[U-Boot-Users] [PATCH] TQM5200: use automatic fdt memory fixup
Call fdt_fixup_memory() on the boards TQM5200, TQM5200_B, TQM5200S, TB5200 and TB5200_B to fixup the /memory node with the memory values detected by U-Boot.
Signed-off-by: Martin Krause martin.krause@tqs.de -- I consider this patch as bugfix, since linux 2.6 will not boot on boards with less SDRAM than the fixed value in the TQM5200 fdt (64 MiB AFAIK) ---
board/tqm5200/tqm5200.c | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/board/tqm5200/tqm5200.c b/board/tqm5200/tqm5200.c index 8c3f701..97e3099 100644 --- a/board/tqm5200/tqm5200.c +++ b/board/tqm5200/tqm5200.c @@ -795,5 +795,6 @@ int board_get_height (void) void ft_board_setup(void *blob, bd_t *bd) { ft_cpu_setup(blob, bd); + fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize); } #endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */
Applied, thanks.
Martin Krause
