[U-Boot] [PATCH 1/2] mmc: pxa: Flip over the remaining boards to pxa_mmc_generic
Some of the boards still used the old PXA_MMC driver instead of the new generic one. Use the new one instead so the old can be removed and the generic MMC framework can be properly used.
Signed-off-by: Marek Vasut marex@denx.de Cc: Andy Fleming afleming@freescale.com --- board/lubbock/lubbock.c | 9 +++++++++ board/palmtc/palmtc.c | 9 +++++++++ board/pxa255_idp/pxa_idp.c | 9 +++++++++ board/trizepsiv/conxs.c | 9 +++++++++ include/configs/lubbock.h | 3 ++- include/configs/palmtc.h | 3 ++- include/configs/pxa255_idp.h | 3 ++- include/configs/trizepsiv.h | 3 ++- 8 files changed, 44 insertions(+), 4 deletions(-)
diff --git a/board/lubbock/lubbock.c b/board/lubbock/lubbock.c index 3527b38..ef2cc24 100644 --- a/board/lubbock/lubbock.c +++ b/board/lubbock/lubbock.c @@ -29,6 +29,7 @@ #include <netdev.h> #include <asm/arch/pxa.h> #include <asm/arch/pxa-regs.h> +#include <asm/arch/regs-mmc.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; @@ -56,6 +57,14 @@ int board_init (void) return 0; }
+#ifdef CONFIG_CMD_MMC +int board_mmc_init(bd_t *bis) +{ + pxa_mmc_register(0); + return 0; +} +#endif + int board_late_init(void) { setenv("stdout", "serial"); diff --git a/board/palmtc/palmtc.c b/board/palmtc/palmtc.c index 4adf152..c850cf9 100644 --- a/board/palmtc/palmtc.c +++ b/board/palmtc/palmtc.c @@ -24,6 +24,7 @@ #include <serial.h> #include <asm/io.h> #include <asm/arch/pxa.h> +#include <asm/arch/regs-mmc.h>
@@ -51,6 +52,14 @@ int board_init(void) return 0; }
+#ifdef CONFIG_CMD_MMC +int board_mmc_init(bd_t *bis) +{ + pxa_mmc_register(0); + return 0; +} +#endif + struct serial_device *default_serial_console(void) { return &serial_ffuart_device; diff --git a/board/pxa255_idp/pxa_idp.c b/board/pxa255_idp/pxa_idp.c index 877e8d9..9931efd 100644 --- a/board/pxa255_idp/pxa_idp.c +++ b/board/pxa255_idp/pxa_idp.c @@ -35,6 +35,7 @@ #include <command.h> #include <asm/io.h> #include <asm/arch/pxa.h> +#include <asm/arch/regs-mmc.h>
@@ -77,6 +78,14 @@ int board_init (void) return 0; }
+#ifdef CONFIG_CMD_MMC +int board_mmc_init(bd_t *bis) +{ + pxa_mmc_register(0); + return 0; +} +#endif + int board_late_init(void) { setenv("stdout", "serial"); diff --git a/board/trizepsiv/conxs.c b/board/trizepsiv/conxs.c index 1291195..af6fe25 100644 --- a/board/trizepsiv/conxs.c +++ b/board/trizepsiv/conxs.c @@ -34,6 +34,7 @@ #include <common.h> #include <asm/arch/pxa-regs.h> #include <asm/arch/pxa.h> +#include <asm/arch/regs-mmc.h> #include <netdev.h> #include <asm/io.h>
@@ -159,3 +160,11 @@ int board_eth_init(bd_t *bis) return dm9000_initialize(bis); } #endif + +#ifdef CONFIG_CMD_MMC +int board_mmc_init(bd_t *bis) +{ + pxa_mmc_register(0); + return 0; +} +#endif diff --git a/include/configs/lubbock.h b/include/configs/lubbock.h index 0a1d1e0..59515f5 100644 --- a/include/configs/lubbock.h +++ b/include/configs/lubbock.h @@ -129,7 +129,8 @@ #define CONFIG_SYS_CPUSPEED 0x161 /* set core clock to 400/200/100 MHz */
#ifdef CONFIG_MMC -#define CONFIG_PXA_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_PXA_MMC_GENERIC #define CONFIG_CMD_MMC #define CONFIG_SYS_MMC_BASE 0xF0000000 #endif diff --git a/include/configs/palmtc.h b/include/configs/palmtc.h index bc88354..699b39f 100644 --- a/include/configs/palmtc.h +++ b/include/configs/palmtc.h @@ -76,7 +76,8 @@ */ #ifdef CONFIG_CMD_MMC #define CONFIG_MMC -#define CONFIG_PXA_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_PXA_MMC_GENERIC #define CONFIG_SYS_MMC_BASE 0xF0000000 #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 diff --git a/include/configs/pxa255_idp.h b/include/configs/pxa255_idp.h index ce9e7d1..d0d88c8 100644 --- a/include/configs/pxa255_idp.h +++ b/include/configs/pxa255_idp.h @@ -244,7 +244,8 @@ #define RTC 1 /* enable 32KHz osc */
#ifdef CONFIG_MMC -#define CONFIG_PXA_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_PXA_MMC_GENERIC #define CONFIG_CMD_MMC #define CONFIG_SYS_MMC_BASE 0xF0000000 #endif diff --git a/include/configs/trizepsiv.h b/include/configs/trizepsiv.h index 151059a..52bc973 100644 --- a/include/configs/trizepsiv.h +++ b/include/configs/trizepsiv.h @@ -170,7 +170,8 @@ #define CONFIG_SYS_CPUSPEED 0x207 /* need to look more closely, I think this is Turbo = 2x, L=91Mhz */
This driver is no longer used and it's remaining users were converted to the new generic PXA MMC driver. Thus, remove this driver.
Signed-off-by: Marek Vasut marex@denx.de Cc: Andy Fleming afleming@freescale.com --- drivers/mmc/Makefile | 1 - drivers/mmc/pxa_mmc.c | 643 ------------------------------------------------- 2 files changed, 644 deletions(-) delete mode 100644 drivers/mmc/pxa_mmc.c
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 565ba6a..ac3cb0b 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -41,7 +41,6 @@ COBJS-$(CONFIG_MV_SDHCI) += mv_sdhci.o COBJS-$(CONFIG_MXC_MMC) += mxcmmc.o COBJS-$(CONFIG_MXS_MMC) += mxsmmc.o COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o -COBJS-$(CONFIG_PXA_MMC) += pxa_mmc.o COBJS-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o COBJS-$(CONFIG_SDHCI) += sdhci.o COBJS-$(CONFIG_S5P_SDHCI) += s5p_sdhci.o diff --git a/drivers/mmc/pxa_mmc.c b/drivers/mmc/pxa_mmc.c deleted file mode 100644 index 80c4445..0000000 --- a/drivers/mmc/pxa_mmc.c +++ /dev/null @@ -1,643 +0,0 @@ -/* - * (C) Copyright 2003 - * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <common.h> -#include <mmc.h> -#include <asm/errno.h> -#include <asm/arch/hardware.h> -#include <part.h> -#include <asm/io.h> - -#include "pxa_mmc.h" - -extern int fat_register_device(block_dev_desc_t * dev_desc, int part_no); - -static block_dev_desc_t mmc_dev; - -block_dev_desc_t *mmc_get_dev(int dev) -{ - return ((block_dev_desc_t *) & mmc_dev); -} - -/* - * FIXME needs to read cid and csd info to determine block size - * and other parameters - */ -static uchar mmc_buf[MMC_BLOCK_SIZE]; -static uchar spec_ver; -static int mmc_ready = 0; -static int wide = 0; - -static uint32_t * -/****************************************************/ -mmc_cmd(ushort cmd, ushort argh, ushort argl, ushort cmdat) -/****************************************************/ -{ - static uint32_t resp[4], a, b, c; - uint32_t status; - int i; - - debug("mmc_cmd %u 0x%04x 0x%04x 0x%04x\n", cmd, argh, argl, - cmdat | wide); - writel(MMC_STRPCL_STOP_CLK, MMC_STRPCL); - writel(~MMC_I_MASK_CLK_IS_OFF, MMC_I_MASK); - while (!(readl(MMC_I_REG) & MMC_I_REG_CLK_IS_OFF)) - ; - writel(cmd, MMC_CMD); - writel(argh, MMC_ARGH); - writel(argl, MMC_ARGL); - writel(cmdat | wide, MMC_CMDAT); - writel(~MMC_I_MASK_END_CMD_RES, MMC_I_MASK); - writel(MMC_STRPCL_START_CLK, MMC_STRPCL); - while (!(readl(MMC_I_REG) & MMC_I_REG_END_CMD_RES)) - ; - - status = readl(MMC_STAT); - debug("MMC status 0x%08x\n", status); - if (status & MMC_STAT_TIME_OUT_RESPONSE) { - return 0; - } - - /* Linux says: - * Did I mention this is Sick. We always need to - * discard the upper 8 bits of the first 16-bit word. - */ - a = (readl(MMC_RES) & 0xffff); - for (i = 0; i < 4; i++) { - b = (readl(MMC_RES) & 0xffff); - c = (readl(MMC_RES) & 0xffff); - resp[i] = (a << 24) | (b << 8) | (c >> 8); - a = c; - debug("MMC resp[%d] = %#08x\n", i, resp[i]); - } - - return resp; -} - -int -/****************************************************/ -mmc_block_read(uchar * dst, uint32_t src, int len) -/****************************************************/ -{ - ushort argh, argl; - ulong status; - - if (len == 0) { - return 0; - } - - debug("mmc_block_rd dst %p src %08x len %d\n", dst, src, len); - - argh = len >> 16; - argl = len & 0xffff; - - /* set block len */ - mmc_cmd(MMC_CMD_SET_BLOCKLEN, argh, argl, MMC_CMDAT_R1); - - /* send read command */ - argh = src >> 16; - argl = src & 0xffff; - writel(MMC_STRPCL_STOP_CLK, MMC_STRPCL); - writel(0xffff, MMC_RDTO); - writel(1, MMC_NOB); - writel(len, MMC_BLKLEN); - mmc_cmd(MMC_CMD_READ_SINGLE_BLOCK, argh, argl, - MMC_CMDAT_R1 | MMC_CMDAT_READ | MMC_CMDAT_BLOCK | - MMC_CMDAT_DATA_EN); - - writel(~MMC_I_MASK_RXFIFO_RD_REQ, MMC_I_MASK); - while (len) { - if (readl(MMC_I_REG) & MMC_I_REG_RXFIFO_RD_REQ) { -#if defined(CONFIG_CPU_PXA27X) || defined(CONFIG_CPU_MONAHANS) - int i; - for (i = min(len, 32); i; i--) { - *dst++ = readb(MMC_RXFIFO); - len--; - } -#else - *dst++ = readb(MMC_RXFIFO); - len--; -#endif - } - status = readl(MMC_STAT); - if (status & MMC_STAT_ERRORS) { - printf("MMC_STAT error %lx\n", status); - return -1; - } - } - writel(~MMC_I_MASK_DATA_TRAN_DONE, MMC_I_MASK); - while (!(readl(MMC_I_REG) & MMC_I_REG_DATA_TRAN_DONE)) - ; - status = readl(MMC_STAT); - if (status & MMC_STAT_ERRORS) { - printf("MMC_STAT error %lx\n", status); - return -1; - } - return 0; -} - -int -/****************************************************/ -mmc_block_write(ulong dst, uchar * src, int len) -/****************************************************/ -{ - ushort argh, argl; - ulong status; - - if (len == 0) { - return 0; - } - - debug("mmc_block_wr dst %lx src %lx len %d\n", dst, (ulong) src, len); - - argh = len >> 16; - argl = len & 0xffff; - - /* set block len */ - mmc_cmd(MMC_CMD_SET_BLOCKLEN, argh, argl, MMC_CMDAT_R1); - - /* send write command */ - argh = dst >> 16; - argl = dst & 0xffff; - writel(MMC_STRPCL_STOP_CLK, MMC_STRPCL); - writel(1, MMC_NOB); - writel(len, MMC_BLKLEN); - mmc_cmd(MMC_CMD_WRITE_SINGLE_BLOCK, argh, argl, - MMC_CMDAT_R1 | MMC_CMDAT_WRITE | MMC_CMDAT_BLOCK | - MMC_CMDAT_DATA_EN); - - writel(~MMC_I_MASK_TXFIFO_WR_REQ, MMC_I_MASK); - while (len) { - if (readl(MMC_I_REG) & MMC_I_REG_TXFIFO_WR_REQ) { - int i, bytes = min(32, len); - - for (i = 0; i < bytes; i++) { - writel(*src++, MMC_TXFIFO); - } - if (bytes < 32) { - writel(MMC_PRTBUF_BUF_PART_FULL, MMC_PRTBUF); - } - len -= bytes; - } - status = readl(MMC_STAT); - if (status & MMC_STAT_ERRORS) { - printf("MMC_STAT error %lx\n", status); - return -1; - } - } - writel(~MMC_I_MASK_DATA_TRAN_DONE, MMC_I_MASK); - while (!(readl(MMC_I_REG) & MMC_I_REG_DATA_TRAN_DONE)) - ; - writel(~MMC_I_MASK_PRG_DONE, MMC_I_MASK); - while (!(readl(MMC_I_REG) & MMC_I_REG_PRG_DONE)) - ; - status = readl(MMC_STAT); - if (status & MMC_STAT_ERRORS) { - printf("MMC_STAT error %lx\n", status); - return -1; - } - return 0; -} - -int -/****************************************************/ -pxa_mmc_read(long src, uchar * dst, int size) -/****************************************************/ -{ - ulong end, part_start, part_end, part_len, aligned_start, aligned_end; - ulong mmc_block_size, mmc_block_address; - - if (size == 0) { - return 0; - } - - if (!mmc_ready) { - printf("Please initial the MMC first\n"); - return -1; - } - - mmc_block_size = MMC_BLOCK_SIZE; - mmc_block_address = ~(mmc_block_size - 1); - - src -= CONFIG_SYS_MMC_BASE; - end = src + size; - part_start = ~mmc_block_address & src; - part_end = ~mmc_block_address & end; - aligned_start = mmc_block_address & src; - aligned_end = mmc_block_address & end; - - /* all block aligned accesses */ - debug - ("src %lx dst %lx end %lx pstart %lx pend %lx astart %lx aend %lx\n", - src, (ulong) dst, end, part_start, part_end, aligned_start, - aligned_end); - if (part_start) { - part_len = mmc_block_size - part_start; - debug - ("ps src %lx dst %lx end %lx pstart %lx pend %lx astart %lx aend %lx\n", - src, (ulong) dst, end, part_start, part_end, aligned_start, - aligned_end); - if ((mmc_block_read(mmc_buf, aligned_start, mmc_block_size)) < - 0) { - return -1; - } - memcpy(dst, mmc_buf + part_start, part_len); - dst += part_len; - src += part_len; - } - debug - ("src %lx dst %lx end %lx pstart %lx pend %lx astart %lx aend %lx\n", - src, (ulong) dst, end, part_start, part_end, aligned_start, - aligned_end); - for (; src < aligned_end; src += mmc_block_size, dst += mmc_block_size) { - debug - ("al src %lx dst %lx end %lx pstart %lx pend %lx astart %lx aend %lx\n", - src, (ulong) dst, end, part_start, part_end, aligned_start, - aligned_end); - if ((mmc_block_read((uchar *) (dst), src, mmc_block_size)) < 0) { - return -1; - } - } - debug - ("src %lx dst %lx end %lx pstart %lx pend %lx astart %lx aend %lx\n", - src, (ulong) dst, end, part_start, part_end, aligned_start, - aligned_end); - if (part_end && src < end) { - debug - ("pe src %lx dst %lx end %lx pstart %lx pend %lx astart %lx aend %lx\n", - src, (ulong) dst, end, part_start, part_end, aligned_start, - aligned_end); - if ((mmc_block_read(mmc_buf, aligned_end, mmc_block_size)) < 0) { - return -1; - } - memcpy(dst, mmc_buf, part_end); - } - return 0; -} - -int -/****************************************************/ -pxa_mmc_write(uchar * src, uint32_t dst, int size) -/****************************************************/ -{ - ulong end, part_start, part_end, part_len, aligned_start, aligned_end; - ulong mmc_block_size, mmc_block_address; - - if (size == 0) { - return 0; - } - - if (!mmc_ready) { - printf("Please initial the MMC first\n"); - return -1; - } - - mmc_block_size = MMC_BLOCK_SIZE; - mmc_block_address = ~(mmc_block_size - 1); - - dst -= CONFIG_SYS_MMC_BASE; - end = dst + size; - part_start = ~mmc_block_address & dst; - part_end = ~mmc_block_address & end; - aligned_start = mmc_block_address & dst; - aligned_end = mmc_block_address & end; - - /* all block aligned accesses */ - debug - ("src %p dst %08x end %lx pstart %lx pend %lx astart %lx aend %lx\n", - src, dst, end, part_start, part_end, aligned_start, - aligned_end); - if (part_start) { - part_len = mmc_block_size - part_start; - debug - ("ps src %p dst %08x end %lx pstart %lx pend %lx astart %lx aend %lx\n", - src, dst, end, part_start, part_end, aligned_start, - aligned_end); - if ((mmc_block_read(mmc_buf, aligned_start, mmc_block_size)) < - 0) { - return -1; - } - memcpy(mmc_buf + part_start, src, part_len); - if ((mmc_block_write(aligned_start, mmc_buf, mmc_block_size)) < - 0) { - return -1; - } - dst += part_len; - src += part_len; - } - debug - ("src %p dst %08x end %lx pstart %lx pend %lx astart %lx aend %lx\n", - src, dst, end, part_start, part_end, aligned_start, - aligned_end); - for (; dst < aligned_end; src += mmc_block_size, dst += mmc_block_size) { - debug - ("al src %p dst %08x end %lx pstart %lx pend %lx astart %lx aend %lx\n", - src, dst, end, part_start, part_end, aligned_start, - aligned_end); - if ((mmc_block_write(dst, (uchar *) src, mmc_block_size)) < 0) { - return -1; - } - } - debug - ("src %p dst %08x end %lx pstart %lx pend %lx astart %lx aend %lx\n", - src, dst, end, part_start, part_end, aligned_start, - aligned_end); - if (part_end && dst < end) { - debug - ("pe src %p dst %08x end %lx pstart %lx pend %lx astart %lx aend %lx\n", - src, dst, end, part_start, part_end, aligned_start, - aligned_end); - if ((mmc_block_read(mmc_buf, aligned_end, mmc_block_size)) < 0) { - return -1; - } - memcpy(mmc_buf, src, part_end); - if ((mmc_block_write(aligned_end, mmc_buf, mmc_block_size)) < 0) { - return -1; - } - } - return 0; -} - -static ulong -/****************************************************/ -mmc_bread(int dev_num, ulong blknr, lbaint_t blkcnt, void *dst) -/****************************************************/ -{ - int mmc_block_size = MMC_BLOCK_SIZE; - ulong src = blknr * mmc_block_size + CONFIG_SYS_MMC_BASE; - - pxa_mmc_read(src, (uchar *) dst, blkcnt * mmc_block_size); - return blkcnt; -} - -#ifdef __GNUC__ -#define likely(x) __builtin_expect(!!(x), 1) -#define unlikely(x) __builtin_expect(!!(x), 0) -#else -#define likely(x) (x) -#define unlikely(x) (x) -#endif - -#define UNSTUFF_BITS(resp,start,size) \ - ({ \ - const int __size = size; \ - const uint32_t __mask = (__size < 32 ? 1 << __size : 0) - 1; \ - const int32_t __off = 3 - ((start) / 32); \ - const int32_t __shft = (start) & 31; \ - uint32_t __res; \ - \ - __res = resp[__off] >> __shft; \ - if (__size + __shft > 32) \ - __res |= resp[__off-1] << ((32 - __shft) % 32); \ - __res & __mask; \ - }) - -/* - * Given the decoded CSD structure, decode the raw CID to our CID structure. - */ -static void mmc_decode_cid(uint32_t * resp) -{ - if (IF_TYPE_SD == mmc_dev.if_type) { - /* - * SD doesn't currently have a version field so we will - * have to assume we can parse this. - */ - sprintf((char *)mmc_dev.vendor, - "Man %02x OEM %c%c "%c%c%c%c%c" Date %02u/%04u", - UNSTUFF_BITS(resp, 120, 8), UNSTUFF_BITS(resp, 112, 8), - UNSTUFF_BITS(resp, 104, 8), UNSTUFF_BITS(resp, 96, 8), - UNSTUFF_BITS(resp, 88, 8), UNSTUFF_BITS(resp, 80, 8), - UNSTUFF_BITS(resp, 72, 8), UNSTUFF_BITS(resp, 64, 8), - UNSTUFF_BITS(resp, 8, 4), UNSTUFF_BITS(resp, 12, - 8) + 2000); - sprintf((char *)mmc_dev.revision, "%d.%d", - UNSTUFF_BITS(resp, 60, 4), UNSTUFF_BITS(resp, 56, 4)); - sprintf((char *)mmc_dev.product, "%u", - UNSTUFF_BITS(resp, 24, 32)); - } else { - /* - * The selection of the format here is based upon published - * specs from sandisk and from what people have reported. - */ - switch (spec_ver) { - case 0: /* MMC v1.0 - v1.2 */ - case 1: /* MMC v1.4 */ - sprintf((char *)mmc_dev.vendor, - "Man %02x%02x%02x "%c%c%c%c%c%c%c" Date %02u/%04u", - UNSTUFF_BITS(resp, 120, 8), UNSTUFF_BITS(resp, - 112, - 8), - UNSTUFF_BITS(resp, 104, 8), UNSTUFF_BITS(resp, - 96, 8), - UNSTUFF_BITS(resp, 88, 8), UNSTUFF_BITS(resp, - 80, 8), - UNSTUFF_BITS(resp, 72, 8), UNSTUFF_BITS(resp, - 64, 8), - UNSTUFF_BITS(resp, 56, 8), UNSTUFF_BITS(resp, - 48, 8), - UNSTUFF_BITS(resp, 12, 4), UNSTUFF_BITS(resp, 8, - 4) + - 1997); - sprintf((char *)mmc_dev.revision, "%d.%d", - UNSTUFF_BITS(resp, 44, 4), UNSTUFF_BITS(resp, - 40, 4)); - sprintf((char *)mmc_dev.product, "%u", - UNSTUFF_BITS(resp, 16, 24)); - break; - - case 2: /* MMC v2.0 - v2.2 */ - case 3: /* MMC v3.1 - v3.3 */ - case 4: /* MMC v4 */ - sprintf((char *)mmc_dev.vendor, - "Man %02x OEM %04x "%c%c%c%c%c%c" Date %02u/%04u", - UNSTUFF_BITS(resp, 120, 8), UNSTUFF_BITS(resp, - 104, - 16), - UNSTUFF_BITS(resp, 96, 8), UNSTUFF_BITS(resp, - 88, 8), - UNSTUFF_BITS(resp, 80, 8), UNSTUFF_BITS(resp, - 72, 8), - UNSTUFF_BITS(resp, 64, 8), UNSTUFF_BITS(resp, - 56, 8), - UNSTUFF_BITS(resp, 12, 4), UNSTUFF_BITS(resp, 8, - 4) + - 1997); - sprintf((char *)mmc_dev.product, "%u", - UNSTUFF_BITS(resp, 16, 32)); - sprintf((char *)mmc_dev.revision, "N/A"); - break; - - default: - printf("MMC card has unknown MMCA version %d\n", - spec_ver); - break; - } - } - printf("%s card.\nVendor: %s\nProduct: %s\nRevision: %s\n", - (IF_TYPE_SD == mmc_dev.if_type) ? "SD" : "MMC", mmc_dev.vendor, - mmc_dev.product, mmc_dev.revision); -} - -/* - * Given a 128-bit response, decode to our card CSD structure. - */ -static void mmc_decode_csd(uint32_t * resp) -{ - unsigned int mult, csd_struct; - - if (IF_TYPE_SD == mmc_dev.if_type) { - csd_struct = UNSTUFF_BITS(resp, 126, 2); - if (csd_struct != 0) { - printf("SD: unrecognised CSD structure version %d\n", - csd_struct); - return; - } - } else { - /* - * We only understand CSD structure v1.1 and v1.2. - * v1.2 has extra information in bits 15, 11 and 10. - */ - csd_struct = UNSTUFF_BITS(resp, 126, 2); - if (csd_struct != 1 && csd_struct != 2) { - printf("MMC: unrecognised CSD structure version %d\n", - csd_struct); - return; - } - - spec_ver = UNSTUFF_BITS(resp, 122, 4); - mmc_dev.if_type = IF_TYPE_MMC; - } - - mult = 1 << (UNSTUFF_BITS(resp, 47, 3) + 2); - mmc_dev.lba = (1 + UNSTUFF_BITS(resp, 62, 12)) * mult; - mmc_dev.blksz = 1 << UNSTUFF_BITS(resp, 80, 4); - - /* FIXME: The following just makes assumes that's the partition type -- should really read it */ - mmc_dev.part_type = PART_TYPE_DOS; - mmc_dev.dev = 0; - mmc_dev.lun = 0; - mmc_dev.type = DEV_TYPE_HARDDISK; - mmc_dev.removable = 0; - mmc_dev.block_read = mmc_bread; - - printf("Detected: %lu blocks of %lu bytes (%luMB) ", - mmc_dev.lba, - mmc_dev.blksz, - mmc_dev.lba * mmc_dev.blksz / (1024 * 1024)); -} - -int -/****************************************************/ -mmc_legacy_init(int verbose) -/****************************************************/ -{ - int retries, rc = -ENODEV; - uint32_t cid_resp[4]; - uint32_t *resp; - uint16_t rca = 0; - - /* Reset device interface type */ - mmc_dev.if_type = IF_TYPE_UNKNOWN; - -#ifdef CONFIG_CPU_MONAHANS /* pxa3xx */ - writel(readl(CKENA) | CKENA_12_MMC0 | CKENA_13_MMC1, CKENA); -#else /* pxa2xx */ - writel(readl(CKEN) | CKEN12_MMC, CKEN); /* enable MMC unit clock */ -#endif - writel(MMC_CLKRT_0_3125MHZ, MMC_CLKRT); - writel(MMC_RES_TO_MAX, MMC_RESTO); - writel(MMC_SPI_DISABLE, MMC_SPI); - - /* reset */ - mmc_cmd(MMC_CMD_GO_IDLE_STATE, 0, 0, MMC_CMDAT_INIT | MMC_CMDAT_R0); - udelay(200000); - retries = 3; - while (retries--) { - resp = mmc_cmd(MMC_CMD_APP_CMD, 0, 0, MMC_CMDAT_R1); - if (!(resp[0] & 0x00000020)) { /* Card does not support APP_CMD */ - debug("Card does not support APP_CMD\n"); - break; - } - - /* Select 3.2-3.3V and 3.3-3.4V */ - resp = mmc_cmd(SD_CMD_APP_SEND_OP_COND, 0x0030, 0x0000, - MMC_CMDAT_R3 | (retries < 2 ? 0 - : MMC_CMDAT_INIT)); - if (resp[0] & 0x80000000) { - mmc_dev.if_type = IF_TYPE_SD; - debug("Detected SD card\n"); - break; - } - udelay(200000); - } - - if (retries <= 0 || !(IF_TYPE_SD == mmc_dev.if_type)) { - debug("Failed to detect SD Card, trying MMC\n"); - resp = - mmc_cmd(MMC_CMD_SEND_OP_COND, 0x00ff, 0x8000, MMC_CMDAT_R3); - - retries = 10; - while (retries-- && resp && !(resp[0] & 0x80000000)) { - udelay(200000); - resp = - mmc_cmd(MMC_CMD_SEND_OP_COND, 0x00ff, 0x8000, - MMC_CMDAT_R3); - } - } - - /* try to get card id */ - resp = - mmc_cmd(MMC_CMD_ALL_SEND_CID, 0, 0, MMC_CMDAT_R2 | MMC_CMDAT_BUSY); - if (resp) { - memcpy(cid_resp, resp, sizeof(cid_resp)); - - /* MMC exists, get CSD too */ - resp = mmc_cmd(MMC_CMD_SET_RELATIVE_ADDR, 0, 0, MMC_CMDAT_R1); - if (IF_TYPE_SD == mmc_dev.if_type) - rca = ((resp[0] & 0xffff0000) >> 16); - resp = mmc_cmd(MMC_CMD_SEND_CSD, rca, 0, MMC_CMDAT_R2); - if (resp) { - mmc_decode_csd(resp); - rc = 0; - mmc_ready = 1; - } - - mmc_decode_cid(cid_resp); - } - - writel(0, MMC_CLKRT); /* 20 MHz */ - resp = mmc_cmd(MMC_CMD_SELECT_CARD, rca, 0, MMC_CMDAT_R1); - -#if defined(CONFIG_CPU_PXA27X) || defined(CONFIG_CPU_MONAHANS) - if (IF_TYPE_SD == mmc_dev.if_type) { - resp = mmc_cmd(MMC_CMD_APP_CMD, rca, 0, MMC_CMDAT_R1); - resp = mmc_cmd(SD_CMD_APP_SET_BUS_WIDTH, 0, 2, MMC_CMDAT_R1); - wide = MMC_CMDAT_SD_4DAT; - } -#endif - - fat_register_device(&mmc_dev, 1); /* partitions start counting with 1 */ - - return rc; -}
Do we want to use CONFIG_CMD_MMC for this?
That technically just means that the mmc *command* exists, but there are other reasons to enable the MMC driver (such as storing the environment or other behind-the-scenes mmc uses).
It looks like this was done a handful of other places. I'm thinking we should use CONFIG_MMC, instead. If you update your patch, I'll submit a patch which fixes the others.
Andy
Dear Andy Fleming,
#include <asm/io.h>
No we don't ... but that's what other boards do use, so ...
Agreed.
Can you just apply this and then fix them all please?
Andy
Best regards, Marek Vasut
Andy Fleming
