[U-Boot] U-Boot on Sparc leon3
I'm trying to build u-boot for a new gaisler board (gr-pci-xc5v-LX110T).
I have some trouble with the leon3/start.S and the linking process so I tried to build u-boot from a fresh clean GIT source with the board on board/gaisler/gr_xc3s_1500 which should be supported.
And I'm having the same linking problem.
I have already tried the u-boot 1.3.3 which is working on my board (booting, but the flash is not supported).
The linking problem is the following:
On version v2013.04:
* In the relocation loop, the start.S define 2 variables which is set during the link: ============= /* un relocated start address of monitor */ #define TEXT_START _text
/* un relocated end address of monitor */ #define DATA_END __init_end
reloc: set TEXT_START,%g2 set DATA_END,%g3 set CONFIG_SYS_RELOC_MONITOR_BASE,%g4 reloc_loop: =============
* compiling this start.S give the following relocation record ============= RELOCATION RECORDS FOR [.text]: OFFSET TYPE VALUE 0000009c R_SPARC_WDISP30 cpu_init_f 000000a4 R_SPARC_HI22 _text 000000a8 R_SPARC_LO10 _text 000000ac R_SPARC_HI22 __init_end 000000b0 R_SPARC_LO10 __init_end ============= with the following assembly code: ============= 000000a4 <reloc>: a4: 05 00 00 00 sethi %hi(0), %g2 a8: 84 10 a0 00 mov %g2, %g2 ! 0 <_hardreset> ac: 07 00 00 00 sethi %hi(0), %g3 b0: 86 10 e0 00 mov %g3, %g3 ! 0 <_hardreset> b4: 09 10 fe 38 sethi %hi(0x43f8e000), %g4
000000b8 <reloc_loop>: =============
For now, everythings is normal.
After the linking process, I've the following elf:
============= 000010a4 <reloc>: 10a4: 05 00 00 03 sethi %hi(0xc00), %g2 10a8: 84 10 a1 3c or %g2, 0x13c, %g2 ! d3c <MINFRAME+0xce0> 10ac: 07 00 00 03 sethi %hi(0xc00), %g3 10b0: 86 10 e1 30 or %g3, 0x130, %g3 ! d30 <MINFRAME+0xcd4> 10b4: 09 10 fe 38 sethi %hi(0x43f8e000), %g4 ============= And the associated .map:
============= .text 0x0000000000000000 0x2d2b8 0x0000000000000000 _load_addr = . 0x0000000000000000 _text = . [...] .data.init *(.data.init) 0x0000000000030000 . = ALIGN (0x1000) 0x0000000000030000 __init_end = . 0x0000000000030000 __bss_start = . =============
And the others symbol in this start.S are not defined correctly either.
On the v2013.01 version, I've the same intermediate file but the following u-boot elf:
============= 000010a4 <reloc>: 10a4: 05 00 00 00 sethi %hi(0), %g2 10a8: 84 10 a0 00 mov %g2, %g2 ! 0 <_load_addr> 10ac: 07 00 00 c0 sethi %hi(0x30000), %g3 10b0: 86 10 e0 00 mov %g3, %g3 ! 30000 <__bss_start> 10b4: 09 10 fe 38 sethi %hi(0x43f8e000), %g4 =============
Which is what I expected.
On IRC, Marex give me the advice to check with git bisect and find the commit which (I think) break the linking process. And It found this one: ============================= eb33809f70e3d3a2c1fba043e56cca8fccedbe0c is the first bad commit commit eb33809f70e3d3a2c1fba043e56cca8fccedbe0c Author: Simon Glass sjg@chromium.org Date: Tue Mar 5 14:40:03 2013 +0000
sparc: Fix out-of-tree building
It isn't clear why the sparc cpu Makefile has its own compile line, but it does not work correctly with an out-of-tree build. Removing it fixes this problem. Perhaps it does not introduce others.
Signed-off-by: Simon Glass sjg@chromium.org
:040000 040000 39dc0c7a3ff2feadaddeda1b7938502f30f2ed76 7e77469d3aa8550d3f712470d45ef73e46b217b8 M arch bisect run success ============================
Which corresponds to remove the specific makefile for sparc.
So what did i do wrong or misunderstund about the compiling u-boot process? Why removing specific compile process for sparc?
Best,
-- Florian.
Hi Florian,
On 23 January 2015 at 04:16, Florian Praden florian.praden@telecom-paristech.fr wrote:
- In the relocation loop, the start.S define 2 variables which is set during the link:
- compiling this start.S give the following relocation record
sparc: Fix out-of-tree building It isn't clear why the sparc cpu Makefile has its own compile line, but it does not work correctly with an out-of-tree build. Removing it fixes this problem. Perhaps it does not introduce others. Signed-off-by: Simon Glass <sjg@chromium.org>
It looks like the compile line was needed, although I'm not sure why. It used to say:
$(START): $(START:.o=.S) $(CC) -D__ASSEMBLY__ $(DBGFLAGS) $(OPTFLAGS) -D__KERNEL__ \ -DCONFIG_SYS_TEXT_BASE=$(CONFIG_SYS_TEXT_BASE) -I$(TOPDIR)/include \ -fno-builtin -ffreestanding -nostdinc -isystem $(gccincdir) -pipe \ $(PLATFORM_CPPFLAGS) -Wall -Wstrict-prototypes \ -I$(TOPDIR)/board -c -o $(START) $(START:.o=.S)
I don't see anything in there that does something special with compiler flags, but there must be some difference.
You could try comparing the compiler flags that are used with start.S in each case. There may be some sort of difference, and then you can add it to PLATFORM_CPPFLAGS or perhaps your arch/xxx/config.mk.
Re your second question, compilation is handled by U-Boot's standard build system, so we should be calling the compiler manually in a Makefile. The Makefile is there mainly to specify what should be built.
Also when you do get it working, I'd encourage you to move to 2015.01 which is newer and has Kconfig.
Florian Praden
