[U-Boot-Users] [PATCH 07/18] include/configs: Use new CONFIG_CMD_* in various H* named board config files.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/HH405.h | 42 ++++++++++++++++++++------------------ include/configs/HIDDEN_DRAGON.h | 22 +++++++++++--------- include/configs/HMI10.h | 42 ++++++++++++++++---------------------- include/configs/HUB405.h | 31 +++++++++++++++------------- 4 files changed, 69 insertions(+), 68 deletions(-)
diff --git a/include/configs/HH405.h b/include/configs/HH405.h index dc40ebc..58f29cd 100644 --- a/include/configs/HH405.h +++ b/include/configs/HH405.h @@ -103,21 +103,26 @@ #define ADD_BMP_CMD 0 #endif /* CONFIG_VIDEO */
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_DHCP | \ - CFG_CMD_PCI | \ - CFG_CMD_IRQ | \ - CFG_CMD_IDE | \ - CFG_CMD_FAT | \ - CFG_CMD_EXT2 | \ - CFG_CMD_ELF | \ - CFG_CMD_NAND | \ - CFG_CMD_I2C | \ - CFG_CMD_DATE | \ - CFG_CMD_MII | \ - CFG_CMD_PING | \ - ADD_BMP_CMD | \ - CFG_CMD_EEPROM ) +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PCI +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_IDE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_ELF +#define CONFIG_CMD_NAND +#define CONFIG_CMD_I2C +#define CONFIG_CMD_DATE +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_BMP_CMD +#define CONFIG_CMD_EEPROM +
#define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION @@ -127,9 +132,6 @@ #define CONFIG_AUTO_UPDATE 1 /* autoupdate via compactflash */ #undef CONFIG_AUTO_UPDATE_SHOW /* use board show routine */
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - #define CFG_NAND_LEGACY
#undef CONFIG_BZIP2 /* include support for bzip2 compressed images */ @@ -148,7 +150,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -377,7 +379,7 @@ #define CFG_DCACHE_SIZE 16384 /* For AMCC 405 CPUs, older 405 ppc's */ /* have only 8kB, 16kB is save here */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/HIDDEN_DRAGON.h b/include/configs/HIDDEN_DRAGON.h index 6864740..972ca08 100644 --- a/include/configs/HIDDEN_DRAGON.h +++ b/include/configs/HIDDEN_DRAGON.h @@ -52,16 +52,18 @@ #define CONFIG_BAUDRATE 9600 #define CONFIG_DRAM_SPEED 100 /* MHz */
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_EEPROM | \ - CFG_CMD_ELF | \ - CFG_CMD_I2C | \ - CFG_CMD_NET | \ - CFG_CMD_PCI | \ - CFG_CMD_PING )
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_I2C +#define CONFIG_CMD_NET +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING
/* * Miscellaneous configurable options @@ -363,7 +365,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 /* For MPC8240 CPU */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/HMI10.h b/include/configs/HMI10.h index 7cce876..29748e1 100644 --- a/include/configs/HMI10.h +++ b/include/configs/HMI10.h @@ -125,31 +125,25 @@ #define CONFIG_RTC_DS1337 /* Use ds1337 rtc via i2c */ #define CFG_I2C_RTC_ADDR 0x68 /* at address 0x68 */
+ +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_NFS +#define CONFIG_CMD_SNTP + #ifdef CONFIG_SPLASH_SCREEN -# define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_BMP | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_FAT | \ - CFG_CMD_I2C | \ - CFG_CMD_IDE | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP ) -#else -# define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_FAT | \ - CFG_CMD_I2C | \ - CFG_CMD_IDE | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP ) + #define CONFIG_CMD_BMP #endif
/* * Miscellaneous configurable options @@ -164,7 +158,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -247,7 +241,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/HUB405.h b/include/configs/HUB405.h index f84e356..d29bddb 100644 --- a/include/configs/HUB405.h +++ b/include/configs/HUB405.h @@ -60,18 +60,21 @@
#define CONFIG_PHY_CLK_FREQ EMAC_STACR_CLK_66MHZ /* 66 MHz OPB clock*/
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_DHCP | \ - CFG_CMD_IRQ | \ - CFG_CMD_ELF | \ - CFG_CMD_NAND | \ - CFG_CMD_I2C | \ - CFG_CMD_MII | \ - CFG_CMD_PING | \ - CFG_CMD_EEPROM ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_ELF +#define CONFIG_CMD_NAND +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_EEPROM +
#undef CONFIG_WATCHDOG /* watchdog disabled */
@@ -88,7 +91,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -271,7 +274,7 @@ #define CFG_DCACHE_SIZE 16384 /* For AMCC 405 CPUs, older 405 ppc's */ /* have only 8kB, 16kB is save here */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
Jon Loeliger
