[U-Boot] [PATCH] 4xx: add support for new PMC440 revision
This patch adds support for the new PMC440 hardware revision 1.4. The board now uses Micrel KSZ9031 phys.
Add missing i2c initialization before reading bootstrap eeprom.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- board/esd/pmc440/pmc440.c | 83 +++++++++++++++++++++++++++++++++------------ 1 file changed, 62 insertions(+), 21 deletions(-)
diff --git a/board/esd/pmc440/pmc440.c b/board/esd/pmc440/pmc440.c index e86996c..7aee8e4 100644 --- a/board/esd/pmc440/pmc440.c +++ b/board/esd/pmc440/pmc440.c @@ -63,6 +63,8 @@ struct serial_device *default_serial_console(void) /* mark scratchreg valid */ scratchreg = (scratchreg & 0xffffff00) | 0x80;
+ i2c_init_all(); + i = bootstrap_eeprom_read(CONFIG_SYS_I2C_BOOT_EEPROM_ADDR, 0x10, buf, 4); if ((i != -1) && (buf[0] == 0x19) && (buf[1] == 0x75)) { @@ -641,34 +643,73 @@ int is_pci_host(struct pci_controller *hose) #endif /* defined(CONFIG_PCI) */
#ifdef CONFIG_RESET_PHY_R +int pmc440_setup_ksz9031(char *devname, int phy_addr) +{ + unsigned short id1, id2; + + if (miiphy_read(devname, phy_addr, 2, &id1) || + miiphy_read(devname, phy_addr, 3, &id2)) { + printf("Phy%d: cannot read id\n", phy_addr); + return -1; + } + + if ((id1 != 0x0022) || ((id2 & 0xfff0) != 0x1620)) { + printf("Phy%d: unexpected id\n", phy_addr); + return -1; + } + + /* MMD 2.08: adjust tx_clk pad skew */ + miiphy_write(devname, phy_addr, 0x0d, 2); + miiphy_write(devname, phy_addr, 0x0e, 8); + miiphy_write(devname, phy_addr, 0x0d, 0x4002); + miiphy_write(devname, phy_addr, 0x0e, 0xf | (0x17 << 5)); + + return 0; +} void reset_phy(void) { char *s; unsigned short val_method, val_behavior;
- /* special LED setup for NGCC/CANDES */ - if ((s = getenv("bd_type")) && - ((!strcmp(s, "ngcc")) || (!strcmp(s, "candes")))) { - val_method = 0x0e0a; - val_behavior = 0x0cf2; - } else { - /* PMC440 standard type */ - val_method = 0x0e10; - val_behavior = 0x0cf0; - } + if (gd->board_type < 4) { + /* special LED setup for NGCC/CANDES */ + s = getenv("bd_type"); + if (s && ((!strcmp(s, "ngcc")) || (!strcmp(s, "candes")))) { + val_method = 0x0e0a; + val_behavior = 0x0cf2; + } else { + /* PMC440 standard type */ + val_method = 0x0e10; + val_behavior = 0x0cf0; + }
- if (miiphy_write("ppc_4xx_eth0", CONFIG_PHY_ADDR, 0x1f, 0x0001) == 0) { - miiphy_write("ppc_4xx_eth0", CONFIG_PHY_ADDR, 0x11, 0x0010); - miiphy_write("ppc_4xx_eth0", CONFIG_PHY_ADDR, 0x11, val_behavior); - miiphy_write("ppc_4xx_eth0", CONFIG_PHY_ADDR, 0x10, val_method); - miiphy_write("ppc_4xx_eth0", CONFIG_PHY_ADDR, 0x1f, 0x0000); - } + if (miiphy_write("ppc_4xx_eth0", + CONFIG_PHY_ADDR, 0x1f, 0x0001) == 0) { + miiphy_write("ppc_4xx_eth0", + CONFIG_PHY_ADDR, 0x11, 0x0010); + miiphy_write("ppc_4xx_eth0", + CONFIG_PHY_ADDR, 0x11, val_behavior); + miiphy_write("ppc_4xx_eth0", + CONFIG_PHY_ADDR, 0x10, val_method); + miiphy_write("ppc_4xx_eth0", + CONFIG_PHY_ADDR, 0x1f, 0x0000); + }
- if (miiphy_write("ppc_4xx_eth1", CONFIG_PHY1_ADDR, 0x1f, 0x0001) == 0) { - miiphy_write("ppc_4xx_eth1", CONFIG_PHY1_ADDR, 0x11, 0x0010); - miiphy_write("ppc_4xx_eth1", CONFIG_PHY1_ADDR, 0x11, val_behavior); - miiphy_write("ppc_4xx_eth1", CONFIG_PHY1_ADDR, 0x10, val_method); - miiphy_write("ppc_4xx_eth1", CONFIG_PHY1_ADDR, 0x1f, 0x0000); + if (miiphy_write("ppc_4xx_eth1", + CONFIG_PHY1_ADDR, 0x1f, 0x0001) == 0) { + miiphy_write("ppc_4xx_eth1", + CONFIG_PHY1_ADDR, 0x11, 0x0010); + miiphy_write("ppc_4xx_eth1", + CONFIG_PHY1_ADDR, 0x11, val_behavior); + miiphy_write("ppc_4xx_eth1", + CONFIG_PHY1_ADDR, 0x10, val_method); + miiphy_write("ppc_4xx_eth1", + CONFIG_PHY1_ADDR, 0x1f, 0x0000); + } + } else { + /* rev. 1.4 uses a Micrel KSZ9031 */ + pmc440_setup_ksz9031("ppc_4xx_eth0", CONFIG_PHY_ADDR); + pmc440_setup_ksz9031("ppc_4xx_eth1", CONFIG_PHY1_ADDR); } } #endif
Hi Matthias,
i2c_init_all();
- i = bootstrap_eeprom_read(CONFIG_SYS_I2C_BOOT_EEPROM_ADDR, 0x10, buf, 4); if ((i != -1) && (buf[0] == 0x19) && (buf[1] == 0x75)) {
- unsigned short id1, id2;
- if (miiphy_read(devname, phy_addr, 2, &id1) ||
return -1;
- if ((id1 != 0x0022) || ((id2 & 0xfff0) != 0x1620)) {
return -1;
- /* MMD 2.08: adjust tx_clk pad skew */
- miiphy_write(devname, phy_addr, 0x0d, 2);
- miiphy_write(devname, phy_addr, 0x0e, 8);
- miiphy_write(devname, phy_addr, 0x0d, 0x4002);
- miiphy_write(devname, phy_addr, 0x0e, 0xf | (0x17 << 5));
- } else {
- if (gd->board_type < 4) {
} else {
This if () section looks very similar to the one before in this patch. Only difference is the string "ppc_4xx_eth1". Can't you move this code into a function to reduce the code size?
I know this code duplication was not introduced with this patch. But it makes sense to simplify this now for my taste.
Thanks, Stefan
You might be right. But I will put it into a separate "refacturing" patch. Stay tuned.
Matthias
Matthias Fuchs
Stefan Roese
