[U-Boot] [PATCH] env: don't generate callback list entries for SPL
SPL doesn't use the environment. These list entries prevent the functions from being garbage-collected, even though nothing will look at the list. This caused several SPL builds (e.g. P2020RDB-PC_NAND) to break due to size limitations.
A static inline function is used to provide a context in which we can consume the callback, and thus avoid unused function warnings.
Signed-off-by: Scott Wood scottwood@freescale.com --- include/env_callback.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/env_callback.h b/include/env_callback.h index 47fdc6f..c583120 100644 --- a/include/env_callback.h +++ b/include/env_callback.h @@ -68,8 +68,16 @@ void env_callback_init(ENTRY *var_entry); * when associated through the ".callbacks" environment variable, the callback * will be executed any time the variable is inserted, overwritten, or deleted. */ +#ifdef CONFIG_SPL_BUILD +#define U_BOOT_ENV_CALLBACK(name, callback) \ + static inline void _u_boot_env_noop_##name(void) \ + { \ + (void)callback; \ + } +#else #define U_BOOT_ENV_CALLBACK(name, callback) \ ll_entry_declare(struct env_clbk_tbl, name, env_clbk, env_clbk) = \ {#name, callback} +#endif
#endif /* __ENV_CALLBACK_H__ */
Hi Scott,
Sorry about that.
SPL with networking support uses the environment, so you need to toss CONFIG_SPL_NET_SUPPORT into the test. That said, it's not an interactive environment and this might push that area over the size limit too (in the USB case, which is already pretty tight).
look at
OK, I saw "env_*" stuff in the "ifndef CONFIG_SPL_BUILD" section, but later some of it shows up in "ifdef CONFIG_SPL_BUILD" as well.
So, do you want a v2, or is it OK because it's not interactive? In the latter case should env_callback.o be removed from the SPL build?
Also, env_nvedit.o, env_common.o, and env_flash.o are included for SPL regardless of CONFIG_SPL_NET_SUPPORT. In fact it looks like env_nvedit.o will be included twice if CONFIG_SPL_NET_SUPPORT is enabled. :-P
-Scott
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
look at
Lets do a v2 (since the commit message would have been wrong) and add in a comment saying SPL doesn't have interactive environment, so we don't need this code.
Since I'd assume 'sort' in make isn't sort -u, I'm not sure how it's filtering out the dupes unless we don't really need it afterall, am335x_evm builds with CONFIG_SPL_NET_SUPPORT enabled. I'm curious now, so I'm poking it.
- -- Tom
Dear Tom,
Wrong assumption.
RTFM shows:
`$(sort LIST)' Sorts the words of LIST in lexical order, removing duplicate words. The output is a list of words separated by single spaces. Thus,
$(sort foo bar lose)
returns the value `bar foo lose'.
Incidentally, since `sort' removes duplicate words, you can use it for this purpose even if you don't care about the sort order.
On 12/17/12 14:55, Wolfgang Denk wrote:
Dear Tom,
Wrong assumption.
RTFM shows:
Which means the Makefile is just a tad messy instead, thanks.
- -- Tom
Hi Tom,
Dear Tom,
Wrong assumption.
RTFM shows:
Not only can you, that's the only reason it's added to those Makefiles.
-Joe
Joe Hershberger
Scott Wood
