; - writel(reg, &mxc_ccm->CCGR2); - - /* clear HDMI PHY reset */ - writeb(HDMI_MC_PHYRSTZ_DEASSERT, &hdmi->mc_phyrstz); - /* set PFD1_FRAC to 0x13 == 455 MHz (480*18)/0x13 */ writel(ANATOP_PFD_480_PFD1_FRAC_MASK, &anatop->pfd_480_clr); writel(0x13<<ANATOP_PFD_480_PFD1_FRAC_SHIFT, &anatop->pfd_480_set); @@ -688,18 +649,6 @@ static void setup_display(void) reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV; writel(reg, &mxc_ccm->cscmr2);
- reg = readl(&mxc_ccm->chsccdr); - reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK - |MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK - |MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); - reg |= (CHSCCDR_CLK_SEL_LDB_DI0 - <<MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET) - |(CHSCCDR_PODF_DIVIDE_BY_3 - <<MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) - |(CHSCCDR_IPU_PRE_CLK_540M_PFD - <<MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); - writel(reg, &mxc_ccm->chsccdr); - reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES |IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_HIGH |IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_LOW diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index 862bc30..21b6bb6 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -42,7 +42,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/mxc_hdmi.h> #include <i2c.h> - +#include<asm/arch/sys_proto.h> DECLARE_GLOBAL_DATA_PTR;
#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ @@ -436,40 +436,12 @@ static iomux_v3_cfg_t const rgb_pads[] = { MX6_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23, };
-static void enable_hdmi(struct display_info_t const *dev) -{ - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - u8 reg; - printf("%s: setup HDMI monitor\n", __func__); - reg = readb(&hdmi->phy_conf0); - reg |= HDMI_PHY_CONF0_PDZ_MASK; - writeb(reg, &hdmi->phy_conf0); - - udelay(3000); - reg |= HDMI_PHY_CONF0_ENTMDS_MASK; - writeb(reg, &hdmi->phy_conf0); - udelay(3000); - reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK; - writeb(reg, &hdmi->phy_conf0); - writeb(HDMI_MC_PHYRSTZ_ASSERT, &hdmi->mc_phyrstz); -} - static int detect_i2c(struct display_info_t const *dev) { return ((0 == i2c_set_bus_num(dev->bus)) @@ -500,7 +472,7 @@ static struct display_info_t const displays[] = {{ .addr = 0, .pixfmt = IPU_PIX_FMT_RGB24, .detect = detect_hdmi, - .enable = enable_hdmi, + .enable = imx_enable_hdmi_phy, .mode = { .name = "HDMI", .refresh = 60, @@ -625,25 +597,15 @@ static void setup_display(void) struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - int reg;
+ imx_setup_hdmi(); + /* Turn on LDB0,IPU,IPU DI0 clocks */ reg = __raw_readl(&mxc_ccm->CCGR3); - reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET - |MXC_CCM_CCGR3_LDB_DI0_MASK; + reg |= MXC_CCM_CCGR3_LDB_DI0_MASK; writel(reg, &mxc_ccm->CCGR3);
- /* Turn on HDMI PHY clock */ - reg = __raw_readl(&mxc_ccm->CCGR2); - reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK - |MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK; - writel(reg, &mxc_ccm->CCGR2); - - /* clear HDMI PHY reset */ - writeb(HDMI_MC_PHYRSTZ_DEASSERT, &hdmi->mc_phyrstz); - /* set PFD1_FRAC to 0x13 == 455 MHz (480*18)/0x13 */ writel(ANATOP_PFD_480_PFD1_FRAC_MASK, &anatop->pfd_480_clr); writel(0x13<<ANATOP_PFD_480_PFD1_FRAC_SHIFT, &anatop->pfd_480_set); @@ -660,18 +622,6 @@ static void setup_display(void) reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV; writel(reg, &mxc_ccm->cscmr2);
- reg = readl(&mxc_ccm->chsccdr); - reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK - |MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK - |MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); - reg |= (CHSCCDR_CLK_SEL_LDB_DI0 - <<MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET) - |(CHSCCDR_PODF_DIVIDE_BY_3 - <<MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) - |(CHSCCDR_IPU_PRE_CLK_540M_PFD - <<MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); - writel(reg, &mxc_ccm->chsccdr); - reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES |IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_HIGH |IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_LOW diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index 43c02ac..4957303 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -28,7 +28,6 @@ #include <miiphy.h> #include <netdev.h> #include <linux/fb.h> - DECLARE_GLOBAL_DATA_PTR;
#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ @@ -211,85 +210,37 @@ int board_phy_config(struct phy_device *phydev) }
#if defined(CONFIG_VIDEO_IPUV3) -static void enable_hdmi(void) -{ - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - u8 reg; - reg = readb(&hdmi->phy_conf0); - reg |= HDMI_PHY_CONF0_PDZ_MASK; - writeb(reg, &hdmi->phy_conf0); - - udelay(3000); - reg |= HDMI_PHY_CONF0_ENTMDS_MASK; - writeb(reg, &hdmi->phy_conf0); - udelay(3000); - reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK; - writeb(reg, &hdmi->phy_conf0); - writeb(HDMI_MC_PHYRSTZ_ASSERT, &hdmi->mc_phyrstz); -} - -static struct fb_videomode const hdmi = { - .name = "HDMI", - .refresh = 60, - .xres = 1024, - .yres = 768, - .pixclock = 15385, - .left_margin = 220, - .right_margin = 40, - .upper_margin = 21, - .lower_margin = 7, - .hsync_len = 60, - .vsync_len = 10, - .sync = FB_SYNC_EXT, - .vmode = FB_VMODE_NONINTERLACED -}; +static struct display_info_t const displays = { + .pixfmt = IPU_PIX_FMT_RGB24, + .enable = imx_enable_hdmi_phy, + .mode = { + .name = "HDMI", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +} };
int board_video_skip(void) { int ret;
- ret = ipuv3_fb_init(&hdmi, 0, IPU_PIX_FMT_RGB24); + ret = ipuv3_fb_init(&displays.mode, 0, displays.pixfmt);
if (ret) printf("HDMI cannot be configured: %d\n", ret); - - enable_hdmi(); + displays.enable(&displays);
return ret; } - -static void setup_display(void) -{ - struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - int reg; - - /* Turn on IPU clock */ - reg = readl(&mxc_ccm->CCGR3); - reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET; - writel(reg, &mxc_ccm->CCGR3); - - /* Turn on HDMI PHY clock */ - reg = readl(&mxc_ccm->CCGR2); - reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK - | MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK; - writel(reg, &mxc_ccm->CCGR2); - - /* clear HDMI PHY reset */ - writeb(HDMI_MC_PHYRSTZ_DEASSERT, &hdmi->mc_phyrstz); - - reg = readl(&mxc_ccm->chsccdr); - reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK - | MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK - | MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); - reg |= (CHSCCDR_CLK_SEL_LDB_DI0 - << MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET) - | (CHSCCDR_PODF_DIVIDE_BY_3 - << MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) - | (CHSCCDR_IPU_PRE_CLK_540M_PFD - << MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); - writel(reg, &mxc_ccm->chsccdr); -} #endif /* CONFIG_VIDEO_IPUV3 */
int board_eth_init(bd_t *bis) @@ -309,7 +260,7 @@ int board_early_init_f(void) { setup_iomux_uart(); #if defined(CONFIG_VIDEO_IPUV3) - setup_display(); + imx_setup_hdmi(); #endif return 0; } diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index c7db81d..4549f24 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -26,6 +26,7 @@ #define CONFIG_MX6Q
#include "mx6_common.h" +#include<asm/sizes.h>
#define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO @@ -35,14 +36,14 @@ #include <asm/arch/imx-regs.h> #include <asm/imx-common/gpio.h>
+/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M) + #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_REVISION_TAG
-/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024) - #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MISC_INIT_R #define CONFIG_MXC_GPIO @@ -141,6 +142,7 @@ #define CONFIG_BMP_16BPP #define CONFIG_VIDEO_LOGO #define CONFIG_IPUV3_CLK 260000000 +#define CONFIG_IMX_HDMI
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 74df66c..5a4d06e 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -154,7 +154,7 @@ #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CMD_HDMIDETECT #define CONFIG_CONSOLE_MUX - +#define CONFIG_IMX_HDMI /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1 diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index ee6bf21..9282e23 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -100,6 +100,7 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_IPUV3_CLK 260000000 +#define CONFIG_IMX_HDMI
#if defined(CONFIG_MX6DL) #define CONFIG_DEFAULT_FDT_FILE "imx6dl-wandboard.dtb"
Signed-off-by: Pardeep Kumar Singla b45784@freescale.com --- board/freescale/mx6sabresd/mx6sabresd.c | 48 +++++++++++++++++++++++++++++++ include/configs/mx6sabre_common.h | 2 +- include/configs/mx6sabresd.h | 18 ++++++++++++ 3 files changed, 67 insertions(+), 1 deletion(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 222ee98..fc00063 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -29,6 +29,11 @@ #include <fsl_esdhc.h> #include <miiphy.h> #include <netdev.h> +#include <asm/arch/crm_regs.h> +#include <ipu_pixfmt.h> +#include <linux/fb.h> +#include <asm/arch/mxc_hdmi.h> +#include <asm/arch/sys_proto.h>
@@ -131,6 +136,37 @@ static void setup_iomux_uart(void) imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); }
+#if defined(CONFIG_VIDEO_IPUV3) +static struct display_info_t const displays = { + .pixfmt = IPU_PIX_FMT_RGB24, + .enable = imx_enable_hdmi_phy, + .mode = { + .name = "HDMI", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +} }; + +int board_video_skip(void) +{ + int ret; + ret = ipuv3_fb_init(&displays.mode, 0, displays.pixfmt); + if (ret) + printf("HDMI cannot be configured: %d\n", ret); + displays.enable(&displays); + return ret; +} +#endif /* CONFIG_VIDEO_IPUV3 */ + #ifdef CONFIG_FSL_ESDHC struct fsl_esdhc_cfg usdhc_cfg[3] = { {USDHC2_BASE_ADDR}, @@ -255,10 +291,22 @@ int board_eth_init(bd_t *bis) int board_early_init_f(void) { setup_iomux_uart(); +#if defined(CONFIG_VIDEO_IPUV3) + imx_setup_hdmi(); +#endif
return 0; }
+/* + * Do not overwrite the console + * Use always serial for U-Boot console + */ +int overwrite_console(void) +{ + return 1; +} + int board_init(void) { /* address of boot parameters */ diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 53cc559..bb1ac8c 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -32,7 +32,7 @@ #define CONFIG_REVISION_TAG
/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_LATE_INIT diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 76675f4..3d3ec9f 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -25,6 +25,24 @@ #define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024)
#include "mx6sabre_common.h" +#include<asm/sizes.h> + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M) + +/* Framebuffer */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_IPUV3_CLK 260000000 +#define CONFIG_IMX_HDMI
#define CONFIG_SYS_FSL_USDHC_NUM 3 #if defined(CONFIG_ENV_IS_IN_MMC)
Hi Pardeep,
The only reason this has a dev parameter is so it can be used by auto-detect code.
It should be kept out of this code to make the interface clearer.
Boards that support auto-detect (mx6qsabrelite/nitrogen6x) can wrap it.
- u8 reg;
- udelay(3000);
- udelay(3000);
- int reg;
- reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK|
There's a lot of policy in this register write and some of it isn't really HDMI-specific (LDB clock selects). I'd recommend keeping that in board-specific code:
- reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK|
- Hdmi controller registers
This is specific to a couple of boards, and not mx6-specific:
- int bus;
- int addr;
- int pixfmt;
<snip>
static void do_enable_hdmi(struct display_info_t const *dev) { return enable_hdmi(); }
Regards,
Eric
Eric Nelson
