[U-Boot] [PATCH 2/2 v5] powerpc/p1023rds: Disable nor flash node and enable nand flash node
In the p1023rds, when system boots from nor flash, kernel only accesses nor flash and can not access nand flash with BR0/OR0; when system boots from nand flash, kernel only accesses nand flash and can not access nor flash with BR0/OR0.
Default device tree nor and nand node should have the following structure:
Example:
nor_flash: nor@0,0 { #address-cells = <1>; #size-cells = <1>; compatible = "cfi-flash"; reg = <0x0 0x0 0x02000000>; bank-width = <2>; device-width = <1>; status = "okay";
partition@0 { label = "ramdisk"; reg = <0x00000000 0x01c00000>; }; }
nand_flash: nand@1,0 { #address-cells = <1>; #size-cells = <1>; compatible = "fsl,p1023-fcm-nand", "fsl,elbc-fcm-nand"; reg = <0x2 0x0 0x00040000>; status = "disabled";
u-boot-nand@0 { /* This location must not be altered */ /* 1MB for u-boot Bootloader Image */ reg = <0x0 0x00100000>; read-only; }; }
When booting from nor flash, the status of nor node is null that means it is enabled and the status of nand node is disabled in the default dts file, so do not do anything.
But, when booting from nand flash, need to do some operations:
o the status of nor node should be disabled. o the status of nand node should be enabled.
Signed-off-by: Chunhe Lan Chunhe.Lan@freescale.com --- board/freescale/p1023rds/p1023rds.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/board/freescale/p1023rds/p1023rds.c b/board/freescale/p1023rds/p1023rds.c index 8cfd199..c99ccee 100644 --- a/board/freescale/p1023rds/p1023rds.c +++ b/board/freescale/p1023rds/p1023rds.c @@ -158,5 +158,10 @@ void ft_board_setup(void *blob, bd_t *bd) size = getenv_bootm_size();
fdt_fixup_memory(blob, (u64)base, (u64)size); + +#ifdef CONFIG_NAND_U_BOOT + do_fixup_by_path_string(fdt, "nor_flash", "status", "disabled"); + do_fixup_by_path_string(fdt, "nand_flash", "status", "okay"); +#endif } #endif
Dear Chunhe Lan,
In message 1314675698-9847-1-git-send-email-Chunhe.Lan@freescale.com you wrote: ...
status = "okay";
Description does not match code.
Make this:
o Disable the NOR node by setting status = "disabled"; o Enable the NAND node by setting status = "okay";
This is patch v5, but there is no change log. This is MANDATORY!
On Tue, 30 Aug 2011 13:24:34 +0800, Wolfgang Denk wd@denx.de wrote:
Dear Chunhe Lan,
status = "okay";
I rewrite it.
Make this:
I rewrite it.
OK. Thanks.
-Jack Lan
Chunhe Lan
Chunhe Lan
